path: root/fs/nfsd
2014-07-06nfsd: don't halt scanning the DRC LRU list when there's an RC_INPROG entryJeff Layton
commit 1b19453d1c6abcfa7c312ba6c9f11a277568fc94 upstream. Currently, the DRC cache pruner will stop scanning the list when it hits an entry that is RC_INPROG. It's possible however for a call to take a *very* long time. In that case, we don't want it to block other entries from being pruned if they are expired or we need to trim the cache to get back under the limit. Fix the DRC cache pruner to just ignore RC_INPROG entries. Signed-off-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06nfsd: don't try to reuse an expired DRC entry off the listJeff Layton
commit a0ef5e19684f0447da9ff0654a12019c484f57ca upstream. Currently when we are processing a request, we try to scrape an expired or over-limit entry off the list in preference to allocating a new one from the slab. This is unnecessarily complicated. Just use the slab layer. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06nfsd: getattr for FATTR4_WORD0_FILES_AVAIL needs the statfs bufferChristoph Hellwig
commit 12337901d654415d9f764b5f5ba50052e9700f37 upstream. Note nobody's ever noticed because the typical client probably never requests FILES_AVAIL without also requesting something else on the list. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06nfsd4: fix FREE_STATEID lockowner leakJ. Bruce Fields
commit 48385408b45523d9a432c66292d47ef43efcbb94 upstream. 27b11428b7de ("nfsd4: remove lockowner when removing lock stateid") introduced a memory leak. Reported-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07nfsd4: remove lockowner when removing lock stateidJ. Bruce Fields
commit a1b8ff4c97b4375d21b6d6c45d75877303f61b3b upstream. The nfsv4 state code has always assumed a one-to-one correspondance between lock stateid's and lockowners even if it appears not to in some places. We may actually change that, but for now when FREE_STATEID releases a lock stateid it also needs to release the parent lockowner. Symptoms were a subsequent LOCK crashing in find_lockowner_str when it calls same_lockowner_ino on a lockowner that unexpectedly has an empty so_stateids list. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07nfsd4: warn on finding lockowner without stateid'sJ. Bruce Fields
commit 27b11428b7de097c42f205beabb1764f4365443b upstream. The current code assumes a one-to-one lockowner<->lock stateid correspondance. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07NFSD: Call ->set_acl with a NULL ACL structure if no entriesKinglong Mee
commit aa07c713ecfc0522916f3cd57ac628ea6127c0ec upstream. After setting ACL for directory, I got two problems that caused by the cached zero-length default posix acl. This patch make sure nfsd4_set_nfs4_acl calls ->set_acl with a NULL ACL structure if there are no entries. Thanks for Christoph Hellwig's advice. First problem: ............ hang ........... Second problem: [ 1610.167668] ------------[ cut here ]------------ [ 1610.168320] kernel BUG at /root/nfs/linux/fs/nfsd/nfs4acl.c:239! [ 1610.168320] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC [ 1610.168320] Modules linked in: nfsv4(OE) nfs(OE) nfsd(OE) rpcsec_gss_krb5 fscache ip6t_rpfilter ip6t_REJECT cfg80211 xt_conntrack rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw auth_rpcgss nfs_acl snd_intel8x0 ppdev lockd snd_ac97_codec ac97_bus snd_pcm snd_timer e1000 pcspkr parport_pc snd parport serio_raw joydev i2c_piix4 sunrpc(OE) microcode soundcore i2c_core ata_generic pata_acpi [last unloaded: nfsd] [ 1610.168320] CPU: 0 PID: 27397 Comm: nfsd Tainted: G OE 3.15.0-rc1+ #15 [ 1610.168320] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006 [ 1610.168320] task: ffff88005ab653d0 ti: ffff88005a944000 task.ti: ffff88005a944000 [ 1610.168320] RIP: 0010:[<ffffffffa034d5ed>] [<ffffffffa034d5ed>] _posix_to_nfsv4_one+0x3cd/0x3d0 [nfsd] [ 1610.168320] RSP: 0018:ffff88005a945b00 EFLAGS: 00010293 [ 1610.168320] RAX: 0000000000000001 RBX: ffff88006700bac0 RCX: 0000000000000000 [ 1610.168320] RDX: 0000000000000000 RSI: ffff880067c83f00 RDI: ffff880068233300 [ 1610.168320] RBP: ffff88005a945b48 R08: ffffffff81c64830 R09: 0000000000000000 [ 1610.168320] R10: ffff88004ea85be0 R11: 000000000000f475 R12: ffff880068233300 [ 1610.168320] R13: 0000000000000003 R14: 0000000000000002 R15: ffff880068233300 [ 1610.168320] FS: 0000000000000000(0000) GS:ffff880077800000(0000) knlGS:0000000000000000 [ 1610.168320] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1610.168320] CR2: 00007f5bcbd3b0b9 CR3: 0000000001c0f000 CR4: 00000000000006f0 [ 1610.168320] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 1610.168320] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 1610.168320] Stack: [ 1610.168320] ffffffff00000000 0000000b67c83500 000000076700bac0 0000000000000000 [ 1610.168320] ffff88006700bac0 ffff880068233300 ffff88005a945c08 0000000000000002 [ 1610.168320] 0000000000000000 ffff88005a945b88 ffffffffa034e2d5 000000065a945b68 [ 1610.168320] Call Trace: [ 1610.168320] [<ffffffffa034e2d5>] nfsd4_get_nfs4_acl+0x95/0x150 [nfsd] [ 1610.168320] [<ffffffffa03400d6>] nfsd4_encode_fattr+0x646/0x1e70 [nfsd] [ 1610.168320] [<ffffffff816a6e6e>] ? kmemleak_alloc+0x4e/0xb0 [ 1610.168320] [<ffffffffa0327962>] ? nfsd_setuser_and_check_port+0x52/0x80 [nfsd] [ 1610.168320] [<ffffffff812cd4bb>] ? selinux_cred_prepare+0x1b/0x30 [ 1610.168320] [<ffffffffa0341caa>] nfsd4_encode_getattr+0x5a/0x60 [nfsd] [ 1610.168320] [<ffffffffa0341e07>] nfsd4_encode_operation+0x67/0x110 [nfsd] [ 1610.168320] [<ffffffffa033844d>] nfsd4_proc_compound+0x21d/0x810 [nfsd] [ 1610.168320] [<ffffffffa0324d9b>] nfsd_dispatch+0xbb/0x200 [nfsd] [ 1610.168320] [<ffffffffa00850cd>] svc_process_common+0x46d/0x6d0 [sunrpc] [ 1610.168320] [<ffffffffa0085433>] svc_process+0x103/0x170 [sunrpc] [ 1610.168320] [<ffffffffa032472f>] nfsd+0xbf/0x130 [nfsd] [ 1610.168320] [<ffffffffa0324670>] ? nfsd_destroy+0x80/0x80 [nfsd] [ 1610.168320] [<ffffffff810a5202>] kthread+0xd2/0xf0 [ 1610.168320] [<ffffffff810a5130>] ? insert_kthread_work+0x40/0x40 [ 1610.168320] [<ffffffff816c1ebc>] ret_from_fork+0x7c/0xb0 [ 1610.168320] [<ffffffff810a5130>] ? insert_kthread_work+0x40/0x40 [ 1610.168320] Code: 78 02 e9 e7 fc ff ff 31 c0 31 d2 31 c9 66 89 45 ce 41 8b 04 24 66 89 55 d0 66 89 4d d2 48 8d 04 80 49 8d 5c 84 04 e9 37 fd ff ff <0f> 0b 90 0f 1f 44 00 00 55 8b 56 08 c7 07 00 00 00 00 8b 46 0c [ 1610.168320] RIP [<ffffffffa034d5ed>] _posix_to_nfsv4_one+0x3cd/0x3d0 [nfsd] [ 1610.168320] RSP <ffff88005a945b00> [ 1610.257313] ---[ end trace 838254e3e352285b ]--- Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07NFSd: call rpc_destroy_wait_queue() from free_client()Trond Myklebust
commit 4cb57e3032d4e4bf5e97780e9907da7282b02b0c upstream. Mainly to ensure that we don't leave any hanging timers. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07NFSd: Move default initialisers from create_client() to alloc_client()Trond Myklebust
commit 5694c93e6c4954fa9424c215f75eeb919bddad64 upstream. Aside from making it clearer what is non-trivial in create_client(), it also fixes a bug whereby we can call free_client() before idr_init() has been called. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd: set timeparms.to_maxval in setup_callback_clientJeff Layton
commit 3758cf7e14b753838fe754ede3862af10b35fdac upstream. ...otherwise the logic in the timeout handling doesn't work correctly. Spotted-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06NFSD: Traverse unconfirmed client through hash-tableKinglong Mee
commit 2b9056359889c78ea5decb5b654a512c2e8a945c upstream. When stopping nfsd, I got BUG messages, and soft lockup messages, The problem is cuased by double rb_erase() in nfs4_state_destroy_net() and destroy_client(). This patch just let nfsd traversing unconfirmed client through hash-table instead of rbtree. [ 2325.021995] BUG: unable to handle kernel NULL pointer dereference at (null) [ 2325.022809] IP: [<ffffffff8133c18c>] rb_erase+0x14c/0x390 [ 2325.022982] PGD 7a91b067 PUD 7a33d067 PMD 0 [ 2325.022982] Oops: 0000 [#1] SMP DEBUG_PAGEALLOC [ 2325.022982] Modules linked in: nfsd(OF) cfg80211 rfkill bridge stp llc snd_intel8x0 snd_ac97_codec ac97_bus auth_rpcgss nfs_acl serio_raw e1000 i2c_piix4 ppdev snd_pcm snd_timer lockd pcspkr joydev parport_pc snd parport i2c_core soundcore microcode sunrpc ata_generic pata_acpi [last unloaded: nfsd] [ 2325.022982] CPU: 1 PID: 2123 Comm: nfsd Tainted: GF O 3.14.0-rc8+ #2 [ 2325.022982] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006 [ 2325.022982] task: ffff88007b384800 ti: ffff8800797f6000 task.ti: ffff8800797f6000 [ 2325.022982] RIP: 0010:[<ffffffff8133c18c>] [<ffffffff8133c18c>] rb_erase+0x14c/0x390 [ 2325.022982] RSP: 0018:ffff8800797f7d98 EFLAGS: 00010246 [ 2325.022982] RAX: ffff880079c1f010 RBX: ffff880079f4c828 RCX: 0000000000000000 [ 2325.022982] RDX: 0000000000000000 RSI: ffff880079bcb070 RDI: ffff880079f4c810 [ 2325.022982] RBP: ffff8800797f7d98 R08: 0000000000000000 R09: ffff88007964fc70 [ 2325.022982] R10: 0000000000000000 R11: 0000000000000400 R12: ffff880079f4c800 [ 2325.022982] R13: ffff880079bcb000 R14: ffff8800797f7da8 R15: ffff880079f4c860 [ 2325.022982] FS: 0000000000000000(0000) GS:ffff88007f900000(0000) knlGS:0000000000000000 [ 2325.022982] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 2325.022982] CR2: 0000000000000000 CR3: 000000007a3ef000 CR4: 00000000000006e0 [ 2325.022982] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 2325.022982] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 2325.022982] Stack: [ 2325.022982] ffff8800797f7de0 ffffffffa0191c6e ffff8800797f7da8 ffff8800797f7da8 [ 2325.022982] ffff880079f4c810 ffff880079bcb000 ffffffff81cc26c0 ffff880079c1f010 [ 2325.022982] ffff880079bcb070 ffff8800797f7e28 ffffffffa01977f2 