path: root/fs/ocfs2/dlmglue.c
2013-05-07aio: remove retry-based AIOZach Brown
This removes the retry-based AIO infrastructure now that nothing in tree is using it. We want to remove retry-based AIO because it is fundemantally unsafe. It retries IO submission from a kernel thread that has only assumed the mm of the submitting task. All other task_struct references in the IO submission path will see the kernel thread, not the submitting task. This design flaw means that nothing of any meaningful complexity can use retry-based AIO. This removes all the code and data associated with the retry machinery. The most significant benefit of this is the removal of the locking around the unused run list in the submission path. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: Zach Brown <zab@redhat.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-21ocfs2: unlock super lock if lockres refresh failedJunxiao Bi
If lockres refresh failed, the super lock will never be released which will cause some processes on other cluster nodes hung forever. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-13ocfs2: convert between kuids and kgids and DLM locksEric W. Biederman
Convert between uid and gids stored in the on the wire format of dlm locks aka struct ocfs2_meta_lvb and kuids and kgids stored in inode->i_uid and inode->i_gid. Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-07-03ocfs2: use spinlock irqsave for downconvert lock.patchSrinivas Eeda
When ocfs2dc thread holds dc_task_lock spinlock and receives soft IRQ it deadlock itself trying to get same spinlock in ocfs2_wake_downconvert_thread. Below is the stack snippet. The patch disables interrupts when acquiring dc_task_lock spinlock. ocfs2_wake_downconvert_thread ocfs2_rw_unlock ocfs2_dio_end_io dio_complete ..... bio_endio req_bio_endio .... scsi_io_completion blk_done_softirq __do_softirq do_softirq irq_exit do_IRQ ocfs2_downconvert_thread [kthread] Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2012-07-03ocfs2: Misplaced parens in unlikleyroel
Fix misplaced parentheses Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-12-01Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (31 commits) ocfs2: avoid unaligned access to dqc_bitmap ocfs2: Use filemap_write_and_wait() instead of write_inode_now() ocfs2: honor O_(D)SYNC flag in fallocate ocfs2: Add a missing journal credit in ocfs2_link_credits() -v2 ocfs2: send correct UUID to cleancache initialization ocfs2: Commit transactions in error cases -v2 ocfs2: make direntry invalid when deleting it fs/ocfs2/dlm/dlmlock.c: free kmem_cache_zalloc'd data using kmem_cache_free ocfs2: Avoid livelock in ocfs2_readpage() ocfs2: serialize unaligned aio ocfs2: Implement llseek() ocfs2: Fix ocfs2_page_mkwrite() ocfs2: Add comment about orphan scanning ocfs2: Clean up messages in the fs ocfs2/cluster: Cluster up now includes network connections too ocfs2/cluster: Add new function o2net_fill_node_map() ocfs2/cluster: Fix output in file elapsed_time_in_ms ocfs2/dlm: dlmlock_remote() needs to account for remastery ocfs2/dlm: Take inflight reference count for remotely mastered resources too ocfs2/dlm: Cleanup dlm_wait_for_node_death() and dlm_wait_for_node_recovery() ...
