commit 54a307ba8d3cd00a3902337ffaae28f436eeb1a4 upstream.
When event on child inodes are sent to the parent inode mark and
parent inode mark was not marked with FAN_EVENT_ON_CHILD, the event
will not be delivered to the listener process. However, if the same
process also has a mount mark, the event to the parent inode will be
delivered regadless of the mount mark mask.
This behavior is incorrect in the case where the mount mark mask does
not contain the specific event type. For example, the process adds
a mark on a directory with mask FAN_MODIFY (without FAN_EVENT_ON_CHILD)
and a mount mark with mask FAN_CLOSE_NOWRITE (without FAN_ONDIR).
A modify event on a file inside that directory (and inside that mount)
should not create a FAN_MODIFY event, because neither of the marks
requested to get that event on the file.
Fixes: 1968f5eed54c ("fanotify: use both marks when possible")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
[natechancellor: Fix small conflict due to lack of 3cd5eca8d7a2f]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 49d31c2f389acfe83417083e1208422b4091cd9e upstream.
take_dentry_name_snapshot() takes a safe snapshot of dentry name;
if the name is a short one, it gets copied into caller-supplied
structure, otherwise an extra reference to external name is grabbed
(those are never modified). In either case the pointer to stable
string is stored into the same structure.
dentry must be held by the caller of take_dentry_name_snapshot(),
but may be freely dropped afterwards - the snapshot will stay
until destroyed by release_dentry_name_snapshot().
Intended use:
struct name_snapshot s;
take_dentry_name_snapshot(&s, dentry);
access s.name
release_dentry_name_snapshot(&s);
Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name
to pass down with event.
commit 4ff33aafd32e084f5ee7faa54ba06e95f8b1b8af upstream.
When delivering an event to userspace for a file on an NFS share,
if the file is deleted on server side before user reads the event,
user will not get the event.
If the event queue contained several events, the stale event is
quietly dropped and read() returns to user with events read so far
in the buffer.
If the event queue contains a single stale event or if the stale
event is a permission event, read() returns to user with the kernel
internal error code 518 (EOPENSTALE), which is not a POSIX error code.
Check the internal return value -EOPENSTALE in fanotify_read(), just
the same as it is checked in path_openat() and drop the event in the
cases that it is not already dropped.
This is a reproducer from Marko Rauhamaa:
Just take the example program listed under "man fanotify" ("fantest")
and follow these steps:
NFS Server NFS Client(1) NFS Client(2)
# echo foo >/nfsshare/bar.txt
# cat /nfsshare/bar.txt
foo
# ./fantest /nfsshare
Press enter key to terminate.
Listening for events.
# rm -f /nfsshare/bar.txt
read: Unknown error 518
cat: /nfsshare/bar.txt: Operation not permitted
where NFS Client (1) and (2) are two terminal sessions on a single NFS
Client machine.
Reported-by: Marko Rauhamaa <marko.rauhamaa@f-secure.com>
Tested-by: Marko Rauhamaa <marko.rauhamaa@f-secure.com>
Cc: <linux-api@vger.kernel.org>
commit 5716863e0f8251d3360d4cbfc0e44e08007075df upstream.
fsnotify_unmount_inodes() plays complex tricks to pin next inode in the
sb->s_inodes list when iterating over all inodes. Furthermore the code has a
bug that if the current inode is the last on i_sb_list that does not have e.g.
I_FREEING set, then we leave next_i pointing to inode which may get removed
from the i_sb_list once we drop s_inode_list_lock thus resulting in
use-after-free issues (usually manifesting as infinite looping in
fsnotify_unmount_inodes()).
Fix the problem by keeping current inode pinned somewhat longer. Then we can
make the code much simpler and standard.
Use assert_spin_locked() macro instead of hand-made BUG_ON statements.
