path: root/fs/nfs/nfs4_fs.h
2008-12-30fs/nfs/nfs4proc.c: make nfs4_map_errors() staticWANG Cong
nfs4_map_errors() can become static. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Convert the open and close ops to use fmodeTrond Myklebust
2008-12-23NFSv4: Clean up nfs_expire_all_delegations()Trond Myklebust
Let the actual delegreturn stuff be run in the state manager thread rather than allocating a separate kthread. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Rename the state reclaimer threadTrond Myklebust
It is really a more general purpose state management thread at this point. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Clean up NFS4ERR_CB_PATH_DOWN error management...Trond Myklebust
Add a delegation cleanup phase to the state management loop, and do the NFS4ERR_CB_PATH_DOWN recovery there. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Add recovery for individual stateidsTrond Myklebust
NFSv4 defines a number of state errors which the client does not currently handle. Among those we should worry about are: NFS4ERR_ADMIN_REVOKED - the server's administrator revoked our locks and/or delegations. NFS4ERR_BAD_STATEID - the client and server are out of sync, possibly due to a delegation return racing with an OPEN request. NFS4ERR_OPENMODE - the client attempted to do something not sanctioned by the open mode of the stateid. Should normally just occur as a result of a delegation return race. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Add a recovery marking scheme for state ownersTrond Myklebust
2008-12-23NFSv4: Remove redundant RENEW calls if we know the lease has expiredTrond Myklebust
2008-12-23NFSv4: Fix state recovery when the client runs over the grace periodTrond Myklebust
If the client for some reason is not able to recover all its state within the time allotted for the grace period, and the server reboots again, the client is not allowed to recover the state that was 'lost' using reboot recovery. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Callers to nfs4_get_renew_cred() need to hold nfs_client->cl_lockTrond Myklebust
Ditto for nfs4_get_setclientid_cred(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: make nfs4_drop_state_owner() staticAdrian Bunk
nfs4_drop_state_owner() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-10NFSv4: Give the lock stateid its own sequence queueTrond Myklebust
Sharing the open sequence queue causes a deadlock when we try to take both a lock sequence id and and open sequence id. This fixes the regression reported by Dimitri Puzin and Jeff Garzik: See http://bugzilla.kernel.org/show_bug.cgi?id=9712 for details. Reported-and-tested-by: Dimitri Puzin <bugs@psycast.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19nfs: Fix build break with CONFIG_NFS_V4=nOlof Johansson
Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19NFSv4: Ensure that we wait for the CLOSE request to completeTrond Myklebust
Otherwise, we do end up breaking close-to-open semantics. We also end up breaking some of the silly-rename tests in Connectathon on some setups. Please refer to the bug-report at http://bugzilla.linux-nfs.org/show_bug.cgi?id=150 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19NFSv4: 'constify' lookup arguments.Trond Myklebust
2007-07-10NFSv4: Make the NFS state model work with the nosharedcache mount optionTrond Myklebust
Consider the case where the user has mounted the remote filesystem server:/foo on the two local directories /bar and /baz using the nosharedcache mount option. The files /bar/file and /baz/file are represented by different inodes in the local namespace, but refer to the same file /foo/file on the server. Consider the case where a process opens both /bar/file and /baz/file, then closes /bar/file: because the nfs4_state is not shared between /bar/file and /baz/file, the kernel will see that the nfs4_state for /bar/file is no longer referenced, so it will send off a CLOSE rpc call. Unless the open_owners differ, then that CLOSE call will invalidate the open state on /baz/file too. Conclusion: we cannot share open state owners between two different non-shared mount instances of the same filesystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFSv4: Fix up stateid locking...Trond Myklebust
We really don't need to grab both the state->so_owner and the inode->i_lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFSv4: Always use the delegation if we have oneTrond Myklebust
2007-07-10NFSv4: Reduce the chances of an open_owner identifier collisionTrond Myklebust
Currently we just use a 32-bit counter. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFSv4: Ensure that nfs4_do_close() doesn't race with umountTrond Myklebust
nfs4_do_close() does not currently have any way to ensure that the user won't attempt to unmount the partition while the asynchronous RPC call is completing. This again may cause Oopses in nfs_update_inode(). Add a vfsmount argument to nfs4_close_state to ensure that the partition remains mounted while we're closing the file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-12Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: net/sunrpc/auth_gss/gss_krb5_crypto.c net/sunrpc/auth_gss/gss_spkm3_token.c net/sunrpc/clnt.c Merge with mainline and fix conflicts.
