commit 924491f2e476f7234d722b24171a4daff61bbe13 upstream.
Currently, if an nfs server returns NFS4ERR_EXPIRED to open(),
we return EIO to applications without even trying to recover.
Fixes: 272289a3df72 ("NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid")
Signed-off-by: Robert Milkowski <rmilkowski@gmail.com>
Reviewed-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit be3df3dd4c70ee020587a943a31b98a0fb4b6424 ]
If the delegation is marked as being revoked, we must not use it
for cached opens.
Fixes: 869f9dfa4d6d ("NFSv4: Fix races between nfs_remove_bad_delegation() and delegation return")
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit 1047ec868332034d1fbcb2fae19fe6d4cb869ff2 ]
Our client can issue multiple SETCLIENTID operations to the same
server in some circumstances. Ensure that calls to
nfs4_proc_setclientid() after the first one do not overwrite the
previously allocated cl_acceptor string.
unreferenced object 0xffff888461031800 (size 32):
comm "mount.nfs", pid 2227, jiffies 4294822467 (age 1407.749s)
hex dump (first 32 bytes):
6e 66 73 40 6b 6c 69 6d 74 2e 69 62 2e 31 30 31 nfs@klimt.ib.101
35 67 72 61 6e 67 65 72 2e 6e 65 74 00 00 00 00 5granger.net....
backtrace:
[<00000000ab820188>] __kmalloc+0x128/0x176
[<00000000eeaf4ec8>] gss_stringify_acceptor+0xbd/0x1a7 [auth_rpcgss]
[<00000000e85e3382>] nfs4_proc_setclientid+0x34e/0x46c [nfsv4]
[<000000003d9cf1fa>] nfs40_discover_server_trunking+0x7a/0xed [nfsv4]
[<00000000b81c3787>] nfs4_discover_server_trunking+0x81/0x244 [nfsv4]
[<000000000801b55f>] nfs4_init_client+0x1b0/0x238 [nfsv4]
[<00000000977daf7f>] nfs4_set_client+0xfe/0x14d [nfsv4]
[<0000000053a68a2a>] nfs4_create_server+0x107/0x1db [nfsv4]
[<0000000088262019>] nfs4_remote_mount+0x2c/0x59 [nfsv4]
[<00000000e84a2fd0>] legacy_get_tree+0x2d/0x4c
[<00000000797e947c>] vfs_get_tree+0x20/0xc7
[<00000000ecabaaa8>] fc_mount+0xe/0x36
[<00000000f15fafc2>] vfs_kern_mount+0x74/0x8d
[<00000000a3ff4e26>] nfs_do_root_mount+0x8a/0xa3 [nfsv4]
[<00000000d1c2b337>] nfs4_try_mount+0x58/0xad [nfsv4]
[<000000004c9bddee>] nfs_fs_mount+0x820/0x869 [nfs]
Fixes: f11b2a1cfbf5 ("nfs4: copy acceptor name from context ... ")
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 8fd1ab747d2b1ec7ec663ad0b41a32eaa35117a8 ]
If the server that does not implement NFSv4.1 persistent session
semantics reboots while we are performing an exclusive create,
then the return value of NFS4ERR_DELAY when we replay the open
during the grace period causes us to lose the verifier.
When the grace period expires, and we present a new verifier,
the server will then correctly reply NFS4ERR_EXIST.
This commit ensures that we always present the same verifier when
replaying the OPEN.
Reported-by: Tigran Mkrtchyan <tigran.mkrtchyan@desy.de>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 0cb98abb5bd13b9a636bde603d952d722688b428 upstream.
Allow the async rpc task for finish and update the open state if needed,
then free the slot. Otherwise, the async rpc unable to decode the reply.
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Fixes: ae55e59da0e4 ("pnfs: Don't release the sequence slot...")
Cc: stable@vger.kernel.org # v4.18+
commit 994b15b983a72e1148a173b61e5b279219bb45ae upstream.
The previous fix broke recovery of delegated stateids because it assumes
that if we did not mark the delegation as suspect, then the delegation has
effectively been revoked, and so it removes that delegation irrespectively
of whether or not it is valid and still in use. While this is "mostly
harmless" for ordinary I/O, we've seen pNFS fail with LAYOUTGET spinning
in an infinite loop while complaining that we're using an invalid stateid
(in this case the all-zero stateid).
