commit 427d6c6646d868fbd3094e7e2e1644d480cd9204 upstream.
Someone noticed exportfs happily accepted exports that would later be
rejected when mountd tried to give them to the kernel. Fix this.
This is a regression from 4c1e1b34d5c800ad3ac9a7e2805b0bea70ad2278
"nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids".
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Reported-by: Yin.JianHong <jiyin@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Pull nfsd changes from J Bruce Fields:
"Miscellaneous bugfixes, plus:
- An overhaul of the DRC cache by Jeff Layton. The main effect is
just to make it larger. This decreases the chances of intermittent
errors especially in the UDP case. But we'll need to watch for any
reports of performance regressions.
- Containerized nfsd: with some limitations, we now support
per-container nfs-service, thanks to extensive work from Stanislav
Kinsbursky over the last year."
Some notes about conflicts, since there were *two* non-data semantic
conflicts here:
- idr_remove_all() had been added by a memory leak fix, but has since
become deprecated since idr_destroy() does it for us now.
- xs_local_connect() had been added by this branch to make AF_LOCAL
connections be synchronous, but in the meantime Trond had changed the
calling convention in order to avoid a RCU dereference.
There were a couple of more obvious actual source-level conflicts due to
the hlist traversal changes and one just due to code changes next to
each other, but those were trivial.
* 'for-3.9' of git://linux-nfs.org/~bfields/linux: (49 commits)
SUNRPC: make AF_LOCAL connect synchronous
nfsd: fix compiler warning about ambiguous types in nfsd_cache_csum
svcrpc: fix rpc server shutdown races
svcrpc: make svc_age_temp_xprts enqueue under sv_lock
lockd: nlmclnt_reclaim(): avoid stack overflow
nfsd: enable NFSv4 state in containers
nfsd: disable usermode helper client tracker in container
nfsd: use proper net while reading "exports" file
nfsd: containerize NFSd filesystem
nfsd: fix comments on nfsd_cache_lookup
SUNRPC: move cache_detail->cache_request callback call to cache_read()
SUNRPC: remove "cache_request" argument in sunrpc_cache_pipe_upcall() function
SUNRPC: rework cache upcall logic
SUNRPC: introduce cache_detail->cache_request callback
NFS: simplify and clean cache library
NFS: use SUNRPC cache creation and destruction helper for DNS cache
nfsd4: free_stid can be static
nfsd: keep a checksum of the first 256 bytes of request
sunrpc: trim off trailing checksum before returning decrypted or integrity authenticated buffer
sunrpc: fix comment in struct xdr_buf definition
For most of SUNRPC caches (except NFS DNS cache) cache_detail->cache_upcall is
redundant since all that it's implementations are doing is calling
sunrpc_cache_pipe_upcall() with proper function address argument.
Cache request function address is now stored on cache_detail structure and
thus all the code can be simplified.
Now, for those cache details, which doesn't have cache_upcall callback (the
only one, which still has is nfs_dns_resolve_template)
sunrpc_cache_pipe_upcall will be called instead.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
This callback will allow to simplify upcalls in further patches in this
series.
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 885c91f7466 in Bruce's tree was causing oopses for me:
general protection fault: 0000 [#1] SMP
Modules linked in: nfsd(OF) nfs_acl(OF) auth_rpcgss(OF) lockd(OF) sunrpc(OF) kvm_amd kvm microcode i2c_piix4 virtio_net virtio_balloon cirrus drm_kms_helper ttm drm virtio_blk i2c_core
CPU 0
Pid: 564, comm: exportfs Tainted: GF O 3.8.0-0.rc5.git2.1.fc19.x86_64 #1 Bochs Bochs
RIP: 0010:[<ffffffff811b1509>] [<ffffffff811b1509>] kfree+0x49/0x280
RSP: 0018:ffff88007a3d7c50 EFLAGS: 00010203
RAX: 01adaf8dadadad80 RBX: 6b6b6b6b6b6b6b6b RCX: 0000000000000001
