path: root/fs/ocfs2/alloc.h
2011-05-23ocfs2: Add ocfs2_trim_fs for SSD trim support.Tao Ma
Add ocfs2_trim_fs to support trimming freed clusters in the volume. A range will be given and all the freed clusters greater than minlen will be discarded to the block layer. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-01-07ocfs2: Remove unused truncate function from alloc.cTao Ma
Tristan Ye has done some refactoring against our truncate process, so some functions like ocfs2_prepare_truncate and ocfs2_free_truncate_context are no use and we'd better remove them. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-18Merge branch 'discontig-bg' of git://oss.oracle.com/git/tma/linux-2.6 into ↵Joel Becker
ocfs2-merge-window
2010-05-18Ocfs2: Make ocfs2_find_cpos_for_left_leaf() public.Tristan Ye
The original idea to pull ocfs2_find_cpos_for_left_leaf() out of alloc.c is to benefit punching-holes optimization patch, it however, can also be referred by other funcs in the future who want to do the same job. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-18Ocfs2: Optimize ocfs2 truncate to use ocfs2_remove_btree_range() instead.Tristan Ye
Truncate is just a special case of punching holes(from new i_size to end), we therefore could take advantage of the existing ocfs2_remove_btree_range() to reduce the comlexity and redundancy in alloc.c. The goal here is to make truncate more generic and straightforward. Several functions only used by ocfs2_commit_truncate() will smiply be removed. ocfs2_remove_btree_range() was originally used by the hole punching code, which didn't take refcount trees into account (definitely a bug). We therefore need to change that func a bit to handle refcount trees. It must take the refcount lock, calculate and reserve blocks for refcount tree changes, and decrease refcounts at the end. We replace ocfs2_lock_allocators() here by adding a new func ocfs2_reserve_blocks_for_rec_trunc() which accepts some extra blocks to reserve. This will not hurt any other code using ocfs2_remove_btree_range() (such as dir truncate and hole punching). I merged the following steps into one patch since they may be logically doing one thing, though I know it looks a little bit fat to review. 1). Remove redundant code used by ocfs2_commit_truncate(), since we're moving to ocfs2_remove_btree_range anyway. 2). Add a new func ocfs2_reserve_blocks_for_rec_trunc() for purpose of accepting some extra blocks to reserve. 3). Change ocfs2_prepare_refcount_change_for_del() a bit to fit our needs. It's safe to do this since it's only being called by truncate. 4). Change ocfs2_remove_btree_range() a bit to take refcount case into account. 5). Finally, we change ocfs2_commit_truncate() to call ocfs2_remove_btree_range() in a proper way. The patch has been tested normally for sanity check, stress tests with heavier workload will be expected. Based on this patch, fixing the punching holes bug will be fairly easy. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-03-22ocfs2: Free block to the right block group.Tao Ma
In case the block we are going to free is allocated from a discontiguous block group, we have to use suballoc_loc to be the right group. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-12-02ocfs2: Find proper end cpos for a leaf refcount block.Tao Ma
ocfs2 refcount tree is stored as an extent tree while the leaf ocfs2_refcount_rec points to a refcount block. The following step can trip a kernel panic. mkfs.ocfs2 -b 512 -C 1M --fs-features=refcount $DEVICE mount -t ocfs2 $DEVICE $MNT_DIR FILE_NAME=$RANDOM FILE_NAME_1=$RANDOM FILE_REF="${FILE_NAME}_ref" FILE_REF_1="${FILE_NAME}_ref_1" for((i=0;i<305;i++)) do # /mnt/1048576 is a file with 1048576 sizes. cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done for((i=0;i<3;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME done for((i=0;i<2;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME for((i=0;i<11;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF # write_f is a program which will write some bytes to a file at offset. # write_f -f file_name -l offset -w write_bytes. ./write_f -f $MNT_DIR/$FILE_REF -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[306*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[311*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF_1 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 #kernel panic here. The reason is that if the ocfs2_extent_rec is the last record in a leaf extent block, the old solution fails to find the suitable end cpos. So this patch try to walk through the b-tree, find the next sub root and get the c_pos the next sub-tree starts from. btw, I have runned tristan's test case against the patched kernel for several days and this type of kernel panic never happens again. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-22ocfs2: Add CoW support.Tao Ma
