Fix the callbacks NFS passes to read_cache_page to actually have the
proper type expected. Casting around function pointers can easily
hide typing bugs, and defeats control flow protection.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
This fixes the typo in comments of nfs_readdir_alloc_pages().
Because nfs_readdir_large_page and nfs_readdir_free_pagearray had been
renamed.
Signed-off-by: Liguang Zhang <zhangliguang@linux.alibaba.com>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
This removes redundant semicolon for ending code.
Fixes: c7944ebb9ce9 ("NFSv4: Fix lookup revalidate of regular files")
When listing very large directories via NFS, clients may take a long
time to complete. There are about three factors involved:
First of all, ls and practically every other method of listing a
directory including python os.listdir and find rely on libc readdir().
However readdir() only reads 32K of directory entries at a time, which
means that if you have a lot of files in the same directory, it is going
to take an insanely long time to read all the directory entries.
Secondly, libc readdir() reads 32K of directory entries at a time, in
kernel space 32K buffer split into 8 pages. One NFS readdirplus rpc will
be called for one page, which introduces many readdirplus rpc calls.
Lastly, one NFS readdirplus rpc asks for 32K data (filled by nfs_dentry)
to fill one page (filled by dentry), we found that nearly one third of
data was wasted.
To solve above problems, pagecache mechanism was introduced. One NFS
readdirplus rpc will ask for a large data (more than 32k), the data can
fill more than one page, the cached pages can be used for next readdir
call. This can reduce many readdirplus rpc calls and improve readdirplus
performance.
TESTING:
When listing very large directories(include 300 thousand files) via NFS
time ls -l /nfs_mount | wc -l
without the patch:
300001
real 1m53.524s
user 0m2.314s
sys 0m2.599s
with the patch:
300001
real 0m23.487s
user 0m2.305s
sys 0m2.558s
Improved performance: 79.6%
readdirplus rpc calls decrease: 85%
Fix up some compiler warnings about function parameters, etc not being
correctly described or formatted.
Use the common 'struct cred' to pass credentials for readdir.
Signed-off-by: NeilBrown <neilb@suse.com>
Rather than keying the access cache with 'struct rpc_cred',
use 'struct cred'. Then use cred_fscmp() to compare
credentials rather than comparing the raw pointer.
A benefit of this approach is that in the common case we avoid the
rpc_lookup_cred_nonblock() call which can be slow when the cred cache is large.
This also keeps many fewer items pinned in the rpc cred cache, so the
cred cache is less likely to get large.
If we're revalidating an existing dentry in order to open a file, we need
to ensure that we check the directory has not changed before we optimise
away the lookup.
Refactor the code in nfs_lookup_revalidate() as a stepping stone towards
optimising and fixing nfs4_lookup_revalidate().
Pull NFS client updates from Anna Schumaker:
"These patches include adding async support for the v4.2 COPY
operation. I think Bruce is planning to send the server patches for
the next release, but I figured we could get the client side out of
the way now since it's been in my tree for a while. This shouldn't
cause any problems, since the server will still respond with
synchronous copies even if the client requests async.
Features:
- Add support for asynchronous server-side COPY operations
Stable bufixes:
- Fix an off-by-one in bl_map_stripe() (v3.17+)
- NFSv4 client live hangs after live data migration recovery (v4.9+)
- xprtrdma: Fix disconnect regression (v4.18+)
- Fix locking in pnfs_generic_recover_commit_reqs (v4.14+)
- Fix a sleep in atomic context in nfs4_callback_sequence() (v4.9+)
Other bugfixes and cleanups:
- Optimizations and fixes involving NFS v4.1 / pNFS layout handling
- Optimize lseek(fd, SEEK_CUR, 0) on directories to avoid locking
- Immediately reschedule writeback when the server replies with an
error
- Fix excessive attribute revalidation in nfs_execute_ok()
- Add error checking to nfs_idmap_prepare_message()
- Use new vm_fault_t return type
- Return a delegation when reclaiming one that the server has
recalled
- Referrals should inherit proto setting from parents
- Make rpc_auth_create_args a const
- Improvements to rpc_iostats tracking
- Fix a potential reference leak when there is an error processing a
callback
- Fix rmdir / mkdir / rename nlink accounting
- Fix updating inode change attribute
- Fix error handling in nfsn4_sp4_select_mode()
- Use an appropriate work queue for direct-write completion
- Don't busy wait if NFSv4 session draining is interrupted"
* tag 'nfs-for-4.19-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (54 commits)
pNFS: Remove unwanted optimisation of layoutget
pNFS/flexfiles: ff_layout_pg_init_read should exit on error
pNFS: Treat RECALLCONFLICT like DELAY...
