path: root/fs/nfs/idmap.c
2015-04-23NFS: Rename idmap.c to nfs4idmap.cAnna Schumaker
I added the nfs4 prefix to make it obvious that this file is built into the NFS v4 module, and not the generic client. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-04-23NFS: Move nfs_idmap.h into fs/nfs/Anna Schumaker
This file is only used internally to the NFS v4 module, so it doesn't need to be in the global include path. I also renamed it from nfs_idmap.h to nfs4idmap.h to emphasize that it's an NFSv4-only include file. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-03pnfs/flexfiles: Add the FlexFile Layout DriverTom Haynes
The flexfile layout is a new layout that extends the file layout. It is currently being drafted as a specification at https://datatracker.ietf.org/doc/draft-ietf-nfsv4-layout-types/ Signed-off-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Tom Haynes <loghyr@primarydata.com> Signed-off-by: Tao Peng <bergwolf@primarydata.com>
2014-09-16KEYS: Remove key_type::match in favour of overriding default by match_preparseDavid Howells
A previous patch added a ->match_preparse() method to the key type. This is allowed to override the function called by the iteration algorithm. Therefore, we can just set a default that simply checks for an exact match of the key description with the original criterion data and allow match_preparse to override it as needed. The key_type::match op is then redundant and can be removed, as can the user_match() function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-07-22Merge branch 'keys-fixes' into keys-nextDavid Howells
2014-07-22KEYS: user: Use key preparsingDavid Howells
Make use of key preparsing in user-defined and logon keys so that quota size determination can take place prior to keyring locking when a key is being added. Also the idmapper key types need to change to match as they use the user-defined key type routines. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com>
2014-07-17KEYS: Allow special keys (eg. DNS results) to be invalidated by CAP_SYS_ADMINDavid Howells
Special kernel keys, such as those used to hold DNS results for AFS, CIFS and NFS and those used to hold idmapper results for NFS, used to be 'invalidateable' with key_revoke(). However, since the default permissions for keys were reduced: Commit: 96b5c8fea6c0861621051290d705ec2e971963f1 KEYS: Reduce initial permissions on keys it has become impossible to do this. Add a key flag (KEY_FLAG_ROOT_CAN_INVAL) that will permit a key to be invalidated by root. This should not be used for system keyrings as the garbage collector will try and remove any invalidate key. For system keyrings, KEY_FLAG_ROOT_CAN_CLEAR can be used instead. After this, from userspace, keyctl_invalidate() and "keyctl invalidate" can be used by any possessor of CAP_SYS_ADMIN (typically root) to invalidate DNS and idmapper keys. Invalidated keys are immediately garbage collected and will be immediately rerequested if needed again. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Steve Dickson <steved@redhat.com>
2013-09-01NFSv4: Convert idmapper to use the new framework for pipefs dentriesTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-30NFSv4: Fix a potentially Oopsable condition in __nfs_idmap_unregisterTrond Myklebust
Ensure that __nfs_idmap_unregister can be called twice without consequences. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-22NFSv4: Add tracepoints for debugging the idmapperTrond Myklebust
Add tracepoints to help debug uid/gid mappings to username/group. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-22NFSv4: Deal with a sparse warning in nfs_idmap_get_key()Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Bryan Schumaker <bjschuma@netapp.com>
2013-06-28NFS: Improve legacy idmapping fallbackBryan Schumaker
Fallback should happen only when the request_key() call fails, because this indicates that there was a problem running the nfsidmap program. We shouldn't call the legacy code if the error was elsewhere. Signed-off-by: Bryan Schumaker <bjschuma@netappp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-03-20NFSv4: Fix the string length returned by the idmapperTrond Myklebust