What we rather want to do here is ensure that the delegation is always
correctly marked as needing testing when that is the case. So we want
to close the loophole offered by nfs4_schedule_stateid_recovery(),
which marks the state as needing to be reclaimed, but not the
delegation that may be backing it.
Fixes: 0e3d3e5df07dc ("NFSv4.1 fix infinite loop on IO BAD_STATEID error")
Cc: stable@vger.kernel.org # v4.11+
commit 0f90be132cbf1537d87a6a8b9e80867adac892f6 upstream.
After a live data migration event at the NFS server, the client may send
I/O requests to the wrong server, causing a live hang due to repeated
recovery events. On the wire, this will appear as an I/O request failing
with NFS4ERR_BADSESSION, followed by successful CREATE_SESSION, repeatedly.
NFS4ERR_BADSSESSION is returned because the session ID being used was
issued by the other server and is not valid at the old server.
The failure is caused by async worker threads having cached the transport
(xprt) in the rpc_task structure. After the migration recovery completes,
the task is redispatched and the task resends the request to the wrong
server based on the old value still present in tk_xprt.
The solution is to recompute the tk_xprt field of the rpc_task structure
so that the request goes to the correct server.
Signed-off-by: Bill Baker <bill.baker@oracle.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Helen Chao <helen.chao@oracle.com>
Fixes: fb43d17210ba ("SUNRPC: Use the multipath iterator to assign a ...")
Cc: stable@vger.kernel.org # v4.9+
[ Upstream commit ae55e59da0e401893b3c52b575fc18a00623d0a1 ]
If the server recalls the layout that was just handed out, we risk hitting
a race as described in RFC5661 Section 2.10.6.3 unless we ensure that we
release the sequence slot after processing the LAYOUTGET operation that
was sent as part of the OPEN compound.
[ Upstream commit dce2630c7da73b0634686bca557cc8945cc450c8 ]
There are 2 comments in the NFSv4 code which suggest that
SIGLOST should possibly be sent to a process. In these
cases a lock has been lost.
The current practice is to set NFS_LOCK_LOST so that
read/write returns EIO when a lock is lost.
So change these comments to code when sets NFS_LOCK_LOST.
One case is when lock recovery after apparent server restart
fails with NFS4ERR_DENIED, NFS4ERR_RECLAIM_BAD, or
NFS4ERRO_RECLAIM_CONFLICT. The other case is when a lock
attempt as part of lease recovery fails with NFS4ERR_DENIED.
In an ideal world, these should not happen. However I have
a packet trace showing an NFSv4.1 session getting
NFS4ERR_BADSESSION after an extended network parition. The
NFSv4.1 client treats this like server reboot until/unless
it get NFS4ERR_NO_GRACE, in which case it switches over to
"nograce" recovery mode. In this network trace, the client
attempts to recover a lock and the server (incorrectly)
reports NFS4ERR_DENIED rather than NFS4ERR_NO_GRACE. This
leads to the ineffective comment and the client then
continues to write using the OPEN stateid.
Signed-off-by: NeilBrown <neilb@suse.com>
[ Upstream commit f4b23de3dda1536590787c9e5c3d16b8738ab108 ]
It turns out the Linux server has a bug in its implementation of
supattr_exclcreat; it returns the set of all attributes, whether
or not they are supported by minor version 1.
In order to avoid a regression, we therefore apply the supported_attrs
as a mask on top of whatever the server sent us.
Reported-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit 0048fdd06614a4ea088f9fcad11511956b795698 ]
If the server returns NFS4ERR_CONN_NOT_BOUND_TO_SESSION because we
are trunking, then RECLAIM_COMPLETE must handle that by calling
nfs4_schedule_session_recovery() and then retrying.
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 4b09ec4b14a168bf2c687e1f598140c3c11e9222 ]
I have reports of a crash that look like __fput() was called twice for
a NFSv4.0 file. It seems possible that the state manager could try to
reclaim a lock and take a reference on the fl->fl_file at the same time the
file is being released if, during the close(), a signal interrupts the wait
for outstanding IO while removing locks which then skips the removal
of that lock.
Since 83bfff23e9ed ("nfs4: have do_vfs_lock take an inode pointer") has
removed the need to traverse fl->fl_file->f_inode in nfs4_lock_done(),
taking that reference is no longer necessary.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
commit c05cefcc72416a37eba5a2b35f0704ed758a9145 upstream.
