path: root/fs/nfsd
2006-02-07[PATCH] knfsd: fix nfs4_open lock leakJ. Bruce Fields
I just noticed that my patch "don't create on open that fails due to ERR_GRACE" (recently commited as fb553c0f17444e090db951b96df4d2d71b4f4b6b) had an obvious problem that causes a deadlock on reboot recovery. Sending in this now since it seems like a clear 2.6.16 candidate.--b. We're returning with a lock held in some error cases. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] knfsd: Restore recently broken ACL functionality to NFS serverAndreas Gruenbacher
A recent patch to Allow run-time selection of NFS versions to export meant that NO nfsacl service versions were exported. This patch restored that functionality. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] knfsd: Provide missing NFSv2 part of patch for checking vfs_getattr.David Shaw
A recent patch which checked the return status of vfs_getattr in nfsd, completely missed the nfsproc.c (NFSv2) part. Here is it. This patch moved the call to vfs_getattr from the xdr encoding (at which point it is too late to return an error) to the call handling. This means several calls to vfs_getattr are needed in nfsproc.c. Many are encapsulated in nfsd_return_attrs and nfsd_return_dirop. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] knfsd: Fix some more errno/nfserr confusion in vfs.cNeilBrown
nfsd_sync* return an errno, which usually needs to be converted to an errno, sometimes immediately, sometimes a little later. Also, nfsd_setattr returns an nfserr which SHOULDN'T be converted from an errno (because it isn't one). Also some tidyups of the form: err = XX err = nfserrno(err) and err = XX if (err) err = nfserrno(err) become err = nfserrno(XX) Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4_lock() returns bogus values to clientsAl Viro
missing nfserrno() in default case of a switch by return value of posix_lock_file(); as the result we send negative host-endian to clients that expect positive network-endian, preferably mentioned in RFC... BTW, that case is not impossible - posix_lock_file() can return -ENOLCK and we do not handle that one explicitly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] NFSERR_SERVERFAULT returned host-endianAl Viro
->rp_status is network-endian and nobody byteswaps it before sending to client; putting NFSERR_SERVERFAULT instead of nfserr_serverfault in there is not nice... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4_truncate() bogus return valueAl Viro
-EINVAL (in host order, no less) is not a good thing to return to client. nfsd4_truncate() returns it in one case and its callers expect nfs_.... from it. AFAICS, it should be nfserr_inval Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd/vfs.c: endianness fixesAl Viro
Several failure exits return -E<something> instead of nfserr_<something> and vice versa. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: clean up settattr codeFred Isaman
Clean up some unnecessary special-casing in the setattr code.. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: Fix bug in rdattr_error returnFred Isaman
Fix bug in rdattr_error return which causes correct error code to be overwritten by nfserr_toosmall. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: fix open_downgradeJ. Bruce Fields
Bad bookkeeping of the share reservations when handling open upgrades was causing open downgrade to fail. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: don't create on open that fails due to ERR_GRACEJ. Bruce Fields
In an earlier patch (commit b648330a1d741d5df8a5076b2a0a2519c69c8f41) I noted that a too-early grace-period check was preventing us from bumping the sequence id on open. Unfortunately in that patch I stupidly moved the grace-period check back too far, so now an open for create can succesfully create the file while still returning ERR_GRACE. The correct place for that check is after we've set the open_owner and handled any replays, but before we actually start mucking with the filesystem. Thanks to Avishay Traeger for reporting the bug. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: simplify process-open1 logicJ. Bruce Fields
nfsd4_process_open1 is very highly nested; flatten it out a bit. Also, the preceding comment, which just outlines the logic, seems redundant. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: nfs4state.c miscellaneous goto removalsJ. Bruce Fields
Remove some goto's that made the logic here a little more tortuous than necessary. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: no replays on unconfirmed ownersJ. Bruce Fields
We shouldn't check for replays until after checking whether the open owner is confirmed. Clients are allowed to reuse openowners without bumping the seqid. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: handle replays of failed open reclaimsJ. Bruce Fields
We need to make sure open reclaims are marked confirmed immediately so that we can handle replays even if they fail (e.g. with a seqid-incrementing error). (See 8.1.8.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: recovery lookup dir checkJ. Bruce Fields
Make sure we get a directory when we look up the recovery directory. Thanks to Christoph Hellwig for the bug report. Based on feedback from Christoph and others, we may remove the need for this lookup and just pass in a file descriptor from userspace instead, and/or completely move the directory handling to userspace. For now we're just fixing the obvious bugs. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: fix open of recovery directoryJ. Bruce Fields
We should be opening this directory RDONLY, not RDWR. Thanks to Christoph Hellwig for the bug report. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: operation debuggingJ. Bruce Fields
Simple, useful debugging printk: print the number of each op as we process it. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: fix check_for_locksJ. Bruce Fields
