path: root/fs/locks.c
2020-03-06locks: fix a potential use-after-free problem when wakeup a waiteryangerkun
'16306a61d3b7 ("fs/locks: always delete_block after waiting.")' add the logic to check waiter->fl_blocker without blocked_lock_lock. And it will trigger a UAF when we try to wakeup some waiter: Thread 1 has create a write flock a on file, and now thread 2 try to unlock and delete flock a, thread 3 try to add flock b on the same file. Thread2 Thread3 flock syscall(create flock b) ...flock_lock_inode_wait flock_lock_inode(will insert our fl_blocked_member list to flock a's fl_blocked_requests) sleep flock syscall(unlock) ...flock_lock_inode_wait locks_delete_lock_ctx ...__locks_wake_up_blocks __locks_delete_blocks( b->fl_blocker = NULL) ... break by a signal locks_delete_block b->fl_blocker == NULL && list_empty(&b->fl_blocked_requests) success, return directly locks_free_lock b wake_up(&b->fl_waiter) trigger UAF Fix it by remove this logic, and this patch may also fix CVE-2019-19769. Cc: stable@vger.kernel.org Fixes: 16306a61d3b7 ("fs/locks: always delete_block after waiting.") Signed-off-by: yangerkun <yangerkun@huawei.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-12-29locks: print unsigned ino in /proc/locksAmir Goldstein
An ino is unsigned, so display it as such in /proc/locks. Cc: stable@vger.kernel.org Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-09-27Merge tag 'nfsd-5.4' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - Add a new knfsd file cache, so that we don't have to open and close on each (NFSv2/v3) READ or WRITE. This can speed up read and write in some cases. It also replaces our readahead cache. - Prevent silent data loss on write errors, by treating write errors like server reboots for the purposes of write caching, thus forcing clients to resend their writes. - Tweak the code that allocates sessions to be more forgiving, so that NFSv4.1 mounts are less likely to hang when a server already has a lot of clients. - Eliminate an arbitrary limit on NFSv4 ACL sizes; they should now be limited only by the backend filesystem and the maximum RPC size. - Allow the server to enforce use of the correct kerberos credentials when a client reclaims state after a reboot. And some miscellaneous smaller bugfixes and cleanup" * tag 'nfsd-5.4' of git://linux-nfs.org/~bfields/linux: (34 commits) sunrpc: clean up indentation issue nfsd: fix nfs read eof detection nfsd: Make nfsd_reset_boot_verifier_locked static nfsd: degraded slot-count more gracefully as allocation nears exhaustion. nfsd: handle drc over-allocation gracefully. nfsd: add support for upcall version 2 nfsd: add a "GetVersion" upcall for nfsdcld nfsd: Reset the boot verifier on all write I/O errors nfsd: Don't garbage collect files that might contain write errors nfsd: Support the server resetting the boot verifier nfsd: nfsd_file cache entries should be per net namespace nfsd: eliminate an unnecessary acl size limit Deprecate nfsd fault injection nfsd: remove duplicated include from filecache.c nfsd: Fix the documentation for svcxdr_tmpalloc() nfsd: Fix up some unused variable warnings nfsd: close cached files prior to a REMOVE or RENAME that would replace target nfsd: rip out the raparms cache nfsd: have nfsd_test_lock use the nfsd_file cache nfsd: hook up nfs4_preprocess_stateid_op to the nfsd_file cache ...