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-05-31ocfs2: Bugfix for hard readonly mountTiger Yang
ocfs2 cannot currently mount a device that is readonly at the media ("hard readonly"). Fix the broken places. see detail: http://oss.oracle.com/bugzilla/show_bug.cgi?id=1322 [ Description edited -- Joel ] Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Reviewed-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-03-28Merge branch 'mlog_replace_for_39' of git://repo.or.cz/taoma-kernel into ↵Joel Becker
ocfs2-merge-window-fix
2011-03-07ocfs2: Remove EXIT from masklog.Tao Ma
mlog_exit is used to record the exit status of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. This patch just try to remove it or change it. So: 1. if all the error paths already use mlog_errno, it is just removed. Otherwise, it will be replaced by mlog_errno. 2. if it is used to print some return value, it is replaced with mlog(0,...). mlog_exit_ptr is changed to mlog(0. All those mlog(0,...) will be replaced with trace events later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: Remove ENTRY from masklog.Tao Ma
ENTRY is used to record the entry of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. So for mlog_entry_void, we just remove it. for mlog_entry(...), we replace it with mlog(0,...), and they will be replace by trace event later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-20ocfs2: Use hrtimer to track ocfs2 fs lock statsSunil Mushran
Patch makes use of the hrtimer to track times in ocfs2 lock stats. The patch is a bit involved to ensure no additional impact on the memory footprint. The size of ocfs2_inode_cache remains 1280 bytes on 32-bit systems. A related change was to modify the unit of the max wait time from nanosec to microsec allowing us to track max time larger than 4 secs. This change necessitated the bumping of the output version in the debugfs file, locking_state, from 2 to 3. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2010-09-10Track negative entries v3Goldwyn Rodrigues
Track negative dentries by recording the generation number of the parent directory in d_fsdata. The generation number for the parent directory is recorded in the inode_info, which increments every time the lock on the directory is dropped. If the generation number of the parent directory and the negative dentry matches, there is no need to perform the revalidate, else a revalidate is forced. This improves performance in situations where nodes look for the same non-existent file multiple times. Thanks Mark for explaining the DLM sequence. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-07-20fs/ocfs2: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-21ocfs2: Avoid unnecessary block mapping when refreshing quota infoJan Kara
The position of global quota file info does not change. So we do not have to do logical -> physical block translation every time we reread it from disk. Thus we can also avoid taking ip_alloc_sem. Acked-by: Joel Becker <Joel.Becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-27ocfs2: Use a separate masklog for AST and BASTsSunil Mushran
This patch adds a new masklog and uses it allow tracing ASTs and BASTs in the dlmglue layer. This has been found to be very useful in debugging cluster locking issues. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-26ocfs2: Pass the locking protocol into ocfs2_cluster_connect().Joel Becker
Inside the stackglue, the locking protocol structure is hanging off of the ocfs2_cluster_connection. This takes it one further; the locking protocol is passed into ocfs2_cluster_connect(). Now different cluster connections can have different locking protocols with distinct asts. Note that all locking protocols have to keep their maximum protocol version in lock-step. With the protocol structure set in ocfs2_cluster_connect(), there is no need for the stackglue to have a static pointer to a specific protocol structure. We can change initialization to only pass in the maximum protocol version. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-26ocfs2: Attach the connection to the lksbJoel Becker
We're going to want it in the ast functions, so we convert union ocfs2_dlm_lksb to struct ocfs2_dlm_lksb and let it carry the connection. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-26ocfs2: Pass lksbs back from stackglue ast/bast functions.Joel Becker
The stackglue ast and bast functions tried to maintain the fiction that their arguments were void pointers. In reality, stack_user.c had to know that the argument was an ocfs2_lock_res in order to get the status off of the lksb. That's ugly. This changes stackglue to always pass the lksb as the argument to ast and bast functions. The caller can always use container_of() to get the ocfs2_lock_res or user_dlm_lock_res. The net effect to the caller is zero. They still get back the lockres in their ast. stackglue gets cleaner, and now can use the lksb itself. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-03ocfs2: Plugs race between the dc thread and an unlock ast messageSunil Mushran