Before traversing a referral and performing a mount, the mounted-on
directory looks strange:
dr-xr-xr-x. 2 4294967294 4294967294 0 Dec 31 1969 dir.0
nfs4_get_referral is wiping out any cached attributes with what was
returned via GETATTR(fs_locations), but the bit mask for that
operation does not request any file attributes.
Retrieve owner and timestamp information so that the memcpy in
nfs4_get_referral fills in more attributes.
Changes since v1:
- Don't request attributes that the client unconditionally replaces
- Request only MOUNTED_ON_FILEID or FILEID attribute, not both
- encode_fs_locations() doesn't use the third bitmask word
Fixes: 6b97fd3da1ea ("NFSv4: Follow a referral")
Suggested-by: Pradeep Thomas <pradeepthomas@gmail.com>
commit fd40559c8657418385e42f797e0b04bfc0add748 upstream.
The verifier is allocated on the stack, but the EXCHANGE_ID RPC call was
changed to be asynchronous by commit 8d89bd70bc939. If we interrrupt
the call to rpc_wait_for_completion_task(), we can therefore end up
transmitting random stack contents in lieu of the verifier.
Fixes: 8d89bd70bc939 ("NFS setup async exchange_id")
commit b7dbcc0e433f0f61acb89ed9861ec996be4f2b38 upstream.
nfs4_retry_setlk() sets the task's state to TASK_INTERRUPTIBLE within the
same region protected by the wait_queue's lock after checking for a
notification from CB_NOTIFY_LOCK callback. However, after releasing that
lock, a wakeup for that task may race in before the call to
freezable_schedule_timeout_interruptible() and set TASK_WAKING, then
freezable_schedule_timeout_interruptible() will set the state back to
TASK_INTERRUPTIBLE before the task will sleep. The result is that the task
will sleep for the entire duration of the timeout.
Since we've already set TASK_INTERRUPTIBLE in the locked section, just use
freezable_schedule_timout() instead.
Fixes: a1d617d8f134 ("nfs: allow blocking locks to be awoken by lock callbacks")
commit bd171930e6a3de4f5cffdafbb944e50093dfb59b upstream.
If the task calling layoutget is signalled, then it is possible for the
calls to nfs4_sequence_free_slot() and nfs4_layoutget_prepare() to race,
in which case we leak a slot.
The fix is to move the call to nfs4_sequence_free_slot() into the
nfs4_layoutget_release() so that it gets called at task teardown time.
Fixes: 2e80dbe7ac51 ("NFSv4.1: Close callback races for OPEN, LAYOUTGET...")
commit 366a1569bff3fe14abfdf9285e31e05e091745f5 upstream.
Because nfs4_opendata_access() has close the state when access is denied,
so the state isn't leak.
Rather than revert the commit a974deee47, I'd like clean the strange state close.
[ 1615.094218] ------------[ cut here ]------------
[ 1615.094607] WARNING: CPU: 0 PID: 23702 at lib/list_debug.c:31 __list_add_valid+0x8e/0xa0
[ 1615.094913] list_add double add: new=ffff9d7901d9f608, prev=ffff9d7901d9f608, next=ffff9d7901ee8dd0.
[ 1615.095458] Modules linked in: nfsv4(E) nfs(E) nfsd(E) tun bridge stp llc fuse ip_set nfnetlink vmw_vsock_vmci_transport vsock f2fs snd_seq_midi snd_seq_midi_event fscrypto coretemp ppdev crct10dif_pclmul crc32_pclmul ghash_clmulni_intel intel_rapl_perf vmw_balloon snd_ens1371 joydev gameport snd_ac97_codec ac97_bus snd_seq snd_pcm snd_rawmidi snd_timer snd_seq_device snd soundcore nfit parport_pc parport acpi_cpufreq tpm_tis tpm_tis_core tpm i2c_piix4 vmw_vmci shpchp auth_rpcgss nfs_acl lockd(E) grace sunrpc(E) xfs libcrc32c vmwgfx drm_kms_helper ttm drm crc32c_intel mptspi e1000 serio_raw scsi_transport_spi mptscsih mptbase ata_generic pata_acpi fjes [last unloaded: nfs]
[ 1615.097663] CPU: 0 PID: 23702 Comm: fstest Tainted: G W E 4.11.0-rc1+ #517