pNFS: When updating the stateid in layoutreturn, also update the recall range
NFSv4: Fix a sleep in atomic context in nfs4_callback_sequence()
NFSv4: Fix locking in pnfs_generic_recover_commit_reqs
NFSv4: Fix a typo in nfs4_init_channel_attrs()
NFSv4: Don't busy wait if NFSv4 session draining is interrupted
NFS recover from destination server reboot for copies
NFS add a simple sync nfs4_proc_commit after async COPY
NFS handle COPY ERR_OFFLOAD_NO_REQS
NFS send OFFLOAD_CANCEL when COPY killed
NFS export nfs4_async_handle_error
NFS handle COPY reply CB_OFFLOAD call race
NFS add support for asynchronous COPY
NFS COPY xdr handle async reply
NFS OFFLOAD_CANCEL xdr
NFS CB_OFFLOAD xdr
NFS: Use an appropriate work queue for direct-write completion
NFSv4: Fix error handling in nfs4_sp4_select_mode()
Pull vfs icache updates from Al Viro:
- NFS mkdir/open_by_handle race fix
- analogous solution for FUSE, replacing the one currently in mainline
- new primitive to be used when discarding halfway set up inodes on
failed object creation; gives sane warranties re icache lookups not
returning such doomed by still not freed inodes. A bunch of
filesystems switched to that animal.
- Miklos' fix for last cycle regression in iget5_locked(); -stable will
need a slightly different variant, unfortunately.
- misc bits and pieces around things icache-related (in adfs and jfs).
* 'work.mkdir' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
jfs: don't bother with make_bad_inode() in ialloc()
adfs: don't put inodes into icache
new helper: inode_fake_hash()
vfs: don't evict uninitialized inode
jfs: switch to discard_new_inode()
ext2: make sure that partially set up inodes won't be returned by ext2_iget()
udf: switch to discard_new_inode()
ufs: switch to discard_new_inode()
btrfs: switch to discard_new_inode()
new primitive: discard_new_inode()
kill d_instantiate_no_diralias()
nfs_instantiate(): prevent multiple aliases for directory inode
Return -ESTALE to force a lookup when the file has no more links
Signed-off-by: Lance Shelton <lance.shelton@hammerspace.com>
execute_ok() will only check the mode bits if the object is not a
directory, so we don't need to revalidate the attributes in that case.
When nfs_update_inode() sets NFS_INO_INVALID_ACCESS it is a sign that
we want to revalidate the access cache, not the inode attributes.
In fact we only want to revalidate here if we see that the mode bits
are invalid, so check for NFS_INO_INVALID_OTHER instead.
Reported-by: Olga Kornievskaia <aglo@umich.edu>
There should be no need to grab the inode lock if we're only reading
the file offset.
now it can be done...
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
__gfs2_lookup(), gfs2_create_inode(), nfs_finish_open() and fuse_create_open()
don't need 'opened' anymore. Get rid of that argument in those.
'opened' argument of finish_open() is unused. Kill it.
Signed-off-by Al Viro <viro@zeniv.linux.org.uk>
Parallel to FILE_CREATED, goes into ->f_mode instead of *opened.
NFS is a bit of a wart here - it doesn't have file at the point
where FILE_CREATED used to be set, so we need to propagate it
there (for now). IMA is another one (here and everywhere)...
Note that this needs do_dentry_open() to leave old bits in ->f_mode
alone - we want it to preserve FMODE_CREATED if it had been already
set (no other bit can be there).
Since NFS allows open-by-fhandle, we have to cope with the possibility
of mkdir vs. open-by-guessed-handle races. A local filesystem could
decide what the inumber of the new object will be and insert a locked
inode with that inumber into icache _before_ the on-disk data structures
begin to look good and unlock it only once it has a dentry alias, so
that open-by-handle coming first would quietly fail and mkdir coming
first would have open-by-handle grab its dentry.