Fix some bad logic. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: remove release_state_owner()J. Bruce Fields
It's confusing having both release_stateowner() and release_state_owner(). And as it turns out, release_state_owner() is short and only called from one place; so just remove it. Also note the confirmed check is superfluous there--preprocess_seqid_op already check this. And remove a redundant comment and a superfluous line assignment while we're at it. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: rename lk_stateownerJ. Bruce Fields
One of the things that's confusing about nfsd4_lock is that the lk_stateowner field could be set to either of two different lockowners: the open owner or the lock owner. Rename to lk_replay_owner and add a comment to make it clear that it's used for whichever stateowner has its sequence id bumped for replay detection. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: fix nfsd4_lock cleanup on failureJ. Bruce Fields
release_state_owner also puts the lock owner on the close_lru. There's no need for that, though; replays of the failed lock would be handled by the openowner not the lockowner. Also consolidate the cleanup a bit, fixing leaks that can happen if errors occur between the time a new lock owner is allocated and the lock is done. Remove a comment and dprintk that look a little redundant. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd4: misc lock fixesAndy Adamson
Logic fixes for LOCK and UNLOCK. - Move the permission check on the current file handle outside of nfs4_lock_state() - remove the file manager fl_release_private calls; fl_ops is not set. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd: remove inline from a couple of large NFS functionsNeilBrown
These are both called from two places close together. I could rearrange that code so there is only one call site, but just removing the 'inline' is probably best. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] nfsd: check error status from nfsd_sync_dirYAMAMOTO Takashi
Change nfsd_sync_dir to return an error if ->sync fails, and pass that error up through the stack. This involves a number of rearrangements of error paths, and care to distinguish between Linux -errno numbers and NFSERR numbers. In the 'create' routines, we continue with the 'setattr' even if a previous sync_dir failed. This patch is quite different from Takashi's in a few ways, but there is still a strong lineage. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] add vfs_* helpers for xattr operationsChristoph Hellwig
Add vfs_getxattr, vfs_setxattr and vfs_removexattr helpers for common checks around invocation of the xattr methods. NFSD already was missing some of the checks and there will be more soon. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: James Morris <jmorris@namei.org> (James, I haven't touched selinux yet because it's doing various odd things and I'm not sure how it would interact with the security attribute fallbacks you added. Could you investigate whether it could use vfs_getxattr or if not add a __vfs_getxattr helper to share the bits it is fine with?) For NFSv4: instead of just converting it add an nfsd_getxattr helper for the code shared by NFSv2/3 and NFSv4 ACLs. In fact that code isn't even NFS-specific, but I'll wait for more users to pop up first before moving it to common code. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-06SUNRPC: get rid of cl_chattyChuck Lever
Clean up: Every ULP that uses the in-kernel RPC client, except the NLM client, sets cl_chatty. There's no reason why NLM shouldn't set it, so just get rid of cl_chatty and always be verbose. Test-plan: Compile with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06[PATCH] knfsd: reduce stack consumptionNeil Brown
A typical nfsd call trace is nfsd -> svc_process -> nfsd_dispatch -> nfsd3_proc_write -> nfsd_write ->nfsd_vfs_write -> vfs_writev These add up to over 300 bytes on the stack. Looking at each of these, I see that nfsd_write (which includes nfsd_vfs_write) contributes 0x8c to stack usage itself!! It turns out this is because it puts a 'struct iattr' on the stack so it can kill suid if needed. The following patch saves about 50 bytes off the stack in this call path. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] knfsd: check error status from vfs_getattr and i_op->fsyncDavid Shaw
Both vfs_getattr and i_op->fsync return error statuses which nfsd was largely ignoring. This as noticed when exporting directories using fuse. This patch cleans up most of the offences, which involves moving the call to vfs_getattr out of the xdr encoding routines (where it is too late to report an error) into the main NFS procedure handling routines. There is still a called to vfs_gettattr (related to the ACL code) where the status is ignored, and called to nfsd_sync_dir don't check return status either. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-20[PATCH] nfsd: check for read-only exports before setting aclsAndreas Gruenbacher
We must check for MAY_SATTR before setting acls, which includes checking for read-only exports: the lower-level setxattr operation that eventually sets the acl cannot check export-level restrictions. Bug reported by Martin Walter <mawa@uni-freiburg.de>. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: make sure svc_process call the correct pg_authenticate for ↵NeilBrown
multi-service port If an RPC socket is serving multiple programs, then the pg_authenticate of the first program in the list is called, instead of pg_authenticate for the program to be run. This does not cause a problem with any programs in the current kernel, but could confuse future code. Also set pg_authenticate for nfsd_acl_program incase it ever gets used. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: Fix some minor sign problems in nfsd/xdrNeilBrown
