path: root/fs/nfs/super.c
2009-12-17Revert "fix mismerge with Trond's stuff (create_mnt_ns() export is gone now)"Linus Torvalds
This reverts commit e9496ff46a20a8592fdc7bdaaf41b45eb808d310. Quoth Al: "it's dependent on a lot of other stuff not currently in mainline and badly broken with current fs/namespace.c. Sorry, badly out-of-order cherry-pick from old queue. PS: there's a large pending series reworking the refcounting and lifetime rules for vfsmounts that will, among other things, allow to rip a subtree away _without_ dissolving connections in it, to be garbage-collected when all active references are gone. It's considerably saner wrt "is the subtree busy" logics, but it's nowhere near being ready for merge at the moment; this changeset is one of the things becoming possible with that sucker, but it certainly shouldn't have been picked during this cycle. My apologies..." Noticed-by: Eric Paris <eparis@redhat.com> Requested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fix mismerge with Trond's stuff (create_mnt_ns() export is gone now)Al Viro
2009-12-03NFS: Revert default r/wsize behaviorChuck Lever
When the "rsize=" or "wsize=" mount options are not specified, text-based mounts have slightly different behavior than legacy binary mounts. Text-based mounts use the smaller of the server's maximum and the client's maximum, but binary mounts use the smaller of the server's _preferred_ size and the client's maximum. This difference is actually pretty subtle. Most servers advertise the same value as their maximum and their preferred transfer size, so the end result is the same in most cases. The reason for this difference is that for text-based mounts, if r/wsize are not specified, they are set to the largest value supported by the client. For legacy mounts, the values are set to zero if these options are not specified. nfs_server_set_fsinfo() can negotiate the transfer size defaults correctly in any case. There's no need to specify any particular value as default in the text-based option parsing logic. Note that nfs4 doesn't use nfs_server_set_fsinfo(), but the mount.nfs4 command does set rsize and wsize to 0 if the user didn't specify these options. So, make the same change for text-based NFSv4 mounts. Thanks to James Pearson <james-p@moving-picture.com> for reporting and diagnosing the problem. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03NFS: Display compressed (shorthand) IPv6 in /proc/mountsChuck Lever
Recent changes to snprintf() introduced the %pI6c formatter, which can display an IPv6 address with standard shorthanding. Use this new formatter when displaying IPv6 server addresses in /proc/mounts. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03NFS: convert proto= option to use netids rather than a protonameJeff Layton
Solaris uses netids as values for the proto= option, so that when someone specifies "tcp6" they get traffic over TCP + IPv6. Until recently, this has never really been an issue for Linux since it didn't support NFS over IPv6. The netid and the protocol name were generally always the same (modulo any strange configuration in /etc/netconfig). The solaris manpage documents their proto= option as: proto= _netid_ | rdma This patch is intended to bring Linux closer to how the Solaris proto= option works, by declaring a static netid mapping in the kernel and converting the proto= and mountproto= options to follow it and display the proper values in /proc/mounts. Much of this functionality will need to be provided by a userspace mount.nfs patch. Chuck Lever has a patch to change mount.nfs in the same way. In principle, we could do *all* of this in userspace but that would mean that the options in /proc/mounts may not match the options used by userspace. The alternative to the static mapping here is to add a mechanism to upcall to userspace for netid's. I'm not opposed to that option, but it'll probably mean more overhead (and quite a bit more code). Rather than shoot for that at first, I figured it was probably better to start simply. Comments welcome. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03NFS: BKL removal from the mount code...Trond Myklebust
None of the code in nfs_umount_begin() or nfs_remount() has any BKL dependency. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-22nfs: Fix nfs_parse_mount_options() kfree() leakYinghai Lu
Fix a (small) memory leak in one of the error paths of the NFS mount options parsing code. Regression introduced in 2.6.30 by commit a67d18f (NFS: load the rpc/rdma transport module automatically). Reported-by: Yinghai Lu <yinghai@kernel.org> Reported-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-12NFS: suppress a build warningStefan Richter
struct sockaddr_storage * can safely be used as struct sockaddr *. Suppress an "incompatible pointer type" warning. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08NFSv4: Kill nfs4_renewd_prepare_shutdown()Trond Myklebust
The NFSv4 renew daemon is shared between all active super blocks that refer to a particular NFS server, so it is wrong to be shutting it down in nfs4_kill_super every time a super block is destroyed. This patch therefore kills nfs4_renewd_prepare_shutdown altogether, and leaves it up to nfs4_shutdown_client() to also shut down the renew daemon by means of the existing call to nfs4_kill_renewd(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-06NFS: Fix port initialisation in nfs_remount()Trond Myklebust
The recent changeset 53a0b9c4c99ab0085a06421f71592722e5b3fd5f (NFS: Replace nfs_parse_ip_address() with rpc_pton()) broke nfs_remount, since the call to rpc_pton() will zero out the port number in data->nfs_server.address. This is actually due to a bug in nfs_remount: it should be looking at the port number in nfs_server.port instead... This fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=14276 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-06NFS: Fix port and mountport display in /proc/self/mountinfoTrond Myklebust
