path: root/fs/nfs/nfs4filelayoutdev.c
2014-05-29Push the file layout driver into a subdirectoryTom Haynes
The object and block layouts already exist in their own subdirectories. This patch completes the set! Note that as a layout denotes nfs4 already, I stripped that prefix out of the file names. Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com> Acked-by: Jeff Layton <jlayton@poochiereds.net> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-05nfs: fix dead code of ipv6_addr_scopeAlexander Aring
The correct way to check on IPV6_ADDR_SCOPE_LINKLOCAL is to check with the ipv6_addr_src_scope function. Currently this can't be work, because ipv6_addr_scope returns a int with a mask of IPV6_ADDR_SCOPE_MASK (0x00f0U) and IPV6_ADDR_SCOPE_LINKLOCAL is 0x02. So the condition is always false. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2013-09-29NFSv4.1: Ensure memory ordering between nfs4_ds_connect and nfs4_fl_prepare_dsTrond Myklebust
We need to ensure that the initialisation of the data server nfs_client structure in nfs4_ds_connect is correctly ordered w.r.t. the read of ds->ds_clp in nfs4_fl_prepare_ds. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-29NFSv4.1: nfs4_fl_prepare_ds - fix bugs when the connect attempt failsTrond Myklebust
- Fix an Oops when nfs4_ds_connect() returns an error. - Always check the device status after waiting for a connect to complete. Reported-by: Andy Adamson <andros@netapp.com> Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: <stable@vger.kernel.org> # v3.10+
2013-06-28NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesizeAndy Adamson
The GETDEVICEINFO gdia_maxcount represents all of the data being returned within the GETDEVICEINFO4resok structure and includes the XDR overhead. The CREATE_SESSION ca_maxresponsesize is the maximum reply and includes the RPC headers (including security flavor credentials and verifiers). Split out the struct pnfs_device field maxcount which is the gdia_maxcount from the pglen field which is the reply (the total) buffer length. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-06-06NFSv4.1: Use layout credentials for get_deviceinfo callsTrond Myklebust
This is not strictly needed, since get_deviceinfo is not allowed to return NFS4ERR_ACCESS or NFS4ERR_WRONG_CRED, but lets do it anyway for consistency with other pNFS operations. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-05-08NFS4.1 Fix data server connection raceAndy Adamson
Unlike meta data server mounts which support multiple mount points to the same server via struct nfs_server, data servers support a single connection. Concurrent calls to setup the data server connection can race where the first call allocates the nfs_client struct, and before the cache struct nfs_client pointer can be set, a second call also tries to setup the connection, finds the already allocated nfs_client, bumps the reference count, re-initializes the session,etc. This results in a hanging data server session after umount. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-02-05sunrpc: move address copy/cmp/convert routines and prototypes from clnt.h to ↵Jeff Layton
addr.h These routines are used by server and client code, so having them in a separate header would be best. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-12-06NFSv4.1: Cleanup move session slot management to fs/nfs/nfs4session.cTrond Myklebust
NFSv4.1 session management is getting complex enough to deserve a separate file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-11-04NFSv4.1: Remove assertion BUG_ON()s from the files and generic layout codeTrond Myklebust
2012-10-15NFSv4.1: Kill nfs4_ds_disconnect()Trond Myklebust
There is nothing to prevent another thread from dereferencing ds->ds_clp during or after the call to nfs4_ds_disconnect(), and Oopsing due to the resulting NULL pointer. Instead, we should just rely on filelayout_mark_devid_invalid() to keep us out of trouble by avoiding that deviceid. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-09-28NFSv4.1: pNFS data servers may be temporarily offlineTrond Myklebust
In cases where the pNFS data server is just temporarily out of service, we want to mark it as such, and then try again later. Typically that will be in cases of network connection errors etc. This patch allows us to mark the devices as being "unavailable" for such transient errors, and will make them available for retries after a 2 minute timeout period. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-09-28NFSv4.1: Replace get_device_info() with filelayout_get_device_info()Trond Myklebust
Fix the namespace pollution issue. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-28NFSv4.1: Use session max response size for GETDEVICEINFO gdia_maxcountAndy Adamson
We prepare for the largest possible GETDEVICEINFO response, which can not be greater than the negotiated session maximum response size. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-23NFSv4.1: Fix session initialisation racesTrond Myklebust