Link: http://lkml.kernel.org/r/1474537439-18919-1-git-send-email-jack@suse.cz
Suggested-by: Heiner Kallweit <hkallweit1@gmail.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
When freeing permission events by fsnotify_destroy_event(), the warning
WARN_ON(!list_empty(&event->list)); may falsely hit.
This is because although fanotify_get_response() saw event->response
set, there is nothing to make sure the current CPU also sees the removal
of the event from the list. Add proper locking around the WARN_ON() to
avoid the false warning.
Link: http://lkml.kernel.org/r/1473797711-14111-7-git-send-email-jack@suse.cz
Reported-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Cc: Eric Paris <eparis@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Fanotify code has its own lock (access_lock) to protect a list of events
waiting for a response from userspace.
However this is somewhat awkward as the same list_head in the event is
protected by notification_lock if it is part of the notification queue
and by access_lock if it is part of the fanotify private queue which
makes it difficult for any reliable checks in the generic code. So make
fanotify use the same lock - notification_lock - for protecting its
private event list.
Link: http://lkml.kernel.org/r/1473797711-14111-6-git-send-email-jack@suse.cz
Cc: Miklos Szeredi <mszeredi@redhat.com>
notification_mutex is used to protect the list of pending events. As such
there's no reason to use a sleeping lock for it. Convert it to a
spinlock.
[jack@suse.cz: fixed version]
Link: http://lkml.kernel.org/r/1474031567-1831-1-git-send-email-jack@suse.cz
Link: http://lkml.kernel.org/r/1473797711-14111-5-git-send-email-jack@suse.cz
Tested-by: Guenter Roeck <linux@roeck-us.net>
fsnotify_flush_notify() and fanotify_release() destroy notification
event while holding notification_mutex.
The destruction of fanotify event includes a path_put() call which may
end up calling into a filesystem to delete an inode if we happen to be
the last holders of dentry reference which happens to be the last holder
of inode reference.
That in turn may violate lock ordering for some filesystems since
notification_mutex is also acquired e. g. during write when generating
fanotify event.
Also this is the only thing that forces notification_mutex to be a
sleeping lock. So drop notification_mutex before destroying a
notification event.
Link: http://lkml.kernel.org/r/1473797711-14111-4-git-send-email-jack@suse.cz
Cc: Lino Sanfilippo <LinoSanfilippo@gmx.de>
fanotify_get_response() calls fsnotify_remove_event() when it finds that
group is being released from fanotify_release() (bypass_perm is set).
However the event it removes need not be only in the group's notification
queue but it can have already moved to access_list (userspace read the
event before closing the fanotify instance fd) which is protected by a
different lock. Thus when fsnotify_remove_event() races with
fanotify_release() operating on access_list, the list can get corrupted.
Fix the problem by moving all the logic removing permission events from
the lists to one place - fanotify_release().
Fixes: 5838d4442bd5 ("fanotify: fix double free of pending permission events")
Link: http://lkml.kernel.org/r/1473797711-14111-3-git-send-email-jack@suse.cz
Tested-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Miklos Szeredi <mszeredi@redhat.com>
Cc: <stable@vger.kernel.org>
Implement a function that can be called when a group is being shutdown
to stop queueing new events to the group. Fanotify will use this.
Link: http://lkml.kernel.org/r/1473797711-14111-2-git-send-email-jack@suse.cz
Inotify instance is destroyed when all references to it are dropped.
That not only means that the corresponding file descriptor needs to be
closed but also that all corresponding instance marks are freed (as each
mark holds a reference to the inotify instance). However marks are
freed only after SRCU period ends which can take some time and thus if
user rapidly creates and frees inotify instances, number of existing
inotify instances can exceed max_user_instances limit although from user
point of view there is always at most one existing instance. Thus
inotify_init() returns EMFILE error which is hard to justify from user
point of view. This problem is exposed by LTP inotify06 testcase on
some machines.