Functions like nfs_map_uid_to_name() and nfs_map_gid_to_group() are expected to return a string without any terminating NUL character. Regression introduced by commit 57e62324e469e092ecc6c94a7a86fe4bd6ac5172 (NFS: Store the legacy idmapper result in the keyring). Reported-by: Dave Chiluk <dave.chiluk@canonical.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Bryan Schumaker <bjschuma@netapp.com> Cc: stable@vger.kernel.org [>=3.4]
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-13nfs: Convert idmap to use kuids and kgidsEric W. Biederman
Convert nfs_map_name_to_uid to return a kuid_t value. Convert nfs_map_name_to_gid to return a kgid_t value. Convert nfs_map_uid_to_name to take a kuid_t paramater. Convert nfs_map_gid_to_name to take a kgid_t paramater. Tweak nfs_fattr_map_owner_to_name to use a kuid_t intermediate value. Tweak nfs_fattr_map_group_to_name to use a kgid_t intermediate value. Which makes these functions properly handle kuids and kgids, including erroring of the generated kuid or kgid is invalid. Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13nfs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring allocEric W. Biederman
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-10-02NFS: Set key construction data for the legacy upcallBryan Schumaker
This prevents a null pointer dereference when nfs_idmap_complete_pipe_upcall_locked() calls complete_request_key(). Fixes a regression caused by commit 0cac12023 (NFSv4: Ensure that idmap_pipe_downcall sanity-checks the downcall data). Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-10-02KEYS: Use keyring_alloc() to create special keyringsDavid Howells
Use keyring_alloc() to create special keyrings now that it has a permissions parameter rather than using key_alloc() + key_instantiate_and_link(). Also document and export keyring_alloc() so that modules can use it too. Signed-off-by: David Howells <dhowells@redhat.com>
2012-10-01Merge branch 'bugfixes' into nfs-for-nextTrond Myklebust
2012-10-01nfs: replace strict_strto* with kstrto*Daniel Walter
[nfs] replace strict_str* with kstr* variants * replace string conversions with newer kstr* functions Signed-off-by: Daniel Walter <sahne@0x90.at> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-10-01NFS: Use kzalloc() instead of kmalloc() in the idmapperBryan Schumaker
This will allocate memory that has already been zeroed, allowing us to remove the memset later on. Signed-off-by: Bryan Schumaker <bjchuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-09-28NFSv4: Ensure that idmap_pipe_downcall sanity-checks the downcall dataTrond Myklebust
Use the idmapper upcall data to verify that the legacy idmapper daemon is indeed responding to an upcall that we sent. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Bryan Schumaker <bjschuma@netapp.com>
2012-09-28NFSv4: Clean up the legacy idmapper upcallTrond Myklebust
Replace the BUG_ON(idmap->idmap_key_cons != NULL) with a WARN_ON_ONCE(). Then get rid of the ACCESS_ONCE(idmap->idmap_key_cons). Then add helper functions for starting, finishing and aborting the legacy upcall. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Bryan Schumaker <bjschuma@netapp.com>
2012-09-28NFSv4: Remove BUG_ON() and ACCESS_ONCE() calls in the idmapperTrond Myklebust
The use of ACCESS_ONCE() is wrong, since the various routines that set/clear idmap->idmap_key_cons should be strictly ordered w.r.t. each other, and the idmap->idmap_mutex ensures that only one thread at a time may be in an upcall situation. Also replace the BUG_ON()s with WARN_ON_ONCE() where appropriate. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-08-16NFS: return -ENOKEY when the upcall fails to map the nameBryan Schumaker
This allows the normal error-paths to handle the error, rather than making a special call to complete_request_key() just for this instance. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Tested-by: William Dauchy <wdauchy@gmail.com> Cc: stable@vger.kernel.org [>= 3.4] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-08-16NFS: Clear key construction data if the idmap upcall failsBryan Schumaker
idmap_pipe_downcall already clears this field if the upcall succeeds, but if it fails (rpc.idmapd isn't running) the field will still be set on the next call triggering a BUG_ON(). This patch tries to handle all possible ways that the upcall could fail and clear the idmap key data for each one. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Tested-by: William Dauchy <wdauchy@gmail.com> Cc: stable@vger.kernel.org [>= 3.4] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-30NFS: Keep module parameters in the generic NFS clientBryan Schumaker