This patch plugs a race between the downconvert thread and an unlock ast message. Specifically, after the downconvert worker has done its task, the dc thread needs to check whether an unlock ast made the downconvert moot. Reported-by: David Teigland <teigland@redhat.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Mark Fasheh <mfasheh@sus.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-02ocfs2: Remove overzealous BUG_ON during blocked lock processingSunil Mushran
During blocked lock processing, we should consider the possibility that the lock is no longer blocking. Joel Becker <joel.becker@oracle.com> assisted in fixing this issue. Reported-by: David Teigland <teigland@redhat.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-02ocfs2: Do not downconvert if the lock level is already compatibleSunil Mushran
During upconvert, if the master were to send a BAST, dlmglue will detect the upconversion in process and send a cancel convert to the master. Upon receiving the AST for the cancel convert, it will re-process the lock resource to determine whether it needs downconverting. Say, the up was from PR to EX and the BAST was for EX. After the cancel convert, it will need to downconvert to NL. However, if the node was originally upconverting from NL to EX, then there would be no reason to downconvert (assuming the same message sequence). This patch makes dlmglue consider the possibility that the current lock level is already compatible and that downconverting is not required. Joel Becker <joel.becker@oracle.com> assisted in fixing this issue. Fixes ossbz#1178 http://oss.oracle.com/bugzilla/show_bug.cgi?id=1178 Reported-by: Coly Li <coly.li@suse.de> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-02ocfs2: Prevent a livelock in dlmglueSunil Mushran
There is possibility of a livelock in __ocfs2_cluster_lock(). If a node were to get an ast for an upconvert request, followed immediately by a bast, there is a small window where the fs may downconvert the lock before the process requesting the upconvert is able to take the lock. This patch adds a new flag to indicate that the upconvert is still in progress and that the dc thread should not downconvert it right now. Wengang Wang <wen.gang.wang@oracle.com> and Joel Becker <joel.becker@oracle.com> contributed heavily to this patch. Reported-by: David Teigland <teigland@redhat.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-02ocfs2: Fix setting of OCFS2_LOCK_BLOCKED during bastWengang Wang
During bast, set the OCFS2_LOCK_BLOCKED flag only if the lock needs to downconverted. Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Acked-by: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-01-25ocfs2/trivial: Remove trailing whitespacesSunil Mushran
Patch removes trailing whitespaces. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23dlmglue.c: add missed mlog linesColy Li
This patch adds the missed mlog_exit() and mlog_exit_void() lines when routines return. Signed-off-by: Coly Li <coly.li@suse.de> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-22ocfs2: Add new refcount tree lock resource in dlmglue.Tao Ma
refcount tree lock resource is used to protect refcount tree read/write among multiple nodes. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Abstract caching info checkpoint.Tao Ma
In meta downconvert, we need to checkpoint the metadata in an inode. For refcount tree, we also need it. So abstract the process out. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-04ocfs2: Pass struct ocfs2_caching_info to the journal functions.Joel Becker
The next step in divorcing metadata I/O management from struct inode is to pass struct ocfs2_caching_info to the journal functions. Thus the journal locks a metadata cache with the cache io_lock function. It also can compare ci_last_trans and ci_created_trans directly. This is a large patch because of all the places we change ocfs2_journal_access..(handle, inode, ...) to ocfs2_journal_access..(handle, INODE_CACHE(inode), ...). Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Take the inode out of the metadata read/write paths.Joel Becker
We are really passing the inode into the ocfs2_read/write_blocks() functions to get at the metadata cache. This commit passes the cache directly into the metadata block functions, divorcing them from the inode. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-22ocfs2: Add lockdep annotationsJan Kara
Add lockdep support to OCFS2. The support also covers all of the cluster locks except for open locks, journal locks, and local quotafile locks. These are special because they are acquired for a node, not for a particular process and lockdep cannot deal with such type of locking. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-22ocfs2: Disable orphan scanning for local and hard-ro mountsSunil Mushran