We fix the problem by making sure all group marks are properly freed
while destroying inotify instance. We wait for SRCU period to end in
that path anyway since we have to make sure there is no event being
added to the instance while we are tearing down the instance. So it
takes only some plumbing to allow for marks to be destroyed in that path
as well and not from a dedicated work item.
Reported-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
Tested-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
We don't require a dedicated thread for fsnotify cleanup. Switch it
over to a workqueue job instead that runs on the system_unbound_wq.
In the interest of not thrashing the queued job too often when there are
a lot of marks being removed, we delay the reaper job slightly when
queueing it, to allow several to gather on the list.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Tested-by: Eryu Guan <guaneryu@gmail.com>
Cc: Eric Paris <eparis@parisplace.org>
This reverts commit c510eff6beba ("fsnotify: destroy marks with
call_srcu instead of dedicated thread").
Eryu reported that he was seeing some OOM kills kick in when running a
testcase that adds and removes inotify marks on a file in a tight loop.
The above commit changed the code to use call_srcu to clean up the
marks. While that does (in principle) work, the srcu callback job is
limited to cleaning up entries in small batches and only once per jiffy.
It's easily possible to overwhelm that machinery with too many call_srcu
callbacks, and Eryu's reproduer did just that.
There's also another potential problem with using call_srcu here. While
you can obviously sleep while holding the srcu_read_lock, the callbacks
run under local_bh_disable, so you can't sleep there.
It's possible when putting the last reference to the fsnotify_mark that
we'll end up putting a chain of references including the fsnotify_group,
uid, and associated keys. While I don't see any obvious ways that that
could occurs, it's probably still best to avoid using call_srcu here
after all.
This patch reverts the above patch. A later patch will take a different
approach to eliminated the dedicated thread here.
Reported-by: Eryu Guan <guaneryu@gmail.com>
Cc: Jan Kara <jack@suse.com>
At the time that this code was originally written, call_srcu didn't
exist, so this thread was required to ensure that we waited for that
SRCU grace period to settle before finally freeing the object.
It does exist now however and we can much more efficiently use call_srcu
to handle this. That also allows us to potentially use srcu_barrier to
ensure that they are all of the callbacks have run before proceeding.
In order to conserve space, we union the rcu_head with the g_list.
This will be necessary for nfsd which will allocate marks from a
dedicated slabcache. We have to be able to ensure that all of the
objects are destroyed before destroying the cache. That's fairly
Reviewed-by: Jan Kara <jack@suse.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
To make the intention clearer, use list_next_entry instead of
list_entry.
Signed-off-by: Geliang Tang <geliangtang@163.com>
The comment here says that it is checking for invalid bits. But, the mask
is *actually* checking to ensure that _any_ valid bit is set, which is
quite different.
Without this check, an unexpected bit could get set on an inotify object.
Since these bits are also interpreted by the fsnotify/dnotify code, there
is the potential for an object to be mishandled inside the kernel. For
instance, can we be sure that setting the dnotify flag FS_DN_RENAME on an
inotify watch is harmless?
Add the actual check which was intended. Retain the existing inotify bits
are being added to the watch. Plus, this is existing behavior which would
be nice to preserve.
I did a quick sniff test that inotify functions and that my
'inotify-tools' package passes 'make check'.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: John McCutchan <john@johnmccutchan.com>
Cc: Robert Love <rlove@rlove.org>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
There was a report that my patch:
inotify: actually check for invalid bits in sys_inotify_add_watch()
broke CRIU.
The reason is that CRIU looks up raw flags in /proc/$pid/fdinfo/* to
figure out how to rebuild inotify watches and then passes those flags
directly back in to the inotify API. One of those flags
(FS_EVENT_ON_CHILD) is set in mark->mask, but is not part of the inotify
API. It is used inside the kernel to _implement_ inotify but it is not
and has never been part of the API.
My patch above ensured that we only allow bits which are part of the API
(IN_ALL_EVENTS). This broke CRIU.