For NFS it's a non-starter - the icache key is server-supplied fhandle
and we do not get that until the object has been fully created on server.
We really have to deal with the possibility that open-by-handle gets
the in-core inode and attaches a dentry to it before mkdir does.
Solution: let nfs_mkdir() use d_splice_alias() to catch those. We can
* get an error. Just return it to our caller.
* get NULL - no preexisting dentry aliases, we'd just done what
d_add() would've done. Success.
* get a reference to preexisting alias. In that case the alias
had been moved in place of nfs_mkdir() argument (and hashed there), while
nfs_mkdir() argument is left unhashed negative. Which is just fine for
->mkdir() callers, all we need is to release the reference we'd got from
d_splice_alias() and report success.
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Allow the getattr() callback to check things like whether or not we hold
a delegation so that it can adjust the attributes that it is asking for.
We may need to revalidate the change attribute, ctime and the nlinks count.
We can optimise away any lookup for a rename target, unless we're
being asked to revalidate a dentry that might be in use.
If nfs_lookup_revalidate() is called with LOOKUP_REVAL because a
previous path lookup failed, then we ought to force a full lookup
of the component name.
NFSv4 should not need to perform an extra close-to-open GETATTR as part
of the process of looking up a regular file, since the OPEN call will
do that for us.
Currently, if the NFS_INO_INVALID_ATTR flag is set, for instance by
a call to nfs_post_op_update_inode_locked(), then it will not be cleared
until all the attributes have been revalidated. This means, for instance,
that NFSv4 writes will always force a full attribute revalidation.
Track the ctime, mtime, size and change attribute separately from the
other attributes so that we can have nfs_post_op_update_inode_locked()
set them correctly, and later have the cache consistency bitmask be
able to clear them.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Move the delegation recall out of the generic code, and into the NFSv4
specific callback.
Move the delegation return out of generic code and down into the
NFSv4 specific unlink code.
Move the delegation return out of generic code.
This is a pure automated search-and-replace of the internal kernel
superblock flags.
The s_flags are now called SB_*, with the names and the values for the
moment mirroring the MS_* flags that they're equivalent to.
Note how the MS_xyz flags are the ones passed to the mount system call,
while the SB_xyz flags are what we then use in sb->s_flags.
The script to do this was:
# places to look in; re security/*: it generally should *not* be
# touched (that stuff parses mount(2) arguments directly), but
# there are two places where we really deal with superblock flags.
FILES="drivers/mtd drivers/staging/lustre fs ipc mm \
include/linux/fs.h include/uapi/linux/bfs_fs.h \
security/apparmor/apparmorfs.c security/apparmor/include/lib.h"
# the list of MS_... constants
SYMS="RDONLY NOSUID NODEV NOEXEC SYNCHRONOUS REMOUNT MANDLOCK \
DIRSYNC NOATIME NODIRATIME BIND MOVE REC VERBOSE SILENT \
POSIXACL UNBINDABLE PRIVATE SLAVE SHARED RELATIME KERNMOUNT \
I_VERSION STRICTATIME LAZYTIME SUBMOUNT NOREMOTELOCK NOSEC BORN \
ACTIVE NOUSER"
