path: root/fs/nfs/direct.c
2008-07-09NFS: Use NFSDBG_FILE for all fopsChuck Lever
Clean up: some fops use NFSDBG_FILE, some use NFSDBG_VFS. Let's use NFSDBG_FILE for all fops, and consistently report file names instead of inode numbers. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFS: Ensure that rpc_run_task() errors are propagated back to the callerTrond Myklebust
2008-04-19NFS: Ensure that the write code cleans up properly when rpc_run_task() failsTrond Myklebust
2008-04-19NFS: Ensure that the read code cleans up properly when rpc_run_task() failsTrond Myklebust
In the case of readpage() we need to ensure that the pages get unlocked, and that the error is flagged. In the case of O_DIRECT, we need to ensure that the pages are all released. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Ensure that the asynchronous RPC calls complete on nfsiod.Trond Myklebust
We want to ensure that rpc_call_ops that involve mntput() are run on nfsiod rather than on rpciod, so that they don't deadlock when the resulting umount calls rpc_shutdown_client(). Hence we specify that read, write and commit calls must complete on nfsiod. Ditto for NFSv4 open, lock, locku and close asynchronous calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Fix a deadlock with lazy umountTrond Myklebust
We can't allow rpc callback functions like task->tk_ops->rpc_call_prepare() and task->tk_ops->rpc_call_done() to call mntput() in any way, since that will cause a deadlock when the call to rpc_shutdown_client() attempts to wait on 'task' to complete. We can avoid the above deadlock by moving calls to mntput to task->tk_ops->rpc_release() callback, since at that time the task will be marked as completed, and so rpc_shutdown_client won't attempt to wait on it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30NFS: Optimise away the sigmask code in aio/dio reads and writesTrond Myklebust
There are no interruptible waits for asynchronous RPC tasks, so we don't need to wrap calls to rpc_run_task() with an rpc_clnt_sigmask/rpc_clnt_unsigmask pair. Instead we can wrap the wait_for_completion_interruptible() in nfs_direct_wait(). This means that we completely optimise away sigmask setting for the case of non-blocking aio/dio. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS/SUNRPC: Convert users of rpc_init_task+rpc_execute to rpc_run_task()Trond Myklebust
2008-01-30NFS: Clean up the (commit|read|write)_setup() callback routinesTrond Myklebust
Move the common code for setting up the nfs_write_data and nfs_read_data structures into fs/nfs/read.c, fs/nfs/write.c and fs/nfs/direct.c. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the initialisation of priority queue scheduling info.Trond Myklebust
We want the default scheduling priority (priority == 0) to remain RPC_PRIORITY_NORMAL. Also ensure that the priority wait queue scheduling is per process id instead of sometimes being per thread, and sometimes being per inode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Cleanup of rpc_task initialisationTrond Myklebust
2007-12-12Revert "NFS: Ensure we return zero if applications attempt to write zero bytes"Trond Myklebust
This reverts commit b9148c6b80d802dbc2a7530b29915a80432e50c7. On Wed, 12 Dec 2007 10:57:30 -0500, Chuck Lever wrote > commit b9148c6b should be reverted. It was recently forward-ported > from some years-old patches, and is clearly not needed now. > > On Dec 11, 2007, at 5:21 PM, Adrian Bunk wrote: > >> This code became dead after commit >> b9148c6b80d802dbc2a7530b29915a80432e50c7 >> (which BTW doesn't seem to have changed any behaviour) and can >> therefore >> be removed. >> >> Spotted by the Coverity checker. >> >> Signed-off-by: Adrian Bunk <bunk@kernel.org> >> >> --- >> --- linux-2.6/fs/nfs/direct.c.old 2007-12-02 21:54:53.000000000 +0100 >> +++ linux-2.6/fs/nfs/direct.c 2007-12-02 21:55:10.000000000 +0100 >> @@ -897,15 +897,12 @@ ssize_t nfs_file_direct_write(struct kio >> if (!count) >> goto out; /* return 0 */ >> >> retval = -EINVAL; >> if ((ssize_t) count < 0) >> goto out; >> - retval = 0; >> - if (!count) >> - goto out; >> >> retval = nfs_sync_mapping(mapping); >> if (retval) >> goto out; >> >> retval = nfs_direct_write(iocb, iov, nr_segs, pos, count); >> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-11-26NFS: Clean up new multi-segment direct I/O changesChuck Lever
Simplify calling sequence of nfs_direct_{read,write}_schedule(), and rename them to reflect their new role. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Ensure we return zero if applications attempt to write zero bytesChuck Lever
A zero byte count direct write request should be a successful no-op, not an error. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Support multiple segment iovecs in the NFS direct I/O pathChuck Lever
Allow applications to perform asynchronous scatter-gather direct I/O to NFS files. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Introduce iovec I/O helpers to fs/nfs/direct.cChuck Lever
Add helpers that iterate over multi-segment iovecs. These will be used to support multi-segment scatter/gather direct I/O in a later patch. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-23NFS: Fix for bug in handling of errors for O_DIRECT writesNeil Brown
Commit eda3cef8dd2b83875affe82595db9d0c278879b2 ("NFS: Fix error handling in nfs_direct_write_result()") ensured that if a WRITE returns an error, then data->res.verf->committed is not tested (as it is not initialised). Then commit 60fa3f769f7651a60125a0f44e3ffe3246d7cf39 ("NFS: Fix two bugs in the O_DIRECT write code") inadvertently reverted this while fixing other problems. So move the test so that we never examine ->committed in an error case, and fix a speeling error while we are there. Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Replace file->private_data with calls to nfs_file_open_context()Trond Myklebust
2007-07-10NFS: Replace vfsmount and dentry in nfs_open_context with struct pathTrond Myklebust
2007-07-10NFS: Don't fail an O_DIRECT read/write if get_user_pages() returns pagesTrond Myklebust
There is no need to fail the entire O_DIRECT read/write just because get_user_pages() returned fewer pages than we requested. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Clean ups in fs/nfs/direct.cChuck Lever