Local and Hard-RO mounts do not need orphan scanning. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-22ocfs2: Do not initialize lvb in ocfs2_orphan_scan_lock_res_init()Sunil Mushran
We don't access the LVB in our ocfs2_*_lock_res_init() functions. Since the LVB can become invalid during some cluster recovery operations, the dlmglue must be able to handle an uninitialized LVB. For the orphan scan lock, we initialized an uninitialzed LVB with our scan sequence number plus one. This starts a normal orphan scan cycle. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-22ocfs2: Provide the ocfs2_dlm_lvb_valid() stack API.Joel Becker
The Lock Value Block (LVB) of a DLM lock can be lost when nodes die and the DLM cannot reconstruct its state. Clients of the DLM need to know this. ocfs2's internal DLM, o2dlm, explicitly zeroes out the LVB when it loses track of the state. This is not a standard behavior, but ocfs2 has always relied on it. Thus, an o2dlm LVB is always "valid". ocfs2 now supports both o2dlm and fs/dlm via the stack glue. When fs/dlm loses track of an LVBs state, it sets a flag (DLM_SBF_VALNOTVALID) on the Lock Status Block (LKSB). The contents of the LVB may be garbage or merely stale. ocfs2 doesn't want to try to guess at the validity of the stale LVB. Instead, it should be checking the VALNOTVALID flag. As this is the 'standard' way of treating LVBs, we will promote this behavior. We add a stack glue API ocfs2_dlm_lvb_valid(). It returns non-zero when the LVB is valid. o2dlm will always return valid, while fs/dlm will check VALNOTVALID. Signed-off-by: Joel Becker <joel.becker@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com>
2009-06-03ocfs2: timer to queue scan of all orphan slotsSrinivas Eeda
When a dentry is unlinked, the unlinking node takes an EX on the dentry lock before moving the dentry to the orphan directory. Other nodes that have this dentry in cache have a PR on the same dentry lock. When the EX is requested, the other nodes flag the corresponding inode as MAYBE_ORPHANED during downconvert. The inode is finally deleted when the last node to iput the inode sees that i_nlink==0 and the MAYBE_ORPHANED flag is set. A problem arises if a node is forced to free dentry locks because of memory pressure. If this happens, the node will no longer get downconvert notifications for the dentries that have been unlinked on another node. If it also happens that node is actively using the corresponding inode and happens to be the one performing the last iput on that inode, it will fail to delete the inode as it will not have the MAYBE_ORPHANED flag set. This patch fixes this shortcoming by introducing a periodic scan of the orphan directories to delete such inodes. Care has been taken to distribute the workload across the cluster so that no one node has to perform the task all the time. Signed-off-by: Srinivas Eeda <srinivas.eeda@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-04-03ocfs2: fix rare stale inode errors when exporting via nfswengang wang
For nfs exporting, ocfs2_get_dentry() returns the dentry for fh. ocfs2_get_dentry() may read from disk when the inode is not in memory, without any cross cluster lock. this leads to the file system loading a stale inode. This patch fixes above problem. Solution is that in case of inode is not in memory, we get the cluster lock(PR) of alloc inode where the inode in question is allocated from (this causes node on which deletion is done sync the alloc inode) before reading out the inode itsself. then we check the bitmap in the group (the inode in question allcated from) to see if the bit is clear. if it's clear then it's stale. if the bit is set, we then check generation as the existing code does. We have to read out the inode in question from disk first to know its alloc slot and allot bit. And if its not stale we read it out using ocfs2_iget(). The second read should then be from cache. And also we have to add a per superblock nfs_sync_lock to cover the lock for alloc inode and that for inode in question. this is because ocfs2_get_dentry() and ocfs2_delete_inode() lock on them in reverse order. nfs_sync_lock is locked in EX mode in ocfs2_get_dentry() and in PR mode in ocfs2_delete_inode(). so that mutliple ocfs2_delete_inode() can run concurrently in normal case. [mfasheh@suse.com: build warning fixes and comment cleanups] Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-02-26ocfs2: Cleanup the lockname print in dlmglue.cSunil Mushran
The dentry lock has a different format than other locks. This patch fixes ocfs2_log_dlm_error() macro to make it print the dentry lock correctly. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-02-02ocfs2: Wakeup the downconvert thread after a successful cancel convertSunil Mushran