This patch try CoW support for a refcounted record. the whole process will be: 1. Calculate how many clusters we need to CoW and where we start. Extents that are not completely encompassed by the write will be broken on 1MB boundaries. 2. Do CoW for the clusters with the help of page cache. 3. Change the b-tree structure with the new allocated clusters. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add functions for extents refcounted.Tao Ma
Add function ocfs2_mark_extent_refcounted which can mark an extent refcounted. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add support of decrementing refcount for delete.Tao Ma
Given a physical cpos and length, decrement the refcount in the tree. If the refcount for any portion of the extent goes to zero, that portion is queued for freeing. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: move tree path functions to alloc.h.Tao Ma
Now fs/ocfs2/alloc.c has more than 7000 lines. It contains our basic b-tree operation. Although we have already make our b-tree operation generic, the basic structrue ocfs2_path which is used to iterate one b-tree branch is still static and limited to only used in alloc.c. As refcount tree need them and I don't want to add any more b-tree unrelated code to alloc.c, export them out. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add refcount b-tree as a new extent tree.Tao Ma
Add refcount b-tree as a new extent tree so that it can use the b-tree to store and maniuplate ocfs2_refcount_rec. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-04ocfs2: Pass ocfs2_caching_info into ocfs_init_*_extent_tree().Joel Becker
With this commit, extent tree operations are divorced from inodes and rely on ocfs2_caching_info. Phew! Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_remove_extent() no longer needs struct inode.Joel Becker
One more generic btree function that is isolated from struct inode. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_add_clusters_in_btree() no longer needs struct inode.Joel Becker
One more function that doesn't need a struct inode to pass to its children. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_insert_extent() no longer needs struct inode.Joel Becker
One more function down, no inode in the entire insert-extent chain. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_find_path() only needs the caching infoJoel Becker
ocfs2_find_path and ocfs2_find_leaf() walk our btrees, reading extent blocks. They need struct ocfs2_caching_info for that, but not struct inode. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Pass ocfs2_caching_info to ocfs2_read_extent_block().Joel Becker
extent blocks belong to btrees on more than just inodes, so we want to pass the ocfs2_caching_info structure directly to ocfs2_read_extent_block(). A number of places in alloc.c can now drop struct inode from their argument list. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Store the ocfs2_caching_info on ocfs2_extent_tree.Joel Becker
What do we cache? Metadata blocks. What are most of our non-inode metadata blocks? Extent blocks for our btrees. struct ocfs2_extent_tree is the main structure for managing those. So let's store the associated ocfs2_caching_info there. This means that ocfs2_et_root_journal_access() doesn't need struct inode anymore, and any place that has an et can refer to et->et_ci instead of INODE_CACHE(inode). Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-04-03ocfs2: Add a name indexed b-tree to directory inodesMark Fasheh
This patch makes use of Ocfs2's flexible btree code to add an additional tree to directory inodes. The new tree stores an array of small, fixed-length records in each leaf block. Each record stores a hash value, and pointer to a block in the traditional (unindexed) directory tree where a dirent with the given name hash resides. Lookup exclusively uses this tree to find dirents, thus providing us with constant time name lookups. Some of the hashing code was copied from ext3. Unfortunately, it has lots of unfixed checkpatch errors. I left that as-is so that tracking changes would be easier. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-01-05ocfs2: Create ocfs2_xattr_value_buf.Joel Becker
When an ocfs2 extended attribute is large enough to require its own allocation tree, we root it with an ocfs2_xattr_value_root. However, these roots can be a part of inodes, xattr blocks, or xattr buckets. Thus, they need a different journal access function for each container. We wrap the bh, its journal access function, and the value root (xv) in a structure called ocfs2_xattr_valu_buf. This is a package that can be passed around. In this first pass, we simply pass it to the extent tree code. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Use metadata-specific ocfs2_journal_access_*() functions.Joel Becker
