path: root/fs/nfsd
2013-04-29nfsd: convert nfs4_alloc_stid() to use idr_alloc_cyclic()Jeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-26nfsd4: reject "negative" acl lengthsJ. Bruce Fields
Since we only enforce an upper bound, not a lower bound, a "negative" length can get through here. The symptom seen was a warning when we attempt to a kmalloc with an excessive size. Reported-by: Toralf Förster <toralf.foerster@gmx.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-03-22nfsd: fix bad offset useKent Overstreet
vfs_writev() updates the offset argument - but the code then passes the offset to vfs_fsync_range(). Since offset now points to the offset after what was just written, this is probably not what was intended Introduced by face15025ffdf664de95e86ae831544154d26c9c "nfsd: use vfs_fsync_range(), not O_SYNC, for stable writes". Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: stable@vger.kernel.org Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-03-18nfsd: fix startup order in nfsd_reply_cache_initJeff Layton
If we end up doing "goto out_nomem" in this function, we'll call nfsd_reply_cache_shutdown. That will attempt to walk the LRU list and free entries, but that list may not be initialized yet if the server is starting up for the first time. It's also possible for the shrinker to kick in before we've initialized the LRU list. Rearrange the initialization so that the LRU list_head and cache size are initialized before doing any of the allocations that might fail. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-03-18nfsd: only unhash DRC entries that are in the hashtableJeff Layton
It's not safe to call hlist_del() on a newly initialized hlist_node. That leads to a NULL pointer dereference. Only do that if the entry is hashed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-03-13nfsd: convert to idr_alloc()Tejun Heo
idr_get_new*() and friends are about to be deprecated. Convert to the new idr_alloc() interface. Only compile-tested. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: J. Bruce Fields <bfields@redhat.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13nfsd: remove unused get_new_stid()Tejun Heo
get_new_stid() is no longer used since commit 3abdb607125 ("nfsd4: simplify idr allocation"). Remove it. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-28Merge branch 'for-3.9' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from J Bruce Fields: "Miscellaneous bugfixes, plus: - An overhaul of the DRC cache by Jeff Layton. The main effect is just to make it larger. This decreases the chances of intermittent errors especially in the UDP case. But we'll need to watch for any reports of performance regressions. - Containerized nfsd: with some limitations, we now support per-container nfs-service, thanks to extensive work from Stanislav Kinsbursky over the last year." Some notes about conflicts, since there were *two* non-data semantic conflicts here: - idr_remove_all() had been added by a memory leak fix, but has since become deprecated since idr_destroy() does it for us now. - xs_local_connect() had been added by this branch to make AF_LOCAL connections be synchronous, but in the meantime Trond had changed the calling convention in order to avoid a RCU dereference. There were a couple of more obvious actual source-level conflicts due to the hlist traversal changes and one just due to code changes next to each other, but those were trivial. * 'for-3.9' of git://linux-nfs.org/~bfields/linux: (49 commits) SUNRPC: make AF_LOCAL connect synchronous nfsd: fix compiler warning about ambiguous types in nfsd_cache_csum svcrpc: fix rpc server shutdown races svcrpc: make svc_age_temp_xprts enqueue under sv_lock lockd: nlmclnt_reclaim(): avoid stack overflow nfsd: enable NFSv4 state in containers nfsd: disable usermode helper client tracker in container nfsd: use proper net while reading "exports" file nfsd: containerize NFSd filesystem nfsd: fix comments on nfsd_cache_lookup SUNRPC: move cache_detail->cache_request callback call to cache_read() SUNRPC: remove "cache_request" argument in sunrpc_cache_pipe_upcall() function SUNRPC: rework cache upcall logic SUNRPC: introduce cache_detail->cache_request callback NFS: simplify and clean cache library NFS: use SUNRPC cache creation and destruction helper for DNS cache nfsd4: free_stid can be static nfsd: keep a checksum of the first 256 bytes of request sunrpc: trim off trailing checksum before returning decrypted or integrity authenticated buffer sunrpc: fix comment in struct xdr_buf definition ...