FS_EVENT_ON_CHILD is really internal to the kernel. It is set _anyway_ on
all inotify marks. So, CRIU was really just trying to set a bit that was
already set.
This patch hides that bit from fdinfo. CRIU will not see the bit, not try
to set it, and should work as before. We should not have been exposing
this bit in the first place, so this is a good patch independent of the
CRIU problem.
Reported-by: Andrey Wagin <avagin@gmail.com>
Acked-by: Andrey Vagin <avagin@openvz.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Eric Paris <eparis@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Pull vfs updates from Al Viro:
"In this one:
- d_move fixes (Eric Biederman)
- UFS fixes (me; locking is mostly sane now, a bunch of bugs in error
handling ought to be fixed)
- switch of sb_writers to percpu rwsem (Oleg Nesterov)
- superblock scalability (Josef Bacik and Dave Chinner)
- swapon(2) race fix (Hugh Dickins)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (65 commits)
vfs: Test for and handle paths that are unreachable from their mnt_root
dcache: Reduce the scope of i_lock in d_splice_alias
dcache: Handle escaped paths in prepend_path
mm: fix potential data race in SyS_swapon
inode: don't softlockup when evicting inodes
inode: rename i_wb_list to i_io_list
sync: serialise per-superblock sync operations
inode: convert inode_sb_list_lock to per-sb
inode: add hlist_fake to avoid the inode hash lock in evict
writeback: plug writeback at a high level
change sb_writers to use percpu_rw_semaphore
shift percpu_counter_destroy() into destroy_super_work()
percpu-rwsem: kill CONFIG_PERCPU_RWSEM
percpu-rwsem: introduce percpu_rwsem_release() and percpu_rwsem_acquire()
percpu-rwsem: introduce percpu_down_read_trylock()
document rwsem_release() in sb_wait_write()
fix the broken lockdep logic in __sb_start_write()
introduce __sb_writers_{acquired,release}() helpers
ufs_inode_get{frag,block}(): get rid of 'phys' argument
ufs_getfrag_block(): tidy up a bit
fsnotify_destroy_mark_locked() is subtle to use because it temporarily
releases group->mark_mutex. To avoid future problems with this
function, split it into two.
fsnotify_detach_mark() is the part that needs group->mark_mutex and
fsnotify_free_mark() is the part that must be called outside of
group->mark_mutex. This way it's much clearer what's going on and we
also avoid some pointless acquisitions of group->mark_mutex.
Signed-off-by: Jan Kara <jack@suse.com>
Free list is used when all marks on given inode / mount should be
destroyed when inode / mount is going away. However we can free all of
the marks without using a special list with some care.
A check in inotify_fdinfo() checking whether mark is valid was always
true due to a bug. Luckily we can never get to invalidated marks since
we hold mark_mutex and invalidated marks get removed from the group list
when they are invalidated under that mutex.
Anyway fix the check to make code more future proof.
I have a _tiny_ microbenchmark that sits in a loop and writes single
bytes to a file. Writing one byte to a tmpfs file is around 2x slower
than reading one byte from a file, which is a _bit_ more than I expecte.
This is a dumb benchmark, but I think it's hard to deny that write() is
a hot path and we should avoid unnecessary overhead there.
I did a 'perf record' of 30-second samples of read and write. The top
item in a diffprofile is srcu_read_lock() from fsnotify(). There are
active inotify fd's from systemd, but nothing is actually listening to
the file or its part of the filesystem.
I *think* we can avoid taking the srcu_read_lock() for the common case
where there are no actual marks on the file. This means that there will
both be nothing to notify for *and* implies that there is no need for
clearing the ignore mask.
This patch gave a 13.1% speedup in writes/second on my test, which is an
improvement from the 10.8% that I saw with the last version.