2019-08-20locks: fix a memory leak bug in __break_lease()Wenwen Wang
In __break_lease(), the file lock 'new_fl' is allocated in lease_alloc(). However, it is not deallocated in the following execution if smp_load_acquire() fails, leading to a memory leak bug. To fix this issue, free 'new_fl' before returning the error. Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-08-19nfsd: convert fi_deleg_file and ls_file fields to nfsd_fileJeff Layton
Have them keep an nfsd_file reference instead of a struct file. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2019-08-19locks: create a new notifier chain for lease attemptsJeff Layton
With the new file caching infrastructure in nfsd, we can end up holding files open for an indefinite period of time, even when they are still idle. This may prevent the kernel from handing out leases on the file, which is something we don't want to block. Fix this by running a SRCU notifier call chain whenever on any lease attempt. nfsd can then purge the cache for that inode before returning. Since SRCU is only conditionally compiled in, we must only define the new chain if it's enabled, and users of the chain must ensure that SRCU is enabled. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2019-07-25locks: Fix procfs output for file leasesPavel Begunkov
Since commit 778fc546f749c588aa2f ("locks: fix tracking of inprogress lease breaks"), leases break don't change @fl_type but modifies @fl_flags. However, procfs's part haven't been updated. Previously, for a breaking lease the target type was printed (see target_leasetype()), as returns fcntl(F_GETLEASE). But now it's always "READ", as F_UNLCK no longer means "breaking". Unlike the previous one, this behaviour don't provide a complete description of the lease. There are /proc/pid/fdinfo/ outputs for a lease (the same for READ and WRITE) breaked by O_WRONLY. -- before: lock: 1: LEASE BREAKING READ 2558 08:03:815793 0 EOF -- after: lock: 1: LEASE BREAKING UNLCK 2558 08:03:815793 0 EOF Signed-off-by: Pavel Begunkov <asml.silence@gmail.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-07-10Merge tag 'nfsd-5.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - Add a new /proc/fs/nfsd/clients/ directory which exposes some long-requested information about NFSv4 clients (like open files) and allows forced revocation of client state. - Replace the global duplicate reply cache by a cache per network namespace; previously, a request in one network namespace could incorrectly match an entry from another, though we haven't seen this in production. This is the last remaining container bug that I'm aware of; at this point you should be able to run separate nfsd's in each network namespace, each with their own set of exports, and everything should work. - Cleanup and modify lock code to show the pid of lockd as the owner of NLM locks. This is the correct version of the bugfix originally attempted in b8eee0e90f97 ("lockd: Show pid of lockd for remote locks")" * tag 'nfsd-5.3' of git://linux-nfs.org/~bfields/linux: (34 commits) nfsd: Make __get_nfsdfs_client() static nfsd: Make two functions static nfsd: Fix misuse of strlcpy sunrpc/cache: remove the exporting of cache_seq_next nfsd: decode implementation id nfsd: create xdr_netobj_dup helper nfsd: allow forced expiration of NFSv4 clients nfsd: create get_nfsdfs_clp helper nfsd4: show layout stateids nfsd: show lock and deleg stateids nfsd4: add file to display list of client's opens nfsd: add more information to client info file nfsd: escape high characters in binary data nfsd: copy client's address including port number to cl_addr nfsd4: add a client info file nfsd: make client/ directory names small ints nfsd: add nfsd/clients directory nfsd4: use reference count to free client nfsd: rename cl_refcount nfsd: persist nfsd filesystem across mounts ...
2019-07-03locks: Cleanup lm_compare_owner and lm_owner_keyBenjamin Coddington
After the update to use nlm_lockowners for the NLM server, there are no more users of lm_compare_owner and lm_owner_key. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2019-06-19locks: eliminate false positive conflicts for write leaseAmir Goldstein
check_conflicting_open() is checking for existing fd's open for read or for write before allowing to take a write lease. The check that was implemented using i_count and d_count is an approximation that has several false positives. For example, overlayfs since v4.19, takes an extra reference on the dentry; An open with O_PATH takes a reference on the dentry although the file cannot be read nor written. Change the implementation to use i_readcount and i_writecount to eliminate the false positive conflicts and allow a write lease to be taken on an overlayfs file. The change of behavior with existing fd's open with O_PATH is symmetric w.r.t. current behavior of lease breakers - an open with O_PATH currently does not break a write lease. This increases the size of struct inode by 4 bytes on 32bit archs when CONFIG_FILE_LOCKING is defined and CONFIG_IMA was not already defined. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-06-19locks: Add trace_leases_conflictIra Weiny
Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-05-21treewide: Add SPDX license identifier for missed filesThomas Gleixner
Add SPDX license identifiers to all files which: - Have no license information of any form - Have EXPORT_.*_SYMBOL_GPL inside which was used in the initial scan/conversion to ignore the file These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-15Merge tag 'nfsd-5.2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "This consists mostly of nfsd container work: Scott Mayhew revived an old api that communicates with a userspace daemon to manage some on-disk state that's used to track clients across server reboots. We've been using a usermode_helper upcall for that, but it's tough to run those with the right namespaces, so a daemon is much friendlier to container use cases. Trond fixed nfsd's handling of user credentials in user namespaces. He also contributed patches that allow containers to support different sets of NFS protocol versions. The only remaining container bug I'm aware of is that the NFS reply cache is shared between all containers. If anyone's aware of other gaps in our container support, let me know. The rest of this is miscellaneous bugfixes" * tag 'nfsd-5.2' of git://linux-nfs.org/~bfields/linux: (23 commits) nfsd: update callback done processing locks: move checks from locks_free_lock() to locks_release_private() nfsd: fh_drop_write in nfsd_unlink nfsd: allow fh_want_write to be called twice nfsd: knfsd must use the container user namespace SUNRPC: rsi_parse() should use the current user namespace SUNRPC: Fix the server AUTH_UNIX userspace mappings lockd: Pass the user cred from knfsd when starting the lockd server SUNRPC: Temporary sockets should inherit the cred from their parent SUNRPC: Cache the process user cred in the RPC server listener nfsd: Allow containers to set supported nfs versions nfsd: Add custom rpcbind callbacks for knfsd SUNRPC: Allow further customisation of RPC program registration SUNRPC: Clean up generic dispatcher code SUNRPC: Add a callback to initialise server requests SUNRPC/nfs: Fix return value for nfs4_callback_compound() nfsd: handle legacy client tracking records sent by nfsdcld nfsd: re-order client tracking method selection nfsd: keep a tally of RECLAIM_COMPLETE operations when using nfsdcld nfsd: un-deprecate nfsdcld ...
