path: root/fs/logfs/inode.c
2016-12-14logfs: remove from treeChristoph Hellwig
Logfs was introduced to the kernel in 2009, and hasn't seen any non drive-by changes since 2012, while having lots of unsolved issues including the complete lack of error handling, with more and more issues popping up without any fixes. The logfs.org domain has been bouncing from a mail, and the maintainer on the non-logfs.org domain hasn't repsonded to past queries either. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06logfs: don't duplicate page_symlink_inode_operationsAl Viro
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert logfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-23logfs: maintain the ordering of meta-inode destructionPrasad Joshi
LogFS does not use a specialized area to maintain the inodes. The inodes information is kept in a specialized file called inode file. Similarly, the segment information is kept in a segment file. Since the segment file also has an inode which is kept in the inode file, the inode for segment file must be evicted before the inode for inode file. The change fixes the following BUG during unmount Pid: 2057, comm: umount Not tainted 3.5.0-rc6+ #25 Bochs Bochs RIP: 0010:[<ffffffffa005c5f2>] [<ffffffffa005c5f2>] move_page_to_btree+0x32/0x1f0 [logfs] Process umount (pid: 2057, threadinfo ...) Call Trace: [<ffffffff8112adca>] ? find_get_pages+0x2a/0x180 [<ffffffffa00549f5>] logfs_invalidatepage+0x85/0x90 [logfs] [<ffffffff81136c51>] truncate_inode_page+0xb1/0xd0 [<ffffffff81136dcf>] truncate_inode_pages_range+0x15f/0x490 [<ffffffff81558549>] ? printk+0x78/0x7a [<ffffffff81137185>] truncate_inode_pages+0x15/0x20 [<ffffffffa005b7fc>] logfs_evict_inode+0x6c/0x190 [logfs] [<ffffffff8155c75b>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff8119e3d7>] evict+0xa7/0x1b0 [<ffffffff8119ea6e>] dispose_list+0x3e/0x60 [<ffffffff8119f1c4>] evict_inodes+0xf4/0x110 [<ffffffff81185b53>] generic_shutdown_super+0x53/0xf0 [<ffffffffa005d8f2>] logfs_kill_sb+0x52/0xf0 [logfs] [<ffffffff81185ec5>] deactivate_locked_super+0x45/0x80 [<ffffffff81186a4a>] deactivate_super+0x4a/0x70 [<ffffffff811a228e>] mntput_no_expire+0xde/0x140 [<ffffffff811a30ff>] sys_umount+0x6f/0x3a0 [<ffffffff8155d8e9>] system_call_fastpath+0x16/0x1b ---[ end trace 45f7752082cefafd ]--- Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-04-02logfs: destroy the reserved inodes while unmountingPrasad Joshi
We were assuming that the evict_inode() would never be called on reserved inodes. However, (after the commit 8e22c1a4e logfs: get rid of magical inodes) while unmounting the file system, in put_super, we call iput() on all of the reserved inodes. The following simple test used to cause a kernel panic on LogFS: 1. Mount a LogFS file system on /mnt 2. Create a file $ touch /mnt/a 3. Try to unmount the FS $ umount /mnt The simple fix would be to drop the assumption and properly destroy the reserved inodes. Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-31Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
There are few important bug fixes for LogFS * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: Logfs: Allow NULL block_isbad() methods logfs: Grow inode in delete path logfs: Free areas before calling generic_shutdown_super() logfs: remove useless BUG_ON MAINTAINERS: Add Prasad Joshi in LogFS maintiners logfs: Propagate page parameter to __logfs_write_inode logfs: set superblock shutdown flag after generic sb shutdown logfs: take write mutex lock during fsync and sync logfs: Prevent memory corruption logfs: update page reference count for pined pages Fix up conflict in fs/logfs/dev_mtd.c due to semantic change in what "mtd->block_isbad" means in commit f2933e86ad93: "Logfs: Allow NULL block_isbad() methods" clashing with the abstraction changes in the commits 7086c19d0742: "mtd: introduce mtd_block_isbad interface" and d58b27ed58a3: "logfs: do not use 'mtd->block_isbad' directly". This resolution takes the semantics from commit f2933e86ad93, and just makes mtd_block_isbad() return zero (false) if the 'block_isbad' function is NULL. But that also means that now "mtd_can_have_bb()" always returns 0. Now, "mtd_block_markbad()" will obviously return an error if the low-level driver doesn't support bad blocks, so this is somewhat non-symmetric, but it actually makes sense if a NULL "block_isbad" function is considered to mean "I assume that all my blocks are always good".