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-03NFSv4: Cleanups for fs_locations code.Trond Myklebust
Start long arduous project... What the hell is struct dentry = {}; all about? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-20[PATCH] xdr annotations: NFS readdir entriesAl Viro
on-the-wire data is big-endian [in large part pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: Share NFS superblocks per-protocol per-server per-FSIDDavid Howells
The attached patch makes NFS share superblocks between mounts from the same server and FSID over the same protocol. It does this by creating each superblock with a false root and returning the real root dentry in the vfsmount presented by get_sb(). The root dentry set starts off as an anonymous dentry if we don't already have the dentry for its inode, otherwise it simply returns the dentry we already have. We may thus end up with several trees of dentries in the superblock, and if at some later point one of anonymous tree roots is discovered by normal filesystem activity to be located in another tree within the superblock, the anonymous root is named and materialises attached to the second tree at the appropriate point. Why do it this way? Why not pass an extra argument to the mount() syscall to indicate the subpath and then pathwalk from the server root to the desired directory? You can't guarantee this will work for two reasons: (1) The root and intervening nodes may not be accessible to the client. With NFS2 and NFS3, for instance, mountd is called on the server to get the filehandle for the tip of a path. mountd won't give us handles for anything we don't have permission to access, and so we can't set up NFS inodes for such nodes, and so can't easily set up dentries (we'd have to have ghost inodes or something). With this patch we don't actually create dentries until we get handles from the server that we can use to set up their inodes, and we don't actually bind them into the tree until we know for sure where they go. (2) Inaccessible symbolic links. If we're asked to mount two exports from the server, eg: mount warthog:/warthog/aaa/xxx /mmm mount warthog:/warthog/bbb/yyy /nnn We may not be able to access anything nearer the root than xxx and yyy, but we may find out later that /mmm/www/yyy, say, is actually the same directory as the one mounted on /nnn. What we might then find out, for example, is that /warthog/bbb was actually a symbolic link to /warthog/aaa/xxx/www, but we can't actually determine that by talking to the server until /warthog is made available by NFS. This would lead to having constructed an errneous dentry tree which we can't easily fix. We can end up with a dentry marked as a directory when it should actually be a symlink, or we could end up with an apparently hardlinked directory. With this patch we need not make assumptions about the type of a dentry for which we can't retrieve information, nor need we assume we know its place in the grand scheme of things until we actually see that place. This patch reduces the possibility of aliasing in the inode and page caches for inodes that may be accessed by more than one NFS export. It also reduces the number of superblocks required for NFS where there are many NFS exports being used from a server (home directory server + autofs for example). This in turn makes it simpler to do local caching of network filesystems, as it can then be guaranteed that there won't be links from multiple inodes in separate superblocks to the same cache file. Obviously, cache aliasing between different levels of NFS protocol could still be a problem, but at least that gives us another key to use when indexing the cache. This patch makes the following changes: (1) The server record construction/destruction has been abstracted out into its own set of functions to make things easier to get right. These have been moved into fs/nfs/client.c. All the code in fs/nfs/client.c has to do with the management of connections to servers, and doesn't touch superblocks in any way; the remaining code in fs/nfs/super.c has to do with VFS superblock management. (2) The sequence of events undertaken by NFS mount is now reordered: (a) A volume representation (struct nfs_server) is allocated. (b) A server representation (struct nfs_client) is acquired. This may be allocated or shared, and is keyed on server address, port and NFS version. (c) If allocated, the client representation is initialised. The state member variable of nfs_client is used to prevent a race during initialisation from two mounts. (d) For NFS4 a simple pathwalk is performed, walking from FH to FH to find the root filehandle for the mount (fs/nfs/getroot.c). For NFS2/3 we are given the root FH in advance. (e) The