The per-metadata-type ocfs2_journal_access_*() functions hook up jbd2 commit triggers and allow us to compute metadata ecc right before the buffers are written out. This commit provides ecc for inodes, extent blocks, group descriptors, and quota blocks. It is not safe to use extened attributes and metaecc at the same time yet. The ocfs2_extent_tree and ocfs2_path abstractions in alloc.c both hide the type of block at their root. Before, it didn't matter, but now the root block must use the appropriate ocfs2_journal_access_*() function. To keep this abstract, the structures now have a pointer to the matching journal_access function and a wrapper call to call it. A few places use naked ocfs2_write_block() calls instead of adding the blocks to the journal. We make sure to calculate their checksum and ecc before the write. Since we pass around the journal_access functions. Let's typedef them in ocfs2.h. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap extent block reads in a dedicated function.Joel Becker
We weren't consistently checking extent blocks after we read them. Most places checked the signature, but none checked h_blkno or h_fs_signature. Create a toplevel ocfs2_read_extent_block() that does the read and the validation. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: turn __ocfs2_remove_inode_range() into ocfs2_remove_btree_range()Mark Fasheh
This patch genericizes the high level handling of extent removal. ocfs2_remove_btree_range() is nearly identical to __ocfs2_remove_inode_range(), except that extent tree operations have been used where necessary. We update ocfs2_remove_inode_range() to use the generic helper. Now extent tree based structures have an easy way to truncate ranges. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-01-05ocfs2/xattr: Reserve meta/data at the beginning of ocfs2_xattr_set.Tao Ma
In ocfs2 xattr set, we reserve metadata and clusters in any place they are needed. It is time-consuming and ineffective, so this patch try to reserve metadata and clusters at the beginning of ocfs2_xattr_set. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add clusters free in dealloc_ctxt.Tao Ma
Now in ocfs2 xattr set, the whole process are divided into many small parts and they are wrapped into diffrent transactions and it make the set doesn't look like a real transaction. So we want to integrate it into a real one. In some cases we will allocate some clusters and free some in just one transaction. e.g, one xattr is larger than inline size, so it and its value root is stored within the inode while the value is outside in a cluster. Then we try to update it with a smaller value(larger than the size of root but smaller than inline size), we may need to free the outside cluster while allocate a new bucket(one cluster) since now the inode may be full. The old solution will lock the global_bitmap(if the local alloc failed in stress test) and then the truncate log. This will cause a ABBA lock with truncate log flush. This patch add the clusters free in dealloc_ctxt, so that we can record the free clusters during the transaction and then free it after we release the global_bitmap in xattr set. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Change ocfs2_get_*_extent_tree() to ocfs2_init_*_extent_tree()Joel Becker
The original get/put_extent_tree() functions held a reference on et_root_bh. However, every single caller already has a safe reference, making the get/put cycle irrelevant. We change ocfs2_get_*_extent_tree() to ocfs2_init_*_extent_tree(). It no longer gets a reference on et_root_bh. ocfs2_put_extent_tree() is removed. Callers now have a simpler init+use pattern. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make ocfs2_extent_tree the first-class representation of a tree.Joel Becker
We now have three different kinds of extent trees in ocfs2: inode data (dinode), extended attributes (xattr_tree), and extended attribute values (xattr_value). There is a nice abstraction for them, ocfs2_extent_tree, but it is hidden in alloc.c. All the calling functions have to pick amongst a varied API and pass in type bits and often extraneous pointers. A better way is to make ocfs2_extent_tree a first-class object. Everyone converts their object to an ocfs2_extent_tree() via the ocfs2_get_*_extent_tree() calls, then uses the ocfs2_extent_tree for all tree calls to alloc.c. This simplifies a lot of callers, making for readability. It also provides an easy way to add additional extent tree types, as they only need to be defined in alloc.c with a ocfs2_get_<new>_extent_tree() function. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Create specific get_extent_tree functions.Joel Becker
A caller knows what kind of extent tree they have. There's no reason they have to call ocfs2_get_extent_tree() with a NULL when they could just as easily call a specific function to their type of extent tree. Introduce ocfs2_dinode_get_extent_tree(), ocfs2_xattr_tree_get_extent_tree(), and ocfs2_xattr_value_get_extent_tree(). They only take the necessary arguments, calling into the underlying __ocfs2_get_extent_tree() to do the real work. __ocfs2_get_extent_tree() is the old ocfs2_get_extent_tree(), but without needing any switch-by-type logic. ocfs2_get_extent_tree() is now a wrapper around the specific calls. It exists because a couple alloc.c functions can take et_type. This will go later. Another benefit is that ocfs2_xattr_value_get_extent_tree() can take a struct ocfs2_xattr_value_root* instead of void*. This gives us typechecking where we didn't have it before. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Optionally limit extent size in ocfs2_insert_extent()Tao Ma