ffff8800797f7df0 [ 2325.022982] Call Trace: [ 2325.022982] [<ffffffffa0191c6e>] destroy_client+0x32e/0x3b0 [nfsd] [ 2325.022982] [<ffffffffa01977f2>] nfs4_state_shutdown_net+0x1a2/0x220 [nfsd] [ 2325.022982] [<ffffffffa01700b8>] nfsd_shutdown_net+0x38/0x70 [nfsd] [ 2325.022982] [<ffffffffa017013e>] nfsd_last_thread+0x4e/0x80 [nfsd] [ 2325.022982] [<ffffffffa001f1eb>] svc_shutdown_net+0x2b/0x30 [sunrpc] [ 2325.022982] [<ffffffffa017064b>] nfsd_destroy+0x5b/0x80 [nfsd] [ 2325.022982] [<ffffffffa0170773>] nfsd+0x103/0x130 [nfsd] [ 2325.022982] [<ffffffffa0170670>] ? nfsd_destroy+0x80/0x80 [nfsd] [ 2325.022982] [<ffffffff810a8232>] kthread+0xd2/0xf0 [ 2325.022982] [<ffffffff810a8160>] ? insert_kthread_work+0x40/0x40 [ 2325.022982] [<ffffffff816c493c>] ret_from_fork+0x7c/0xb0 [ 2325.022982] [<ffffffff810a8160>] ? insert_kthread_work+0x40/0x40 [ 2325.022982] Code: 48 83 e1 fc 48 89 10 0f 84 02 01 00 00 48 3b 41 10 0f 84 08 01 00 00 48 89 51 08 48 89 fa e9 74 ff ff ff 0f 1f 40 00 48 8b 50 10 <f6> 02 01 0f 84 93 00 00 00 48 8b 7a 10 48 85 ff 74 05 f6 07 01 [ 2325.022982] RIP [<ffffffff8133c18c>] rb_erase+0x14c/0x390 [ 2325.022982] RSP <ffff8800797f7d98> [ 2325.022982] CR2: 0000000000000000 [ 2325.022982] ---[ end trace 28c27ed011655e57 ]--- [ 228.064071] BUG: soft lockup - CPU#0 stuck for 22s! [nfsd:558] [ 228.064428] Modules linked in: ip6t_rpfilter ip6t_REJECT cfg80211 xt_conntrack rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw nfsd(OF) auth_rpcgss nfs_acl lockd snd_intel8x0 snd_ac97_codec ac97_bus joydev snd_pcm snd_timer e1000 sunrpc snd ppdev parport_pc serio_raw pcspkr i2c_piix4 microcode parport soundcore i2c_core ata_generic pata_acpi [ 228.064539] CPU: 0 PID: 558 Comm: nfsd Tainted: GF O 3.14.0-rc8+ #2 [ 228.064539] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006 [ 228.064539] task: ffff880076adec00 ti: ffff880074616000 task.ti: ffff880074616000 [ 228.064539] RIP: 0010:[<ffffffff8133ba17>] [<ffffffff8133ba17>] rb_next+0x27/0x50 [ 228.064539] RSP: 0018:ffff880074617de0 EFLAGS: 00000282 [ 228.064539] RAX: ffff880074478010 RBX: ffff88007446f860 RCX: 0000000000000014 [ 228.064539] RDX: ffff880074478010 RSI: 0000000000000000 RDI: ffff880074478010 [ 228.064539] RBP: ffff880074617de0 R08: 0000000000000000 R09: 0000000000000012 [ 228.064539] R10: 0000000000000001 R11: ffffffffffffffec R12: ffffea0001d11a00 [ 228.064539] R13: ffff88007f401400 R14: ffff88007446f800 R15: ffff880074617d50 [ 228.064539] FS: 0000000000000000(0000) GS:ffff88007f800000(0000) knlGS:0000000000000000 [ 228.064539] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 228.064539] CR2: 00007fe9ac6ec000 CR3: 000000007a5d6000 CR4: 00000000000006f0 [ 228.064539] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 228.064539] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 228.064539] Stack: [ 228.064539] ffff880074617e28 ffffffffa01ab7db ffff880074617df0 ffff880074617df0 [ 228.064539] ffff880079273000 ffffffff81cc26c0 ffffffff81cc26c0 0000000000000000 [ 228.064539] 0000000000000000 ffff880074617e48 ffffffffa01840b8 ffffffff81cc26c0 [ 228.064539] Call Trace: [ 228.064539] [<ffffffffa01ab7db>] nfs4_state_shutdown_net+0x18b/0x220 [nfsd] [ 228.064539] [<ffffffffa01840b8>] nfsd_shutdown_net+0x38/0x70 [nfsd] [ 228.064539] [<ffffffffa018413e>] nfsd_last_thread+0x4e/0x80 [nfsd] [ 228.064539] [<ffffffffa00aa1eb>] svc_shutdown_net+0x2b/0x30 [sunrpc] [ 228.064539] [<ffffffffa018464b>] nfsd_destroy+0x5b/0x80 [nfsd] [ 228.064539] [<ffffffffa0184773>] nfsd+0x103/0x130 [nfsd] [ 228.064539] [<ffffffffa0184670>] ? nfsd_destroy+0x80/0x80 [nfsd] [ 228.064539] [<ffffffff810a8232>] kthread+0xd2/0xf0 [ 228.064539] [<ffffffff810a8160>] ? insert_kthread_work+0x40/0x40 [ 228.064539] [<ffffffff816c493c>] ret_from_fork+0x7c/0xb0 [ 228.064539] [<ffffffff810a8160>] ? insert_kthread_work+0x40/0x40 [ 228.064539] Code: 1f 44 00 00 55 48 8b 17 48 89 e5 48 39 d7 74 3b 48 8b 47 08 48 85 c0 75 0e eb 25 66 0f 1f 84 00 00 00 00 00 48 89 d0 48 8b 50 10 <48> 85 d2 75 f4 5d c3 66 90 48 3b 78 08 75 f6 48 8b 10 48 89 c7 Fixes: ac55fdc408039 (nfsd: move the confirmed and unconfirmed hlists...) Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd4: fix setclientid encode sizeJ. Bruce Fields
commit 480efaee085235bb848f1063f959bf144103c342 upstream. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd: check passed socket's net matches NFSd superblock's oneStanislav Kinsbursky
