path: root/fs/nfs/netns.h
2012-10-02nfs: include NFSv4 header in netns.hStanislav Kinsbursky
Build error: fs/nfs/netns.h:27:15: error: 'NFS4_MAX_MINOR_VERSION' undeclared here (not in a function) Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-10-01NFS: callback per-net usage counting introducedStanislav Kinsbursky
This patch also introduces refcount-aware nfs_callback_down_net() wrapper for svc_shutdown_net(). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-10-01NFS: make nfs_callback_tcpport6 per network contextStanislav Kinsbursky
2012-10-01NFS: make nfs_callback_tcpport per network contextStanislav Kinsbursky
2012-07-30NFS: Convert v4 into a moduleBryan Schumaker
This patch exports symbols needed by the v4 module. In addition, I also switch over to using IS_ENABLED() to check if CONFIG_NFS_V4 or CONFIG_NFS_V4_MODULE are set. The module (nfs4.ko) will be created in the same directory as nfs.ko and will be automatically loaded the first time you try to mount over NFS v4. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-22NFS: Always use the same SETCLIENTID boot verifierChuck Lever
Currently our NFS client assigns a unique SETCLIENTID boot verifier for each server IP address it knows about. It's set to CURRENT_TIME when the struct nfs_client for that server IP is created. During the SETCLIENTID operation, our client also presents an nfs_client_id4 string to servers, as an identifier on which the server can hang all of this client's NFSv4 state. Our client's nfs_client_id4 string is unique for each server IP address. An NFSv4 server is obligated to wipe all NFSv4 state associated with an nfs_client_id4 string when the client presents the same nfs_client_id4 string along with a changed SETCLIENTID boot verifier. When our client unmounts the last of a server's shares, it destroys that server's struct nfs_client. The next time the client mounts that NFS server, it creates a fresh struct nfs_client with a fresh boot verifier. On seeing the fresh verifer, the server wipes any previous NFSv4 state associated with that nfs_client_id4. However, NFSv4.1 clients are supposed to present the same nfs_client_id4 string to all servers. And, to support Transparent State Migration, the same nfs_client_id4 string should be presented to all NFSv4.0 servers so they recognize that migrated state for this client belongs with state a server may already have for this client. (This is known as the Uniform Client String model). If the nfs_client_id4 string is the same but the boot verifier changes for each server IP address, SETCLIENTID and EXCHANGE_ID operations from such a client could unintentionally result in a server wiping a client's previously obtained lease. Thus, if our NFS client is going to use a fixed nfs_client_id4 string, either for NFSv4.0 or NFSv4.1 mounts, our NFS client should use a boot verifier that does not change depending on server IP address. Replace our current per-nfs_client boot verifier with a per-nfs_net boot verifier. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-11NFS: replace global bl_wq with per-net oneStanislav Kinsbursky
This queue is used for sleeping in kernel and it have to be per-net since we don't want to wake any other waiters except in out network nemespace. BTW, move wq to per-net data is easy. But some way to handle upcall timeouts have to be provided. On message destroy in case of timeout, tasks, waiting for message to be delivered, should be awakened. Thus, some data required to located the right wait queue. Chosen solution replaces rpc_pipe_msg object with new introduced bl_pipe_msg object, containing rpc_pipe_msg and proper wq. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-11NFS: replace global bl_mount_reply with per-net oneStanislav Kinsbursky
This global variable is used for blocklayout downcall and thus can be corrupted if case of existence of multiple networks namespaces. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: make nfs_client_lock per net nsStanislav Kinsbursky
This patch makes nfs_clients_lock allocated per network namespace. All items it protects are already network namespace aware. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: make cb_ident_idr per net nsStanislav Kinsbursky
This patch makes ID's infrastructure network namespace aware. This was done mainly because of nfs_client_lock, which is desired to be per network namespace, but protects NFS clients ID's. NOTE: NFS client's net pointer have to be set prior to ID initialization, proper assignment was moved. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: make nfs_volume_list per net nsStanislav Kinsbursky
This patch splits global list of NFS servers into per-net-ns array of lists. This looks more strict and clearer. BTW, this patch also makes "/proc/fs/nfsfs/volumes" content depends on /proc mount owner pid namespace. See below for details. NOTE: few words about how was /proc/fs/nfsfs/ entries content show per network namespace done. This is a little bit tricky and not the best is could be. But it's cheap (proper fix for /proc conteinerization is a hard nut to crack). The idea is simple: take proper network namespace from pid namespace child reaper nsproxy of /proc/ mount creator. This actually means, that if there are 2 containers with different net namespace sharing pid namespace, then read of /proc/fs/nfsfs/ entries will always return content, taken from net namespace of pid namespace creator task (and thus second namespace set wil be unvisible). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: make nfs_client_list per net nsStanislav Kinsbursky
This patch splits global list of NFS clients into per-net-ns array of lists. This looks more strict and clearer. BTW, this patch also makes "/proc/fs/nfsfs/servers" entry content depends on /proc mount owner pid namespace. See below for details. NOTE: few words about how was /proc/fs/nfsfs/ entries content show per network namespace done. This is a little bit tricky and not the best is could be. But it's cheap (proper fix for /proc conteinerization is a hard nut to crack). The idea is simple: take proper network namespace from pid namespace child reaper nsproxy of /proc/ mount creator. This actually means, that if there are 2 containers with different net namespace sharing pid namespace, then read of /proc/fs/nfsfs/ entries will always return content, taken from net namespace of pid namespace creator task (and thus second namespace set wil be unvisible). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-31NFS: blocklayout pipe creation per network namespace context introducedStanislav Kinsbursky
This patch implements blocklayout pipe creation and registration per each existent network namespace. This was achived by registering NFS per-net operations, responsible for blocklayout pipe allocation/register and unregister/destruction instead of initialization and destruction of static "bl_device_pipe" pipe (this one was removed). Note, than pointer to network blocklayout pipe is stored in per-net "nfs_net" structure, because allocating of one more per-net structure for blocklayout module looks redundant. This patch also changes dev_remove() function prototype (and all it's callers, where it' requied) by adding network namespace pointer parameter, which is used to discover proper blocklayout pipe for rpc_queue_upcall() call. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-31NFS: DNS resolver cache per network namespace context introducedStanislav Kinsbursky
This patch implements DNS resolver cache creation and registration for each alive network namespace context. This was done by registering NFS per-net operations, responsible for DNS cache allocation/register and unregister/destructioning instead of initialization and destruction of static "nfs_dns_resolve" cache detail (this one was removed). Pointer to network dns resolver cache is stored in new per-net "nfs_net" structure. This patch also changes nfs_dns_resolve_name() function prototype (and it's calls) by adding network pointer parameter, which is used to get proper DNS resolver cache pointer for do_cache_lookup_wait() call. Note: empty nfs_dns_resolver_init() and nfs_dns_resolver_destroy() functions will be used in next patch in the series. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