In xattr bucket, we want to limit the maximum size of a btree leaf, otherwise we'll lose the benefits of hashing because we'll have to search large leaves. So add a new field in ocfs2_extent_tree which indicates the maximum leaf cluster size we want so that we can prevent ocfs2_insert_extent() from merging the leaf record even if it is contiguous with an adjacent record. Other btree types are not affected by this change. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add xattr index tree operationsTao Ma
When necessary, an ocfs2_xattr_block will embed an ocfs2_extent_list to store large numbers of EAs. This patch adds a new type in ocfs2_extent_tree_type and adds the implementation so that we can re-use the b-tree code to handle the storage of many EAs. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add extent tree operation for xattr value btreesTao Ma
Add some thin wrappers around ocfs2_insert_extent() for each of the 3 different btree types, ocfs2_inode_insert_extent(), ocfs2_xattr_value_insert_extent() and ocfs2_xattr_tree_insert_extent(). The last is for the xattr index btree, which will be used in a followup patch. All the old callers in file.c etc will call ocfs2_dinode_insert_extent(), while the other two handle the xattr issue. And the init of extent tree are handled by these functions. When storing xattr value which is too large, we will allocate some clusters for it and here ocfs2_extent_list and ocfs2_extent_rec will also be used. In order to re-use the b-tree operation code, a new parameter named "private" is added into ocfs2_extent_tree and it is used to indicate the root of ocfs2_exent_list. The reason is that we can't deduce the root from the buffer_head now. It may be in an inode, an ocfs2_xattr_block or even worse, in any place in an ocfs2_xattr_bucket. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Make high level btree extend code genericTao Ma
Factor out the non-inode specifics of ocfs2_do_extend_allocation() into a more generic function, ocfs2_do_cluster_allocation(). ocfs2_do_extend_allocation calls ocfs2_do_cluster_allocation() now, but the latter can be used for other btree types as well. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Abstract ocfs2_extent_tree in b-tree operations.Tao Ma
In the old extent tree operation, we take the hypothesis that we are using the ocfs2_extent_list in ocfs2_dinode as the tree root. As xattr will also use ocfs2_extent_list to store large value for a xattr entry, we refactor the tree operation so that xattr can use it directly. The refactoring includes 4 steps: 1. Abstract set/get of last_eb_blk and update_clusters since they may be stored in different location for dinode and xattr. 2. Add a new structure named ocfs2_extent_tree to indicate the extent tree the operation will work on. 3. Remove all the use of fe_bh and di, use root_bh and root_el in extent tree instead. So now all the fe_bh is replaced with et->root_bh, el with root_el accordingly. 4. Make ocfs2_lock_allocators generic. Now it is limited to be only used in file extend allocation. But the whole function is useful when we want to store large EAs. Note: This patch doesn't touch ocfs2_commit_truncate() since it is not used for anything other than truncate inode data btrees. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Use ocfs2_extent_list instead of ocfs2_dinode.Tao Ma
ocfs2_extend_meta_needed(), ocfs2_calc_extend_credits() and ocfs2_reserve_new_metadata() are all useful for extent tree operations. But they are all limited to an inode btree because they use a struct ocfs2_dinode parameter. Change their parameter to struct ocfs2_extent_list (the part of an ocfs2_dinode they actually use) so that the xattr btree code can use these functions. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Modify ocfs2_num_free_extents for future xattr usage.Tao Ma
ocfs2_num_free_extents() is used to find the number of free extent records in an inode btree. Hence, it takes an "ocfs2_dinode" parameter. We want to use this for extended attribute trees in the future, so genericize the interface the take a buffer head. A future patch will allow that buffer_head to contain any structure rooting an ocfs2 btree. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-03ocfs2: fiemap supportMark Fasheh
Plug ocfs2 into ->fiemap. Some portions of ocfs2_get_clusters() had to be refactored so that the extent cache can be skipped in favor of going directly to the on-disk records. This makes it easier for us to determine which extent is the last one in the btree. Also, I'm not sure we want to be caching fiemap lookups anyway as they're not directly related to data read/write. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: ocfs2-devel@oss.oracle.com Cc: linux-fsdevel@vger.kernel.org
2007-10-12ocfs2: Write support for directories with inline dataMark Fasheh