SED_PROG=
for i in $SYMS; do SED_PROG="$SED_PROG -e s/MS_$i/SB_$i/g"; done
# we want files that contain at least one of MS_...,
# with fs/namespace.c and fs/pnode.c excluded.
L=$(for i in $SYMS; do git grep -w -l MS_$i $FILES; done| sort|uniq|grep -v '^fs/namespace.c'|grep -v '^fs/pnode.c')
for f in $L; do sed -i $f $SED_PROG; done
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
"Stable bugfixes:
- Revalidate "." and ".." correctly on open
- Avoid RCU usage in tracepoints
- Fix ugly referral attributes
- Fix a typo in nomigration mount option
- Revert "NFS: Move the flock open mode check into nfs_flock()"
Features:
- Implement a stronger send queue accounting system for NFS over RDMA
- Switch some atomics to the new refcount_t type
- Clean up access mode bits
- Remove special-case revalidations in nfs_opendir()
- Improve invalidating NFS over RDMA memory for async operations that
time out
- Handle NFS over RDMA replies with a worqueue
- Handle NFS over RDMA sends with a workqueue
- Fix up replaying interrupted requests
- Remove dead NFS over RDMA definitions
- Update NFS over RDMA copyright information
- Be more consistent with bool initialization and comparisons
- Mark expected switch fall throughs
- Various sunrpc tracepoint cleanups
- Fix various OPEN races
- Fix a typo in nfs_rename()
- Use common error handling code in nfs_lock_and_join_request()
- Check that some structures are properly cleaned up during
net_exit()
- Remove net pointer from dprintk()s"
* tag 'nfs-for-4.15-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (62 commits)
NFS: Revert "NFS: Move the flock open mode check into nfs_flock()"
NFS: Fix typo in nomigration mount option
nfs: Fix ugly referral attributes
NFS: super: mark expected switch fall-throughs
sunrpc: remove net pointer from messages
nfs: remove net pointer from messages
sunrpc: exit_net cleanup check added
nfs client: exit_net cleanup check added
nfs/write: Use common error handling code in nfs_lock_and_join_requests()
NFSv4: Replace closed stateids with the "invalid special stateid"
NFSv4: nfs_set_open_stateid must not trigger state recovery for closed state
NFSv4: Check the open stateid when searching for expired state
NFSv4: Clean up nfs4_delegreturn_done
NFSv4: cleanup nfs4_close_done
NFSv4: Retry NFS4ERR_OLD_STATEID errors in layoutreturn
pNFS: Retry NFS4ERR_OLD_STATEID errors in layoutreturn-on-close
NFSv4: Don't try to CLOSE if the stateid 'other' field has changed
NFSv4: Retry CLOSE and DELEGRETURN on NFS4ERR_OLD_STATEID.
NFS: Fix a typo in nfs_rename()
NFSv4: Fix open create exclusive when the server reboots
On successful rename, the "old_dentry" is retained and is attached to
the "new_dir", so we need to call nfs_set_verifier() accordingly.
Bool initializations should use true and false. Bool tests don't need
comparisons.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
to READ_ONCE()/WRITE_ONCE()
Please do not apply this to mainline directly, instead please re-run the
coccinelle script shown below and apply its output.
For several reasons, it is desirable to use {READ,WRITE}_ONCE() in
preference to ACCESS_ONCE(), and new code is expected to use one of the
former. So far, there's been no reason to change most existing uses of
ACCESS_ONCE(), as these aren't harmful, and changing them results in
churn.
However, for some features, the read/write distinction is critical to
correct operation. To distinguish these cases, separate read/write
accessors must be used. This patch migrates (most) remaining
ACCESS_ONCE() instances to {READ,WRITE}_ONCE(), using the following
coccinelle script:
// Convert trivial ACCESS_ONCE() uses to equivalent READ_ONCE() and
// WRITE_ONCE()
// $ make coccicheck COCCI=/home/mark/once.cocci SPFLAGS="--include-headers" MODE=patch
virtual patch
@ depends on patch @
expression E1, E2;
- ACCESS_ONCE(E1) = E2
+ WRITE_ONCE(E1, E2)
expression E;
- ACCESS_ONCE(E)
+ READ_ONCE(E)
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: davem@davemloft.net
Cc: mpe@ellerman.id.au
Cc: shuah@kernel.org
Cc: snitzer@redhat.com
Cc: thor.thayer@linux.intel.com
Cc: tj@kernel.org
Cc: viro@zeniv.linux.org.uk
Cc: will.deacon@arm.com
Link: http://lkml.kernel.org/r/1508792849-3115-19-git-send-email-paulmck@linux.vnet.ibm.com
Commit f5a73672d181 ("NFS: allow close-to-open cache semantics to
apply to root of NFS filesystem") added a call to
__nfs_revalidate_inode() to nfs_opendir to as the lookup
process wouldn't reliable do this.
Subsequent commit a3fbbde70a0c ("VFS: we need to set LOOKUP_JUMPED
on mountpoint crossing") make this unnecessary. So remove the
unnecessary code.
For correct close-to-open semantics, NFS must validate
the change attribute of a directory (or file) on open.
Since commit ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a
d_weak_revalidate dentry op"), open() of "." or a path ending ".." is
not revalidated reliably (except when that direct is a mount point).
