path: root/fs/logfs/readwrite.c
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-22logfs: fix "Kernel BUG at readwrite.c:1193"Prasad Joshi
This happens when __logfs_create() tries to write a new inode to the disk which is full. __logfs_create() associates the transaction pointer with inode. During the logfs_write_inode() function call chain this transaction pointer is moved from inode to page->private using function move_inode_to_page (do_write_inode() -> inode_to_page() -> move_inode_to_page) When the write inode fails, the transaction is aborted and iput is called on the failed inode. During delete_inode the same transaction pointer associated with the page is getting used. Thus causing kernel BUG. The patch checks for error in write_inode() and restores the page->private to NULL. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=20162 Signed-off-by: Prasad Joshi <prasadjoshi124@gmail.com> Cc: Joern Engel <joern@logfs.org> Cc: Florian Mickler <florian@mickler.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Maciej Rutecki <maciej.rutecki@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09convert logfs to ->evict_inode()Al Viro
2010-08-09logfs: get rid of magical inodesAl Viro
ordering problems at ->kill_sb() time are solved by doing iput() of these suckers in ->put_super() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-04logfs: commit reservations under space pressureJoern Engel
Ensures we only return -ENOSPC when there really is no space. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: fix logfs_seek_hole()Joern Engel
logfs_seek_hole(inode, 0x200) would crap itself if the inode contained just 0x1ff (or fewer) blocks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-29LogFS: Fix typo in b6349ac8Joern Engel
2010-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Split large truncated into smaller chunks [LogFS] Set s_bdi [LogFS] Prevent mempool_destroy NULL pointer dereference [LogFS] Move assertion [LogFS] Plug 8 byte information leak [LogFS] Prevent memory corruption on large deletes [LogFS] Remove unused method Fix trivial conflict with added header includes in fs/logfs/super.c
2010-04-20[LogFS] Split large truncated into smaller chunksJoern Engel
Truncate would do an almost limitless amount of work without invoking the garbage collector in between. Split it up into more manageable, though still large, chunks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-15[LogFS] Prevent mempool_destroy NULL pointer dereferenceJoern Engel
It would probably be better to just accept NULL pointers in mempool_destroy(). But for the current -rc series let's keep things simple. This patch was lost in the cracks for a while. Kevin Cernekee <cernekee@gmail.com> had to rediscover the problem and send a similar patch because of it. :( Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-13[LogFS] Prevent memory corruption on large deletesJoern Engel
Removing sufficiently large files would create aliases for a large number of segments. This in turn results in a large number of journal entries and an overflow of s_je_array. Cheap fix is to add a BUG_ON, turning memory corruption into something annoying, but less dangerous. Real fix is to count the number of affected segments and prevent the problem completely. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-03-30[LogFS] Remove unused methodJoern Engel
All callers are long gone. Signed-off-by: Joern Engel <joern@logfs.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-28Prevent data corruption in logfs_rewrite_block()Joern Engel
The comment was correct, so make the code match the comment. As the new comment indicates, we might be able to do a little less work. But for the current -rc series let's keep it simple and just fix the bug. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-04[LogFS] Only write journal if dirtyJoern Engel
This prevents unnecessary journal writes. More importantly it prevents an oops due to a journal write on failed mount.
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
