path: root/fs/nfsd/export.c
2007-01-30[PATCH] knfsd: ratelimit some nfsd messages that are triggered by external ↵NeilBrown
events Also remove {NFSD,RPC}_PARANOIA as having the defines doesn't really add anything. The printks covered by RPC_PARANOIA were triggered by badly formatted packets and so should be ratelimited. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] knfsd: Fix up some bit-rot in exp_exportNeilBrown
The nfsservctl system call isn't used but recent nfs-utils releases for exporting filesystems, and consequently the code that is uses - exp_export - has suffered some bitrot. Particular: - some newly added fields in 'struct svc_export' are being initialised properly. - the return value is now always -ENOMEM ... This patch fixes both these problems. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: nfsd: don't drop silently on upcall deferralJ.Bruce Fields
To avoid tying up server threads when nfsd makes an upcall (to mountd, to get export options, to idmapd, for nfsv4 name<->id mapping, etc.), we temporarily "drop" the request and save enough information so that we can revisit it later. Certain failures during the deferral process can cause us to really drop the request and never revisit it. This is often less than ideal, and is unacceptable in the NFSv4 case--rfc 3530 forbids the server from dropping a request without also closing the connection. As a first step, we modify the deferral code to return -ETIMEDOUT (which is translated to nfserr_jukebox in the v3 and v4 cases, and remains a drop in the v2 case). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: nfsd: simplify exp_pseudorootJ.Bruce Fields
Note there's no need for special handling of -EAGAIN here; nfserrno() does what we want already. So this is a pure cleanup with no change in functionality. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: nfsd: make exp_rootfh handle exp_parent errorsJ.Bruce Fields
Since exp_parent can fail by returning an error (-EAGAIN) in addition to by returning NULL, we should check for that case in exp_rootfh. (TODO: we should check that userland handles these errors too.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] nfsd: misc endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: fslocations data structuresManoj Naik
Define FS locations structures, some functions to manipulate them, and add code to parse FS locations in downcall and add to the exports structure. [bfields@fieldses.org: bunch of fixes and cleanups] Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd: store export path in exportJ.Bruce Fields
Store the export path in the svc_export structure instead of storing only the dentry. This will prevent the need for additional d_path calls to provide NFSv4 fs_locations support. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: clean up exp_pseudorootJ.Bruce Fields
The previous patch enables some minor simplification here. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: refactor exp_pseudorootJ.Bruce Fields
We could be using more common code in exp_pseudoroot(). This will also simplify some changes we need to make later. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] nfsd: add lock annotations to e_start and e_stopJosh Triplett
e_start acquires svc_export_cache.hash_lock, and e_stop releases it. Add lock annotations to these two functions so that sparse can check callers for lock pairing, and so that sparse will not complain about these functions since they intentionally use locks in this manner. Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Use SEQ_START_TOKEN instead of hardcoded magic (void*)1Greg Banks
Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: remove an unused variable from e_show()Greg Banks
Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add some missing newlines in printksGreg Banks
2006-06-30[PATCH] knfsd: fixing missing 'expkey' support for fsid type 3Frank Filz
Type '3' is used for the fsid in filehandles when the device number of the device holding the filesystem has more than 8 bits in either major or minor. Unfortunately expkey_parse doesn't recognise type 3. Fix this. (Slighty modified from Frank's original) Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-23[PATCH] knfsd: Fix two problems that can cause rmmod nfsd to dieNeilBrown
Both cause the 'entries' count in the export cache to be non-zero at module removal time, so unregistering that cache fails and results in an oops. 1/ exp_pseudoroot (used for NFSv4 only) leaks a reference to an export entry. 2/ sunrpc_cache_update doesn't increment the entries count when it adds an entry. Thanks to "david m. richter" <richterd@citi.umich.edu> for triggering the problem and finding one of the bugs. Cc: "david m. richter" <richterd@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] knfsd: nfsd: oops exporting nonexistent directoryNeilBrown
Export a directory that does not exist: exportfs -orw,fsid=0,insecure,no_subtree_check client:/home/NFS4 Try to mount from client with nfs4. Mount hangs (I'm not sure why - that's another issue). While client is hung, back on server mkdir /home/NFS4 The server panics in dput. I traced the problem back to svc_export_parse() calling path_release() even though path_lookup() failed (it happens to fill in the nameidata structure with a negative dentry - so the test after out: succeeds). After patching, an recreating the problem, the client mount still takes some time before finally exiting with a message "couldn't read superblock". Here is a simple patch to resolve this issue: Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] fs/nfsd/export.c,net/sunrpc/cache.c: make needlessly global code staticAdrian Bunk
We can now make some code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Convert sunrpc_cache to use krefsNeilBrown
.. it makes some of the code nicer. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Use new cache_lookup for svc_expkey cacheNeilBrown
2006-03-27[PATCH] knfsd: Use new cache_lookup for svc_exportNeilBrown
2006-03-27[PATCH] knfsd: Get rid of 'inplace' sunrpc cachesNeilBrown
These were an unnecessary wart. Also only have one 'DefineSimpleCache..' instead of two. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Break the hard linkage from svc_expkey to svc_exportNeilBrown
Current svc_expkey holds a pointer to the svc_export structure, so updates to that structure have to be in-place, which is a wart on the whole cache infrastruct. So we break that linkage and just do a second lookup. If this became a performance issue, it would be possible to put a direct link back in which was only used conditionally. i.e. when an object is replaced in the cache, we set a flag in the old object. When dereferencing the link from svc_expkey, if the flag is set, we drop the reference and do a fresh lookup. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Change the store of auth_domains to not be a 'cache'NeilBrown
The 'auth_domain's are simply handles on internal data structures. They do not cache information from user-space, and forcing them into the mold of a 'cache' misrepresents their true nature and causes confusion. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sunrpc: cache_register can use wrong module referenceBruce Allan
When registering an RPC cache, cache_register() always sets the owner as the sunrpc module. However, there are RPC caches owned by other modules. With the incorrect owner setting, the real owning module can be removed potentially with an open reference to the cache from userspace. For example, if one were to stop the nfs server and unmount the nfsd filesystem, the nfsd module could be removed eventhough rpc.idmapd had references to the idtoname and nametoid caches (i.e. /proc/net/rpc/nfs4.<cachename>/channel is still open). This resulted in a system panic on one of our machines when attempting to restart the nfs services after reloading the nfsd module. The following patch adds a 'struct module *owner' field in struct cache_detail. The owner is further assigned to the struct proc_dir_entry in cache_register() so that the module cannot be unloaded while user-space daemons have an open reference on the associated file under /proc. Signed-off-by: Bruce Allan <bwa@us.ibm.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