When two nodes holding PR locks on a resource concurrently attempt to upconvert the locks to EX, the master sends a BAST to one of the nodes. This message tells that node to first cancel convert the upconvert request, followed by downconvert to a NL. Only when this lock is downconverted to NL, can the master upconvert the first node's lock to EX. While the fs was doing the cancel convert, it was forgetting to wake up the dc thread after a successful cancel, leading to a deadlock. Reported-and-Tested-by: David Teigland <teigland@redhat.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-08fix similar typos to successfullColy Li
When I review ocfs2 code, find there are 2 typos to "successfull". After doing grep "successfull " in kernel tree, 22 typos found totally -- great minds always think alike :) This patch fixes all the similar typos. Thanks for Randy's ack and comments. Signed-off-by: Coly Li <coyli@suse.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05ocfs2: remove unneeded lvb castsMark Fasheh
dlmglue.c has lots of code which casts the return value of ocfs2_dlm_lvb(). This is pointless however, as ocfs2_dlm_lvb() returns void *. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Fix ocfs2_read_quota_block() error handling.Joel Becker
ocfs2_bread() has become ocfs2_read_virt_blocks(), with a prototype to match ocfs2_read_blocks(). The quota code, converting from ocfs2_bread(), wraps the call to ocfs2_read_virt_blocks() in ocfs2_read_quota_block(). Unfortunately, the prototype of ocfs2_read_quota_block() matches the old prototype of ocfs2_bread(). The problem is that ocfs2_bread() returned the buffer head, and callers assumed that a NULL pointer was indicative of error. It wasn't. This is why ocfs2_bread() took an int*err argument as well. The new prototype of ocfs2_read_virt_blocks() avoids this error handling confusion. Let's change ocfs2_read_quota_block() to match. Signed-off-by: Joel Becker <joel.becker@oracle.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Implementation of local and global quota file handlingJan Kara
For each quota type each node has local quota file. In this file it stores changes users have made to disk usage via this node. Once in a while this information is synced to global file (and thus with other nodes) so that limits enforcement at least aproximately works. Global quota files contain all the information about usage and limits. It's mostly handled by the generic VFS code (which implements a trie of structures inside a quota file). We only have to provide functions to convert structures from on-disk format to in-memory one. We also have to provide wrappers for various quota functions starting transactions and acquiring necessary cluster locks before the actual IO is really started. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap inode block reads in a dedicated function.Joel Becker
The ocfs2 code currently reads inodes off disk with a simple ocfs2_read_block() call. Each place that does this has a different set of sanity checks it performs. Some check only the signature. A couple validate the block number (the block read vs di->i_blkno). A couple others check for VALID_FL. Only one place validates i_fs_generation. A couple check nothing. Even when an error is found, they don't all do the same thing. We wrap inode reading into ocfs2_read_inode_block(). This will validate all the above fields, going readonly if they are invalid (they never should be). ocfs2_read_inode_block_full() is provided for the places that want to pass read_block flags. Every caller is passing a struct inode with a valid ip_blkno, so we don't need a separate blkno argument either. We will remove the validation checks from the rest of the code in a later commit, as they are no longer necessary. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-12-01ocfs2: fix wake_up in unlock_astDavid Teigland
In ocfs2_unlock_ast(), call wake_up() on lockres before releasing the spin lock on it. As soon as the spin lock is released, the lockres can be freed. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Simplify ocfs2_read_block()Joel Becker
More than 30 callers of ocfs2_read_block() pass exactly OCFS2_BH_CACHED. Only six pass a different flag set. Rather than have every caller care, let's make ocfs2_read_block() take no flags and always do a cached read. The remaining six places can call ocfs2_read_blocks() directly. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Require an inode for ocfs2_read_block(s)().Joel Becker
Now that synchronous readers are using ocfs2_read_blocks_sync(), all callers of ocfs2_read_blocks() are passing an inode. Use it unconditionally. Since it's there, we don't need to pass the ocfs2_super either. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
