path: root/fs/nfs/client.c
2011-10-20Check validity of cl_rpcclient in nfs_server_list_showMalahal Naineni
As soon as the nfs_client gets created, its cl_rpcclient is set to ERR_PTR(-EINVAL). The rpc client structure is allocated later. Check if the client is ready before using the cl_rpcclient pointer. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-18nfs: fix bug about IPv6 address scope checkingMi Jinlong
The result from ipv6_addr_scope() always not be a single SCOPE, so we can't use equal to compare the result with IPV6_ADDR_SCOPE_LINKLOCAL at nfs_sockaddr_match_ipaddr6. This patch fixs the problem, and lets checking address before scope_id. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-31pnfsblock: add device operationsJim Rees
Signed-off-by: Jim Rees <rees@umich.edu> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> [upcall bugfixes] Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-31pnfs: ask for layout_blksize and save it in nfs_serverFred Isaman
Block layout needs it to determine IO size. Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Tao Guo <glorioustao@gmail.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Jim Rees <rees@umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-31pnfs: add set-clear layoutdriver interfaceBenny Halevy
To allow layout driver to issue getdevicelist at mount time, and clean up at umount time. [fixup non NFS_V4_1 set_pnfs_layoutdriver definition] [pnfs: pass mntfh down the init_pnfs path] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Jim Rees <rees@umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-15NFS: Convert nfs4_set_ds_client to EXPORT_SYMBOL_GPLTrond Myklebust
This is not part of an external ABI... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: move pnfs layouts to nfs_server structureWeston Andros Adamson
Layouts should be tracked per nfs_server (aka superblock) instead of per struct nfs_client, which may have multiple FSIDs associated with it. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: use scope from exchange_id to skip reclaimWeston Andros Adamson
can be skipped if the "eir_server_scope" from the exchange_id proc differs from previous calls. Also, in the future server_scope will be useful for determining whether client trunking is available Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-29NFSv4.1: purge deviceid cache on nfs_free_clientBenny Halevy
Use the pnfs_layoutdriver_type both as a qualifier for the deviceid, distinguishing deviceid from different layout types on the server, and for freeing the layout-driver allocated structure containing the nfs4_deviceid_node. [BUG in _deviceid_purge_client] [layout_driver MUST set free_deviceid_node if using dev-cache] [let ver < 4.1 compile] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> [removed EXPORT_SYMBOL_GPL(nfs4_deviceid_purge_client)] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-03-11NFSv4: Send unmapped uid/gids to the server when using auth_sysTrond Myklebust
The new behaviour is enabled using the new module parameter 'nfs4_disable_idmapping'. Note that if the server rejects an unmapped uid or gid, then the client will automatically switch back to using the idmapper. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: data server connectionAndy Adamson
Introduce a data server set_client and init session following the nfs4_set_client and nfs4_init_session convention. Once a new nfs_client is on the nfs_client_list, the nfs_client cl_cons_state serializes access to creating an nfs_client struct with matching properties. Use the new nfs_get_client() that initializes new clients. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: add MDS mount DS only checkAndy Adamson
The DS only role cannot be used to mount. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: new flag for lease time checkAndy Adamson
Data servers cannot send nfs4_proc_get_lease_time. but still need to setup state renewal. Add the NFS_CS_CHECK_LEASE_TIME bit to indicate if the lease time can be checked. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: new flag for state renewal checkAndy Adamson
Data servers not sharing a session with the mount MDS always have an empty cl_superblocks list. Replace the cl_superblocks empty list check to see if it is time to shut down renewd with the NFS_CS_STOP_RENEW bit which is not set by such a data server. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFS move nfs_client initialization into nfs_get_clientAndy Adamson
Now nfs_get_client returns an nfs_client ready to be used no matter if it was found or created. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS do not find client in NFSv4 pg_authenticateAndy Adamson
The information required to find the nfs_client cooresponding to the incoming back channel request is contained in the NFS layer. Perform minimal checking in the RPC layer pg_authenticate method, and push more detailed checking into the NFS layer where the nfs_client can be found. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS: Move cl_delegations to the nfs_server structChuck Lever
Delegations are per-inode, not per-nfs_client. When a server file system is migrated, delegations on the client must be moved from the source to the destination nfs_server. Make it easier to manage a mount point's delegation list across a migration event by moving the list to the nfs_server struct. Clean up: I added documenting comments to public functions I changed in this patch. For consistency I added comments to all the other public functions in fs/nfs/delegation.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS: Allow walking nfs_client.cl_superblocks list outside client.cChuck Lever