There are a couple of tests which could possibly be confused by extremely large numbers appearing in 'xdr' packets. I think the closest to an exploit you could get would be writing random data from a free page into a file - i.e. leak data out of kernel space. I'm fairly sure they cannot be used for remote compromise. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: Allow run-time selection of NFS versions to exportNeilBrown
Provide a file in the NFSD filesystem that allows setting and querying of which version of NFS are being exported. Changes are only allowed while no server is running. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: Restore functionality to read from file in /proc/fs/nfsd/NeilBrown
Most files in the nfsd filesystems are transaction files. You write a request, and read a response. For some (e.g. 'threads') it makes sense to just be able to read and get the current value. This functionality did exist but was broken recently when someone modified nfsctl.c without going through the maintainer. This patch fixes the regression. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: fix setattr-on-symlink error returnNeilBrown
This is a somewhat cosmetic fix to keep the SpecFS validation test from complaining. SpecFS want's to try chmod on symlinks, and ext3 and reiser (at least) return ENOTSUPP. Probably both sides are being silly, but it is easiest to simply make it a non-issue and filter out chmod requests on symlinks at the nfsd level. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] nfsd4: fix setclientid unlock of unlocked state lockNeil Brown
We could try to unlock the state lock here without having first locked it. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] nfsd4: fix open seqid incrementing in lockNeil Brown
In the case of a lock which introduces a new lockowner, the openowner's sequence id should be incremented, even when the operation fails, if the error is a sequence-id-mutating error. The current code fails to do that in some cases. Fix this by using the same sequence-id-incrementing mechanism that all other such operations use. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] nfsd4: move replay_ownerNeil Brown
It seems more natural to move the setting of the replay_owner into the relevant procedure instead of doing it in nfsv4_proc_compound. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] nfsd4: printk reductionNeil Brown
Demote some printk's that look like they could be triggered by non-buggy clients to dprintk's. (For example, stale clientid's are normal occurrences on reboot, and on a server with a lot of clients these messages could become annoying.) Also remove some redundant dprintk's (e.g. no need for both STALE_CLIENTID and its callers to do dprintks). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sunrpc: cache_register can use wrong module referenceBruce Allan
When registering an RPC cache, cache_register() always sets the owner as the sunrpc module. However, there are RPC caches owned by other modules. With the incorrect owner setting, the real owning module can be removed potentially with an open reference to the cache from userspace. For example, if one were to stop the nfs server and unmount the nfsd filesystem, the nfsd module could be removed eventhough rpc.idmapd had references to the idtoname and nametoid caches (i.e. /proc/net/rpc/nfs4.<cachename>/channel is still open). This resulted in a system panic on one of our machines when attempting to restart the nfs services after reloading the nfsd module. The following patch adds a 'struct module *owner' field in struct cache_detail. The owner is further assigned to the struct proc_dir_entry in cache_register() so that the module cannot be unloaded while user-space daemons have an open reference on the associated file under /proc. Signed-off-by: Bruce Allan <bwa@us.ibm.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[CRYPTO]: crypto_free_tfm() callers no longer need to check for NULLJesper Juhl
Since the patch to add a NULL short-circuit to crypto_free_tfm() went in, there's no longer any need for callers of that function to check for NULL. This patch removes the redundant NULL checks and also a few similar checks for NULL before calls to kfree() that I ran into while doing the crypto_free_tfm bits. I've succesfuly compile tested this patch, and a kernel with the patch applied boots and runs just fine. When I posted the patch to LKML (and other lists/people on Cc) it drew the following comments : J. Bruce Fields commented "I've no problem with the auth_gss or nfsv4 bits.--b." Sridhar Samudrala said "sctp change looks fine." Herbert Xu signed off on the patch. So, I guess this is ready to be dropped into -mm and eventually mainline. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-01[CRYPTO]: Use CRYPTO_TFM_REQ_MAY_SLEEP where appropriateHerbert Xu
This patch goes through the current users of the crypto layer and sets CRYPTO_TFM_REQ_MAY_SLEEP at crypto_alloc_tfm() where all crypto operations are performed in process context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-17[PATCH] nfsd to unlock kernel before exitingSteven Rostedt
The nfsd holds the big kernel lock upon exit, when it really shouldn't. Not to mention that this breaks Ingo's RT patch. This is a trivial fix to release the lock. Ingo, this patch also works with your kernel, and stops the problem with nfsd. Note, there's a "goto out;" where "out:" is right above svc_exit_thread. The point of the goto also holds the kernel_lock, so I don't see any problem here in releasing it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] nfsd4: fix fh_expire_typeNeilBrown
After discussion at the recent NFSv4 bake-a-thon, I realized that my assumption that NFS4_FH_PERSISTENT required filehandles to persist was a misreading of the spec. This also fixes an interoperability problem with the Solaris client. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