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26nfsd: handle vfs_getattr errors in acl protocolJ. Bruce Fields
We're currently ignoring errors from vfs_getattr. The correct thing to do is to do the stat in the main service procedure not in the response encoding. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26switch vfs_getattr() to struct pathAl Viro
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-23fs/nfsd: change type of max_delegations, nfsd_drc_max_mem and nfsd_drc_mem_usedZhang Yanfei
The three variables are calculated from nr_free_buffer_pages so change their types to unsigned long in case of overflow. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22new helper: file_inode(file)Al Viro
2013-02-17nfsd: fix compiler warning about ambiguous types in nfsd_cache_csumJeff Layton
kbuild test robot says: tree: git://linux-nfs.org/~bfields/linux.git for-3.9 head: deb4534f4f3be7aea7d9d24c3b0d58f370cbf9ef commit: 01a7decf75930925322c5efc87af0b5e58eb8650 [32/44] nfsd: keep a checksum of the first 256 bytes of request config: i386-randconfig-x088 (attached as .config) All warnings: fs/nfsd/nfscache.c: In function 'nfsd_cache_csum': >> fs/nfsd/nfscache.c:266:9: warning: comparison of distinct pointer types lacks a cast [enabled by default] vim +266 fs/nfsd/nfscache.c 250 __wsum csum; 251 struct xdr_buf *buf = &rqstp->rq_arg; 252 const unsigned char *p = buf->head[0].iov_base; 253 size_t csum_len = min_t(size_t, buf->head[0].iov_len + buf->page_len, 254 RC_CSUMLEN); 255 size_t len = min(buf->head[0].iov_len, csum_len); 256 257 /* rq_arg.head first */ 258 csum = csum_partial(p, len, 0); 259 csum_len -= len; 260 261 /* Continue into page array */ 262 idx = buf->page_base / PAGE_SIZE; 263 base = buf->page_base & ~PAGE_MASK; 264 while (csum_len) { 265 p = page_address(buf->pages[idx]) + base; > 266 len = min(PAGE_SIZE - base, csum_len); 267 csum = csum_partial(p, len, csum); 268 csum_len -= len; 269 base = 0; 270 ++idx; 271 } 272 return csum; 273 } 274 Signed-off-by: Jeff Layton <jlayton@redhat.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15nfsd: enable NFSv4 state in containersStanislav Kinsbursky
Currently, NFSd is ready to operate in network namespace based containers. So let's drop check for "init_net" and make it able to fly. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15nfsd: disable usermode helper client tracker in containerStanislav Kinsbursky
This tracker uses khelper kthread to execute binaries. Execution itself is done from kthread context - i.e. global root is used. This is not suitable for containers with own root. So, disable this tracker for a while. Note: one of possible solutions can be pass "init" callback to khelper, which will swap root to desired one. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15nfsd: use proper net while reading "exports" fileStanislav Kinsbursky
Functuon "exports_open" is used for both "/proc/fs/nfs/exports" and "/proc/fs/nfsd/exports" files. Now NFSd filesystem is containerised, so proper net can be taken from superblock for "/proc/fs/nfsd/exports" reader. But for "/proc/fs/nfsd/exports" only current->nsproxy->net_ns can be used. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15nfsd: containerize NFSd filesystemStanislav Kinsbursky
This patch makes NFSD file system superblock to be created per net. This makes possible to get proper network namespace from superblock instead of using hard-coded "init_net". Note: NFSd fs super-block holds network namespace. This garantees, that network namespace won't disappear from underneath of it. This, obviously, means, that in case of kill of a container's "init" (which is not a mount namespace, but network namespace creator) netowrk namespace won't be destroyed. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15nfsd: fix comments on nfsd_cache_lookupJeff Layton
2013-02-15SUNRPC: rework cache upcall logicStanislav Kinsbursky