Otherwise we break backwards compatibility when v4 becomes a modules. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-30NFS: Fix a number of bugs in the idmapperDavid Howells
Fix a number of bugs in the NFS idmapper code: (1) Only registered key types can be passed to the core keys code, so register the legacy idmapper key type. This is a requirement because the unregister function cleans up keys belonging to that key type so that there aren't dangling pointers to the module left behind - including the key->type pointer. (2) Rename the legacy key type. You can't have two key types with the same name, and (1) would otherwise require that. (3) complete_request_key() must be called in the error path of nfs_idmap_legacy_upcall(). (4) There is one idmap struct for each nfs_client struct. This means that idmap->idmap_key_cons is shared without the use of a lock. This is a problem because key_instantiate_and_link() - as called indirectly by idmap_pipe_downcall() - releases anyone waiting for the key to be instantiated. What happens is that idmap_pipe_downcall() running in the rpc.idmapd thread, releases the NFS filesystem in whatever thread that is running in to continue. This may then make another idmapper call, overwriting idmap_key_cons before idmap_pipe_downcall() gets the chance to call complete_request_key(). I *think* that reading idmap_key_cons only once, before key_instantiate_and_link() is called, and then caching the result in a variable is sufficient. Bug (4) is the cause of: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [< (null)>] (null) PGD 0 Oops: 0010 [#1] SMP CPU 1 Modules linked in: ppdev parport_pc lp parport ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack nfs fscache xt_CHECKSUM auth_rpcgss iptable_mangle nfs_acl bridge stp llc lockd be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i libcxgbi cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi snd_hda_codec_realtek snd_usb_audio snd_hda_intel snd_hda_codec snd_seq snd_pcm snd_hwdep snd_usbmidi_lib snd_rawmidi snd_timer uvcvideo videobuf2_core videodev media videobuf2_vmalloc snd_seq_device videobuf2_memops e1000e vhost_net iTCO_wdt joydev coretemp snd soundcore macvtap macvlan i2c_i801 snd_page_alloc tun iTCO_vendor_support microcode kvm_intel kvm sunrpc hid_logitech_dj usb_storage i915 drm_kms_helper drm i2c_algo_bit i2c_core video [last unloaded: scsi_wait_scan] Pid: 1229, comm: rpc.idmapd Not tainted 3.4.2-1.fc16.x86_64 #1 Gateway DX4710-UB801A/G33M05G1 RIP: 0010:[<0000000000000000>] [< (null)>] (null) RSP: 0018:ffff8801a3645d40 EFLAGS: 00010246 RAX: ffff880077707e30 RBX: ffff880077707f50 RCX: ffff8801a18ccd80 RDX: 0000000000000006 RSI: ffff8801a3645e75 RDI: ffff880077707f50 RBP: ffff8801a3645d88 R08: ffff8801a430f9c0 R09: ffff8801a3645db0 R10: 000000000000000a R11: 0000000000000246 R12: ffff8801a18ccd80 R13: ffff8801a3645e75 R14: ffff8801a430f9c0 R15: 0000000000000006 FS: 00007fb6fb51a700(0000) GS:ffff8801afc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 00000001a49b0000 CR4: 00000000000027e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rpc.idmapd (pid: 1229, threadinfo ffff8801a3644000, task ffff8801a3bf9710) Stack: ffffffff81260878 ffff8801a3645db0 ffff8801a3645db0 ffff880077707a90 ffff880077707f50 ffff8801a18ccd80 0000000000000006 ffff8801a3645e75 ffff8801a430f9c0 ffff8801a3645dd8 ffffffff81260983 ffff8801a3645de8 Call Trace: [<ffffffff81260878>] ? __key_instantiate_and_link+0x58/0x100 [<ffffffff81260983>] key_instantiate_and_link+0x63/0xa0 [<ffffffffa057062b>] idmap_pipe_downcall+0x1cb/0x1e0 [nfs] [<ffffffffa0107f57>] rpc_pipe_write+0x67/0x90 [sunrpc] [<ffffffff8117f833>] vfs_write+0xb3/0x180 [<ffffffff8117fb5a>] sys_write+0x4a/0x90 [<ffffffff81600329>] system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [< (null)>] (null) RSP <ffff8801a3645d40> CR2: 0000000000000000 Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.4]
2012-06-20NFS: Force the legacy idmapper to be single threadedBryan Schumaker