We're about to move some fields from struct nfs_client to struct nfs_server. There is a many-to-one relationship between nfs_servers and nfs_clients. After these fields are moved to the nfs_server struct, to visit all of the data in these fields that is owned by one nfs_client, code will need to visit each nfs_server on the cl_superblocks list for that nfs_client. To serialize changes to the cl_superblocks list during these little expeditions, protect the list with RCU. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06pnfs: layout roc codeFred Isaman
A layout can request return-on-close. How this interacts with the forgetful model of never sending LAYOUTRETURNS is a bit ambiguous. We forget any layouts marked roc, and wait for them to be completely forgotten before continuing with the close. In addition, to compensate for races with any inflight LAYOUTGETs, and the fact that we do not get any layout stateid back from the server, we set the barrier to the worst case scenario of current_seqid + number of outstanding LAYOUTGETS. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS refactor nfs_find_client and reference client across callback processingAndy Adamson
Fixes a bug where the nfs_client could be freed during callback processing. Refactor nfs_find_client to use minorversion specific means to locate the correct nfs_client structure. In the NFS layer, V4.0 clients are found using the callback_ident field in the CB_COMPOUND header. V4.1 clients are found using the sessionID in the CB_SEQUENCE operation which is also compared against the sessionID associated with the back channel thread after a successful CREATE_SESSION. Each of these methods finds the one an only nfs_client associated with the incoming callback request - so nfs_find_client_next is not needed. In the RPC layer, the pg_authenticate call needs to find the nfs_client. For the v4.0 callback service, the callback identifier has not been decoded so a search by address, version, and minorversion is used. The sessionid for the sessions based callback service has (usually) not been set for the pg_authenticate on a CB_NULL call which can be sent prior to the return of a CREATE_SESSION call, so the sessionid associated with the back channel thread is not used to find the client in pg_authenticate for CB_NULL calls. Pass the referenced nfs_client to each CB_COMPOUND operation being proceesed via the new cb_process_state structure. The reference is held across cb_compound processing. Use the new cb_process_state struct to move the NFS4ERR_RETRY_UNCACHED_REP processing from process_op into nfs4_callback_sequence where it belongs. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS implement v4.0 callback_identAndy Adamson
Use the small id to pointer translator service to provide a unique callback identifier per SETCLIENTID call used to identify the v4.0 callback service associated with the clientid. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS do not clear minor version at nfs_client freeAndy Adamson
Resetting the client minor version operations causes nfs4_destroy_callback to fail to shutdown the NFSv4.1 callback service. There is no reason to reset the client minorversion operations when the nfs_client struct is being freed. Remove the minorverion reset and rename the function. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
2010-10-26Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: net/sunrpc: Use static const char arrays nfs4: fix channel attribute sanity-checks NFSv4.1: Use more sensible names for 'initialize_mountpoint' NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO infrastructure NFSv4.1: pnfs: add LAYOUTGET and GETDEVICEINFO infrastructure NFS: client needs to maintain list of inodes with active layouts NFS: create and destroy inode's layout cache NFSv4.1: pnfs: filelayout: introduce minimal file layout driver NFSv4.1: pnfs: full mount/umount infrastructure NFS: set layout driver NFS: ask for layouttypes during v4 fsinfo call NFS: change stateid to be a union NFSv4.1: pnfsd, pnfs: protocol level pnfs constants SUNRPC: define xdr_decode_opaque_fixed NFSD: remove duplicate NFS4_STATEID_SIZE
2010-10-25Merge branch 'nfs-for-2.6.37' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.37' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (67 commits) SUNRPC: Cleanup duplicate assignment in rpcauth_refreshcred nfs: fix unchecked value Ask for time_delta during fsinfo probe Revalidate caches on lock SUNRPC: After calling xprt_release(), we must restart from call_reserve NFSv4: Fix up the 'dircount' hint in encode_readdir NFSv4: Clean up nfs4_decode_dirent NFSv4: nfs4_decode_dirent must clear entry->fattr->valid NFSv4: Fix a regression in decode_getfattr NFSv4: Fix up decode_attr_filehandle() to handle the case of empty fh pointer NFS: Ensure we check all allocation return values in new readdir code NFS: Readdir plus in v4 NFS: introduce generic decode_getattr function NFS: check xdr_decode for errors NFS: nfs_readdir_filler catch all errors NFS: readdir with vmapped pages NFS: remove page size checking code NFS: decode_dirent should use an xdr_stream SUNRPC: Add a helper function xdr_inline_peek NFS: remove readdir plus limit ...