Currently, the port and mount port will both display as 65535 if you do not specify a port number. That would be wrong... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-06NFS: Fix a default mount regression...Trond Myklebust
With the recent spate of changes, the nfs protocol version will now default to 2 instead of 3, while the mount protocol version defaults to 3. The following patch should ensure the defaults are consistent with the previous defaults of vers=3,proto=tcp,mountvers=3,mountproto=tcp. This fixes the bug http://bugzilla.kernel.org/show_bug.cgi?id=14259 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-24nfs[23] tcp breakage in mount with binary optionsAl Viro
We forget to set nfs_server.protocol in tcp case when old-style binary options are passed to mount. The thing remains zero and never validated afterwards. As the result, we hit BUG in fs/nfs/client.c:588. Breakage has been introduced in NFS: Add nfs_alloc_parsed_mount_data merged yesterday... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23NFS: Propagate 'fsc' mount option through automountsDavid Howells
Propagate the NFS 'fsc' mount option through NFS automounts of various types. This is now required as commit: commit c02d7adf8c5429727a98bad1d039bccad4c61c50 Author: Trond Myklebust <Trond.Myklebust@netapp.com> Date: Mon Jun 22 15:09:14 2009 -0400 NFSv4: Replace nfs4_path_walk() with VFS path lookup in a private namespace uses VFS-driven automounting to reach all submounts barring the root, thus preventing fscaching from being enabled on any submount other than the root. This patch gets around that by propagating the NFS_OPTION_FSCACHE flag across automounts. If a uniquifier is supplied to a mount then this is propagated to all automounts of that mount too. Signed-off-by: David Howells <dhowells@redhat.com> [Trond: Fixed up the definition of nfs_fscache_get_super_cookie for the case of #undef CONFIG_NFS_FSCACHE] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23NFS: Add nfs_alloc_parsed_mount_dataChuck Lever
Allocating nfs_parsed_mount_data and setting up the defaults is nearly the same for both nfs and nfs4 mounts. Both paths seem to use nfs_validate_transport_protocol(), so setting a default value for nfs_server.protocol ought to be unnecessary. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23NFS: Get rid of the NFS_MOUNT_VER3 and NFS_MOUNT_TCP flagsTrond Myklebust
Keep it in the case of the legacy binary mount interface, but purge it from the nfs_server structure. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-21nfs: nfs_kill_super() should call bdi_unregister() after killing superJens Axboe
Otherwise we could be attempting to flush data for a writeback thread and bdi that have already disappeared. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-16fs: Assign bdi in super_blockJens Axboe
We do this automatically in get_sb_bdev() from the set_bdev_super() callback. Filesystems that have their own private backing_dev_info must assign that in ->fill_super(). Note that ->s_bdi assignment is required for proper writeback! Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-08NFSv4: Disallow 'mount -t nfs4 -overs=2' and 'mount -t nfs4 -overs=3'Trond Myklebust
2009-09-08NFS: Allow the "nfs" file system type to support NFSv4Chuck Lever
When mounting an "nfs" type file system, recognize "v4," "vers=4," or "nfsvers=4" mount options, and convert the file system to "nfs4" under the covers. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> [trondmy: fixed up binary mount code so it sets the 'version' field too] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-08NFS: Move details of nfs4_get_sb() to a helperChuck Lever
Clean up: Refactor nfs4_get_sb() to allow its guts to be invoked by nfs_get_sb(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-08NFS: Refactor NFSv4 text-based mount option validationChuck Lever
Clean up: Refactor the part of nfs4_validate_mount_options() that handles text-based options, so we can call it from the NFSv2/v3 option validation function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-08NFS: Mount option parser should detect missing "port="Chuck Lever
The meaning of not specifying the "port=" mount option is different for "-t nfs" and "-t nfs4" mounts. The default port value for NFSv2/v3 mounts is 0, but the default for NFSv4 mounts is 2049. To support "-t nfs -o vers=4", the mount option parser must detect when "port=" is missing so that the correct default port value can be set depending on which NFS version is requested. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-23NFS: Handle a zero-length auth flavor listChuck Lever
Some releases of Linux rpc.mountd (nfs-utils 1.1.4 and later) return an empty auth flavor list if no sec= was specified for the export. This is notably broken server behavior. The new auth flavor list checking added in a recent commit rejects this case. The OpenSolaris client does too. The broken mountd implementation is already widely deployed. To avoid a behavioral regression, the kernel's mount client skips flavor checking (ie reverts to the pre-2.6.32 behavior) if mountd returns an empty flavor list. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFS: Replace nfs_set_port() with rpc_set_port()Chuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFS: Replace nfs_parse_ip_address() with rpc_pton()Chuck Lever
Clean up: Use the common routine now provided in sunrpc.ko for parsing mount addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFS: Use the authentication flavor list returned by mountdChuck Lever