For most of SUNRPC caches (except NFS DNS cache) cache_detail->cache_upcall is redundant since all that it's implementations are doing is calling sunrpc_cache_pipe_upcall() with proper function address argument. Cache request function address is now stored on cache_detail structure and thus all the code can be simplified. Now, for those cache details, which doesn't have cache_upcall callback (the only one, which still has is nfs_dns_resolve_template) sunrpc_cache_pipe_upcall will be called instead. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-15SUNRPC: introduce cache_detail->cache_request callbackStanislav Kinsbursky
This callback will allow to simplify upcalls in further patches in this series. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-13nfsd: Properly compare and initialize kuids and kgidsEric W. Biederman
Use uid_eq(uid, GLOBAL_ROOT_UID) instead of !uid. Use gid_eq(gid, GLOBAL_ROOT_GID) instead of !gid. Use uid_eq(uid, INVALID_UID) instead of uid == -1 Use gid_eq(uid, INVALID_GID) instead of gid == -1 Use uid = GLOBAL_ROOT_UID instead of uid = 0; Use gid = GLOBAL_ROOT_GID instead of gid = 0; Use !uid_eq(uid1, uid2) instead of uid1 != uid2. Use !gid_eq(gid1, gid2) instead of gid1 != gid2. Use uid_eq(uid1, uid2) instead of uid1 == uid2. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgidsEric W. Biederman
2013-02-13nfsd: Modify nfsd4_cb_sec to use kuids and kgidsEric W. Biederman
Change uid and gid in struct nfsd4_cb_sec to be of type kuid_t and kgid_t. In nfsd4_decode_cb_sec when reading uids and gids off the wire convert them to kuids and kgids, and if they don't convert to valid kuids or valid kuids ignore RPC_AUTH_UNIX and don't fill in any of the fields. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversionEric W. Biederman
In struct nfs4_ace remove the member who and replace it with an anonymous union holding who_uid and who_gid. Allowing typesafe storage uids and gids. Add a helper pace_gt for sorting posix_acl_entries. In struct posix_user_ace_state to replace uid with a union of kuid_t uid and kgid_t gid. Remove all initializations of the deprecated posic_acl_entry e_id field. Which is not present when user namespaces are enabled. Split find_uid into two functions find_uid and find_gid that work in a typesafe manner. In nfs4xdr update nfsd4_encode_fattr to deal with the changes in struct nfs4_ace. Rewrite nfsd4_encode_name to take a kuid_t and a kgid_t instead of a generic id and flag if it is a group or a uid. Replace the group flag with a test for a valid gid. Modify nfsd4_encode_user to take a kuid_t and call the modifed nfsd4_encode_name. Modify nfsd4_encode_group to take a kgid_t and call the modified nfsd4_encode_name. Modify nfsd4_encode_aclname to take an ace instead of taking the fields of an ace broken out. This allows it to detect if the ace is for a user or a group and to pass the appropriate value while still being typesafe. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Convert nfsxdr to use kuids and kgidsEric W. Biederman
When reading uids and gids off the wire convert them to kuids and kgids. If the conversion results in an invalid result don't set the ATTR_UID or ATTR_GID. When putting kuids and kgids onto the wire first convert them to uids and gids the other side will understand. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Convert nfs3xdr to use kuids and kgidsEric W. Biederman
When reading uids and gids off the wire convert them to kuids and kgids. When putting kuids and kgids onto the wire first convert them to uids and gids the other side will understand. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Remove nfsd_luid, nfsd_lgid, nfsd_ruid and nfsd_rgidEric W. Biederman
These trivial macros that don't currently do anything are the last vestiages of an old attempt at uid mapping that was removed from the kernel in September of 2002. Remove them to make it clear what the code is currently doing. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Convert idmap to use kuids and kgidsEric W. Biederman