2012-01-28logfs: Propagate page parameter to __logfs_write_inodePrasad Joshi
During GC LogFS has to rewrite each valid block to a separate segment. Rewrite operation reads data from an old segment and writes it to a newly allocated segment. Since every write operation changes data block pointers maintained in inode, inode should also be rewritten. In GC path to avoid AB-BA deadlock LogFS marks a page with PG_pre_locked in addition to locking the page (PG_locked). The page lock is ignored iff the page is pre-locked. LogFS uses a special file called segment file. The segment file maintains an 8 bytes entry for every segment. It keeps track of erase count, level etc. for every segment. Bad things happen with a segment belonging to the segment file is GCed ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/readwrite.c:297! invalid opcode: 0000 [#1] SMP Modules linked in: logfs joydev usbhid hid psmouse e1000 i2c_piix4 serio_raw [last unloaded: logfs] Pid: 20161, comm: mount Not tainted 3.1.0-rc3+ #3 innotek GmbH VirtualBox EIP: 0060:[<f809132a>] EFLAGS: 00010292 CPU: 0 EIP is at logfs_lock_write_page+0x6a/0x70 [logfs] EAX: 00000027 EBX: f73f5b20 ECX: c16007c8 EDX: 00000094 ESI: 00000000 EDI: e59be6e4 EBP: c7337b28 ESP: c7337b18 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process mount (pid: 20161, ti=c7336000 task=eb323f70 task.ti=c7336000) Stack: f8099a3d c7337b24 f73f5b20 00001002 c7337b50 f8091f6d f8099a4d f80994e4 00000003 00000000 c7337b68 00000000 c67e4400 00001000 c7337b80 f80935e5 00000000 00000000 00000000 00000000 e1fcf000 0000000f e59be618 c70bf900 Call Trace: [<f8091f6d>] logfs_get_write_page.clone.16+0xdd/0x100 [logfs] [<f80935e5>] logfs_mod_segment_entry+0x55/0x110 [logfs] [<f809460d>] logfs_get_segment_entry+0x1d/0x20 [logfs] [<f8091060>] ? logfs_cleanup_journal+0x50/0x50 [logfs] [<f809521b>] ostore_get_erase_count+0x1b/0x40 [logfs] [<f80965b8>] logfs_open_area+0xc8/0x150 [logfs] [<c141a7ec>] ? kmemleak_alloc+0x2c/0x60 [<f809668e>] __logfs_segment_write.clone.16+0x4e/0x1b0 [logfs] [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<f809696f>] logfs_segment_write+0x17f/0x1d0 [logfs] [<f8092e8c>] logfs_write_i0+0x11c/0x180 [logfs] [<f8092f35>] logfs_write_direct+0x45/0x90 [logfs] [<f80934cd>] __logfs_write_buf+0xbd/0xf0 [logfs] [<c102900e>] ? kmap_atomic_prot+0x4e/0xe0 [<f809424b>] logfs_write_buf+0x3b/0x60 [logfs] [<f80947a9>] __logfs_write_inode+0xa9/0x110 [logfs] [<f8094cb0>] logfs_rewrite_block+0xc0/0x110 [logfs] [<f8095300>] ? get_mapping_page+0x10/0x60 [logfs] [<f8095aa0>] ? logfs_load_object_aliases+0x2e0/0x2f0 [logfs] [<f808e57d>] logfs_gc_segment+0x2ad/0x310 [logfs] [<f808e62a>] __logfs_gc_once+0x4a/0x80 [logfs] [<f808ed43>] logfs_gc_pass+0x683/0x6a0 [logfs] [<f8097a89>] logfs_mount+0x5a9/0x680 [logfs] [<c1126b21>] mount_fs+0x21/0xd0 [<c10f6f6f>] ? __alloc_percpu+0xf/0x20 [<c113da41>] ? alloc_vfsmnt+0xb1/0x130 [<c113db4b>] vfs_kern_mount+0x4b/0xa0 [<c113e06e>] do_kern_mount+0x3e/0xe0 [<c113f60d>] do_mount+0x34d/0x670 [<c10f2749>] ? strndup_user+0x49/0x70 [<c113fcab>] sys_mount+0x6b/0xa0 [<c142d87c>] syscall_call+0x7/0xb Code: f8 e8 8b 93 39 c9 8b 45 f8 3e 0f ba 28 00 19 d2 85 d2 74 ca eb d0 0f 0b 8d 45 fc 89 44 24 04 c7 04 24 3d 9a 09 f8 e8 09 92 39 c9 <0f> 0b 8d 74 26 00 55 89 e5 3e 8d 74 26 00 8b 10 80 e6 01 74 09 EIP: [<f809132a>] logfs_lock_write_page+0x6a/0x70 [logfs] SS:ESP 0068:c7337b18 ---[ end trace 96e67d5b3aa3d6ca ]--- The patch passes locked page to __logfs_write_inode. It calls function logfs_get_wblocks() to pre-lock the page. This ensures any further attempts to lock the page are ignored (esp from get_erase_count). Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: take write mutex lock during fsync and syncPrasad Joshi
