Lift IS_DEADDIR handling up into the part common with atomic_open(),
remove it from the latter. Collapse permission checks into the
call of may_o_create(), getting it closer to atomic_open() case.
do_last() and lookup_open() simpler that way and so does O_PATH
itself. As it bloody well should: we find what the pathname
resolves to, same way as in stat() et.al. and associate it with
FMODE_PATH struct file.
ta-da!
The main issue is the lack of down_write_killable(), so the places
like readdir.c switched to plain inode_lock(); once killable
variants of rwsem primitives appear, that'll be dealt with.
lockdep side also might need more work
If we *do* run into an in-lookup match, we need to wait for it to
cease being in-lookup. Fortunately, we do have unused space in
in-lookup dentries - d_lru is never looked at until it stops being
in-lookup.
So we can stash a pointer to wait_queue_head from stack frame of
the caller of ->lookup(). Some precautions are needed while
waiting, but it's not that hard - we do hold a reference to dentry
we are waiting for, so it can't go away. If it's found to be
in-lookup the wait_queue_head is still alive and will remain so
at least while ->d_lock is held. Moreover, the condition we
are waiting for becomes true at the same point where everything
on that wq gets woken up, so we can just add ourselves to the
queue once.
d_alloc_parallel() gets a pointer to wait_queue_head_t from its
caller; lookup_slow() adjusted, d_add_ci() taught to use
d_alloc_parallel() if the dentry passed to it happens to be
in-lookup one (i.e. if it's been called from the parallel lookup).
That's pretty much it - all that remains is to switch ->i_mutex
to rwsem and have lookup_slow() take it shared.
We will need to be able to check if there is an in-lookup
dentry with matching parent/name. Right now it's impossible,
but as soon as start locking directories shared such beasts
will appear.
Add a secondary hash for locating those. Hash chains go through
the same space where d_alias will be once it's not in-lookup anymore.
Search is done under the same bitlock we use for modifications -
with the primary hash we can rely on d_rehash() into the wrong
chain being the worst that could happen, but here the pointers are
buggered once it's removed from the chain. On the other hand,
the chains are not going to be long and normally we'll end up
adding to the chain anyway. That allows us to avoid bothering with
->d_lock when doing the comparisons - everything is stable until
removed from chain.
New helper: d_alloc_parallel(). Right now it allocates, verifies
that no hashed and in-lookup matches exist and adds to in-lookup
hash.
Returns ERR_PTR() for error, hashed match (in the unlikely case it's
been found) or new dentry. In-lookup matches trigger BUG() for
now; that will change in the next commit when we introduce waiting
for ongoing lookup to finish. Note that in-lookup matches won't be
possible until we actually go for shared locking.
lookup_slow() switched to use of d_alloc_parallel().
Again, these commits are separated only for making it easier to
review. All this machinery will start doing something useful only
when we go for shared locking; it's just that the combination is
too large for my taste.
marked as such when (would be) parallel lookup is about to pass them
to actual ->lookup(); unmarked when
* __d_add() is about to make it hashed, positive or not.
* __d_move() (from d_splice_alias(), directly or via
__d_unalias()) puts a preexisting dentry in its place
* in caller of ->lookup() if it has escaped all of the
above. Bug (WARN_ON, actually) if it reaches the final dput()
or d_instantiate() while still marked such.
As the result, we are guaranteed that for as long as the flag is
set, dentry will
* remain negative unhashed with positive refcount
* never have its ->d_alias looked at
* never have its ->d_lru looked at
* never have its ->d_parent and ->d_name changed
Right now we have at most one such for any given parent directory.
With parallel lookups that restriction will weaken to
* only exist when parent is locked shared
* at most one with given (parent,name) pair (comparison of
names is according to ->d_compare())
* only exist when there's no hashed dentry with the same
(parent,name)
Transition will take the next several commits; unfortunately, we'll
only be able to switch to rwsem at the end of this series. The
reason for not making it a single patch is to simplify review.
New primitives: d_in_lookup() (a predicate checking if dentry is in
the in-lookup state) and d_lookup_done() (tells the system that
we are done with lookup and if it's still marked as in-lookup, it
should cease to be such).