The process of reducing contention on per-superblock inode lists
starts with moving the locking to match the per-superblock inode
list. This takes the global lock out of the picture and reduces the
contention problems to within a single filesystem. This doesn't get
rid of contention as the locks still have global CPU scope, but it
does isolate operations on different superblocks form each other.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
Tested-by: Dave Chinner <dchinner@redhat.com>
fsnotify_clear_marks_by_group_flags() can race with
fsnotify_destroy_marks() so that when fsnotify_destroy_mark_locked()
drops mark_mutex, a mark from the list iterated by
fsnotify_clear_marks_by_group_flags() can be freed and thus the next
entry pointer we have cached may become stale and we dereference free
memory.
Fix the problem by first moving marks to free to a special private list
and then always free the first entry in the special list. This method
is safe even when entries from the list can disappear once we drop the
lock.
Reported-by: Ashish Sangwan <a.sangwan@samsung.com>
Reviewed-by: Ashish Sangwan <a.sangwan@samsung.com>
This reverts commit a2673b6e040663bf16a552f8619e6bde9f4b9acf.
Kinglong Mee reports a memory leak with that patch, and Jan Kara confirms:
"Thanks for report! You are right that my patch introduces a race
between fsnotify kthread and fsnotify_destroy_group() which can result
in leaking inotify event on group destruction.
I haven't yet decided whether the right fix is not to queue events for
dying notification group (as that is pointless anyway) or whether we
should just fix the original problem differently... Whenever I look
at fsnotify code mark handling I get lost in the maze of locks, lists,
and subtle differences between how different notification systems
handle notification marks :( I'll think about it over night"
and after thinking about it, Jan says:
"OK, I have looked into the code some more and I found another
relatively simple way of fixing the original oops. It will be IMHO
better than trying to fixup this issue which has more potential for
breakage. I'll ask Linus to revert the fsnotify fix he already merged
and send a new fix"
Reported-by: Kinglong Mee <kinglongmee@gmail.com>
Requested-by: Jan Kara <jack@suse.cz>
fsnotify_destroy_marks() so when fsnotify_destroy_mark_locked() drops
fsnotify_clear_marks_by_group_flags() can be freed and we dereference free
memory in the loop there.
Fix the problem by keeping mark_mutex held in
fsnotify_destroy_mark_locked(). The reason why we drop that mutex is that
we need to call a ->freeing_mark() callback which may acquire mark_mutex
again. To avoid this and similar lock inversion issues, we move the call
to ->freeing_mark() callback to the kthread destroying the mark.
Suggested-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
The INOTIFY_USER option is bool, and hence this code is either
present or absent. It will never be modular, so using
module_init as an alias for __initcall is rather misleading.
Fix this up now, so that we can relocate module_init from
init.h into module.h in the future. If we don't do this, we'd
have to add module.h to obviously non-modular code, and that
would be a worse thing.
Note that direct use of __initcall is discouraged, vs. one
of the priority categorized subgroups. As __initcall gets
mapped onto device_initcall, our use of fs_initcall (which
makes sense for fs code) will thus change this registration
from level 6-device to level 5-fs (i.e. slightly earlier).
However no observable impact of that small difference has
been observed during testing, or is expected.
With FAN_ONDIR set, the user can end up getting events, which it hasn't
marked. This was revealed with fanotify04 testcase failure on
Linux-4.0-rc1, and is a regression from 3.19, revealed with 66ba93c0d7fe6
("fanotify: don't set FAN_ONDIR implicitly on a marks ignored mask").
# /opt/ltp/testcases/bin/fanotify04
fanotify04 7 TPASS : event generated properly for type 100000
fanotify04 8 TFAIL : fanotify04.c:147: got unexpected event 30
fanotify04 9 TPASS : No event as expected
The testcase sets the adds the following marks : FAN_OPEN | FAN_ONDIR for
a fanotify on a dir. Then does an open(), followed by close() of the
directory and expects to see an event FAN_OPEN(0x20). However, the
fanotify returns (FAN_OPEN|FAN_CLOSE_NOWRITE(0x10)). This happens due to
the flaw in the check for event_mask in fanotify_should_send_event() which
does:
if (event_mask & marks_mask & ~marks_ignored_mask)
return true;
where, event_mask == (FAN_ONDIR | FAN_CLOSE_NOWRITE),
marks_mask == (FAN_ONDIR | FAN_OPEN),
marks_ignored_mask == 0
Fix this by masking the outgoing events to the user, as we already take
care of FAN_ONDIR and FAN_EVENT_ON_CHILD.