[ 1615.098015] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
[ 1615.098807] Call Trace:
[ 1615.099183] dump_stack+0x63/0x86
[ 1615.099578] __warn+0xcb/0xf0
[ 1615.099967] warn_slowpath_fmt+0x5f/0x80
[ 1615.100370] __list_add_valid+0x8e/0xa0
[ 1615.100760] nfs4_put_state_owner+0x75/0xc0 [nfsv4]
[ 1615.101136] __nfs4_close+0x109/0x140 [nfsv4]
[ 1615.101524] nfs4_close_state+0x15/0x20 [nfsv4]
[ 1615.101949] nfs4_close_context+0x21/0x30 [nfsv4]
[ 1615.102691] __put_nfs_open_context+0xb8/0x110 [nfs]
[ 1615.103155] put_nfs_open_context+0x10/0x20 [nfs]
[ 1615.103586] nfs4_file_open+0x13b/0x260 [nfsv4]
[ 1615.103978] do_dentry_open+0x20a/0x2f0
[ 1615.104369] ? nfs4_copy_file_range+0x30/0x30 [nfsv4]
[ 1615.104739] vfs_open+0x4c/0x70
[ 1615.105106] ? may_open+0x5a/0x100
[ 1615.105469] path_openat+0x623/0x1420
[ 1615.105823] do_filp_open+0x91/0x100
[ 1615.106174] ? __alloc_fd+0x3f/0x170
[ 1615.106568] do_sys_open+0x130/0x220
[ 1615.106920] ? __put_cred+0x3d/0x50
[ 1615.107256] SyS_open+0x1e/0x20
[ 1615.107588] entry_SYSCALL_64_fastpath+0x1a/0xa9
[ 1615.107922] RIP: 0033:0x7fab599069b0
[ 1615.108247] RSP: 002b:00007ffcf0600d78 EFLAGS: 00000246 ORIG_RAX: 0000000000000002
[ 1615.108575] RAX: ffffffffffffffda RBX: 00007fab59bcfae0 RCX: 00007fab599069b0
[ 1615.108896] RDX: 0000000000000200 RSI: 0000000000000200 RDI: 00007ffcf060255e
[ 1615.109211] RBP: 0000000000040010 R08: 0000000000000000 R09: 0000000000000016
[ 1615.109515] R10: 00000000000006a1 R11: 0000000000000246 R12: 0000000000041000
[ 1615.109806] R13: 0000000000040010 R14: 0000000000001000 R15: 0000000000002710
[ 1615.110152] ---[ end trace 96ed63b1306bf2f3 ]---
Fixes: a974deee47 ("NFSv4: Fix memory and state leak in...")
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
commit 56e0d71ef12f026d96213e45a662bde6bbff4676 upstream.
If the server fails to return the attributes as part of an OPEN
reply, and then reboots, we can end up hanging. The reason is that
the client attempts to send a GETATTR in order to pick up the
missing OPEN call, but fails to release the slot first, causing
reboot recovery to deadlock.
Fixes: 2e80dbe7ac51a ("NFSv4.1: Close callback races for OPEN, LAYOUTGET...")
commit 0e3d3e5df07dcf8a50d96e0ecd6ab9a888f55dfc upstream.
Commit 63d63cbf5e03 "NFSv4.1: Don't recheck delegations that
have already been checked" introduced a regression where when a
client received BAD_STATEID error it would not send any TEST_STATEID
and instead go into an infinite loop of resending the IO that caused
the BAD_STATEID.
Fixes: 63d63cbf5e03 ("NFSv4.1: Don't recheck delegations that have already been checked")
commit 63513232f8cd219dcaa5eafae028740ed3067d83 upstream.
Since rpc_task is async, the release function should be called which
will free the impl_id, scope, and owner.
Trond pointed at 2 more problems:
-- use of client pointer after free in the nfs4_exchangeid_release() function
-- cl_count mismatch if rpc_run_task() isn't run
Fixes: 8d89bd70bc9 ("NFS setup async exchange_id")
commit ed92d8c137b7794c2c2aa14479298b9885967607 upstream.
We're not taking into account that the space needed for the (variable
length) attr bitmap, with the result that we'd sometimes get a spurious
ERANGE when the ACL data got close to the end of a page.
Just add in an extra page to make sure.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit a974deee477af89411e0f80456bfb344ac433c98 upstream.
If we exit because the file access check failed, we currently
leak the struct nfs4_state. We need to attach it to the
open context before returning.
Fixes: 3efb9722475e ("NFSv4: Refactor _nfs4_open_and_get_state..")
commit a430607b2ef7c3be090f88c71cfcb1b3988aa7c0 upstream.