2010-10-24NFSv4.1: pnfs: filelayout: add driver's LAYOUTGET and GETDEVICEINFO ↵Andy Adamson
infrastructure Implement the driver's io_ops->alloc_lseg and free_lseg functions, which integrate into the deviceid cache and calls out to nfs4_proc_getdeviceinfo when necessary. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFS: client needs to maintain list of inodes with active layoutsAndy Adamson
In particular, server reboot will invalidate all layouts. Note that in order to have an active layout, we must get a successful response from the server. To avoid adding that machinery, this patch just includes a stub that fakes up a successful return. Since the layout is never referenced for io, this is not a problem. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFS: set layout driverRicardo Labiaga
Put in the infrastructure that uses information returned from the server at mount to select a layout driver module. In this patch, a stub is used that always returns "no driver found". Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24Revalidate caches on lockRicardo Labiaga
Instead of blindly zapping the caches, attempt to revalidate them if the server has indicated that it uses high resolution timestamps. NFSv4 should be able to always revalidate the cache since the protocol requires the update of the change attribute on modification of the data. In reality, there are servers (the Linux NFS server for example) that do not obey this requirement and use ctime as the basis for change attribute. Long term, the server needs to be fixed. At this time, and to be on the safe side, continue zapping caches if the server indicates that it does not have a high resolution timestamp. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: Readdir plus in v4Bryan Schumaker
By requsting more attributes during a readdir, we can mimic the readdir plus operation that was in NFSv3. To test, I ran the command `ls -lU --color=none` on directories with various numbers of files. Without readdir plus, I see this: n files | 100 | 1,000 | 10,000 | 100,000 | 1,000,000 --------+-----------+-----------+-----------+-----------+---------- real | 0m00.153s | 0m00.589s | 0m05.601s | 0m56.691s | 9m59.128s user | 0m00.007s | 0m00.007s | 0m00.077s | 0m00.703s | 0m06.800s sys | 0m00.010s | 0m00.070s | 0m00.633s | 0m06.423s | 1m10.005s access | 3 | 1 | 1 | 4 | 31 getattr | 2 | 1 | 1 | 1 | 1 lookup | 104 | 1,003 | 10,003 | 100,003 | 1,000,003 readdir | 2 | 16 | 158 | 1,575 | 15,749 total | 111 | 1,021 | 10,163 | 101,583 | 1,015,784 With readdir plus enabled, I see this: n files | 100 | 1,000 | 10,000 | 100,000 | 1,000,000 --------+-----------+-----------+-----------+-----------+---------- real | 0m00.115s | 0m00.206s | 0m01.079s | 0m12.521s | 2m07.528s user | 0m00.003s | 0m00.003s | 0m00.040s | 0m00.290s | 0m03.296s sys | 0m00.007s | 0m00.020s | 0m00.120s | 0m01.357s | 0m17.556s access | 3 | 1 | 1 | 1 | 7 getattr | 2 | 1 | 1 | 1 | 1 lookup | 4 | 3 | 3 | 3 | 3 readdir | 6 | 62 | 630 | 6,300 | 62,993 total | 15 | 67 | 635 | 6,305 | 63,004 Readdir plus disabled has about a 16x increase in the number of rpc calls and is 4 - 5 times slower on large directories. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: readdir with vmapped pagesBryan Schumaker
We can use vmapped pages to read more information from the network at once. This will reduce the number of calls needed to complete a readdir. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> [trondmy: Added #include for linux/vmalloc.h> in fs/nfs/dir.c] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-01sunrpc: Add net to rpc_create_argsPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-23nfs: introduce mount option '-olocal_lock' to make locks localSuresh Jayaraman
NFS clients since 2.6.12 support flock locks by emulating fcntl byte-range locks. Due to this, some windows applications which seem to use both flock (share mode lock mapped as flock by Samba) and fcntl locks sequentially on the same file, can't lock as they falsely assume the file is already locked. The problem was reported on a setup with windows clients accessing excel files on a Samba exported share which is originally a NFS mount from a NetApp filer. Older NFS clients (< 2.6.12) did not see this problem as flock locks were considered local. To support legacy flock behavior, this patch adds a mount option "-olocal_lock=" which can take the following values: 'none' - Neither flock locks nor POSIX locks are local 'flock' - flock locks are local 'posix' - fcntl/POSIX locks are local 'all' - Both flock locks and POSIX locks are local Testing: - This patch was tested by using -olocal_lock option with different values and the NLM calls were noted from the network packet captured. 'none' - NLM calls were seen during both flock() and fcntl(), flock lock was granted, fcntl was denied 'flock' - no NLM calls for flock(), NLM call was seen for fcntl(), granted 'posix' - NLM call was seen for flock() - granted, no NLM call for fcntl() 'all' - no NLM calls were seen during both flock() and fcntl() - No bugs were seen during NFSv4 locking/unlocking in general and NFSv4 reboot recovery. Cc: Neil Brown <neilb@suse.de> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-12NFS: Fix a typo in nfs_sockaddr_match_ipaddr6Trond Myklebust
Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2010-06-22NFSv41: Cleanup for nfs4_alloc_session.Trond Myklebust
There is no reason to change the nfs_client state every time we allocate a new session. Move that line into nfs4_init_client_minor_version. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv41: Clean up the NFSv4.1 minor version specific operationsTrond Myklebust
2010-06-22NFSv4.1: Ensure that we initialise the session when following a referralTrond Myklebust
Put the code that is common to both the referral and ordinary mount cases into a common helper routine. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-14NFS: Reduce the stack footprint of nfs_create_serverTrond Myklebust
2010-05-14NFSv4: Eliminate nfs4_path_walk()Trond Myklebust
All we really want is the ability to retrieve the root file handle. We no longer need the ability to walk down the path, since that is now done in nfs_follow_remote_path(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-04-22NFS: rsize and wsize settings ignored on v4 mountsChuck Lever
NFSv4 mounts ignore the rsize and wsize mount options, and always use the default transfer size for both. This seems to be because all NFSv4 mounts are now cloned, and the cloning logic doesn't copy the rsize and wsize settings from the parent nfs_server. I tested Fedora's 2.6.32.11-99 and it seems to have this problem as well, so I'm guessing that .33, .32, and perhaps older kernels have this issue as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Stable <stable@kernel.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-04-12NFSv4: fix delegated lockingTrond Myklebust
Arnaud Giersch reports that NFSv4 locking is broken when we hold a delegation since commit 8e469ebd6dc32cbaf620e134d79f740bf0ebab79 (NFSv4: Don't allow posix locking against servers that don't support it). According to Arnaud, the lock succeeds the first time he opens the file (since we cannot do a delegated open) but then fails after we start using delegated opens. The following patch fixes it by ensuring that locking behaviour is governed by a per-filesystem capability flag that is initially set, but gets cleared if the server ever returns an OPEN without the NFS4_OPEN_RESULT_LOCKTYPE_POSIX flag being set. Reported-by: Arnaud Giersch <arnaud.giersch@iut-bm.univ-fcomte.fr> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02nfs: kill renewd before clearing client minor versionAlexandros Batsakis
renewd should be synchronously killed before we destroy the session in nfs4_clear_minor_version Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> [Trond.Myklebust@netapp.com: clean up to remove 'unused function warning when !CONFIG_NFS_V4] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: V2 adjust max_rqst_sz, max_resp_sz w.r.t to rsize, wsizeAlexandros Batsakis
The v4.1 client should take into account the desired rsize, wsize when negotiating the max size in CREATE_SESSION. Accordingly, it should use rsize, wsize that are smaller than the session negotiated values. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-06nfs: Avoid overrun when copying client IP address stringBen Hutchings
As seen in <http://bugs.debian.org/549002>, nfs4_init_client() can overrun the source string when copying the client IP address from nfs_parsed_mount_data::client_address to nfs_client::cl_ipaddr. Since these are both treated as null-terminated strings elsewhere, the copy should be done with strlcpy() not memcpy(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23NFS: Propagate 'fsc' mount option through automountsDavid Howells
Propagate the NFS 'fsc' mount option through NFS automounts of various types. This is now required as commit: commit c02d7adf8c5429727a98bad1d039bccad4c61c50 Author: Trond Myklebust <Trond.Myklebust@netapp.com> Date: Mon Jun 22 15:09:14 2009 -0400 NFSv4: Replace nfs4_path_walk() with VFS path lookup in a private namespace uses VFS-driven automounting to reach all submounts barring the root, thus preventing fscaching from being enabled on any submount other than the root. This patch gets around that by propagating the NFS_OPTION_FSCACHE flag across automounts. If a uniquifier is supplied to a mount then this is propagated to all automounts of that mount too. Signed-off-by: David Howells <dhowells@redhat.com> [Trond: Fixed up the definition of nfs_fscache_get_super_cookie for the case of #undef CONFIG_NFS_FSCACHE] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23NFS: Get rid of the NFS_MOUNT_VER3 and NFS_MOUNT_TCP flagsTrond Myklebust
Keep it in the case of the legacy binary mount interface, but purge it from the nfs_server structure. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21nfs: initialize the backing_dev_info when creating the serverJens Axboe
NFS may free the server structure without ever having used the bdi, so we either need to flag the bdi as being uninitialized or initialize it up front. This does the latter. This fixes a crash with mounting more than one NFS file system, should people ever need that kind of obscure NFS functionality. Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11Merge branch 'nfs-for-2.6.32'Trond Myklebust