volume FSID is probed for on the root FH. (f) The volume representation is initialised from the FSINFO record retrieved on the root FH. (g) sget() is called to acquire a superblock. This may be allocated or shared, keyed on client pointer and FSID. (h) If allocated, the superblock is initialised. (i) If the superblock is shared, then the new nfs_server record is discarded. (j) The root dentry for this mount is looked up from the root FH. (k) The root dentry for this mount is assigned to the vfsmount. (3) nfs_readdir_lookup() creates dentries for each of the entries readdir() returns; this function now attaches disconnected trees from alternate roots that happen to be discovered attached to a directory being read (in the same way nfs_lookup() is made to do for lookup ops). The new d_materialise_unique() function is now used to do this, thus permitting the whole thing to be done under one set of locks, and thus avoiding any race between mount and lookup operations on the same directory. (4) The client management code uses a new debug facility: NFSDBG_CLIENT which is set by echoing 1024 to /proc/net/sunrpc/nfs_debug. (5) Clone mounts are now called xdev mounts. (6) Use the dentry passed to the statfs() op as the handle for retrieving fs statistics rather than the root dentry of the superblock (which is now a dummy). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Generalise the nfs_client structureDavid Howells
Generalise the nfs_client structure by: (1) Moving nfs_client to a more general place (nfs_fs_sb.h). (2) Renaming its maintenance routines to be non-NFS4 specific. (3) Move those maintenance routines to a new non-NFS4 specific file (client.c) and move the declarations to internal.h. (4) Make nfs_find/get_client() take a full sockaddr_in to include the port number (will be required for NFS2/3). (5) Make nfs_find/get_client() take the NFS protocol version (again will be required to differentiate NFS2, 3 & 4 client records). Also: (6) Make nfs_client construction proceed akin to inodes, marking them as under construction and providing a function to indicate completion. (7) Make nfs_get_client() wait interruptibly if it finds a client that it can share, but that client is currently being constructed. (8) Make nfs4_create_client() use (6) and (7) instead of locking cl_sem. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Rename struct nfs4_client to struct nfs_clientDavid Howells
Rename struct nfs4_client to struct nfs_client so that it can become the basis for a general client record for NFS2 and NFS3 in addition to NFS4. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFSv4: Define an fs_locations bitmapManoj Naik
This is (similar to getattr bitmap) but includes fs_locations and mounted_on_fileid attributes. Use this bitmap for encoding in fs_locations requests. Note: We can probably do better by requesting locations as part of fsinfo itself. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFSv4: convert fs-locations-components to conform to RFC3530Manoj Naik
Use component4-style formats for decoding list of servers and pathnames in fs_locations. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFSv4: Implement the fs_locations function callTrond Myklebust
NFSv4 allows for the fact that filesystems may be replicated across several servers or that they may be migrated to a backup server in case of failure of the primary server. fs_locations is an NFSv4 operation for retrieving information about the location of migrated and/or replicated filesystems. Based on an initial implementation by Jiaying Zhang <jiayingz@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Ensure the client submounts, when it crosses a server mountpoint.Trond Myklebust
2006-01-06NFSv4: Remove requirement for machine creds for the "setclientid" operationTrond Myklebust
Use a cred from the nfs4_client->cl_state_owners list. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Remove requirement for machine creds for the "renew" operationTrond Myklebust
In RFC3530, the RENEW operation is allowed to use either the same principal, RPC security flavour and (if RPCSEC_GSS), the same mechanism and service that was used for SETCLIENTID_CONFIRM OR Any principal, RPC security flavour and service combination that currently has an OPEN file on the server. Choose the latter since that doesn't require us to keep credentials for the same principal for the entire duration of the mount. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Send RENEW requests to the server only when we're holding stateTrond Myklebust
2006-01-06NFSv4: State recovery cleanupTrond Myklebust
Use wait_on_bit() when waiting for state recovery to complete. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Make nfs4_state track O_RDWR, O_RDONLY and O_WRONLY separatelyTrond Myklebust