Commit a14017db added support in the kernel's NFS mount client to decode the authentication flavor list returned by mountd. The NFS client can now use this list to determine whether the authentication flavor requested by the user is actually supported by the server. Note we don't actually negotiate the security flavor if none was specified by the user. Instead, we try to use AUTH_SYS, and fail if the server does not support it. This prevents us from negotiating an inappropriate security flavor (some servers list AUTH_NULL first). If the server does not support AUTH_SYS, the user must provide an appropriate security flavor by specifying the "sec=" mount option. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFS: Fix auth flavor len accountingChuck Lever
Previous logic in the NFS mount parsing code path assumed auth_flavor_len was set to zero for simple authentication flavors (like AUTH_UNIX), and 1 for compound flavors (like AUTH_GSS). At some earlier point (maybe even before the option parsers were merged?) specific checks for auth_flavor_len being zero were removed from the functions that validate the mount option that sets the mount point's authentication flavor. Since we are populating an array for authentication flavors, the auth_flavor_len should always be set to the number of flavors. Let's eliminate some cleverness here, and prepare for new logic that needs to know the number of flavors in the auth_flavors[] array. (auth_flavors[] is an array because at some point we want to allow a list of acceptable authentication flavors to be specified via the sec= mount option. For now it remains a single element array). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09NFS: Fix up new minorversion= optionChuck Lever
The new minorversion= mount option (commit 3fd5be9e) was merged at the same time as the recent sloppy parser fixes (commit a5a16bae), so minorversion= still uses the old value parsing logic. If the minorversion= option specifies a bogus value, it should fail with "bad value" not "bad option." Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-22NFS: Correct the NFS mount path when following a referralTrond Myklebust
2009-06-22NFSv4: Replace nfs4_path_walk() with VFS path lookup in a private namespaceTrond Myklebust
As noted in the previous patch, the NFSv4 client mount code currently has several limitations. If the mount path contains symlinks, or referrals, or even if it just contains a '..', then the client code in nfs4_path_walk() will fail with an error. This patch replaces the nfs4_path_walk()-based lookup with a helper function that sets up a private namespace to represent the namespace on the server, then uses the ordinary VFS and NFS path lookup code to walk down the mount path in that namespace. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18Merge branch 'devel-for-2.6.31' into for-2.6.31Trond Myklebust
Conflicts: fs/nfs/client.c fs/nfs/super.c
2009-06-17NFS: More "sloppy" parsing problemsChuck Lever
Specifying "port=-5" with the kernel's current mount option parser generates "unrecognized mount option". If "sloppy" is set, this causes the mount to succeed and use the default values; the desired behavior is that, since this is a valid option with an invalid value, the mount should fail, even with "sloppy." To properly handle "sloppy" parsing, we need to distinguish between correct options with invalid values, and incorrect options. We will need to parse integer values by hand, therefore, and not rely on match_token(). For instance, these must all fail with "invalid value": port=12345678 port=-5 port=samuel and not with "unrecognized option," as they do currently. Thus, for the sake of match_token() we need to treat the values for these options as strings, and do the conversion to integers using strict_strtol(). This is basically the same solution we used for the earlier "retry=" fix (commit ecbb3845), except in this case the kernel actually has to parse the value, rather than ignore it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Invalid mount option values should always fail, even with "sloppy"Chuck Lever
Ian Kent reports: "I've noticed a couple of other regressions with the options vers and proto option of mount.nfs(8). The commands: mount -t nfs -o vers=<invalid version> <server>:/<path> /<mountpoint> mount -t nfs -o proto=<invalid proto> <server>:/<path> /<mountpoint> both immediately fail. But if the "-s" option is also used they both succeed with the mount falling back to defaults (by the look of it). In the past these failed even when the sloppy option was given, as I think they should. I believe the sloppy option is meant to allow the mount command to still function for mount options (for example in shared autofs maps) that exist on other Unix implementations but aren't present in the Linux mount.nfs(8). So, an invalid value specified for a known mount option is different to an unknown mount option and should fail appropriately." See RH bugzilla 486266. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Update MNT and MNT3 reply decoding functionsChuck Lever
Solder xdr_stream-based XDR decoding functions into the in-kernel mountd client that are more careful about checking data types and watching for buffer overflows. The new MNT3 decoder includes support for auth-flavor list decoding. The "_sz" macro for MNT3 replies was missing the size of the file handle. I've added this back, and included the size of the auth flavor array. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Do not display the setting of the "intr" mount optionChuck Lever
The "intr" mount option has been deprecated for a while, but /proc/mounts continues to display "nointr" whether "intr" or "nointr" has been specified for a mount point. Since these options do not have any effect, simply do not display them. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17Merge commit 'linux-pnfs/nfs41-for-2.6.31' into nfsv41-for-2.6.31Trond Myklebust