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Tested-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Fanotify probably doesn't want to watch autodirs so make it use d_can_lookup()
rather than d_is_dir() when checking a dir watch and give an error on fake
directories.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Currently FAN_ONDIR is always set on a mark's ignored mask when the
event mask is extended without FAN_MARK_ONDIR being set. This may
result in events for directories being ignored unexpectedly for call
sequences like
fanotify_mark(fd, FAN_MARK_ADD, FAN_OPEN | FAN_ONDIR , AT_FDCWD, "dir");
fanotify_mark(fd, FAN_MARK_ADD, FAN_CLOSE, AT_FDCWD, "dir");
Also FAN_MARK_ONDIR is only honored when adding events to a mark's mask,
but not for event removal. Fix both issues by not setting FAN_ONDIR
implicitly on the ignore mask any more. Instead treat FAN_ONDIR as any
other event flag and require FAN_MARK_ONDIR to be set by the user for
both event mask and ignore mask. Furthermore take FAN_MARK_ONDIR into
account when set for event removal.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
If removing bits from a mark's ignored mask, the concerning
inodes/vfsmounts mask is not affected. So don't recalculate it.
In fanotify_mark_remove_from_mask() a mark is destroyed if only one of
both bitmasks (mask or ignored_mask) of a mark is cleared. However the
other mask may still be set and contain information that should not be
lost. So only destroy a mark if both masks are cleared.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Documentation updates.
- Miscellaneous fixes.
- Preemptible-RCU fixes, including fixing an old bug in the
interaction of RCU priority boosting and CPU hotplug.
- SRCU updates.
- RCU CPU stall-warning updates.
- RCU torture-test updates.
As per e23738a7300a ("sched, inotify: Deal with nested sleeps").
fanotify_read is a wait loop with sleeps in. Wait loops rely on
task_struct::state and sleeps do too, since that's the only means of
actually sleeping. Therefore the nested sleeps destroy the wait loop
state and the wait loop breaks the sleep functions that assume
TASK_RUNNING (mutex_lock).
Fix this by using the new woken_wake_function and wait_woken() stuff,
which registers wakeups in wait and thereby allows shrinking the
task_state::state changes to the actual sleep part.
Reported-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Link: http://lkml.kernel.org/r/20141216152838.GZ3337@twins.programming.kicks-ass.net
SRCU is not necessary to be compiled by default in all cases. For tinification
efforts not compiling SRCU unless necessary is desirable.
The current patch tries to make compiling SRCU optional by introducing a new
Kconfig option CONFIG_SRCU which is selected when any of the components making
use of SRCU are selected.
If we do not select CONFIG_SRCU, srcu.o will not be compiled at all.
2007 0 0 2007 7d7 kernel/rcu/srcu.o
Size of arch/powerpc/boot/zImage changes from
831552 64180 23944 919676 e087c arch/powerpc/boot/zImage : before
829504 64180 23952 917636 e0084 arch/powerpc/boot/zImage : after
so the savings are about ~2000 bytes.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
CC: Josh Triplett <josh@joshtriplett.org>
CC: Lai Jiangshan <laijs@cn.fujitsu.com>
[ paulmck: resolve conflict due to removal of arch/ia64/kvm/Kconfig. ]
destroy_list is used to track marks which still need waiting for srcu
period end before they can be freed. However by the time mark is added to
destroy_list it isn't in group's list of marks anymore and thus we can
reuse fsnotify_mark->g_list for queueing into destroy_list. This saves
two pointers for each fsnotify_mark.