Create all new directories with OCFS2_INLINE_DATA_FL and the inline data bytes formatted as an empty directory. Inode size field reflects the actual amount of inline data available, which makes searching for dirent space very similar to the regular directory search. Inline-data directories are automatically pushed out to extents on any insert request which is too large for the available space. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Joel Becker <joel.becker@oracle.com>
2007-10-12ocfs2: Write support for inline dataMark Fasheh
This fixes up write, truncate, mmap, and RESVSP/UNRESVP to understand inline inode data. For the most part, the changes to the core write code can be relied on to do the heavy lifting. Any code calling ocfs2_write_begin (including shared writeable mmap) can count on it doing the right thing with respect to growing inline data to an extent tree. Size reducing truncates, including UNRESVP can simply zero that portion of the inode block being removed. Size increasing truncatesm, including RESVP have to be a little bit smarter and grow the inode to an extent tree if necessary. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Joel Becker <joel.becker@oracle.com>
2007-07-10ocfs2: support for removing file regionsMark Fasheh
Provide an internal interface for the removal of arbitrary file regions. ocfs2_remove_inode_range() takes a byte range within a file and will remove existing extents within that range. Partial clusters will be zeroed so that any read from within the region will return zeros. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: update truncate handling of partial clustersMark Fasheh
The partial cluster zeroing code used during truncate usually assumes that the rightmost byte in the range to be zeroed lies on a cluster boundary. This makes sense for truncate, but punching holes might require zeroing on non-aligned rightmost boundaries. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: Support creation of unwritten extentsMark Fasheh
This can now be trivially supported with re-use of our existing extend code. ocfs2_allocate_unwritten_extents() takes a start offset and a byte length and iterates over the inode, adding extents (marked as unwritten) until len is reached. Existing extents are skipped over. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: btree changes for unwritten extentsMark Fasheh
Writes to a region marked as unwritten might result in a record split or merge. We can support splits by making minor changes to the existing insert code. Merges require left rotations which mostly re-use right rotation support functions. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: plug truncate into cached dealloc routinesMark Fasheh
2007-07-10ocfs2: simplify deallocation lockingMark Fasheh
Deallocation of suballocator blocks, most notably extent blocks, might involve multiple suballocator inodes. The locking for this can get extremely complicated, especially when the suballocator inodes to delete from aren't known until deep within an unrelated codepath. Implement a simple scheme for recording the blocks to be unlinked so that the actual deallocation can be done in a context which won't deadlock. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: make room for unwritten extents flagMark Fasheh
Due to the size of our group bitmaps, we'll never have a leaf node extent record with more than 16 bits worth of clusters. Split e_clusters up so that leaf nodes can get a flags field where we can mark unwritten extents. Interior nodes whose length references all the child nodes beneath it can't split their e_clusters field, so we use a union to preserve sizing there. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: zero tail of sparse files on truncateMark Fasheh
Since we don't zero on extend anymore, truncate needs to be fixed up to zero the part of a file between i_size and and end of it's cluster. Otherwise a subsequent extend could expose bad data. This introduced a new helper, which can be used in ocfs2_write(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: temporarily remove extent map cachingMark Fasheh
The code in extent_map.c is not prepared to deal with a subtree being rotated between lookups. This can happen when filling holes in sparse files. Instead of a lengthy patch to update the code (which would likely lose the benefit of caching subtree roots), we remove most of the algorithms and implement a simple path based lookup. A less ambitious extent caching scheme will be added in a later patch. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: sparse b-tree supportMark Fasheh
Introduce tree rotations into the b-tree code. This will allow ocfs2 to support sparse files. Much of the added code is designed to be generic (in the ocfs2 sense) so that it can later be re-used to implement large extended attributes. This patch only adds the rotation code and does minimal updates to callers of the extent api. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