Some nfsv4.0 servers may return a mode for the verifier following an open
with EXCLUSIVE4 createmode, but this does not mean the client should skip
setting the mode in the following SETATTR. It should only do that for
EXCLUSIVE4_1 or UNGAURDED createmode.
Fixes: 5334c5bdac92 ("NFS: Send attributes in OPEN request for NFS4_CREATE_EXCLUSIVE4_1")
commit 8ac092519ad91931c96d306c4bfae2c6587c325f upstream.
We cannot call nfs4_handle_exception() without first ensuring that the
slot has been freed. If not, we end up deadlocking with the process
waiting for recovery to complete, and recovery waiting for the slot
table to drain.
Pull NFS client bugfixes from Anna Schumaker:
"Most of these fix regressions or races, but there is one patch for
stable that Arnd sent me
Stable bugfix:
- Hide array-bounds warning
Bugfixes:
- Keep a reference on lock states while checking
- Handle NFS4ERR_OLD_STATEID in nfs4_reclaim_open_state
- Don't call close if the open stateid has already been cleared
- Fix CLOSE rases with OPEN
- Fix a regression in DELEGRETURN"
* tag 'nfs-for-4.9-4' of git://git.linux-nfs.org/projects/anna/linux-nfs:
NFSv4.x: hide array-bounds warning
NFSv4.1: Keep a reference on lock states while checking
NFSv4.1: Handle NFS4ERR_OLD_STATEID in nfs4_reclaim_open_state
NFSv4: Don't call close if the open stateid has already been cleared
NFSv4: Fix CLOSE races with OPEN
NFSv4.1: Fix a regression in DELEGRETURN
While walking the list of lock_states, keep a reference on each
nfs4_lock_state to be checked, otherwise the lock state could be removed
while the check performs TEST_STATEID and possible FREE_STATEID.
Ensure we test to see if the open stateid is actually set, before we
send a CLOSE.
If the reply to a successful CLOSE call races with an OPEN to the same
file, we can end up scribbling over the stateid that represents the
new open state.
The race looks like:
Client Server
CLOSE stateid A on file "foo"
CLOSE stateid A, return stateid C
OPEN file "foo"
OPEN "foo", return stateid B
Receive reply to OPEN
Reset open state for "foo"
Associate stateid B to "foo"
Receive CLOSE for A
Replace stateid B with C
The fix is to examine the argument of the CLOSE, and check for a match
with the current stateid "other" field. If the two do not match, then
the above race occurred, and we should just ignore the CLOSE.
Reported-by: Benjamin Coddington <bcodding@redhat.com>
We don't want to call nfs4_free_revoked_stateid() in the case where
the delegreturn was successful.
"Just two bugfixes this time:
Stable bugfix:
- Fix last_write_offset incorrectly set to page boundary
Other bugfix:
- Fix missing-braces warning"
* tag 'nfs-for-4.9-2' of git://git.linux-nfs.org/projects/anna/linux-nfs:
nfs4: fix missing-braces warning
pnfs/blocklayout: fix last_write_offset incorrectly set to page boundary
A bugfix introduced a harmless warning for update_open_stateid:
fs/nfs/nfs4proc.c:1548:2: error: missing braces around initializer [-Werror=missing-braces]
Removing the zero in the initializer will do the right thing here
and initialize the entire structure to zero.