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
There's a lot of common code in inode and mount marks handling. Factor it
out to a common helper function.
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle are:
- 'Nested Sleep Debugging', activated when CONFIG_DEBUG_ATOMIC_SLEEP=y.
This instruments might_sleep() checks to catch places that nest
blocking primitives - such as mutex usage in a wait loop. Such
bugs can result in hard to debug races/hangs.
Another category of invalid nesting that this facility will detect
is the calling of blocking functions from within schedule() ->
sched_submit_work() -> blk_schedule_flush_plug().
There's some potential for false positives (if secondary blocking
primitives themselves are not ready yet for this facility), but the
kernel will warn once about such bugs per bootup, so the warning
isn't much of a nuisance.
This feature comes with a number of fixes, for problems uncovered
with it, so no messages are expected normally.
- Another round of sched/numa optimizations and refinements, for
CONFIG_NUMA_BALANCING=y.
- Another round of sched/dl fixes and refinements.
Plus various smaller fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits)
sched: Add missing rcu protection to wake_up_all_idle_cpus
sched/deadline: Introduce start_hrtick_dl() for !CONFIG_SCHED_HRTICK
sched/numa: Init numa balancing fields of init_task
sched/deadline: Remove unnecessary definitions in cpudeadline.h
sched/cpupri: Remove unnecessary definitions in cpupri.h
sched/deadline: Fix rq->dl.pushable_tasks bug in push_dl_task()
sched/fair: Fix stale overloaded status in the busiest group finding logic
sched: Move p->nr_cpus_allowed check to select_task_rq()
sched/completion: Document when to use wait_for_completion_io_*()
sched: Update comments about CLONE_NEWUTS and CLONE_NEWIPC
sched/fair: Kill task_struct::numa_entry and numa_group::task_list
sched: Refactor task_struct to use numa_faults instead of numa_* pointers
sched/deadline: Don't check CONFIG_SMP in switched_from_dl()
sched/deadline: Reschedule from switched_from_dl() after a successful pull
sched/deadline: Push task away if the deadline is equal to curr during wakeup
sched/deadline: Add deadline rq status print
sched/deadline: Fix artificial overrun introduced by yield_task_dl()
sched/rt: Clean up check_preempt_equal_prio()
sched/core: Use dl_bw_of() under rcu_read_lock_sched()
sched: Check if we got a shallowest_idle_cpu before searching for least_loaded_cpu
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into for-next
Pull the beginning of seq_file cleanup from Steven:
"I'm looking to clean up the seq_file code and to eventually merge the
trace_seq code with seq_file as well, since they basically do the same thing.
Part of this process is to remove the return code of seq_printf() and friends
as they are rather inconsistent. It is better to use the new function
seq_has_overflowed() if you want to stop processing when the buffer
is full. Note, if the buffer is full, the seq_file code will throw away
the contents, allocate a bigger buffer, and then call your code again
to fill in the data. The only thing that breaking out of the function
early does is to save a little time which is probably never noticed.
I started with patches from Joe Perches and modified them as well.
There's many more places that need to be updated before we can convert
seq_printf() and friends to return void. But this patch set introduces
the seq_has_overflowed() and does some initial updates."
applying more changes
fsnotify() needs to merge inode and mount marks lists when notifying
groups about events so that ignore masks from inode marks are reflected
in mount mark notifications and groups are notified in proper order
(according to priorities).
Currently the sorting of the lists done by fsnotify_add_inode_mark() /
fsnotify_add_vfsmount_mark() and fsnotify() differed which resulted
ignore masks not being used in some cases.
Fix the problem by always using the same comparison function when
sorting / merging the mark lists.
Thanks to Heinrich Schuchardt for improvements of my patch.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=87721
Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
seq_printf functions shouldn't really check the return value.
Checking seq_has_overflowed() occasionally is used instead.
Update vfs documentation.