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream. There could be a case, when NFSd file system is mounted in network, different to socket's one, like below: "ip netns exec" creates new network and mount namespace, which duplicates NFSd mount point, created in init_net context. And thus NFS server stop in nested network context leads to RPCBIND client destruction in init_net. Then, on NFSd start in nested network context, rpc.nfsd process creates socket in nested net and passes it into "write_ports", which leads to RPCBIND sockets creation in init_net context because of the same reason (NFSd monut point was created in init_net context). An attempt to register passed socket in nested net leads to panic, because no RPCBIND client present in nexted network namespace. This patch add check that passed socket's net matches NFSd superblock's one. And returns -EINVAL error to user psace otherwise. v2: Put socket on exit. Reported-by: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd: notify_change needs elevated write countJ. Bruce Fields
commit 9f67f189939eccaa54f3d2c9cf10788abaf2d584 upstream. Looks like this bug has been here since these write counts were introduced, not sure why it was just noticed now. Thanks also to Jan Kara for pointing out the problem. Reported-by: Matthew Rahtz <mrahtz@rapitasystems.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd4: fix test_stateid error reply encodingJ. Bruce Fields
commit a11fcce1544df08c723d950ff0edef3adac40405 upstream. If the entire operation fails then there's nothing to encode. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd4: buffer-length check for SUPPATTR_EXCLCREATJ. Bruce Fields
commit de3997a7eeb9ea286b15879fdf8a95aae065b4f7 upstream. This was an omission from 8c18f2052e756e7d5dea712fc6e7ed70c00e8a39 "nfsd41: SUPPATTR_EXCLCREAT attribute". Cc: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-06nfsd4: session needs room for following op to error outJ. Bruce Fields
commit 4c69d5855a16f7378648c5733632628fa10431db upstream. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20nfsd: when reusing an existing repcache entry, unhash it firstJeff Layton
commit 781c2a5a5f75eacc04663aced0f0f1a648d4f308 upstream. The DRC code will attempt to reuse an existing, expired cache entry in preference to allocating a new one. It'll then search the cache, and if it gets a hit it'll then free the cache entry that it was going to reuse. The cache code doesn't unhash the entry that it's going to reuse however, so it's possible for it end up designating an entry for reuse and then subsequently freeing the same entry after it finds it. This leads it to a later use-after-free situation and usually some list corruption warnings or an oops. Fix this by simply unhashing the entry that we intend to reuse. That will mean that it's not findable via a search and should prevent this situation from occurring. Reported-by: Christoph Hellwig <hch@infradead.org> Reported-by: g. artim <gartim@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29nfsd: make sure to balance get/put_write_accessChristoph Hellwig
commit 987da4791052fa298b7cfcde4dea9f6f2bbc786b upstream. Use a straight goto error label style in nfsd_setattr to make sure we always do the put_write_access call after we got it earlier. Note that the we have been failing to do that in the case nfsd_break_lease() returns an error, a bug introduced into 2.6.38 with 6a76bebefe15d9a08864f824d7f8d5beaf37c997 "nfsd4: break lease on nfsd setattr". Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29nfsd: split up nfsd_setattrChristoph Hellwig
commit 818e5a22e907fbae75e9c1fd78233baec9fa64b6 upstream. Split out two helpers to make the code more readable and easier to verify for correctness. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29nfsd: return better errors to exportfsJ. Bruce Fields
commit 427d6c6646d868fbd3094e7e2e1644d480cd9204 upstream. Someone noticed exportfs happily accepted exports that would later be rejected when mountd tried to give them to the kernel. Fix this. This is a regression from 4c1e1b34d5c800ad3ac9a7e2805b0bea70ad2278 "nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids". Cc: "Eric W. Biederman" <ebiederm@xmission.com> Reported-by: Yin.JianHong <jiyin@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04nfsd: nfsd_open: when dentry_open returns an error do not propagate as ↵Harshula Jayasuriya
struct file commit e4daf1ffbe6cc3b12aab4d604e627829e93e9914 upstream. The following call chain: ------------------------------------------------------------ nfs4_get_vfs_file - nfsd_open - dentry_open - do_dentry_open - __get_file_write_access - get_write_access - return atomic_inc_unless_negative(&inode->i_writecount) ? 0 : -ETXTBSY; ------------------------------------------------------------ can result in the following state: ------------------------------------------------------------ struct nfs4_file { ... fi_fds = {0xffff880c1fa65c80, 0xffffffffffffffe6, 0x0}, fi_access = {{ counter = 0x1 }, { counter = 0x0 }}, ... ------------------------------------------------------------ 1) First time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is NULL, hence nfsd_open() is called where we get status set to an error and fp->fi_fds[O_WRONLY] to -ETXTBSY. Thus we do not reach nfs4_file_get_access() and fi_access[O_WRONLY] is not incremented. 