path: root/fs/ntfs/inode.h
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - In fs/ntfs/compress.c, use i_size_read() at the start and then use theAnton Altaparmakov
cached value everywhere. Cache the initialized_size in the same way and protect the critical region where the two sizes are read using the new size_lock of the ntfs inode. - Add the new size_lock to the ntfs_inode structure (fs/ntfs/inode.h) and initialize it (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