The rest of work.xattr stuff isn't needed for this branch
Commit 3034a14 "ima: pass 'opened' flag to identify newly created files"
stopped identifying empty files as new files. However new empty files
can be created using the mknodat syscall. On systems with IMA-appraisal
enabled, these empty files are not labeled with security.ima extended
attributes properly, preventing them from subsequently being opened in
order to write the file data contents. This patch defines a new hook
named ima_post_path_mknod() to mark these empty files, created using
mknodat, as new in order to allow the file data contents to be written.
In addition, files with security.ima xattrs containing a file signature
are considered "immutable" and can not be modified. The file contents
need to be written, before signing the file. This patch relaxes this
requirement for new files, allowing the file signature to be written
before the file contents.
Changelog:
- defer identifying files with signatures stored as security.ima
(based on Dmitry Rozhkov's comments)
- removing tests (eg. dentry, dentry->d_inode, inode->i_size == 0)
(based on Al's review)
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: Al Viro <<viro@zeniv.linux.org.uk>
Tested-by: Dmitry Rozhkov <dmitry.rozhkov@linux.intel.com>
* if we have a hashed negative dentry and either CREAT|EXCL on
r/o filesystem, or CREAT|TRUNC on r/o filesystem, or CREAT|EXCL
with failing may_o_create(), we should fail with EROFS or the
error may_o_create() has returned, but not ENOENT. Which is what
the current code ends up returning.
* if we have CREAT|TRUNC hitting a regular file on a read-only
filesystem, we can't fail with EROFS here. At the very least,
not until we'd done follow_managed() - we might have a writable
file (or a device, for that matter) bound on top of that one.
Moreover, the code downstream will see that O_TRUNC and attempt
to grab the write access (*after* following possible mount), so
if we really should fail with EROFS, it will happen. No need
to do that inside atomic_open().
The real logics is much simpler than what the current code is
trying to do - if we decided to go for simple lookup, ended
up with a negative dentry *and* had create_error set, fail with
create_error. No matter whether we'd got that negative dentry
from lookup_real() or had found it in dcache.
Cc: stable@vger.kernel.org # v3.6+
Acked-by: Miklos Szeredi <mszeredi@redhat.com>
... and neither can ever be NULL
Also drop the now unused readlink_copy export.
[dchinner: use d_inode(dentry) rather than dentry->d_inode]
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
lookup_one_len_unlocked()"
We should try to trigger automount *before* bailing out on negative dentry.
Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Reported-by: Arend van Spriel <arend@broadcom.com>
Tested-by: Arend van Spriel <arend@broadcom.com>
Tested-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
... as well as unix_mknod() and may_o_create()
the last user is gone
... and make mountpoint_last() use it. That makes all
candidates for lookup with parent locked shared go
through lookup_slow().
Return dentry and don't pass nameidata or path; lift crossing mountpoints
into the caller.
No need to lock parent just because of ->d_revalidate() on child;
contrary to the stale comment, lookup_dcache() *can* be used without
locking the parent. Result can be moved as soon as we return, of
course, but the same is true for lookup_one_len_unlocked() itself.
Have lookup_fast() return 1 on success and 0 on "need to fall back";
lookup_slow() and follow_managed() return positive (1) on success.
... and kill need_lookup thing
bugger off on negatives a bit earlier, simplify the tests
... or we risk seeing a bogus value of d_is_symlink() there.
Cc: stable@vger.kernel.org # v4.2+
... otherwise d_is_symlink() above might have nothing to do with
the inode value we've got.
both do_last() and walk_component() risk picking a NULL inode out
of dentry about to become positive, *then* checking its flags and
seeing that it's not negative anymore and using (already stale by
then) value they'd fetched earlier. Usually ends up oopsing soon
after that...
Cc: stable@vger.kernel.org # v3.13+
... into returning a positive to path_openat(), which would interpret that
as "symlink had been encountered" and proceed to corrupt memory, etc.
It can only happen due to a bug in some ->open() instance or in some LSM
hook, etc., so we report any such event *and* make sure it doesn't trick
us into further unpleasantness.