RDX: ffffffff7fffffff RSI: 0000000000000000 RDI: 6b6b6b6b6b6b6b6b
RBP: ffff88007a3d7c80 R08: 6b6b6b6b6b6b6b6b R09: 0000000000000000
R10: 0000000000000018 R11: 0000000000000000 R12: ffff88006a117b50
R13: ffffffffa01a589c R14: ffff8800631b0f50 R15: 01ad998dadadad80
FS: 00007fcaa3616740(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f5d84b6fdd8 CR3: 0000000064db4000 CR4: 00000000000006f0
Process exportfs (pid: 564, threadinfo ffff88007a3d6000, task ffff88006af28000)
Stack:
ffff88007a3d7c80 ffff88006a117b68 ffff88006a117b50 0000000000000000
ffff8800631b0f50 ffff88006a117b50 ffff88007a3d7ca0 ffffffffa01a589c
ffff880036be1148 ffff88007a3d7cf8 ffff88007a3d7e28 ffffffffa01a6a98
Call Trace:
[<ffffffffa01a589c>] svc_export_put+0x5c/0x70 [nfsd]
[<ffffffffa01a6a98>] svc_export_parse+0x328/0x7e0 [nfsd]
[<ffffffffa016f1c7>] cache_do_downcall+0x57/0x70 [sunrpc]
[<ffffffffa016f25e>] cache_downcall+0x7e/0x100 [sunrpc]
[<ffffffffa016f338>] cache_write_procfs+0x58/0x90 [sunrpc]
[<ffffffffa016f2e0>] ? cache_downcall+0x100/0x100 [sunrpc]
[<ffffffff8123b0e5>] proc_reg_write+0x75/0xb0
[<ffffffff811ccecf>] vfs_write+0x9f/0x170
[<ffffffff811cd089>] sys_write+0x49/0xa0
[<ffffffff816e0919>] system_call_fastpath+0x16/0x1b
Code: 66 66 66 90 48 83 fb 10 0f 86 c3 00 00 00 48 89 df 49 bf 00 00 00 00 00 ea ff ff e8 f2 12 ea ff 48 c1 e8 0c 48 c1 e0 06 49 01 c7 <49> 8b 07 f6 c4 80 0f 85 1d 02 00 00 49 8b 07 a8 80 0f 84 ee 01
RIP [<ffffffff811b1509>] kfree+0x49/0x280
RSP <ffff88007a3d7c50>
I think Majianpeng's patch is correct, but incomplete. In order for it
to be safe to free the ex_uuid unconditionally in svc_export_put, we
need to make sure it's initialized to NULL in the init routine.
Cc: majianpeng <majianpeng@gmail.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
In func svc_export_parse, the uuid which used kmemdup to alloc will be
changed in func export_update.So the later kfree don't free this memory.
And it can't be free in func svc_export_parse because other place still
used.So put this operation in func svc_export_put.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
This is a cleanup patch - makes code looks simplier.
It replaces widely used rqstp->rq_xprt->xpt_net by introduced SVC_NET(rqstp).
I don't think there's a practical difference for the range of values
these interfaces should see, but it would be safer to be unambiguous.
Move the rq_flavor into struct svc_cred, and use it in setclientid and
exchange_id comparisons as well.
This patch also changes svcauth_unix_purge() function: added network namespace
as a parameter and thus loop over all networks was replaced by only one call
for ip map cache purge.
This patch also changes prototypes of nfsd_export_flush() and exp_rootfh():
network namespace parameter added.
This cache will be per-net soon. And it's easier to get the pointer to desired
per-net instance only once and then pass it down instead of discovering it in
every place were required.
These functions will be called from per-net operations.
Hard-code is redundant and will prevent from making caches per net ns.
Global svc_export_cache cache is going to be replaced with per-net instance. So
prepare the ground for it.
This patch replaces cache_put() call for svc_export_cache by exp_put() call.
Without info about owner cache datail it won't be able to find out, which
per-net cache detail have to be.
Using of hard-coded svc_expkey_cache pointer in expkey_parse() looks redundant.
Moreover, global cache will be replaced with per-net instance soon.
We check for zero length strings in the caller now, so these aren't
needed.
v2: cache_register_net() and cache_unregister_net() GPL exports added
This is a cleanup patch. Hope, some day generic cache_register() and
cache_unregister() will be removed.
expkey_parse() oopses when handling a 0 length export. This is easily
triggerable from usermode by writing 0 bytes into
'/proc/[proc id]/net/rpc/nfsd.fh/channel'.