2019-05-07Merge tag 'Wimplicit-fallthrough-5.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux Pull Wimplicit-fallthrough updates from Gustavo A. R. Silva: "Mark switch cases where we are expecting to fall through. This is part of the ongoing efforts to enable -Wimplicit-fallthrough. Most of them have been baking in linux-next for a whole development cycle. And with Stephen Rothwell's help, we've had linux-next nag-emails going out for newly introduced code that triggers -Wimplicit-fallthrough to avoid gaining more of these cases while we work to remove the ones that are already present. We are getting close to completing this work. Currently, there are only 32 of 2311 of these cases left to be addressed in linux-next. I'm auditing every case; I take a look into the code and analyze it in order to determine if I'm dealing with an actual bug or a false positive, as explained here: https://lore.kernel.org/lkml/c2fad584-1705-a5f2-d63c-824e9b96cf50@embeddedor.com/ While working on this, I've found and fixed the several missing break/return bugs, some of them introduced more than 5 years ago. Once this work is finished, we'll be able to universally enable "-Wimplicit-fallthrough" to avoid any of these kinds of bugs from entering the kernel again" * tag 'Wimplicit-fallthrough-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gustavoars/linux: (27 commits) memstick: mark expected switch fall-throughs drm/nouveau/nvkm: mark expected switch fall-throughs NFC: st21nfca: Fix fall-through warnings NFC: pn533: mark expected switch fall-throughs block: Mark expected switch fall-throughs ASN.1: mark expected switch fall-through lib/cmdline.c: mark expected switch fall-throughs lib: zstd: Mark expected switch fall-throughs scsi: sym53c8xx_2: sym_nvram: Mark expected switch fall-through scsi: sym53c8xx_2: sym_hipd: mark expected switch fall-throughs scsi: ppa: mark expected switch fall-through scsi: osst: mark expected switch fall-throughs scsi: lpfc: lpfc_scsi: Mark expected switch fall-throughs scsi: lpfc: lpfc_nvme: Mark expected switch fall-through scsi: lpfc: lpfc_nportdisc: Mark expected switch fall-through scsi: lpfc: lpfc_hbadisc: Mark expected switch fall-throughs scsi: lpfc: lpfc_els: Mark expected switch fall-throughs scsi: lpfc: lpfc_ct: Mark expected switch fall-throughs scsi: imm: mark expected switch fall-throughs scsi: csiostor: csio_wr: mark expected switch fall-through ...