Prior to that commit, "." was revalidated using nfs_lookup_revalidate()
which checks the LOOKUP_OPEN flag and forces revalidation if the flag is
set.
Since that commit, nfs_weak_revalidate() is used for NFSv3 (which
ignores the flags) and nothing is used for NFSv4.
This is fixed by using nfs_lookup_verify_inode() in
nfs_weak_revalidate(). This does the revalidation exactly when needed.
Also, add a definition of .d_weak_revalidate for NFSv4.
The incorrect behavior is easily demonstrated by running "echo *" in
some non-mountpoint NFS directory while watching network traffic.
Without this patch, "echo *" sometimes doesn't produce any traffic.
With the patch it always does.
Fixes: ecf3d1f1aa74 ("vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op")
cc: stable@vger.kernel.org (3.9+)
The NFS_ACCESS_* flags aren't a 1:1 mapping to the MAY_* flags, so
checking for MAY_WHATEVER might have surprising results in
nfs*_proc_access(). Let's simplify this check when determining which
bits to ask for, and do it in a generic place instead of copying code
for each NFS version.
Passing the NFS v4 flags into the v3 code seems weird to me, even if
they are defined to the same values. This patch adds in generic flags
to help me feel better
This field hasn't been used since commit 57b691819ee2 ("NFS: Cache
access checks more aggressively").
Pull NFS client bugfixes from Anna Schumaker:
"Stable bugfix:
- Fix error reporting regression
Bugfixes:
- Fix setting filelayout ds address race
- Fix subtle access bug when using ACLs
- Fix setting mnt3_counts array size
- Fix a couple of pNFS commit races"
* tag 'nfs-for-4.13-2' of git://git.linux-nfs.org/projects/anna/linux-nfs:
NFS/filelayout: Fix racy setting of fl->dsaddr in filelayout_check_deviceid()
NFS: Be more careful about mapping file permissions
NFS: Store the raw NFS access mask in the inode's access cache
NFSv3: Convert nfs3_proc_access() to use nfs_access_set_mask()
NFS: Refactor NFS access to kernel access mask calculation
net/sunrpc/xprt_sock: fix regression in connection error reporting.
nfs: count correct array for mnt3_counts array size
Revert commit 722f0b891198 ("pNFS: Don't send COMMITs to the DSes if...")
pNFS/flexfiles: Handle expired layout segments in ff_layout_initiate_commit()
NFS: Fix another COMMIT race in pNFS
NFS: Fix a COMMIT race in pNFS
mount: copy the port field into the cloned nfs_server structure.
NFS: Don't run wake_up_bit() when nobody is waiting...
nfs: add export operations
When mapping a directory, we want the MAY_WRITE permissions to reflect
whether or not we have permission to modify, add and delete the directory
entries. MAY_EXEC must map to lookup permissions.
On the other hand, for files, we want MAY_WRITE to reflect a permission
to modify and extend the file.
"Stable bugfixes:
- Fix -EACCESS on commit to DS handling
- Fix initialization of nfs_page_array->npages
- Only invalidate dentries that are actually invalid
Features:
- Enable NFSoRDMA transparent state migration
- Add support for lookup-by-filehandle
- Add support for nfs re-exporting
- Christoph cleaned up the way we declare NFS operations
- Clean up various internal structures
- Various cleanups to commits
- Various improvements to error handling
- Set the dt_type of . and .. entries in NFS v4
- Make slot allocation more reliable
- Fix fscache stat printing
- Fix uninitialized variable warnings
- Fix potential list overrun in nfs_atomic_open()
- Fix a race in NFSoRDMA RPC reply handler
- Fix return size for nfs42_proc_copy()
- Fix against MAC forgery timing attacks"
* tag 'nfs-for-4.13-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (68 commits)
nfs4: add NFSv4 LOOKUPP handlers
nfs: add a nfs_ilookup helper
nfs: replace d_add with d_splice_alias in atomic_open
sunrpc: use constant time memory comparison for mac
NFSv4.2 fix size storage for nfs42_proc_copy
xprtrdma: Fix documenting comments in frwr_ops.c
xprtrdma: Replace PAGE_MASK with offset_in_page()
xprtrdma: FMR does not need list_del_init()
xprtrdma: Demote "connect" log messages
NFSv4.1: Use seqid returned by EXCHANGE_ID after state migration
NFSv4.1: Handle EXCHGID4_FLAG_CONFIRMED_R during NFSv4.1 migration
xprtrdma: Don't defer MR recovery if ro_map fails
xprtrdma: Fix FRWR invalidation error recovery
xprtrdma: Fix client lock-up after application signal fires
xprtrdma: Rename rpcrdma_req::rl_free
xprtrdma: Pass only the list of registered MRs to ro_unmap_sync
xprtrdma: Pre-mark remotely invalidated MRs
xprtrdma: On invalidation failure, remove MWs from rl_registered
It's a trival change but follows knfsd export document that asks
for d_splice_alias during lookup.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
A confused server could return a filehandle for an
NFSv4 OPEN request, which it previously returned for a directory.