Link: http://lkml.kernel.org/p/e37e6e7b76acbdcc3bb4ab2a57c8f8ca1ae11b9a.1412031505.git.joe@perches.com
[ did a few clean ups ]
During file system stress testing on 3.10 and 3.12 based kernels, the
umount command occasionally hung in fsnotify_unmount_inodes in the
section of code:
spin_lock(&inode->i_lock);
if (inode->i_state & (I_FREEING|I_WILL_FREE|I_NEW)) {
spin_unlock(&inode->i_lock);
continue;
As this section of code holds the global inode_sb_list_lock, eventually
the system hangs trying to acquire the lock.
Multiple crash dumps showed:
The inode->i_state == 0x60 and i_count == 0 and i_sb_list would point
back at itself. As this is not the value of list upon entry to the
function, the kernel never exits the loop.
To help narrow down problem, the call to list_del_init in
inode_sb_list_del was changed to list_del. This poisons the pointers in
the i_sb_list and causes a kernel to panic if it transverse a freed
inode.
Subsequent stress testing paniced in fsnotify_unmount_inodes at the
bottom of the list_for_each_entry_safe loop showing next_i had become
free.
We believe the root cause of the problem is that next_i is being freed
during the window of time that the list_for_each_entry_safe loop
temporarily releases inode_sb_list_lock to call fsnotify and
fsnotify_inode_delete.
The code in fsnotify_unmount_inodes attempts to prevent the freeing of
inode and next_i by calling __iget. However, the code doesn't do the
__iget call on next_i
if i_count == 0 or
if i_state & (I_FREEING | I_WILL_FREE)
The patch addresses this issue by advancing next_i in the above two cases
until we either find a next_i which we can __iget or we reach the end of
the list. This makes the handling of next_i more closely match the
handling of the variable "inode."
The time to reproduce the hang is highly variable (from hours to days.) We
ran the stress test on a 3.10 kernel with the proposed patch for a week
without failure.
During list_for_each_entry_safe, next_i is becoming free causing
the loop to never terminate. Advance next_i in those cases where
__iget is not done.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hp.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Ken Helias <kenhelias@firemail.de>
inotify_read is a wait loop with sleeps in. Wait loops rely on
Cc: tglx@linutronix.de
Cc: ilya.dryomov@inktank.com
Cc: umgwanakikbuti@gmail.com
Link: http://lkml.kernel.org/r/20140924082242.254858080@infradead.org
Pull file locking related changes from Jeff Layton:
"This release is a little more busy for file locking changes than the
last:
- a set of patches from Kinglong Mee to fix the lockowner handling in
knfsd
- a pile of cleanups to the internal file lease API. This should get
us a bit closer to allowing for setlease methods that can block.
There are some dependencies between mine and Bruce's trees this cycle,
and I based my tree on top of the requisite patches in Bruce's tree"
* tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits)
locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING
locks: flock_make_lock should return a struct file_lock (or PTR_ERR)
locks: set fl_owner for leases to filp instead of current->files
locks: give lm_break a return value
locks: __break_lease cleanup in preparation of allowing direct removal of leases
locks: remove i_have_this_lease check from __break_lease
locks: move freeing of leases outside of i_lock
locks: move i_lock acquisition into generic_*_lease handlers
locks: define a lm_setup handler for leases
locks: plumb a "priv" pointer into the setlease routines
nfsd: don't keep a pointer to the lease in nfs4_file
locks: clean up vfs_setlease kerneldoc comments
locks: generic_delete_lease doesn't need a file_lock at all
nfsd: fix potential lease memory leak in nfs4_setlease
locks: close potential race in lease_get_mtime
security: make security_file_set_fowner, f_setown and __f_setown void return
locks: consolidate "nolease" routines
locks: remove lock_may_read and lock_may_write
lockd: rip out deferred lock handling from testlock codepath
NFSD: Get reference of lockowner when coping file_lock