2) Second time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is NOT NULL (-ETXTBSY), so nfsd_open() is NOT called, but nfs4_file_get_access() IS called and fi_access[O_WRONLY] is incremented. Thus we leave a landmine in the form of the nfs4_file data structure in an incorrect state. 3) Eventually, when __nfs4_file_put_access() is called it finds fi_access[O_WRONLY] being non-zero, it decrements it and calls nfs4_file_put_fd() which tries to fput -ETXTBSY. ------------------------------------------------------------ ... [exception RIP: fput+0x9] RIP: ffffffff81177fa9 RSP: ffff88062e365c90 RFLAGS: 00010282 RAX: ffff880c2b3d99cc RBX: ffff880c2b3d9978 RCX: 0000000000000002 RDX: dead000000100101 RSI: 0000000000000001 RDI: ffffffffffffffe6 RBP: ffff88062e365c90 R8: ffff88041fe797d8 R9: ffff88062e365d58 R10: 0000000000000008 R11: 0000000000000000 R12: 0000000000000001 R13: 0000000000000007 R14: 0000000000000000 R15: 0000000000000000 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 #9 [ffff88062e365c98] __nfs4_file_put_access at ffffffffa0562334 [nfsd] #10 [ffff88062e365cc8] nfs4_file_put_access at ffffffffa05623ab [nfsd] #11 [ffff88062e365ce8] free_generic_stateid at ffffffffa056634d [nfsd] #12 [ffff88062e365d18] release_open_stateid at ffffffffa0566e4b [nfsd] #13 [ffff88062e365d38] nfsd4_close at ffffffffa0567401 [nfsd] #14 [ffff88062e365d88] nfsd4_proc_compound at ffffffffa0557f28 [nfsd] #15 [ffff88062e365dd8] nfsd_dispatch at ffffffffa054543e [nfsd] #16 [ffff88062e365e18] svc_process_common at ffffffffa04ba5a4 [sunrpc] #17 [ffff88062e365e98] svc_process at ffffffffa04babe0 [sunrpc] #18 [ffff88062e365eb8] nfsd at ffffffffa0545b62 [nfsd] #19 [ffff88062e365ee8] kthread at ffffffff81090886 #20 [ffff88062e365f48] kernel_thread at ffffffff8100c14a ------------------------------------------------------------ Signed-off-by: Harshula Jayasuriya <harshula@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13nfsd4: fix decoding of compounds across page boundariesJ. Bruce Fields
commit 247500820ebd02ad87525db5d9b199e5b66f6636 upstream. A freebsd NFSv4.0 client was getting rare IO errors expanding a tarball. A network trace showed the server returning BAD_XDR on the final getattr of a getattr+write+getattr compound. The final getattr started on a page boundary. I believe the Linux client ignores errors on the post-write getattr, and that that's why we haven't seen this before. Reported-by: Rick Macklem <rmacklem@uoguelph.ca> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-10Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "Small fixes for two bugs and two warnings" * 'for-3.10' of git://linux-nfs.org/~bfields/linux: nfsd: fix oops when legacy_recdir_name_error is passed a -ENOENT error SUNRPC: fix decoding of optional gss-proxy xdr fields SUNRPC: Refactor gssx_dec_option_array() to kill uninitialized warning nfsd4: don't allow owner override on 4.1 CLAIM_FH opens
2013-05-09nfsd: fix oops when legacy_recdir_name_error is passed a -ENOENT errorJeff Layton
Toralf reported the following oops to the linux-nfs mailing list: -----------------[snip]------------------ NFSD: unable to generate recoverydir name (-2). NFSD: disabling legacy clientid tracking. Reboot recovery will not function correctly! BUG: unable to handle kernel NULL pointer dereference at 000003c8 IP: [<f90a3d91>] nfsd4_client_tracking_exit+0x11/0x50 [nfsd] *pdpt = 000000002ba33001 *pde = 0000000000000000 Oops: 0000 [#1] SMP Modules linked in: loop nfsd auth_rpcgss ipt_MASQUERADE xt_owner xt_multiport ipt_REJECT xt_tcpudp xt_recent xt_conntrack nf_conntrack_ftp xt_limit xt_LOG iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_filter ip_tables x_tables af_packet pppoe pppox ppp_generic slhc bridge stp llc tun arc4 iwldvm mac80211 coretemp kvm_intel uvcvideo sdhci_pci sdhci mmc_core videobuf2_vmalloc videobuf2_memops usblp videobuf2_core i915 iwlwifi psmouse videodev cfg80211 kvm fbcon bitblit cfbfillrect acpi_cpufreq mperf evdev softcursor font cfbimgblt i2c_algo_bit cfbcopyarea intel_agp intel_gtt drm_kms_helper snd_hda_codec_conexant drm agpgart fb fbdev tpm_tis thinkpad_acpi tpm nvram e1000e rfkill thermal ptp wmi pps_core tpm_bios 8250_pci processor 8250 ac snd_hda_intel snd_hda_codec snd_pcm battery video i2c_i801 snd_page_alloc snd_timer button serial_core i2c_core snd soundcore thermal_sys hwmon aesni_intel ablk_helper cryp td lrw aes_i586 xts gf128mul cbc fuse nfs lockd sunrpc dm_crypt dm_mod hid_monterey hid_microsoft hid_logitech hid_ezkey hid_cypress hid_chicony hid_cherry hid_belkin hid_apple hid_a4tech hid_generic usbhid hid sr_mod cdrom sg [last unloaded: microcode] Pid: 6374, comm: nfsd Not tainted 3.9.1 #6 LENOVO 4180F65/4180F65 EIP: 0060:[<f90a3d91>] EFLAGS: 00010202 CPU: 0 EIP is at nfsd4_client_tracking_exit+0x11/0x50 [nfsd] EAX: 00000000 EBX: fffffffe ECX: 00000007 EDX: 00000007 ESI: eb9dcb00 EDI: eb2991c0 EBP: eb2bde38 ESP: eb2bde34 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 