It was initially coded under the assumption that there would only be one request at a time, so use a lock to enforce this requirement.. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> CC: stable@vger.kernel.org [3.4+] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-23NFS: Add memory barriers to the nfs_client->cl_cons_state initialisationTrond Myklebust
Ensure that a process that uses the nfs_client->cl_cons_state test for whether the initialisation process is finished does not read stale data. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-23NFSv4: Fix a race in the net namespace mount notificationTrond Myklebust
Since the struct nfs_client gets added to the global nfs_client_list before it is initialised, it is possible that rpc_pipefs_event can end up trying to create idmapper entries on such a thing. The solution is to have the mount notification wait for the initialisation of each nfs_client to complete, and then to skip any entries for which the it failed. Reported-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
2012-05-22NFS: Use proper naming conventions for the nfs_client.net fieldChuck Lever
Clean up: When naming fields and data types, follow established conventions to facilitate accurate grep/cscope searches. Introduced by commit e50a7a1a "NFS: make NFS client allocated per network namespace context," Tue Jan 10, 2012. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-14NFS: kmalloc() doesn't return an ERR_PTR()Dan Carpenter
Obviously we should check for NULL here instead of IS_ERR(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable@vger.kernel.org [3.4] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-04-28NFS: get module in idmap PipeFS notifier callbackStanislav Kinsbursky
This is bug fix. Notifier callback is called from SUNRPC module. So before dereferencing NFS module we have to make sure, that it's alive. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-23Merge tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates for Linux 3.4 from Trond Myklebust: "New features include: - Add NFS client support for containers. This should enable most of the necessary functionality, including lockd support, and support for rpc.statd, NFSv4 idmapper and RPCSEC_GSS upcalls into the correct network namespace from which the mount system call was issued. - NFSv4 idmapper scalability improvements Base the idmapper cache on the keyring interface to allow concurrent access to idmapper entries. Start the process of migrating users from the single-threaded daemon-based approach to the multi-threaded request-key based approach. - NFSv4.1 implementation id. Allows the NFSv4.1 client and server to mutually identify each other for logging and debugging purposes. - Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of having to use the more counterintuitive 'vers=4,minorversion=1'. - SUNRPC tracepoints. Start the process of adding tracepoints in order to improve debugging of the RPC layer. - pNFS object layout support for autologin. Important bugfixes include: - Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to fail to wake up all tasks when applied to priority waitqueues. - Ensure that we handle read delegations correctly, when we try to truncate a file. - A number of fixes for NFSv4 state manager loops (mostly to do with delegation recovery)." * tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits) NFS: fix sb->s_id in nfs debug prints xprtrdma: Remove assumption that each segment is <= PAGE_SIZE xprtrdma: The transport should not bug-check when a dup reply is received pnfs-obj: autologin: Add support for protocol autologin NFS: Remove nfs4_setup_sequence from generic rename code NFS: Remove nfs4_setup_sequence from generic unlink code NFS: Remove nfs4_setup_sequence from generic read code NFS: Remove nfs4_setup_sequence from generic write code NFS: Fix more NFS debug related build warnings SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined nfs: non void functions must return a value SUNRPC: Kill compiler warning when RPC_DEBUG is unset SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG NFS: Use cond_resched_lock() to reduce latencies in the commit scans NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner NFS: ncommit count is being double decremented SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up() Try using machine credentials for RENEW calls NFSv4.1: Fix a few issues in filelayout_commit_pagelist NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code ...