Below is the log:
[ 1402.286893] BUG: unable to handle kernel paging request at ffff880077c49fff
[ 1402.287632] IP: [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] PGD 2206063 PUD 1fdfd067 PMD 1ffbc067 PTE 8000000077c49160
[ 1402.287632] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 1402.287632] CPU 1
[ 1402.287632] Pid: 20198, comm: trinity Not tainted 3.2.0-rc2-sasha-00058-gc65cd37 #6
[ 1402.287632] RIP: 0010:[<ffffffff812b4b99>] [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP: 0018:ffff880077f0fd68 EFLAGS: 00010292
[ 1402.287632] RAX: ffff880077c49fff RBX: 00000000ffffffea RCX: 0000000001043400
[ 1402.287632] RDX: 0000000000000000 RSI: ffff880077c4a000 RDI: ffffffff82283de0
[ 1402.287632] RBP: ffff880077f0fe18 R08: 0000000000000001 R09: ffff880000000000
[ 1402.287632] R10: 0000000000000000 R11: 0000000000000001 R12: ffff880077c4a000
[ 1402.287632] R13: ffffffff82283de0 R14: 0000000001043400 R15: ffffffff82283de0
[ 1402.287632] FS: 00007f25fec3f700(0000) GS:ffff88007d400000(0000) knlGS:0000000000000000
[ 1402.287632] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1402.287632] CR2: ffff880077c49fff CR3: 0000000077e1d000 CR4: 00000000000406e0
[ 1402.287632] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 1402.287632] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 1402.287632] Process trinity (pid: 20198, threadinfo ffff880077f0e000, task ffff880077db17b0)
[ 1402.287632] Stack:
[ 1402.287632] ffff880077db17b0 ffff880077c4a000 ffff880077f0fdb8 ffffffff810b411e
[ 1402.287632] ffff880000000000 ffff880077db17b0 ffff880077c4a000 ffffffff82283de0
[ 1402.287632] 0000000001043400 ffffffff82283de0 ffff880077f0fde8 ffffffff81111f63
[ 1402.287632] Call Trace:
[ 1402.287632] [<ffffffff810b411e>] ? lock_release+0x1af/0x1bc
[ 1402.287632] [<ffffffff81111f63>] ? might_fault+0x97/0x9e
[ 1402.287632] [<ffffffff81111f1a>] ? might_fault+0x4e/0x9e
[ 1402.287632] [<ffffffff81a8bcf2>] cache_do_downcall+0x3e/0x4f
[ 1402.287632] [<ffffffff81a8c950>] cache_write.clone.16+0xbb/0x130
[ 1402.287632] [<ffffffff81a8c9df>] ? cache_write_pipefs+0x1a/0x1a
[ 1402.287632] [<ffffffff81a8c9f8>] cache_write_procfs+0x19/0x1b
[ 1402.287632] [<ffffffff8118dc54>] proc_reg_write+0x8e/0xad
[ 1402.287632] [<ffffffff8113fe81>] vfs_write+0xaa/0xfd
[ 1402.287632] [<ffffffff8114142d>] ? fget_light+0x35/0x9e
[ 1402.287632] [<ffffffff8113ff8b>] sys_write+0x48/0x6f
[ 1402.287632] [<ffffffff81bbdb92>] system_call_fastpath+0x16/0x1b
[ 1402.287632] Code: c0 c9 c3 55 48 63 d2 48 89 e5 48 8d 44 32 ff 41 57 41 56 41 55 41 54 53 bb ea ff ff ff 48 81 ec 88 00 00 00 48 89 b5 58 ff ff ff
[ 1402.287632] 38 0a 0f 85 89 02 00 00 c6 00 00 48 8b 3d 44 4a e5 01 48 85
[ 1402.287632] RIP [<ffffffff812b4b99>] expkey_parse+0x28/0x2e1
[ 1402.287632] RSP <ffff880077f0fd68>
[ 1402.287632] ---[ end trace 368ef53ff773a5e3 ]---
Cc: Neil Brown <neilb@suse.de>
Cc: linux-nfs@vger.kernel.org
Cc: stable@kernel.org
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
There are no more users...
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
The current code is sort of hackish in that it assumes a referral is always
matched to an export. When we add support for junctions that may not be the
case.
We can replace nfsd4_path() with a function that encodes the components
directly from the dentries. Since nfsd4_path is currently the only user of
the 'ex_pathname' field in struct svc_export, this has the added benefit
of allowing us to get rid of that.
We don't need this any more.
As promised in feature-removal-schedule.txt it is time to
remove the nfsctl system call.
Userspace has perferred to not use this call throughout 2.6 and it has been
excluded in the default configuration since 2.6.36 (9 months ago).
So this patch removes all the code that was being compiled out.
There are still references to sys_nfsctl in various arch systemcall tables
and related code. These should be cleaned out too, probably in the next
merge window.
Signed-off-by: NeilBrown <neilb@suse.de>
When PUTFH is followed by an operation that uses the filehandle, and
when the current client is using a security flavor that is inconsistent
with the given filehandle, we have a choice: we can return WRONGSEC
either when the current filehandle is set using the PUTFH, or when the
filehandle is first used by the following operation.
Follow the recommendations of RFC 5661 in making this choice.
(Our current behavior prevented the client from doing security
negotiation by returning WRONGSEC on PUTFH+SECINFO_NO_NAME.)
These macros had never been used for several years.
So, remove them.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
We've long had these pointless #ifdef MSNFS's sprinkled throughout the
code--pointless because MSNFS is always defined (and we give no config
option to make that easy to change). So we could just remove the
ifdef's and compile the resulting code unconditionally.
But as long as we're there: why not just rip out this code entirely?