CR0: 80050033 CR2: 000003c8 CR3: 2ba80000 CR4: 000407f0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Process nfsd (pid: 6374, ti=eb2bc000 task=eb2711c0 task.ti=eb2bc000) Stack: fffffffe eb2bde4c f90a3e0c f90a7754 fffffffe eb0a9c00 eb2bdea0 f90a41ed eb2991c0 1b270000 eb2991c0 eb2bde7c f9099ce9 eb2bde98 0129a020 eb29a020 eb2bdecc eb2991c0 eb2bdea8 f9099da5 00000000 eb9dcb00 00000001 67822f08 Call Trace: [<f90a3e0c>] legacy_recdir_name_error+0x3c/0x40 [nfsd] [<f90a41ed>] nfsd4_create_clid_dir+0x15d/0x1c0 [nfsd] [<f9099ce9>] ? nfsd4_lookup_stateid+0x99/0xd0 [nfsd] [<f9099da5>] ? nfs4_preprocess_seqid_op+0x85/0x100 [nfsd] [<f90a4287>] nfsd4_client_record_create+0x37/0x50 [nfsd] [<f909d6ce>] nfsd4_open_confirm+0xfe/0x130 [nfsd] [<f90980b1>] ? nfsd4_encode_operation+0x61/0x90 [nfsd] [<f909d5d0>] ? nfsd4_free_stateid+0xc0/0xc0 [nfsd] [<f908fd0b>] nfsd4_proc_compound+0x41b/0x530 [nfsd] [<f9081b7b>] nfsd_dispatch+0x8b/0x1a0 [nfsd] [<f857b85d>] svc_process+0x3dd/0x640 [sunrpc] [<f908165d>] nfsd+0xad/0x110 [nfsd] [<f90815b0>] ? nfsd_destroy+0x70/0x70 [nfsd] [<c1054824>] kthread+0x94/0xa0 [<c1486937>] ret_from_kernel_thread+0x1b/0x28 [<c1054790>] ? flush_kthread_work+0xd0/0xd0 Code: 86 b0 00 00 00 90 c5 0a f9 c7 04 24 70 76 0a f9 e8 74 a9 3d c8 eb ba 8d 76 00 55 89 e5 53 66 66 66 66 90 8b 15 68 c7 0a f9 85 d2 <8b> 88 c8 03 00 00 74 2c 3b 11 77 28 8b 5c 91 08 85 db 74 22 8b EIP: [<f90a3d91>] nfsd4_client_tracking_exit+0x11/0x50 [nfsd] SS:ESP 0068:eb2bde34 CR2: 00000000000003c8 ---[ end trace 09e54015d145c9c6 ]--- The problem appears to be a regression that was introduced in commit 9a9c6478 "nfsd: make NFSv4 recovery client tracking options per net". Prior to that commit, it was safe to pass a NULL net pointer to nfsd4_client_tracking_exit in the legacy recdir case, and legacy_recdir_name_error did so. After that comit, the net pointer must be valid. This patch just fixes legacy_recdir_name_error to pass in a valid net pointer to that function. Cc: <stable@vger.kernel.org> # v3.8+ Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-03nfsd4: don't allow owner override on 4.1 CLAIM_FH opensJ. Bruce Fields
The Linux client is using CLAIM_FH to implement regular opens, not just recovery cases, so it depends on the server to check permissions correctly. Therefore the owner override, which may make sense in the delegation recovery case, isn't right in the CLAIM_FH case. Symptoms: on a client with 49f9a0fafd844c32f2abada047c0b9a5ba0d6255 "NFSv4.1: Enable open-by-filehandle", Bryan noticed this: touch test.txt chmod 000 test.txt echo test > test.txt succeeding. Cc: stable@kernel.org Reported-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-03Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from J Bruce Fields: "Highlights include: - Some more DRC cleanup and performance work from Jeff Layton - A gss-proxy upcall from Simo Sorce: currently krb5 mounts to the server using credentials from Active Directory often fail due to limitations of the svcgssd upcall interface. This replacement lifts those limitations. The existing upcall is still supported for backwards compatibility. - More NFSv4.1 support: at this point, if a user with a current client who upgrades from 4.0 to 4.1 should see no regressions. In theory we do everything a 4.1 server is required to do. Patches for a couple minor exceptions are ready for 3.11, and with those and some more testing I'd like to turn 4.1 on by default in 3.11." Fix up semantic conflict as per Stephen Rothwell and linux-next: Commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication") adds two new users of "PDE(inode)->data", but we're supposed to use "PDE_DATA(inode)" instead since commit d9dda78bad87 ("procfs: new helper - PDE_DATA(inode)"). The old PDE() macro is no longer available since commit c30480b92cf4 ("proc: Make the PROC_I() and PDE() macros internal to procfs") * 'for-3.10' of git://linux-nfs.org/~bfields/linux: (60 commits) NFSD: SECINFO doesn't handle unsupported pseudoflavors correctly NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo() nfsd: make symbol nfsd_reply_cache_shrinker static svcauth_gss: fix error return code in rsc_parse() nfsd4: don't remap EISDIR errors in rename svcrpc: fix gss-proxy to respect user namespaces SUNRPC: gssp_procedures[] can be static SUNRPC: define {create,destroy}_use_gss_proxy_proc_entry in !PROC case nfsd4: better error return to indicate SSV non-support nfsd: fix EXDEV checking in rename SUNRPC: Use gssproxy upcall for server RPCGSS authentication. SUNRPC: Add RPC based upcall mechanism for RPCGSS auth SUNRPC: conditionally return endtime from import_sec_context SUNRPC: allow disabling idle timeout SUNRPC: attempt AF_LOCAL connect on setup nfsd: Decode and send 64bit time values nfsd4: put_client_renew_locked can be static nfsd4: remove unused macro nfsd4: remove some useless code nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKED ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30NFSD: SECINFO doesn't handle unsupported pseudoflavors correctlyChuck Lever