2012-03-12NFS: Check return value from rpc_queue_upcall()Bryan Schumaker
This function could fail to queue the upcall if rpc.idmapd is not running, causing a warning message to be printed. Instead, I want to check the return value and revoke the key if the upcall can't be run. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-11NFS: Fix a number of sparse warningsTrond Myklebust
Fix a number of "warning: symbol 'foo' was not declared. Should it be static?" conditions. Fix 2 cases of "warning: Using plain integer as NULL pointer" fs/nfs/delegation.c:263:31: warning: restricted fmode_t degrades to integer - We want to allow upgrades to a WRITE delegation, but should otherwise consider servers that hand out duplicate delegations to be borken. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-01NFS: Store the legacy idmapper result in the keyringBryan Schumaker
This patch removes the old hashmap-based caching and instead uses a "request key actor" to place an upcall to the legacy idmapper rather than going through /sbin/request-key. This will only be used as a fallback if /etc/request-key.conf isn't configured to use nfsidmap. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-27NFS: release per-net clients lock before calling PipeFS dentries creationStanislav Kinsbursky
v3: 1) Lookup for client is performed from the beginning of the list on each PipeFS event handling operation. Lockdep is sad otherwise, because inode mutex is taken on PipeFS dentry creation, which can be called on mount notification, where this per-net client lock is taken on clients list walk. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-15NFSv4: Further reduce the footprint of the idmapperTrond Myklebust
Don't allocate the legacy idmapper tables until we actually need them. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-02-15NFSv4: Reduce the footprint of the idmapperTrond Myklebust
Instead of pre-allocating the storage for all the strings, we can significantly reduce the size of that table by doing the allocation when we do the downcall. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-02-06NFS: build fixed in case of NFS_USE_NEW_IDMAPPER is undefinedStanislav Kinsbursky
2012-02-06NFS: make nfs_client_lock per net nsStanislav Kinsbursky
This patch makes nfs_clients_lock allocated per network namespace. All items it protects are already network namespace aware. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: make nfs_client_list per net nsStanislav Kinsbursky
This patch splits global list of NFS clients into per-net-ns array of lists. This looks more strict and clearer. BTW, this patch also makes "/proc/fs/nfsfs/servers" entry content depends on /proc mount owner pid namespace. See below for details. NOTE: few words about how was /proc/fs/nfsfs/ entries content show per network namespace done. This is a little bit tricky and not the best is could be. But it's cheap (proper fix for /proc conteinerization is a hard nut to crack). The idea is simple: take proper network namespace from pid namespace child reaper nsproxy of /proc/ mount creator. This actually means, that if there are 2 containers with different net namespace sharing pid namespace, then read of /proc/fs/nfsfs/ entries will always return content, taken from net namespace of pid namespace creator task (and thus second namespace set wil be unvisible). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: Keep idmapper include files in one placeBryan Schumaker
2012-02-06NFS: Fall back on old idmapper if request_key() failsBryan Schumaker
This patch removes the CONFIG_NFS_USE_NEW_IDMAPPER compile option. First, the idmapper will attempt to map the id using /sbin/request-key and nfsidmap. If this fails (if /etc/request-key.conf is not configured properly) then the idmapper will call the legacy code to perform the mapping. I left a comment stating where the legacy code begins to make it easier for somebody to remove in the future. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: start printks w/ NFS: even if __func__ shownWeston Andros Adamson
This patch addresses printks that have some context to show that they are from fs/nfs/, but for the sake of consistency now start with NFS: Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: printks in fs/nfs/ should start with NFS:Weston Andros Adamson
Messages like "Got error -10052 from the server on DESTROY_SESSION. Session has been destroyed regardless" can be confusing to users who aren't very familiar with NFS. NOTE: This patch ignores any printks() that start by printing __func__ - that will be in a separate patch. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