Convert nfsd_map_name_to_uid to return a kuid_t value. Convert nfsd_map_name_to_gid to return a kgid_t value. Convert nfsd_map_uid_to_name to take a kuid_t parameter. Convert nfsd_map_gid_to_name to take a kgid_t paramater. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: idmap use u32 not uid_t as the intermediate typeEric W. Biederman
u32 and uid_t have the same size and semantics so this change should have no operational effect. This just removes the WTF factor when looking at variables that hold both uids and gids whos type is uid_t. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfsd: Remove declaration of nonexistent nfs4_acl_permisisonEric W. Biederman
2013-02-11nfsd4: free_stid can be staticFengguang Wu
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
2013-02-08nfsd: keep a checksum of the first 256 bytes of requestJeff Layton
Now that we're allowing more DRC entries, it becomes a lot easier to hit problems with XID collisions. In order to mitigate those, calculate a checksum of up to the first 256 bytes of each request coming in and store that in the cache entry, along with the total length of the request. This initially used crc32, but Chuck Lever and Jim Rees pointed out that crc32 is probably more heavyweight than we really need for generating these checksums, and recommended looking at using the same routines that are used to generate checksums for IP packets. On an x86_64 KVM guest measurements with ftrace showed ~800ns to use csum_partial vs ~1750ns for crc32. The difference probably isn't terribly significant, but for now we may as well use csum_partial. Signed-off-by: Jeff Layton <jlayton@redhat.com> Stones-thrown-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-05sunrpc: move address copy/cmp/convert routines and prototypes from clnt.h to ↵Jeff Layton
addr.h These routines are used by server and client code, so having them in a separate header would be best. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-05nfsd4: simplify idr allocationJ. Bruce Fields
We don't really need to preallocate at all; just allocate and initialize everything at once, but leave the sc_type field initially 0 to prevent finding the stateid till it's fully initialized. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-05nfsd: Fix memleakmajianpeng
When free nfs-client, it must free the ->cl_stateids. Cc: stable@kernel.org Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: register a shrinker for DRC cache entriesJeff Layton
Since we dynamically allocate them now, allow the system to call us up to release them if it gets low on memory. Since these entries aren't replaceable, only free ones that are expired or that are over the cap. The the seeks value is set to '1' however to indicate that freeing the these entries is low-cost. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: add recurring workqueue job to clean the cacheJeff Layton
It's not sufficient to only clean the cache when requests come in. What if we have a flurry of activity and then the server goes idle? Add a workqueue job that will clean the cache every RC_EXPIRE period. Care is taken to only run this when we expect to have entries expiring. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: when updating an entry with RC_NOCACHE, just free itJeff Layton
There's no need to keep entries around that we're declaring RC_NOCACHE. Ditto if there's a problem with the entry. With this change too, there's no need to test for RC_UNUSED in the search function. If the entry's in the hash table then it's either INPROG or DONE. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: remove the cache_disabled flagJeff Layton
With the change to dynamically allocate entries, the cache is never disabled on the fly. Remove this flag. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: dynamically allocate DRC entriesJeff Layton