Fixes: 1393d9612ba0 ("NFSv4: Fix a race when updating an open_stateid")
Pull NFS client updates from Anna Schumaker:
"Highlights include:
Stable bugfixes:
- sunrpc: fix writ espace race causing stalls
- NFS: Fix inode corruption in nfs_prime_dcache()
- NFSv4: Don't report revoked delegations as valid in nfs_have_delegation()
- NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid
- NFSv4: Open state recovery must account for file permission changes
- NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic
Features:
- Add support for tracking multiple layout types with an ordered list
- Add support for using multiple backchannel threads on the client
- Add support for pNFS file layout session trunking
- Delay xprtrdma use of DMA API (for device driver removal)
- Add support for xprtrdma remote invalidation
- Add support for larger xprtrdma inline thresholds
- Use a scatter/gather list for sending xprtrdma RPC calls
- Add support for the CB_NOTIFY_LOCK callback
- Improve hashing sunrpc auth_creds by using both uid and gid
Bugfixes:
- Fix xprtrdma use of DMA API
- Validate filenames before adding to the dcache
- Fix corruption of xdr->nwords in xdr_copy_to_scratch
- Fix setting buffer length in xdr_set_next_buffer()
- Don't deadlock the state manager on the SEQUENCE status flags
- Various delegation and stateid related fixes
- Retry operations if an interrupted slot receives EREMOTEIO
- Make nfs boot time y2038 safe"
* tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits)
fs: nfs: Make nfs boot time y2038 safe
sunrpc: replace generic auth_cred hash with auth-specific function
sunrpc: add RPCSEC_GSS hash_cred() function
sunrpc: add auth_unix hash_cred() function
sunrpc: add generic_auth hash_cred() function
sunrpc: add hash_cred() function to rpc_authops struct
Retry operation on EREMOTEIO on an interrupted slot
pNFS: Fix atime updates on pNFS clients
sunrpc: queue work on system_power_efficient_wq
NFSv4.1: Even if the stateid is OK, we may need to recover the open modes
NFSv4: If recovery failed for a specific open stateid, then don't retry
NFSv4: Fix retry issues with nfs41_test/free_stateid
NFSv4: Mark the lock and open stateids as invalid after freeing them
NFSv4: Don't test open_stateid unless it is set
NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation
NFSv4: Fix a race in nfs_inode_reclaim_delegation()
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
boot_time is represented as a struct timespec.
struct timespec and CURRENT_TIME are not y2038 safe.
Overall, the plan is to use timespec64 and ktime_t for
all internal kernel representation of timestamps.
CURRENT_TIME will also be removed.
boot_time is used to construct the nfs client boot verifier.
Use ktime_t to represent boot_time and ktime_get_real() for
the boot_time value.
Following Trond's request https://lkml.org/lkml/2016/6/9/22 ,
use ktime_t instead of converting to struct timespec64.
Use higher and lower 32 bit parts of ktime_t for the boot
verifier.
Use the lower 32 bit part of ktime_t for the authsys_parms
stamp field.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Cc: linux-nfs@vger.kernel.org
If an operation got interrupted, then since we don't know if the
server processed it on not, we keep the seq#. Upon reuse of slot
and seq# if we get reply from the cache (ie EREMOTEIO) then we
need to retry the operation after bumping the seq#
Fix the code so that we always mark the atime as invalid in nfs4_read_done().
Currently, the expectation appears to be that the pNFS drivers should always
do this, with the result that most of them don't.
TEST_STATEID only tells you that you have a valid open stateid. It doesn't
tell the client anything about whether or not it holds the required share
locks.
Tested-by: Oleg Drokin <green@linuxhacker.ru>
[Anna: Wrap nfs_open_stateid_recover_openmode in CONFIG_NFS_V4_1 checks]
_nfs41_free_stateid() needs to be cached by the session, but
nfs41_test_stateid() may return NFS4ERR_RETRY_UNCACHED_REP (in which
case we should just retry).
We need to test the NFS_OPEN_STATE flag for whether or not the
open_stateid is valid.
If we're not yet sure that all state has expired or been revoked, we
should try to do a minimal recovery on just the one stateid.
If we're replacing an old stateid which has a different 'other' field,
then we probably need to free the old stateid.
The actual stateid used in the READ or WRITE can represent a delegation,
a lock or a stateid, so it is useful to pass it as an argument to the
exception handler when an expired/revoked response is received from the
server. It also ensures that we don't re-label the state as needing
recovery if that has already occurred.
Handle revoked open/lock/delegation stateids when LAYOUTGET tells us
the state was revoked.
If the server tells us our stateid has expired, then handle that as if
it was revoked.
it was revoked.
If a server returns NFS4ERR_ADMIN_REVOKED, NFS4ERR_DELEG_REVOKED
or NFS4ERR_EXPIRED on a call to close, open_downgrade, delegreturn, or
locku, we should call FREE_STATEID before attempting to recover.
Nothing should need to be serialised with FREE_STATEID on the client,
so let's make the RPC call always asynchronous. Also constify the
stateid argument.
Right now, we're only running TEST/FREE_STATEID on the locks if
the open stateid recovery succeeds. The protocol requires us to
always do so.
The fix would be to move the call to TEST/FREE_STATEID and do it
before we attempt open recovery.
In some cases (e.g. when the SEQ4_STATUS_EXPIRED_ALL_STATE_REVOKED sequence
flag is set) we may already know that the stateid was revoked and that the
only valid operation we can call is FREE_STATEID. In those cases, allow
the stateid to carry the information in the type field, so that we skip
the redundant call to TEST_STATEID.
