path: root/fs/nfsd/nfs3proc.c
2007-05-09RPC: add wrapper for svc_reserve to account for checksumJeff Layton
When the kernel calls svc_reserve to downsize the expected size of an RPC reply, it fails to account for the possibility of a checksum at the end of the packet. If a client mounts a NFSv2/3 with sec=krb5i/p, and does I/O then you'll generally see messages similar to this in the server's ring buffer: RPC request reserved 164 but used 208 While I was never able to verify it, I suspect that this problem is also the root cause of some oopses I've seen under these conditions: https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=227726 This is probably also a problem for other sec= types and for NFSv4. The large reserved size for NFSv4 compound packets seems to generally paper over the problem, however. This patch adds a wrapper for svc_reserve that accounts for the possibility of a checksum. It also fixes up the appropriate callers of svc_reserve to call the wrapper. For now, it just uses a hardcoded value that I determined via testing. That value may need to be revised upward as things change, or we may want to eventually add a new auth_op that attempts to calculate this somehow. Unfortunately, there doesn't seem to be a good way to reliably determine the expected checksum length prior to actually calculating it, particularly with schemes like spkm3. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-08[PATCH] nfsd4: fix open-create permissionsJ. Bruce Fields
In the case where an open creates the file, we shouldn't be rechecking permissions to open the file; the open succeeds regardless of what the new file's mode bits say. This patch fixes the problem, but only by introducing yet another parameter to nfsd_create_v3. This is ugly. This will be fixed by later patches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] nfsd: NFSv{2,3} trivial endianness annotations for error valuesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] fix svc_procfunc declarationAl Viro
svc_procfunc instances return __be32, not int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: Prepare knfsd for support of rsize/wsize of up to 1MB, over TCPGreg Banks
The limit over UDP remains at 32K. Also, make some of the apparently arbitrary sizing constants clearer. The biggest change here involves replacing NFSSVC_MAXBLKSIZE by a function of the rqstp. This allows it to be different for different protocols (udp/tcp) and also allows it to depend on the servers declared sv_bufsiz. Note that we don't actually increase sv_bufsz for nfs yet. That comes next. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: Avoid excess stack usage in svc_tcp_recvfromNeilBrown
.. by allocating the array of 'kvec' in 'struct svc_rqst'. As we plan to increase RPCSVC_MAXPAGES from 8 upto 256, we can no longer allocate an array of this size on the stack. So we allocate it in 'struct svc_rqst'. However svc_rqst contains (indirectly) an array of the same type and size (actually several, but they are in a union). So rather than waste space, we move those arrays out of the separately allocated union and into svc_rqst to share with the kvec moved out of svc_tcp_recvfrom (various arrays are used at different times, so there is no conflict). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] knfsd: Correct reserved reply space for read requests.NeilBrown
NFSd makes sure there is enough space to hold the maximum possible reply before accepting a request. The units for this maximum is (4byte) words. However in three places, particularly for read request, the number given is a number of bytes. This means too much space is reserved which is slightly wasteful. This is the sort of patch that could uncover a deeper bug, and it is not critical, so it would be best for it to spend a while in -mm before going in to mainline. (akpm: target 2.6.17-rc2, 2.6.16.3 (approx)) Discovered-by: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] knfsd: check error status from vfs_getattr and i_op->fsyncDavid Shaw
Both vfs_getattr and i_op->fsync return error statuses which nfsd was largely ignoring. This as noticed when exporting directories using fuse. This patch cleans up most of the offences, which involves moving the call to vfs_getattr out of the xdr encoding routines (where it is too late to report an error) into the main NFS procedure handling routines. There is still a called to vfs_gettattr (related to the ACL code) where the status is ignored, and called to nfsd_sync_dir don't check return status either. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
