path: root/fs/logfs/dev_mtd.c
2010-10-29logfs: fix a leak in get_sbAl Viro
a) switch ->put_device() to logfs_super * b) actually call it on early failures in logfs_get_sb_device() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29logfs get_sb, part 3Al Viro
take logfs_get_sb_device() calls to logfs_get_sb() itself Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29logfs get_sb, part 2Al Viro
take setting s_bdev/s_mtd/s_devops to callers of logfs_get_sb_device(), don't bother passing them separately Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29logfs get_sb massage, part 1Al Viro
move allocation of logfs_super to logfs_get_sb, pass it to logfs_get_sb_...(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-07logfs: handle powerfail on NAND flashJoern Engel
The write buffer may not have been written and may no longer be written due to an interrupted write in the affected page. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-07logfs: handle errors from get_mtd_device()Dan Carpenter
The get_mtd_device() function returns error pointers on failure and if we don't handle it, it leads to a crash. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-04[LogFS] Fix bdev erasesJoern Engel
Erases for block devices were always just emulated by writing 0xff. Some time back the write was removed and only the page cache was changed to 0xff. Superficialy a good idea with two problems: 1. Touching the page cache isn't necessary either. 2. However, writing out 0xff _is_ necessary for the journal. As the journal is scanned linearly, an old non-overwritten commit entry can be used on next mount and cause havoc. This should fix both aspects.
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