So the inode returned by ->open_context() in nfs_atomic_open()
could conceivably be a directory inode.
This has particular implications for the call to
nfs_file_set_open_context() in nfs_finish_open().
If that is called on a directory inode, then the nfs_open_context
that gets stored in the filp->private_data will be linked to
nfs_inode->open_files.
When the directory is closed, nfs_closedir() will (ultimately)
free the ->private_data, but not unlink it from nfs_inode->open_files
(because it doesn't expect an nfs_open_context there).
Subsequently the memory could get used for something else and eventually
if the ->open_files list is walked, the walker will fall off the end and
crash.
So: change nfs_finish_open() to only call nfs_file_set_open_context()
for regular-file inodes.
This failure mode has been seen in a production setting (unknown NFS
server implementation). The kernel was v3.0 and the specific sequence
seen would not affect more recent kernels, but I think a risk is still
present, and caution is wise.
Since commit bafc9b754f75 ("vfs: More precise tests in d_invalidate")
in v3.18, a return of '0' from ->d_revalidate() will cause the dentry
to be invalidated even if it has filesystems mounted on or it or on a
descendant. The mounted filesystem is unmounted.
This means we need to be careful not to return 0 unless the directory
referred to truly is invalid. So -ESTALE or -ENOENT should invalidate
the directory. Other errors such a -EPERM or -ERESTARTSYS should be
returned from ->d_revalidate() so they are propagated to the caller.
A particular problem can be demonstrated by:
1/ mount an NFS filesystem using NFSv3 on /mnt
2/ mount any other filesystem on /mnt/foo
3/ ls /mnt/foo
4/ turn off network, or otherwise make the server unable to respond
5/ ls /mnt/foo &
6/ cat /proc/$!/stack # note that nfs_lookup_revalidate is in the call stack
7/ kill -9 $! # this results in -ERESTARTSYS being returned
8/ observe that /mnt/foo has been unmounted.
This patch changes nfs_lookup_revalidate() to only treat
-ESTALE from nfs_lookup_verify_inode() and
-ESTALE or -ENOENT from ->lookup()
as indicating an invalid inode. Other errors are returned.
Also nfs_check_inode_attributes() is changed to return -ESTALE rather
than -EIO. This is consistent with the error returned in similar
circumstances from nfs_update_inode().
As this bug allows any user to unmount a filesystem mounted on an NFS
filesystem, this fix is suitable for stable kernels.
Fixes: bafc9b754f75 ("vfs: More precise tests in d_invalidate")
Cc: stable@vger.kernel.org (v3.18+)
An interrupted rename will leave the old dentry behind if the rename
succeeds. Fix this by forcing a lookup the next time through
->d_revalidate.
A previous attempt at solving this problem took the approach to complete
the work of the rename asynchronously, however that approach was wrong
since it would allow the d_move() to occur after the directory's i_mutex
had been dropped by the original process.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
NFS uses some int, and unsigned int :1, and bool as flags in structs and
args. Assert the preference for uniformly replacing these with the bool
type.
This reverts commit 920b4530fb80430ff30ef83efe21ba1fa5623731 which could
call d_move() without holding the directory's i_mutex, and reverts commit
d4ea7e3c5c0e341c15b073016dbf3ab6c65f12f3 "NFS: Fix old dentry rehash after
move", which was a follow-up fix.
Fixes: 920b4530fb80 ("NFS: nfs_rename() handle -ERESTARTSYS dentry left behind")
Cc: stable@vger.kernel.org # v4.10+
