Pull nfsd updates from Bruce Fields:
"A quiet cycle this time; this is basically entirely bugfixes.
The few that aren't cc'd to stable are cleanup or seemed unlikely to
affect anyone much"
* 'for-4.1' of git://linux-nfs.org/~bfields/linux:
uapi: Remove kernel internal declaration
nfsd: fix nsfd startup race triggering BUG_ON
nfsd: eliminate NFSD_DEBUG
nfsd4: fix READ permission checking
nfsd4: disallow SEEK with special stateids
nfsd4: disallow ALLOCATE with special stateids
nfsd: add NFSEXP_PNFS to the exflags array
nfsd: Remove duplicate macro define for max sec label length
nfsd: allow setting acls with unenforceable DENYs
nfsd: NFSD_FAULT_INJECTION depends on DEBUG_FS
nfsd: remove unused status arg to nfsd4_cleanup_open_state
nfsd: remove bogus setting of status in nfsd4_process_open2
NFSD: Use correct reply size calculating function
NFSD: Using path_equal() for checking two paths
There are a lot of embedded systems that run most or all of their
functionality in init, running as root:root. For these systems,
supporting multiple users is not necessary.
This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for
non-root users, non-root groups, and capabilities optional. It is enabled
under CONFIG_EXPERT menu.
When this symbol is not defined, UID and GID are zero in any possible case
and processes always have all capabilities.
The following syscalls are compiled out: setuid, setregid, setgid,
setreuid, setresuid, getresuid, setresgid, getresgid, setgroups,
getgroups, setfsuid, setfsgid, capget, capset.
Also, groups.c is compiled out completely.
In kernel/capability.c, capable function was moved in order to avoid
adding two ifdef blocks.
This change saves about 25 KB on a defconfig build. The most minimal
kernels have total text sizes in the high hundreds of kB rather than
low MB. (The 25k goes down a bit with allnoconfig, but not that much.
The kernel was booted in Qemu. All the common functionalities work.
Adding users/groups is not possible, failing with -ENOSYS.
Bloat-o-meter output:
add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650)
Signed-off-by: Iulia Manda <iulia.manda21@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
NFSD_FAULT_INJECTION depends on DEBUG_FS, otherwise the debugfs_create_*
interface may return unexpected error -ENODEV, and cause system crash.
Signed-off-by: Chengyu Song <csong84@gatech.edu>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Add support for the GETDEVICEINFO, LAYOUTGET, LAYOUTCOMMIT and
LAYOUTRETURN NFSv4.1 operations, as well as backing code to manage
outstanding layouts and devices.
Layout management is very straight forward, with a nfs4_layout_stateid
structure that extends nfs4_stid to manage layout stateids as the
top-level structure. It is linked into the nfs4_file and nfs4_client
structures like the other stateids, and contains a linked list of
layouts that hang of the stateid. The actual layout operations are
implemented in layout drivers that are not part of this commit, but
will be added later.
The worst part of this commit is the management of the pNFS device IDs,
which suffers from a specification that is not sanely implementable due
to the fact that the device-IDs are global and not bound to an export,
and have a small enough size so that we can't store the fsid portion of
a file handle, and must never be reused. As we still do need perform all
export authentication and validation checks on a device ID passed to
GETDEVICEINFO we are caught between a rock and a hard place. To work
around this issue we add a new hash that maps from a 64-bit integer to a
fsid so that we can look up the export to authenticate against it,
a 32-bit integer as a generation that we can bump when changing the device,
and a currently unused 32-bit integer that could be used in the future
to handle more than a single device per export. Entries in this hash
table are never deleted as we can't reuse the ids anyway, and would have
a severe lifetime problem anyway as Linux export structures are temporary
structures that can go away under load.
Parts of the XDR data, structures and marshaling/unmarshaling code, as
well as many concepts are derived from the old pNFS server implementation
from Andy Adamson, Benny Halevy, Dean Hildebrand, Marc Eshel, Fred Isaman,
Mike Sager, Ricardo Labiaga and many others.
Currently, all of the grace period handling is part of lockd. Eventually
though we'd like to be able to build v4-only servers, at which point
we'll need to put all of this elsewhere.
Move the code itself into fs/nfs_common and have it build a grace.ko
module. Then, rejigger the Kconfig options so that both nfsd and lockd
enable it automatically.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
The working group appears committed to keeping the protocol stable, the
code has gotten some use and seems to work OK.
The description text for CONFIG_NFSD_V4_SECURITY_LABEL has an unpaired
quote sign which breaks syntax highlighting for the nfsd Kconfig file.
Remove it.
Implement labeled NFS on the server: encoding and decoding, and writing
and reading, of file labels.
Enabled with CONFIG_NFSD_V4_SECURITY_LABEL.
Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com>
Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg>
Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg>
Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "J. Bruce Fields" <bfields@fieldses.org>
Fault injection on the NFS server makes it easier to test the client's
state manager and recovery threads. Simulating errors on the server is
easier than finding the right conditions that cause them naturally.
This patch uses debugfs to add a simple framework for fault injection to
the server. This framework is a config option, and can be enabled
through CONFIG_NFSD_FAULT_INJECTION. Assuming you have debugfs mounted
to /sys/debug, a set of files will be created in /sys/debug/nfsd/.
Writing to any of these files will cause the corresponding action and
write a log entry to dmesg.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
As promised in feature-removal-schedule.txt it is time to
remove the nfsctl system call.
Userspace has perferred to not use this call throughout 2.6 and it has been
excluded in the default configuration since 2.6.36 (9 months ago).
So this patch removes all the code that was being compiled out.
There are still references to sys_nfsctl in various arch systemcall tables
and related code. These should be cleaned out too, probably in the next
merge window.
Signed-off-by: NeilBrown <neilb@suse.de>
nfsd V4 support uses crypto interfaces, so select CRYPTO
to fix build errors in 2.6.39:
ERROR: "crypto_destroy_tfm" [fs/nfsd/nfsd.ko] undefined!
ERROR: "crypto_alloc_base" [fs/nfsd/nfsd.ko] undefined!
Reported-by: Wakko Warner <wakko@animx.eu.org>
Cc: stable@kernel.org
lockd should use lock_flocks() instead of lock_kernel()
to lock against posix locks accessing the i_flock list.
This is a prerequisite to turning lock_flocks into a
spinlock.
Acked-by: J. Bruce Fields <bfields@redhat.com>
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits)
svcrpc: svc_tcp_sendto XPT_DEAD check is redundant
svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue
svcrpc: assume svc_delete_xprt() called only once
svcrpc: never clear XPT_BUSY on dead xprt
nfsd4: fix connection allocation in sequence()
nfsd4: only require krb5 principal for NFSv4.0 callbacks
nfsd4: move minorversion to client
nfsd4: delay session removal till free_client
nfsd4: separate callback change and callback probe
nfsd4: callback program number is per-session
nfsd4: track backchannel connections
nfsd4: confirm only on succesful create_session
nfsd4: make backchannel sequence number per-session
nfsd4: use client pointer to backchannel session
nfsd4: move callback setup into session init code
nfsd4: don't cache seq_misordered replies
SUNRPC: Properly initialize sock_xprt.srcaddr in all cases
SUNRPC: Use conventional switch statement when reclassifying sockets
sunrpc/xprtrdma: clean up workqueue usage
sunrpc: Turn list_for_each-s into the ..._entry-s
Fix up trivial conflicts (two different deprecation notices added in
separate branches) in Documentation/feature-removal-schedule.txt
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
With all the patches we have queued in the BKL removal tree, only a
few dozen modules are left that actually rely on the BKL, and even
there are lots of low-hanging fruit. We need to decide what to do
about them, this patch illustrates one of the options:
Every user of the BKL is marked as 'depends on BKL' in Kconfig,
and the CONFIG_BKL becomes a user-visible option. If it gets
disabled, no BKL using module can be built any more and the BKL
code itself is compiled out.
The one exception is file locking, which is practically always
enabled and does a 'select BKL' instead. This effectively forces
CONFIG_BKL to be enabled until we have solved the fs/lockd
mess and can apply the patch that removes the BKL from fs/locks.c.
Add CONFIG_NFSD_DEPRECATED, default to y.
Only include deprecated interface if this is defined.
This allows distros to remove this interface before the official
removal, and allows developers to test without it.
The NFSv4 client's callback server calls svc_gss_principal(), which
is defined in the auth_rpcgss.ko
The NFSv4 server has the same dependency, and in addition calls
svcauth_gss_flavor(), gss_mech_get_by_pseudoflavor(),
gss_pseudoflavor_to_service() and gss_mech_put() from the same module.
The module auth_rpcgss itself has no dependencies aside from sunrpc,
so we only need to select RPCSEC_GSS.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Randy Dunlap reports:
ERROR: "svc_gss_principal" [fs/nfs/nfs.ko] undefined!
because in fs/nfs/Kconfig, NFS_V4 selects RPCSEC_GSS_KRB5
and/or in fs/nfsd/Kconfig, NFSD_V4 selects RPCSEC_GSS_KRB5.
RPCSEC_GSS_KRB5 does 5 selects, but none of these is enforced/followed
by the fs/nfs[d]/Kconfig configs:
select SUNRPC_GSS
select CRYPTO
select CRYPTO_MD5
select CRYPTO_DES
select CRYPTO_CBC
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: J. Bruce Fields <bfields@fieldses.org>
Enable NFSD only when FILE_LOCKING is enabled, since we don't want to
support NFSD without FILE_LOCKING.
Signed-off-by: Manish Katiyar <mkatiyar@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