2009-06-17nfs41: Release backchannel resources associated with sessionAndy Adamson
Frees the preallocated backchannel resources that are associated with this session when the session is destroyed. A backchannel is currently created once per session. Destroy the backchannel only when the session is destroyed. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17NFSv4: Fix the 'nolock' option regressionTrond Myklebust
NFSv4 should just ignore the 'nolock' option. It is an NFSv2/v3 thing... This fixes the Oops in http://bugzilla.kernel.org/show_bug.cgi?id=13330 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: destroy_session operationAndy Adamson
Implement the destroy_session operation conforming to http://tools.ietf.org/html/draft-ietf-nfsv4-minorversion1-26 Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: remove extraneous rpc_clnt pointer] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41; NFS_CS_READY required for DESTROY_SESSION] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: pass *session in seq_args and seq_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [nfs41: fix encode_destroy_session's xdr Xcoding pointer type] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: add mount command option minorversionMike Sager
mount -t nfs4 -o minorversion=[0|1] specifies whether to use 4.0 or 4.1. By default, the minorversion is set to 0. Signed-off-by: Mike Sager <sager@netapp.com> [set default minorversion to 0 as per Trond and SteveD's request] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-05-09vfs: umount_begin BKL pushdownAlessio Igor Bogani
Push BKL down into ->umount_begin() Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-06NFS: Fix a double free in nfs_parse_mount_options()Trond Myklebust
Due to an apparent typo, commit a67d18f89f5782806135aad4ee012ff78d45aae7 (NFS: load the rpc/rdma transport module automatically) lead to the 'proto=' mount option doing a double free, while Opt_mountproto leaks a string. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03NFS: Add mount options to enable local caching on NFSDavid Howells
Add NFS mount options to allow the local caching support to be enabled. The attached patch makes it possible for the NFS filesystem to be told to make use of the network filesystem local caching service (FS-Cache). To be able to use this, a recent nfsutils package is required. There are three variant NFS mount options that can be added to a mount command to control caching for a mount. Only the last one specified takes effect: (*) Adding "fsc" will request caching. (*) Adding "fsc=<string>" will request caching and also specify a uniquifier. (*) Adding "nofsc" will disable caching. For example: mount warthog:/ /a -o fsc The cache of a particular superblock (NFS FSID) will be shared between all mounts of that volume, provided they have the same connection parameters and are not marked 'nosharecache'. Where it is otherwise impossible to distinguish superblocks because all the parameters are identical, but the 'nosharecache' option is supplied, a uniquifying string must be supplied, else only the first mount will be permitted to use the cache. If there's a key collision, then the second mount will disable caching and give a warning into the kernel log. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Add some new I/O counters for FS-Cache doing things for NFSDavid Howells
Add some new NFS I/O counters for FS-Cache doing things for NFS. A new line is emitted into /proc/pid/mountstats if caching is enabled that looks like: fsc: <rok> <rfl> <wok> <wfl> <unc> Where <rok> is the number of pages read successfully from the cache, <rfl> is the number of failed page reads against the cache, <wok> is the number of successful page writes to the cache, <wfl> is the number of failed page writes to the cache, and <unc> is the number of NFS pages that have been disconnected from the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create superblock-level objectsDavid Howells
Define and create superblock-level cache index objects (as managed by nfs_server structs). Each superblock object is created in a server level index object and is itself an index into which inode-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The superblock object key is a sequence consisting of: (1) Certain superblock s_flags. (2) Various connection parameters that serve to distinguish superblocks for sget(). (3) The volume FSID. (4) The security flavour. (5) The uniquifier length. (6) The uniquifier text. This is normally an empty string, unless the fsc=xyz mount option was used to explicitly specify a uniquifier. The key blob is of variable length, depending on the length of (6). The superblock object is given no coherency data to carry in the auxiliary data permitted by the cache. It is assumed that the superblock is always coherent. This patch also adds uniquification handling such that two otherwise identical superblocks, at least one of which is marked "nosharecache", won't end up trying to share the on-disk cache. It will be possible to manually provide a uniquifier through a mount option with a later patch to avoid the error otherwise produced. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-03-11NFS: load the rpc/rdma transport module automaticallyTom Talpey
When mounting an NFS/RDMA server with the "-o proto=rdma" or "-o rdma" options, attempt to dynamically load the necessary "xprtrdma" client transport module. Doing so improves usability, while avoiding a static module dependency and any unnecesary resources. Signed-off-by: Tom Talpey <tmtalpey@gmail.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-30Merge branch 'devel' into nextTrond Myklebust