Session initialisation is not complete until the lease manager has run. We need to ensure that both nfs4_init_session and nfs4_init_ds_session do so, and that they check for any resulting errors in clp->cl_cons_state. Only after this is done, can nfs4_ds_connect check the contents of clp->cl_exchange_flags. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Andy Adamson <andros@netapp.com>
2012-05-22NFS: Use proper naming conventions for the nfs_client.net fieldChuck Lever
Clean up: When naming fields and data types, follow established conventions to facilitate accurate grep/cscope searches. Introduced by commit e50a7a1a "NFS: make NFS client allocated per network namespace context," Tue Jan 10, 2012. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-19NFSv4.1 dereference a disconnected data server client recordAndy Adamson
When the last DS io is processed, the data server client record will be freed. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-19NFSv4.1 data server timeo and retrans module parametersAndy Adamson
Set the recovery parameters for data servers. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-19NFSv4.1: cleanup filelayout invalid deviceid handlingAndy Adamson
Move the invalid deviceid test into nfs4_fl_prepare_ds, called by the filelayout read, write, and commit routines. NFS4_DEVICE_ID_NEG_ENTRY is no longer needed. Remove redundant printk's - filelayout_mark_devid_invalid prints a KERN_WARNING. An invalid device prevents pNFS io. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-04-26NFSv4.1 fix page number calculation bug for filelayout decode buffersAndy Adamson
2012-03-11NFS: Fix a number of sparse warningsTrond Myklebust
Fix a number of "warning: symbol 'foo' was not declared. Should it be static?" conditions. Fix 2 cases of "warning: Using plain integer as NULL pointer" fs/nfs/delegation.c:263:31: warning: restricted fmode_t degrades to integer - We want to allow upgrades to a WRITE delegation, but should otherwise consider servers that hand out duplicate delegations to be borken. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: Fix comparison between DS address listsWeston Andros Adamson
data_server_cache entries should only be treated as the same if the address list hasn't changed. A new entry will be made when an MDS changes an address list (as seen by GETDEVINFO). The old entry will be freed once all references are gone. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: start printks w/ NFS: even if __func__ shownWeston Andros Adamson
This patch addresses printks that have some context to show that they are from fs/nfs/, but for the sake of consistency now start with NFS: Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-31NFS: decode destination address in proper network namespace contextStanislav Kinsbursky
This patch replaces "init_net" with NFS client's owner net in rpc_pton() call in decode_ds_addr(). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-31SUNRPC: parametrize rpc_pton() by network contextStanislav Kinsbursky
Parametrize rpc_pton() by network context and thus force it's callers to pass in network context instead of using hard-coded "init_net". Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-12NFS: cleanup endian type in decode_ds_addr()Dan Carpenter
port is supposed to be a __be16 here. The existing code should work fine, but this is a cleanup. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: fix commentWeston Andros Adamson
We support IPv4 and IPv6 now. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: pnfs: loop over multipath addrs on connectWeston Andros Adamson
Don't just use the first addr in the multipath list - instead, loop over addresses when calling nfs4_set_ds_client() (which calls connect) until it is successful. Although this is not real multipath support, it's a quick fix to handle when an MDS sends a list of addresses for a DS and some of the addr families are unsupported or misconfigured (like no routable ipv6 addr assigned). This will attempt all paths to the DS before giving up, instead of immediately falling back to the MDS. As before, an error encountered after a successful connect() will cause all i/o to fall back to the MDS. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: Parse and store all multipath DS addressesWeston Andros Adamson
This parses and stores all addresses associated with each data server, laying the groundwork for supporting multipath to data servers. - Skips over addresses that cannot be parsed (ie IPv6 addrs if v6 is not enabled). Only fails if none of the addresses are recognizable - Currently only uses the first address that parsed cleanly - Tested against pynfs server (modified to support multipath) Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: pnfs IPv6 supportWeston Andros Adamson
Handle ipv6 remote addresses from GETDEVICEINFO - supports netid "tcp" for ipv4 and "tcp6" for ipv6 as rfc 5665 specifies - added ds_remotestr to avoid having to handle different AFs in every dprintk - tested against pynfs 4.1 server, submitting ipv6 support patch to pynfs - tested with IPv6 disabled, it compiles cleanly and relies on rpc_pton to refuse to accept IPv6 addresses Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-29SUNRPC: introduce xdr_init_decode_pagesBenny Halevy