2019-04-24locks: move checks from locks_free_lock() to locks_release_private()NeilBrown
Code that allocates locks using locks_alloc_lock() will free it using locks_free_lock(), and will benefit from the BUG_ON() consistency checks therein. However some code (nfsd and lockd) allocate a lock embedded in some other data structure, and so free the lock themselves after calling locks_release_private(). This path does not benefit from the consistency checks. To help catch future errors, move the BUG_ON() checks to locks_release_private() - which locks_free_lock() already calls. This ensures that all users for locks will find out if the lock isn't detached properly before being free. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Jeff Layton <jlayton@kernel.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2019-04-08fs: mark expected switch fall-throughsGustavo A. R. Silva
In preparation to enabling -Wimplicit-fallthrough, mark switch cases where we are expecting to fall through. This patch fixes the following warnings: fs/affs/affs.h:124:38: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/configfs/dir.c:1692:11: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/configfs/dir.c:1694:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ceph/file.c:249:3: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/hash.c:233:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/hash.c:246:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext2/inode.c:1237:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext2/inode.c:1244:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1182:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1188:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1432:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1440:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/f2fs/node.c:618:8: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/f2fs/node.c:620:8: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/btrfs/ref-verify.c:522:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/gfs2/bmap.c:711:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/gfs2/bmap.c:722:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/jffs2/fs.c:339:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/nfsd/nfs4proc.c:429:12: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ufs/util.h:62:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ufs/util.h:43:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/fcntl.c:770:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/seq_file.c:319:10: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/libfs.c:148:11: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/libfs.c:150:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/signalfd.c:178:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/locks.c:1473:16: warning: this statement may fall through [-Wimplicit-fallthrough=] Warning level 3 was used: -Wimplicit-fallthrough=3 This patch is part of the ongoing efforts to enabling -Wimplicit-fallthrough. Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
2019-03-25locks: wake any locks blocked on request before deadlock checkJeff Layton
Andreas reported that he was seeing the tdbtorture test fail in some cases with -EDEADLCK when it wasn't before. Some debugging showed that deadlock detection was sometimes discovering the caller's lock request itself in a dependency chain. While we remove the request from the blocked_lock_hash prior to reattempting to acquire it, any locks that are blocked on that request will still be present in the hash and will still have their fl_blocker pointer set to the current request. This causes posix_locks_deadlock to find a deadlock dependency chain when it shouldn't, as a lock request cannot block itself. We are going to end up waking all of those blocked locks anyway when we go to reinsert the request back into the blocked_lock_hash, so just do it prior to checking for deadlocks. This ensures that any lock blocked on the current request will no longer be part of any blocked request chain. URL: https://bugzilla.kernel.org/show_bug.cgi?id=202975 Fixes: 5946c4319ebb ("fs/locks: allow a lock request to block other requests.") Cc: stable@vger.kernel.org Reported-by: Andreas Schneider <asn@redhat.com> Signed-off-by: Neil Brown <neilb@suse.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2019-02-28locking/percpu-rwsem: Remove preempt_disable variantsPeter Zijlstra
Effective revert commit: 87709e28dc7c ("fs/locks: Use percpu_down_read_preempt_disable()") This is causing major pain for PREEMPT_RT. Sebastian did a lot of lockperf runs on 2 and 4 node machines with all preemption modes (PREEMPT=n should be an obvious NOP for this patch and thus serves as a good control) and no results showed significance over 2-sigma (the PREEMPT=n results were almost empty at 1-sigma). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-01-02locks: fix error in locks_move_blocks()NeilBrown
After moving all requests from fl->fl_blocked_requests to new->fl_blocked_requests it is nonsensical to do anything to all the remaining elements, there aren't any. This should do something to all the requests that have been moved. For simplicity, it does it to all requests in the target list. Setting "f->fl_blocker = new" to all members of new->fl_blocked_requests is "obviously correct" as it preserves the invariant of the linkage among requests. Reported-by: syzbot+239d99847eb49ecb3899@syzkaller.appspotmail.com Fixes: 5946c4319ebb ("fs/locks: allow a lock request to block other requests.") Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-17locks: Use inode_is_open_for_writeNikolay Borisov
Use the aptly named function rather than open coding it. No functional changes. Signed-off-by: Nikolay Borisov <nborisov@suse.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-07fs/locks: remove unnecessary white space.NeilBrown
- spaces before tabs, - spaces at the end of lines, - multiple blank lines, - blank lines before EXPORT_SYMBOL, can all go. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-07fs/locks: merge posix_unblock_lock() and locks_delete_block()NeilBrown
posix_unblock_lock() is not specific to posix locks, and behaves nearly identically to locks_delete_block() - the former returning a status while the later doesn't. So discard posix_unblock_lock() and use locks_delete_block() instead, after giving that function an appropriate return value. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-07fs/locks: create a tree of dependent requests.NeilBrown