Cc: stable@vger.kernel.org # v3.6+, at least
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
We need information about exports when crossing mountpoints during
lookup or NFSv4 readdir. If we don't already have that information
cached, we may have to ask (and wait for) rpc.mountd.
In both cases we currently hold the i_mutex on the parent of the
directory we're asking rpc.mountd about. We've seen situations where
rpc.mountd performs some operation on that directory that tries to take
the i_mutex again, resulting in deadlock.
With some care, we may be able to avoid that in rpc.mountd. But it
seems better just to avoid holding a mutex while waiting on userspace.
It appears that lookup_one_len is pretty much the only operation that
needs the i_mutex. So we could just drop the i_mutex elsewhere and do
something like
mutex_lock()
lookup_one_len()
mutex_unlock()
In many cases though the lookup would have been cached and not required
the i_mutex, so it's more efficient to create a lookup_one_len() variant
that only takes the i_mutex when necessary.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
more or less along the lines of Neil's patchset, sans the insanity
around kmap().
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
microoptimization: in all callers *now is in the frame we are about to leave.
... and use it both in path_init() (for absolute pathnames) and
get_link() (for absolute symlinks).
that allows to kill the recheck of nd->seq on the way out in
this case, and this check on the way out is left only for
absolute pathnames.
we already zero it on outermost set_nameidata(), so initialization in
path_init() is pointless and wrong. The same DoS exists on pre-4.2
kernels, but there a slightly different fix will be needed.
Merge second patch-bomb from Andrew Morton:
- most of the rest of MM
- procfs
- lib/ updates
- printk updates
- bitops infrastructure tweaks
- checkpatch updates
- nilfs2 update
- signals
- various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc,
dma-debug, dma-mapping, ...
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits)
ipc,msg: drop dst nil validation in copy_msg
include/linux/zutil.h: fix usage example of zlib_adler32()
panic: release stale console lock to always get the logbuf printed out
dma-debug: check nents in dma_sync_sg*
dma-mapping: tidy up dma_parms default handling
pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode
kexec: use file name as the output message prefix
fs, seqfile: always allow oom killer
seq_file: reuse string_escape_str()
fs/seq_file: use seq_* helpers in seq_hex_dump()
coredump: change zap_threads() and zap_process() to use for_each_thread()
coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP
signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)
signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()
signal: turn dequeue_signal_lock() into kernel_dequeue_signal()
signals: kill block_all_signals() and unblock_all_signals()
nilfs2: fix gcc uninitialized-variable warnings in powerpc build
nilfs2: fix gcc unused-but-set-variable warnings
MAINTAINERS: nilfs2: add header file for tracing
nilfs2: add tracepoints for analyzing reading and writing metadata files
Pull trivial updates from Jiri Kosina:
"Trivial stuff from trivial tree that can be trivially summed up as:
- treewide drop of spurious unlikely() before IS_ERR() from Viresh
Kumar
- cosmetic fixes (that don't really affect basic functionality of the
driver) for pktcdvd and bcache, from Julia Lawall and Petr Mladek
- various comment / printk fixes and updates all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
bcache: Really show state of work pending bit
hwmon: applesmc: fix comment typos
Kconfig: remove comment about scsi_wait_scan module
class_find_device: fix reference to argument "match"
debugfs: document that debugfs_remove*() accepts NULL and error values
net: Drop unlikely before IS_ERR(_OR_NULL)
mm: Drop unlikely before IS_ERR(_OR_NULL)
fs: Drop unlikely before IS_ERR(_OR_NULL)
drivers: net: Drop unlikely before IS_ERR(_OR_NULL)
drivers: misc: Drop unlikely before IS_ERR(_OR_NULL)
UBI: Update comments to reflect UBI_METAONLY flag
pktcdvd: drop null test before destroy functions
There are many places which use mapping_gfp_mask to restrict a more
generic gfp mask which would be used for allocations which are not
directly related to the page cache but they are performed in the same
context.
Let's introduce a helper function which makes the restriction explicit and
easier to track. This patch doesn't introduce any functional changes.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