The only purpose is to implement the "msnfs" export option which turns
on Windows-like behavior in some cases, and:
- the export option isn't documented anywhere;
- the userland utilities (which would need to be able to parse
"msnfs" in an export file) don't support it;
- I don't know how to maintain this, as I don't know what the
proper behavior is; and
- google shows no evidence that anyone has ever used this.
There are two calls that operate on ip_map_cache and are
directly called from the nfsd code. Other places will be
handled in a different way.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Note with "first" always 0, and "lastflags" initially 0, we always dump
a spurious set of 0 flags at the start, among other problems.
Fix. And attempt to make the code a little more obvious.
Add CONFIG_NFSD_DEPRECATED, default to y.
Only include deprecated interface if this is defined.
This allows distros to remove this interface before the official
removal, and allows developers to test without it.
Rather can duplicating this idiom twice, put it in an inline function.
This reduces the usage of 'expiry_time' out side the sunrpc/cache.c
code and thus the impact of a change that is about to be made to that
field.
fs/nfsd/nfs4callback.c
We "goto finish" from several places where "exp" is an ERR_PTR. Also I
changed the check for "fsid_key" so that it was consistent with the check
I added.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Both the _lookup and the _update functions for these two caches
independently calculate the hash of the key.
So factor out that code for improved reuse.
Commit f39bde24b275ddc45d fixed the error return from PUTROOTFH in the
case where there is no pseudofilesystem.
This is really a case we shouldn't hit on a correctly configured server:
in the absence of a root filehandle, there's no point accepting version
4 NFS rpc calls at all.
But the shared responsibility between kernel and userspace here means
the kernel on its own can't eliminate the possiblity of this happening.
And we have indeed gotten this wrong in distro's, so new client-side
mount code that attempts to negotiate v4 by default first has to work
around this case.
Therefore when commit f39bde24b275ddc45d arrived at roughly the same
time as the new v4-default mount code, which explicitly checked only for
the previous error, the result was previously fine mounts suddenly
failing.
We'll fix both sides for now: revert the error change, and make the
client-side mount workaround more robust.
The new .h files have paths at the top that are now out of date. While
we're here, just remove all of those from fs/nfsd; they never served any
purpose.
Most of this can be trivially moved to a private header as well.
I can't see any use for writeable V4ROOT exports.
We want to allow exports of symlinks, to allow mountd to communicate to
the kernel which symlinks lead to exports, and hence which symlinks need
to be visible on the pseudofilesystem.
NFSv4 differs from v2 and v3 in that it presents a single unified
filesystem tree, whereas v2 and v3 exported multiple filesystem (whose
roots could be found using a separate mount protocol).
Our original NFSv4 server implementation asked the administrator to
designate a single filesystem as the NFSv4 root, then to mount
filesystems they wished to export underneath. (Often using bind mounts
of already-existing filesystems.)
This was conceptually simple, and allowed easy implementation, but
created a serious obstacle to upgrading between v2/v3: since the paths
to v4 filesystems were different, administrators would have to adjust
all the paths in client-side mount commands when switching to v4.
Various workarounds are possible. For example, the administrator could
export "/" and designate it as the v4 root. However, the security risks
of that approach are obvious, and in any case we shouldn't be requiring
the administrator to take extra steps to fix this problem; instead, the
server should present consistent paths across different versions by
default.
These patches take a modified version of that approach: we provide a new
export option which exports only a subset of a filesystem. With this
flag, it becomes safe for mountd to export "/" by default, with no need
for additional configuration.
We begin just by defining the new flag.
Signed-off-by: Steve Dickson <steved@redhat.com>
Lots of include/linux/nfsd/* headers are only used by
nfsd module. Move them to the source directory
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Now that the headers are fixed and carry their own wait, all fs/nfsd/
source files can include a minimal set of headers. and still compile just
fine.
This patch should improve the compilation speed of the nfsd module.
We really shouldn't hit this case at all, and forthcoming kernel and
nfs-utils changes should eliminate this case; if it does happen,
consider it a bug rather than reporting an error that doesn't really
make sense for the operation (since there's no reason for a server to be
accepting v4 traffic yet have no root filehandle).
Also move some exp_pseudoroot code into a helper function while we're
here.
Make all seq_operations structs const, to help mitigate against
revectoring user-triggerable function pointers.
This is derived from the grsecurity patch, although generated from scratch
because it's simpler than extracting the changes from there.
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
nfsd4_path() allocates a temporary filehandle and then fails to free it
before the function exits, leaking reference counts to the dentry and
export that it refers to.
Also, nfsd4_lookupp() puts the result of exp_pseudoroot() in a temporary
filehandle which it releases on success of exp_pseudoroot() but not on
failure; fix exp_pseudoroot to ensure that on failure it releases the
filehandle before returning.