If nfsd4_do_encode_secinfo() can't find GSS info that matches an export security flavor, it assumes the flavor is not a GSS pseudoflavor, and simply puts it on the wire. However, if this XDR encoding logic is given a legitimate GSS pseudoflavor but the RPC layer says it does not support that pseudoflavor for some reason, then the server leaks GSS pseudoflavor numbers onto the wire. I confirmed this happens by blacklisting rpcsec_gss_krb5, then attempted a client transition from the pseudo-fs to a Kerberos-only share. The client received a flavor list containing the Kerberos pseudoflavor numbers, rather than GSS tuples. The encoder logic can check that each pseudoflavor in flavs[] is less than MAXFLAVOR before writing it into the buffer, to prevent this. But after "nflavs" is written into the XDR buffer, the encoder can't skip writing flavor information into the buffer when it discovers the RPC layer doesn't support that flavor. So count the number of valid flavors as they are written into the XDR buffer, then write that count into a placeholder in the XDR buffer when all recognized flavors have been encoded. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-30NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo()Chuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-30nfsd: make symbol nfsd_reply_cache_shrinker staticWei Yongjun
symbol 'nfsd_reply_cache_shrinker' only used within this file. It should be static. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-30nfsd4: don't remap EISDIR errors in renameJ. Bruce Fields
We're going out of our way here to remap an error to make rfc 3530 happy--but the rfc itself (nor rfc 1813, which has similar language) gives no justification. And disagrees with local filesystem behavior, with Linux and posix man pages, and knfsd's implemented behavior for v2 and v3. And the documented behavior seems better, in that it gives a little more information--you could implement the 3530 behavior using the posix behavior, but not the other way around. Also, the Linux client makes no attempt to remap this error in the v4 case, so it can end up just returning EEXIST to the application in a case where it should return EISDIR. So honestly I think the rfc's are just buggy here--or in any case it doesn't see worth the trouble to remap this error. Reported-by: Frank S Filz <ffilz@us.ibm.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-30Merge tag 'nfs-for-3.10-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes and cleanups from Trond Myklebust: - NLM: stable fix for NFSv2/v3 blocking locks - NFSv4.x: stable fixes for the delegation recall error handling code - NFSv4.x: Security flavour negotiation fixes and cleanups by Chuck Lever - SUNRPC: A number of RPCSEC_GSS fixes and cleanups also from Chuck - NFSv4.x assorted state management and reboot recovery bugfixes - NFSv4.1: In cases where we have already looked up a file, and hold a valid filehandle, use the new open-by-filehandle operation instead of opening by name. - Allow the NFSv4.1 callback thread to freeze - NFSv4.x: ensure that file unlock waits for readahead to complete - NFSv4.1: ensure that the RPC layer doesn't override the NFS session table size negotiation by limiting the number of slots. - NFSv4.x: Fix SETATTR spec compatibility issues * tag 'nfs-for-3.10-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (67 commits) NFSv4: Warn once about servers that incorrectly apply open mode to setattr NFSv4: Servers should only check SETATTR stateid open mode on size change NFSv4: Don't recheck permissions on open in case of recovery cached open NFSv4.1: Don't do a delegated open for NFS4_OPEN_CLAIM_DELEG_CUR_FH modes NFSv4.1: Use the more efficient open_noattr call for open-by-filehandle NFS: Retry SETCLIENTID with AUTH_SYS instead of AUTH_NONE NFSv4: Ensure that we clear the NFS_OPEN_STATE flag when appropriate LOCKD: Ensure that nlmclnt_block resets block->b_status after a server reboot NFSv4: Ensure the LOCK call cannot use the delegation stateid NFSv4: Use the open stateid if the delegation has the wrong mode nfs: Send atime and mtime as a 64bit value NFSv4: Record the OPEN create mode used in the nfs4_opendata structure NFSv4.1: Set the RPC_CLNT_CREATE_INFINITE_SLOTS flag for NFSv4.1 transports SUNRPC: Allow rpc_create() to request that TCP slots be unlimited SUNRPC: Fix a livelock problem in the xprt->backlog queue NFSv4: Fix handling of revoked delegations by setattr NFSv4 release the sequence id in the return on close case nfs: remove unnecessary check for NULL inode->i_flock from nfs_delegation_claim_locks NFS: Ensure that NFS file unlock waits for readahead to complete NFS: Add functionality to allow waiting on all outstanding reads to complete ...