A closer reading of RFC3530 reveals that OPEN_DOWNGRADE must always specify a access modes that have been the argument of a previous OPEN operation. IOW: doing OPEN(O_RDWR) and then OPEN_DOWNGRADE(O_WRONLY) is forbidden unless the user called OPEN(O_WRONLY) In order to fix that, we really need to track the three possible open states separately. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix problem with OPEN_DOWNGRADETrond Myklebust
RFC 3530 states that for OPEN_DOWNGRADE "The share_access and share_deny bits specified must be exactly equal to the union of the share_access and share_deny bits specified for some subset of the OPENs in effect for current openowner on the current file. Setattr is currently violating the NFSv4 rules for OPEN_DOWNGRADE in that it may cause a downgrade from OPEN4_SHARE_ACCESS_BOTH to OPEN4_SHARE_ACCESS_WRITE despite the fact that there exists no open file with O_WRONLY access mode. Fix the problem by replacing nfs4_find_state() with a modified version of nfs_find_open_context(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix a race between open() and close()Trond Myklebust
We must not remove the nfs4_state structure from the inode open lists before we are in sequence lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-20NFSv4: Fix up locking for nfs4_state_ownerTrond Myklebust
2005-10-20NFSv4: Final tweak to sequence idTrond Myklebust
Sacrifice queueing fairness for performance. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Fix an oopsable condition in nfs_free_seqidTrond Myklebust
Storing a pointer to the struct rpc_task in the nfs_seqid is broken since the nfs_seqid may be freed well after the task has been destroyed. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Eliminate nfsv4 open race...Trond Myklebust
Make NFSv4 return the fully initialized file pointer with the stateid that it created in the lookup w/intent. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Make NFS clean up byte range locks asynchronouslyTrond Myklebust
Currently we fail to do so if the process was signalled. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Remove obsolete state_owner and lock_owner semaphoresTrond Myklebust
OPEN, CLOSE, etc no longer need these semaphores to ensure ordering of requests. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Add functions to order RPC callsTrond Myklebust
NFSv4 file state-changing functions such as OPEN, CLOSE, LOCK,... are all labelled with "sequence identifiers" in order to prevent the server from reordering RPC requests, as this could cause its file state to become out of sync with the client. Currently the NFS client code enforces this ordering locally using semaphores to restrict access to structures until the RPC call is done. This, of course, only works with synchronous RPC calls, since the user process must first grab the semaphore. By dropping semaphores, and instead teaching the RPC engine to hold the RPC calls until they are ready to be sent, we can extend this process to work nicely with asynchronous RPC calls too. This patch adds a new list called "rpc_sequence" that defines the order of the RPC calls to be sent. We add one such list for each state_owner. When an RPC call is ready to be sent, it checks if it is top of the rpc_sequence list. If so, it proceeds. If not, it goes back to sleep, and loops until it hits top of the list. Once the RPC call has completed, it can then bump the sequence id counter, and remove itself from the rpc_sequence list, and then wake up the next sleeper. Note that the state_owner sequence ids and lock_owner sequence ids are all indexed to the same rpc_sequence list, so OPEN, LOCK,... requests are all ordered w.r.t. each other. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Clean up nfs4 lock state accountingTrond Myklebust
Ensure that lock owner structures are not released prematurely. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix build warningReuben Farrelly
From: Reuben Farrelly <reuben-lkml@reub.net> With gcc-4.0: fs/nfs/nfs4proc.c:2976: error: static declaration of 'nfs4_file_inode_operations' follows non-static declaration fs/nfs/nfs4_fs.h:179: error: previous declaration of 'nfs4_file_inode_operations' was here Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Add {get,set,list}xattr methods for nfs4J. Bruce Fields
Add {get,set,list}xattr methods for nfs4. The new methods are no-ops, to be used by subsequent ACL patch. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Header file cleanup...Trond Myklebust
- Move NFSv4 state definitions into a private header file. - Clean up gunk in nfs_fs.h Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