When we find an existing lock which conflicts with a request, and the request wants to wait, we currently add the request to a list. When the lock is removed, the whole list is woken. This can cause the thundering-herd problem. To reduce the problem, we make use of the (new) fact that a pending request can itself have a list of blocked requests. When we find a conflict, we look through the existing blocked requests. If any one of them blocks the new request, the new request is attached below that request, otherwise it is added to the list of blocked requests, which are now known to be mutually non-conflicting. This way, when the lock is released, only a set of non-conflicting locks will be woken, the rest can stay asleep. If the lock request cannot be granted and the request needs to be requeued, all the other requests it blocks will then be woken To make this more concrete: If you have a many-core machine, and have many threads all wanting to briefly lock a give file (udev is known to do this), you can get quite poor performance. When one thread releases a lock, it wakes up all other threads that are waiting (classic thundering-herd) - one will get the lock and the others go to sleep. When you have few cores, this is not very noticeable: by the time the 4th or 5th thread gets enough CPU time to try to claim the lock, the earlier threads have claimed it, done what was needed, and released. So with few cores, many of the threads don't end up contending. With 50+ cores, lost of threads can get the CPU at the same time, and the contention can easily be measured. This patchset creates a tree of pending lock requests in which siblings don't conflict and each lock request does conflict with its parent. When a lock is released, only requests which don't conflict with each other a woken. Testing shows that lock-acquisitions-per-second is now fairly stable even as the number of contending process goes to 1000. Without this patch, locks-per-second drops off steeply after a few 10s of processes. There is a small cost to this extra complexity. At 20 processes running a particular test on 72 cores, the lock acquisitions per second drops from 1.8 million to 1.4 million with this patch. For 100 processes, this patch still provides 1.4 million while without this patch there are about 700,000. Reported-and-tested-by: Martin Wilck <mwilck@suse.de> Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-07fs/locks: change all *_conflict() functions to return bool.NeilBrown
posix_locks_conflict() and flock_locks_conflict() both return int. leases_conflict() returns bool. This inconsistency will cause problems for the next patch if not fixed. So change posix_locks_conflict() and flock_locks_conflict() to return bool. Also change the locks_conflict() helper. And convert some return (foo); to return foo; Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-12-07fs/locks: always delete_block after waiting.NeilBrown
Now that requests can block other requests, we need to be careful to always clean up those blocked requests. Any time that we wait for a request, we might have other requests attached, and when we stop waiting, we must clean them up. If the lock was granted, the requests might have been moved to the new lock, though when merged with a pre-exiting lock, this might not happen. In all cases we don't want blocked locks to remain attached, so we remove them to be safe. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Tested-by: syzbot+a4a3d526b4157113ec6a@syzkaller.appspotmail.com Tested-by: kernel test robot <rong.a.chen@intel.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-11-30fs/locks: allow a lock request to block other requests.NeilBrown
Currently, a lock can block pending requests, but all pending requests are equal. If lots of pending requests are mutually exclusive, this means they will all be woken up and all but one will fail. This can hurt performance. So we will allow pending requests to block other requests. Only the first request will be woken, and it will wake the others. This patch doesn't implement this fully, but prepares the way. - It acknowledges that a request might be blocking other requests, and when the request is converted to a lock, those blocked requests are moved across. - When a request is requeued or discarded, all blocked requests are woken. - When deadlock-detection looks for the lock which blocks a given request, we follow the chain of ->fl_blocker all the way to the top. Tested-by: kernel test robot <rong.a.chen@intel.com> Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-11-30fs/locks: use properly initialized file_lock when unlocking.NeilBrown
Both locks_remove_posix() and locks_remove_flock() use a struct file_lock without calling locks_init_lock() on it. This means the various list_heads are not initialized, which will become a problem with a later patch. So change them both to initialize properly. For flock locks, this involves using flock_make_lock(), and changing it to allow a file_lock to be passed in, so memory allocation isn't always needed. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-11-30fs/locks: split out __locks_wake_up_blocks().NeilBrown
This functionality will be useful in future patches, so split it out from locks_wake_up_blocks(). Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-11-30fs/locks: rename some lists and pointers.NeilBrown
struct file lock contains an 'fl_next' pointer which is used to point to the lock that this request is blocked waiting for. So rename it to fl_blocker. The fl_blocked list_head in an active lock is the head of a list of blocked requests. In a request it is a node in that list. These are two distinct uses, so replace with two list_heads with different names. fl_blocked_requests is the head of a list of blocked requests fl_blocked_member is a node in a member of that list. The two different list_heads are never used at the same time, but that will change in a future patch. Note that a tracepoint is changed to report fl_blocker instead of fl_next. Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-08-21Merge tag 'ovl-update-4.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull overlayfs updates from Miklos Szeredi: "This contains two new features: - Stack file operations: this allows removal of several hacks from the VFS, proper interaction of read-only open files with copy-up, possibility to implement fs modifying ioctls properly, and others. - Metadata only copy-up: when file is on lower layer and only metadata is modified (except size) then only copy up the metadata and continue to use the data from the lower file" * tag 'ovl-update-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: (66 commits) ovl: Enable metadata only feature ovl: Do not do metacopy only for ioctl modifying file attr ovl: Do not do metadata only copy-up for truncate operation ovl: add helper to force data copy-up ovl: Check redirect on index as well ovl: Set redirect on upper inode when it is linked ovl: Set redirect on metacopy files upon rename ovl: Do not set dentry type ORIGIN for broken hardlinks ovl: Add an inode flag OVL_CONST_INO ovl: Treat metacopy dentries as type OVL_PATH_MERGE ovl: Check redirects for metacopy files ovl: Move some dir related ovl_lookup_single() code in else block ovl: Do not expose metacopy only dentry from d_real() ovl: Open file with data except for the case of fsync ovl: Add helper ovl_inode_realdata() ovl: Store lower data inode in ovl_inode ovl: Fix ovl_getattr() to get number of blocks from lower ovl: Add helper ovl_dentry_lowerdata() to get lower data dentry ovl: Copy up meta inode data from lowest data inode ovl: Modify ovl_lookup() and friends to lookup metacopy dentry ...