Initialize xdr_stream and xdr_buf using an array of page pointers and length of buffer. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29NFSv4.1: purge deviceid cache on nfs_free_clientBenny Halevy
Use the pnfs_layoutdriver_type both as a qualifier for the deviceid, distinguishing deviceid from different layout types on the server, and for freeing the layout-driver allocated structure containing the nfs4_deviceid_node. [BUG in _deviceid_purge_client] [layout_driver MUST set free_deviceid_node if using dev-cache] [let ver < 4.1 compile] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> [removed EXPORT_SYMBOL_GPL(nfs4_deviceid_purge_client)] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29NFSv4.1: make deviceid cache globalBenny Halevy
Move deviceid cache from the pnfs files layout driver to the generic layer in preparation for the objects layout driver. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29NFSv4.1: use struct nfs_client to qualify deviceidBenny Halevy
deviceids are unique per server, per layout type. Therefore, in the global cache in the files layout driver deviceids from different servers may clash so we need to qualify them with a struct nfs_client that represents the nfs server that returned the deviceid. Introduced in 2.6.39 commit ea8eecdd "NFSv4.1 move deviceid cache to filelayout driver" Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-11NFSv4.1: Ensure that layoutget uses the correct gfp modesTrond Myklebust
Currently, writebacks may end up recursing back into the filesystem due to GFP_KERNEL direct reclaims in the pnfs subsystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-24Cleanup XDR parsing for LAYOUTGET, GETDEVICEINFOWeston Andros Adamson
changes LAYOUTGET and GETDEVICEINFO XDR parsing to: - not use vmap, which doesn't work on incoherent archs - use xdr_stream parsing for all xdr Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: turn off pNFS on ds connection failureAndy Adamson
If a data server is unavailable, go through MDS. Mark the deviceid containing the data server as a negative cache entry. Do not try to connect to any data server on a deviceid marked as a negative cache entry. Mark any layout that tries to use the marked deviceid as failed. Inodes with a layout marked as fails will not use the layout for I/O, and will not perform any more layoutgets. Inodes without a layout will still do layoutget, but the layout will get marked immediately. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1 move deviceid cache to filelayout driverChristoph Hellwig
No need for generic cache with only one user. Keep a simple hash of deviceids in the filelayout driver. Signed-off-by: Christoph Hellwig <hch@infradead.org> Acked-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: filelayout i/o helpersFred Isaman
Prepare for filelayout_read_pagelist with helper functions that find the correct data server, filehandle, and offset. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Tigran Mkrtchyan <tigran@anahit.desy.de> Signed-off-by: Tigran Mkrtchyan <tigran.mkrtchyan@desy.de> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: data server connectionAndy Adamson
Introduce a data server set_client and init session following the nfs4_set_client and nfs4_init_session convention. Once a new nfs_client is on the nfs_client_list, the nfs_client cl_cons_state serializes access to creating an nfs_client struct with matching properties. Use the new nfs_get_client() that initializes new clients. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-10nfs: add kmalloc return value check in decode_and_add_dsStanislav Fomichev
add kmalloc return value check in decode_and_add_ds Signed-off-by: Stanislav Fomichev <kernel@fomichev.me> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS4: Avoid potential NULL pointer dereference in decode_and_add_ds().Jesper Juhl
On Mon, 17 Jan 2011, Mi Jinlong wrote: > > > Jesper Juhl: > > strrchr() can return NULL if nothing is found. If this happens we'll > > dereference a NULL pointer in > > fs/nfs/nfs4filelayoutdev.c::decode_and_add_ds(). > > > > I tried to find some other code that guarantees that this can never > > happen but I was unsuccessful. So, unless someone else can point to some > > code that ensures this can never be a problem, I believe this patch is > > needed. > > > > While I was changing this code I also noticed that all the dprintk() > > statements, except one, start with "%s:". The one missing the ":" I added > > it to. > > Maybe another one also should be changed at decode_and_add_ds() at line 243: > > 243 printk("%s Decoded address and port %s\n", __func__, buf); > Missed that one. Thanks. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO ↵Andy Adamson
infrastructure Implement the driver's io_ops->alloc_lseg and free_lseg functions, which integrate into the deviceid cache and calls out to nfs4_proc_getdeviceinfo when necessary. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