LogFS uses super->s_write_mutex while writing data to disk. Taking the same mutex lock in sync and fsync code path solves the following BUG: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/dev_bdev.c:134! Pid: 2387, comm: flush-253:16 Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa007deed>] [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] Call Trace: [<ffffffffa007c381>] logfs_open_area+0x91/0x150 [logfs] [<ffffffff8128dcb2>] ? find_level.clone.9+0x62/0x100 [<ffffffffa007c49c>] __logfs_segment_write.clone.20+0x5c/0x190 [logfs] [<ffffffff810ef005>] ? mempool_kmalloc+0x15/0x20 [<ffffffff810ef383>] ? mempool_alloc+0x53/0x130 [<ffffffffa007c7a4>] logfs_segment_write+0x1d4/0x230 [logfs] [<ffffffffa0078f8e>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0079300>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0079444>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa00795b6>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa007a13e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa0073e33>] __logfs_writepage+0x23/0x80 [logfs] [<ffffffffa007410c>] logfs_writepage+0xdc/0x110 [logfs] [<ffffffff810f5ba7>] __writepage+0x17/0x40 [<ffffffff810f6208>] write_cache_pages+0x208/0x4f0 [<ffffffff810f5b90>] ? set_page_dirty+0x70/0x70 [<ffffffff810f653a>] generic_writepages+0x4a/0x70 [<ffffffff810f75d1>] do_writepages+0x21/0x40 [<ffffffff8116b9d1>] writeback_single_inode+0x101/0x250 [<ffffffff8116bdbd>] writeback_sb_inodes+0xed/0x1c0 [<ffffffff8116c5fb>] writeback_inodes_wb+0x7b/0x1e0 [<ffffffff8116cc23>] wb_writeback+0x4c3/0x530 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff8116cd6b>] wb_do_writeback+0xdb/0x290 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff814d6208>] ? _raw_spin_unlock_irqrestore+0x18/0x40 [<ffffffff8105aa5a>] ? del_timer+0x8a/0x120 [<ffffffff8116cfac>] bdi_writeback_thread+0x8c/0x2e0 [<ffffffff8116cf20>] ? wb_do_writeback+0x290/0x290 [<ffffffff8106d2e6>] kthread+0x96/0xa0 [<ffffffff814de514>] kernel_thread_helper+0x4/0x10 [<ffffffff8106d250>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814de510>] ? gs_change+0xb/0xb RIP [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] ---[ end trace 0211ad60a57657c4 ]--- Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-03logfs: propagate umode_tAl Viro
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-11-02logfs: remove unnecessary nlink settingMiklos Szeredi
alloc_inode() initializes i_nlink to 1. Remove unnecessary re-initialization. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Joern Engel <joern@logfs.org> CC: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-03-24fs: remove inode_lock from iput_final and prune_icacheDave Chinner
Now that inode state changes are protected by the inode->i_lock and the inode LRU manipulations by the inode_lru_lock, we can remove the inode_lock from prune_icache and the initial part of iput_final(). instead of using the inode_lock to protect the inode during iput_final, use the inode->i_lock instead. This protects the inode against new references being taken while we change the inode state to I_FREEING, as well as preventing prune_icache from grabbing the inode while we are manipulating it. Hence we no longer need the inode_lock in iput_final prior to setting I_FREEING on the inode. For prune_icache, we no longer need the inode_lock to protect the LRU list, and the inodes themselves are protected against freeing races by the inode->i_lock. Hence we can lift the inode_lock from prune_icache as well. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-08-09Make ->drop_inode() just return whether inode needs to be droppedAl Viro
... and let iput_final() do the actual eviction or retention Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09convert logfs to ->evict_inode()Al Viro
2010-08-09logfs: get rid of magical inodesAl Viro
ordering problems at ->kill_sb() time are solved by doing iput() of these suckers in ->put_super() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21logfs: replace inode uid,gid,mode initialization with helper functionAl Viro
2010-05-05logfs: fix syncJoern Engel
Rather self-explanatory. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-04logfs: initialize li->li_refcountPrasad Joshi
li_refcount was not re-initialized in function logfs_init_inode(), small patch that will fix the problem Signed-off-by: Prasad Joshi <prasadjoshi124@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: Close i_ino reuse raceJoern Engel
logfs_seek_hole() may return the same offset it is passed as argument. Found by Prasad Joshi <prasadjoshi124@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