The existing code keeps a fixed-size cache of 1024 entries. This is much too small for a busy server, and wastes memory on an idle one. This patch changes the code to dynamically allocate and free these cache entries. A cap on the number of entries is retained, but it's much larger than the existing value and now scales with the amount of low memory in the machine. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: track the number of DRC entries in the cacheJeff Layton
2013-02-04nfsd: always move DRC entries to the end of LRU list when updating timestampJeff Layton
...otherwise, we end up with the list ordering wrong. Currently, it's not a problem since we skip RC_INPROG entries, but keeping the ordering strict will be necessary for a later patch that adds a cache cleaner. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: initialize the exp->ex_uuid field in svc_export_initJeff Layton
commit 885c91f7466 in Bruce's tree was causing oopses for me: general protection fault: 0000 [#1] SMP Modules linked in: nfsd(OF) nfs_acl(OF) auth_rpcgss(OF) lockd(OF) sunrpc(OF) kvm_amd kvm microcode i2c_piix4 virtio_net virtio_balloon cirrus drm_kms_helper ttm drm virtio_blk i2c_core CPU 0 Pid: 564, comm: exportfs Tainted: GF O 3.8.0-0.rc5.git2.1.fc19.x86_64 #1 Bochs Bochs RIP: 0010:[<ffffffff811b1509>] [<ffffffff811b1509>] kfree+0x49/0x280 RSP: 0018:ffff88007a3d7c50 EFLAGS: 00010203 RAX: 01adaf8dadadad80 RBX: 6b6b6b6b6b6b6b6b RCX: 0000000000000001 RDX: ffffffff7fffffff RSI: 0000000000000000 RDI: 6b6b6b6b6b6b6b6b RBP: ffff88007a3d7c80 R08: 6b6b6b6b6b6b6b6b R09: 0000000000000000 R10: 0000000000000018 R11: 0000000000000000 R12: ffff88006a117b50 R13: ffffffffa01a589c R14: ffff8800631b0f50 R15: 01ad998dadadad80 FS: 00007fcaa3616740(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f5d84b6fdd8 CR3: 0000000064db4000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process exportfs (pid: 564, threadinfo ffff88007a3d6000, task ffff88006af28000) Stack: ffff88007a3d7c80 ffff88006a117b68 ffff88006a117b50 0000000000000000 ffff8800631b0f50 ffff88006a117b50 ffff88007a3d7ca0 ffffffffa01a589c ffff880036be1148 ffff88007a3d7cf8 ffff88007a3d7e28 ffffffffa01a6a98 Call Trace: [<ffffffffa01a589c>] svc_export_put+0x5c/0x70 [nfsd] [<ffffffffa01a6a98>] svc_export_parse+0x328/0x7e0 [nfsd] [<ffffffffa016f1c7>] cache_do_downcall+0x57/0x70 [sunrpc] [<ffffffffa016f25e>] cache_downcall+0x7e/0x100 [sunrpc] [<ffffffffa016f338>] cache_write_procfs+0x58/0x90 [sunrpc] [<ffffffffa016f2e0>] ? cache_downcall+0x100/0x100 [sunrpc] [<ffffffff8123b0e5>] proc_reg_write+0x75/0xb0 [<ffffffff811ccecf>] vfs_write+0x9f/0x170 [<ffffffff811cd089>] sys_write+0x49/0xa0 [<ffffffff816e0919>] system_call_fastpath+0x16/0x1b Code: 66 66 66 90 48 83 fb 10 0f 86 c3 00 00 00 48 89 df 49 bf 00 00 00 00 00 ea ff ff e8 f2 12 ea ff 48 c1 e8 0c 48 c1 e0 06 49 01 c7 <49> 8b 07 f6 c4 80 0f 85 1d 02 00 00 49 8b 07 a8 80 0f 84 ee 01 RIP [<ffffffff811b1509>] kfree+0x49/0x280 RSP <ffff88007a3d7c50> I think Majianpeng's patch is correct, but incomplete. In order for it to be safe to free the ex_uuid unconditionally in svc_export_put, we need to make sure it's initialized to NULL in the init routine. Cc: majianpeng <majianpeng@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: break out hashtable search into separate functionJeff Layton
Later, we'll need more than one call site for this, so break it out into a new function. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: clean up and clarify the cache expiration codeJeff Layton
Add a preprocessor constant for the expiry time of cache entries, and move the test for an expired entry into a function. Note that the current code does not test for RC_INPROG. It just assumes that it won't take more than 2 minutes to fill out an in-progress entry. I'm not sure how valid that assumption is though, so let's just ensure that we never consider an RC_INPROG entry to be expired. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-02-04nfsd: remove redundant test from nfsd_reply_cache_freeJeff Layton
Entries can only get a c_type of RC_REPLBUFF iff they are RC_DONE. Therefore the test for RC_DONE isn't necessary here. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