2007-05-30NFS: Fix a refcount leakage in O_DIRECTTrond Myklebust
The current code is leaking a reference to dreq->kref when the calls to nfs_direct_read_schedule() and nfs_direct_write_schedule() return an error. This patch moves the call to kref_put() from nfs_direct_wait() back into nfs_direct_read() and nfs_direct_write() (which are the functions that actually took the reference in the first place) fixing the leak. Thanks to Denis V. Lunev for spotting the bug and proposing the original fix. Acked-by: Denis V. Lunev <dlunev@gmail.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix nfs_direct_dirty_pages()Trond Myklebust
We only need to dirty the pages that were actually read in. Also convert nfs_direct_dirty_pages() to call set_page_dirty() instead of set_page_dirty_lock(). A call to lock_page() is unacceptable in an rpciod callback function. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix handful of compiler warnings in direct.cChuck Lever
This patch fixes a couple of signage issues that were causing an Oops when running the LTP diotest4 test. get_user_pages() returns a signed error, hence we need to be careful when comparing with the unsigned number of pages from data->npages. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix a buffer overflow in the allocation of struct nfs_read/writedataTrond Myklebust
2007-04-14NFS: Fix two bugs in the O_DIRECT write codeTrond Myklebust
Do not flag an error if the COMMIT call fails and we decide to resend the writes. Let the resend flag the error if it fails. If a write has failed, then nfs_direct_write_result should not attempt to send a commit. It should just exit asap and return the error to the user. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03NFS: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Also clean up some miscellaneous print formatting nits. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
2006-12-06NFS: Remove use of the Big Kernel Lock around calls to rpc_execute.Frank Filz
Remove use of the Big Kernel Lock around calls to rpc_execute. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] NFS: Deal with failure of invalidate_inode_pages2()Trond Myklebust
If invalidate_inode_pages2() fails, then it should in principle just be because the current process was signalled. In that case, we just want to ensure that the inode's page cache remains marked as invalid. Also add a helper to allow the O_DIRECT code to simply mark the page cache as invalid once it is finished writing, instead of calling invalidate_inode_pages2() itself. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] NFS: Fix error handling in nfs_direct_write_result()Trond Myklebust
If the RPC call tanked, we should not be checking the return value of data->res.verf->committed, since it is unlikely to even be initialised. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-08[PATCH] NFS: large non-page-aligned direct I/O clobbers memoryTrond Myklebust
The logic in nfs_direct_read_schedule and nfs_direct_write_schedule can allow data->npages to be one larger than rpages. This causes a page pointer to be written beyond the end of the pagevec in nfs_read_data (or nfs_write_data). Fix this by making nfs_(read|write)_alloc() calculate the size of the pagevec array, and initialise data->npages. Also get rid of the redundant argument to nfs_commit_alloc(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
2006-06-28Revert "Merge branch 'odirect'"Trond Myklebust
This reverts ccf01ef7aa9c6c293a1c64c27331a2ce227916ec commit. No idea how git managed this one: when I asked it to merge the odirect topic branch it actually generated a patch which reverted the change. Reverting the 'merge' will once again reveal Chuck's recent NFS/O_DIRECT work to the world. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-27[PATCH] fix static linking of NFSDavid Brownell
Builds on ARM report link problems with common configurations like statically linked NFS (for nfsroot). The symptom is that __init section code references __exit section code; that won't work since the exit sections are discarded (since they can never be called). The best fix for these particular cases would be an "__init_or_exit" section annotation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge branch 'odirect'Trond Myklebust
2006-06-24NFS: alloc nfs_read/write_data as direct I/O is scheduledChuck Lever
Re-arrange the logic in the NFS direct I/O path so that nfs_read/write_data structs are allocated just before they are scheduled, rather than allocating them all at once before we start scheduling requests. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: Eliminate nfs_get_user_pages()Chuck Lever
Neil Brown observed that the kmalloc() in nfs_get_user_pages() is more likely to fail if the I/O is large enough to require the allocation of more than a single page to keep track of all the pinned pages in the user's buffer. Instead of tracking one large page array per dreq/iocb, track pages per nfs_read/write_data, just like the cached I/O path does. An array for pages is already allocated for us by nfs_readdata_alloc() (and the write and commit equivalents). This is also required for adding support for vectored I/O to the NFS direct I/O path. The original reason to pin the user buffer and allocate all the NFS data structures before trying to schedule I/O was to ensure all needed resources are allocated on the client before starting to send requests. This reduces the chance that resource exhaustion on the client will cause a short read or write. On the other hand, for an application making very large application I/O requests, this means that it will be nearly impossible for the application to make forward progress on a resource-limited client. Thus, moving the buffer pinning functionality into the I/O scheduling loops should be good for scalability. The next patch will do the same for NFS data structure allocation. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: refactor nfs_direct_free_user_pagesChuck Lever
Clean-up and fix a minor bug: the logic was dirtying page cache pages on both read and write operations. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