2013-04-29nfsd: convert nfs4_alloc_stid() to use idr_alloc_cyclic()Jeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29Merge branch 'nfs-for-next' of git://linux-nfs.org/~trondmy/nfs-2.6 into ↵J. Bruce Fields
for-3.10 Note conflict: Chuck's patches modified (and made static) gss_mech_get_by_OID, which is still needed by gss-proxy patches. The conflict resolution is a bit minimal; we may want some more cleanup.
2013-04-26nfsd4: better error return to indicate SSV non-supportJ. Bruce Fields
As 4.1 becomes less experimental and SSV still isn't implemented, we have to admit it's not going to be, and return some sensible error rather than just saying "our server's broken". Discussion in the ietf group hasn't turned up any objections to using NFS4ERR_ENC_ALG_UNSUPP for that purpose. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-26nfsd: fix EXDEV checking in renameJ. Bruce Fields
We again check for the EXDEV a little later on, so the first check is redundant. This check is also slightly racier, since a badly timed eviction from the export cache could leave us with the two fh_export pointers pointing to two different cache entries which each refer to the same underlying export. It's better to compare vfsmounts as the later check does, but that leaves a minor security hole in the case where the two exports refer to two different directories especially if (for example) they have different root-squashing options. So, compare ex_path.dentry too. Reported-by: Joe Habermann <joe.habermann@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-23nfsd: Decode and send 64bit time valuesBryan Schumaker
The seconds field of an nfstime4 structure is 64bit, but we are assuming that the first 32bits are zero-filled. So if the client tries to set atime to a value before the epoch (touch -t 196001010101), then the server will save the wrong value on disk. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: put_client_renew_locked can be staticFengguang Wu
Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: remove unused macroJ. Bruce Fields
Cleanup a piece I forgot to remove in 9411b1d4c7df26dca6bc6261b5dc87a5b4c81e5c "nfsd4: cleanup handling of nfsv4.0 closed stateid's". Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: remove some useless codefanchaoting
The "list_empty(&oo->oo_owner.so_stateids)" is aways true, so remove it. Signed-off-by: fanchaoting <fanchaoting@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKEDJ. Bruce Fields
A 4.1 server must notify a client that has had any state revoked using the SEQ4_STATUS_RECALLABLE_STATE_REVOKED flag. The client can figure out exactly which state is the problem using CHECK_STATEID and then free it using FREE_STATEID. The status flag will be unset once all such revoked stateids are freed. Our server's only recallable state is delegations. So we keep with each 4.1 client a list of delegations that have timed out and been recalled, but haven't yet been freed by FREE_STATEID. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: clean up validate_stateidJ. Bruce Fields
The logic here is better expressed with a switch statement. While we're here, CLOSED stateids (or stateids of an unkown type--which would indicate a server bug) should probably return nfserr_bad_stateid, though this behavior shouldn't affect any non-buggy client. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: check backchannel attributes on create_sessionJ. Bruce Fields
Make sure the client gives us an adequate backchannel. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: fix forechannel attribute negotiationJ. Bruce Fields
Negotiation of the 4.1 session forechannel attributes is a mess. Fix: - Move it all into check_forechannel_attrs instead of spreading it between that, alloc_session, and init_forechannel_attrs. - set a minimum "slotsize" so that our drc memory limits apply even for small maxresponsesize_cached. This also fixes some bugs when slotsize becomes <= 0. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: cleanup check_forechannel_attrsJ. Bruce Fields
Pass this struct by reference, not by value, and return an error instead of a boolean to allow for future additions. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09constify a bunch of struct file_operations instancesAl Viro
2013-04-09nfsd4: don't close read-write opens too soonJ. Bruce Fields
Don't actually close any opens until we don't need them at all. This means being left with write access when it's not really necessary, but that's better than putting a file that might still have posix locks held on it, as we have been. Reported-by: Toralf Förster <toralf.foerster@gmx.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: release lockowners on last unlock in 4.1 caseJ. Bruce Fields
In the 4.1 case we're supposed to release lockowners as soon as they're no longer used. It would probably be more efficient to reference count them, but that's slightly fiddly due to the need to have callbacks from locks.c to take into account lock merging and splitting. For most cases just scanning the inode's lock list on unlock for matching locks will be sufficient. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: more sessions/open-owner-replay cleanupJ. Bruce Fields
More logic that's unnecessary in the 4.1 case. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
