path: root/fs/ntfs/volume.h
2012-09-21userns: Convert ntfs to use kuid and kgid where appropriateEric W. Biederman
Cc: Anton Altaparmakov <anton@tuxera.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-03ntfs: propagate umode_tAl Viro
same story as with isofs and udf... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-24NTFS: Do more detailed reporting of why we cannot mount read-write byAnton Altaparmakov
special casing the VOLUME_MODIFIED_BY_CHKDSK flag. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Stamp the transaction log ($UsnJrnl), aka user space journal, if itAnton Altaparmakov
is active on the volume and we are mounting read-write or remounting from read-only to read-write. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