2018-08-21Merge branch 'siginfo-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull core signal handling updates from Eric Biederman: "It was observed that a periodic timer in combination with a sufficiently expensive fork could prevent fork from every completing. This contains the changes to remove the need for that restart. This set of changes is split into several parts: - The first part makes PIDTYPE_TGID a proper pid type instead something only for very special cases. The part starts using PIDTYPE_TGID enough so that in __send_signal where signals are actually delivered we know if the signal is being sent to a a group of processes or just a single process. - With that prep work out of the way the logic in fork is modified so that fork logically makes signals received while it is running appear to be received after the fork completes" * 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (22 commits) signal: Don't send signals to tasks that don't exist signal: Don't restart fork when signals come in. fork: Have new threads join on-going signal group stops fork: Skip setting TIF_SIGPENDING in ptrace_init_task signal: Add calculate_sigpending() fork: Unconditionally exit if a fatal signal is pending fork: Move and describe why the code examines PIDNS_ADDING signal: Push pid type down into complete_signal. signal: Push pid type down into __send_signal signal: Push pid type down into send_signal signal: Pass pid type into do_send_sig_info signal: Pass pid type into send_sigio_to_task & send_sigurg_to_task signal: Pass pid type into group_send_sig_info signal: Pass pid and pid type into send_sigqueue posix-timers: Noralize good_sigevent signal: Use PIDTYPE_TGID to clearly store where file signals will be sent pid: Implement PIDTYPE_TGID pids: Move the pgrp and session pid pointers from task_struct to signal_struct kvm: Don't open code task_pid in kvm_vcpu_ioctl pids: Compute task_tgid using signal->leader_pid ...
2018-08-13Merge tag 'locks-v4.19-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux Pull file locking updates from Jeff Layton: "Just a couple of patches from Konstantin to fix /proc/locks when the process that set the lock has exited, and a new tracepoint for the flock() codepath. Also threw in mailmap entries for my addresses and a comment cleanup" * tag 'locks-v4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux: locks: remove misleading obsolete comment mailmap: remap some of my email addresses to kernel.org address locks: add tracepoint in flock codepath fs/lock: show locks taken by processes from another pidns fs/lock: skip lock owner pid translation in case we are in init_pid_ns
2018-08-08locks: remove misleading obsolete commentJeff Layton
The spinlock handling in this file has changed significantly since this comment was written, and the file_lock_lock is no more. In addition, this overall comment no longer applies. Deleting an entry now requires both locks. Signed-off-by: Jeff Layton <jlayton@kernel.org>
2018-08-06locks: add tracepoint in flock codepathJeff Layton
2018-07-21signal: Use PIDTYPE_TGID to clearly store where file signals will be sentEric W. Biederman
When f_setown is called a pid and a pid type are stored. Replace the use of PIDTYPE_PID with PIDTYPE_TGID as PIDTYPE_TGID goes to the entire thread group. Replace the use of PIDTYPE_MAX with PIDTYPE_PID as PIDTYPE_PID now is only for a thread. Update the users of __f_setown to use PIDTYPE_TGID instead of PIDTYPE_PID. For now the code continues to capture task_pid (when task_tgid would really be appropriate), and iterate on PIDTYPE_PID (even when type == PIDTYPE_TGID) out of an abundance of caution to preserve existing behavior. Oleg Nesterov suggested using the test to ensure we use PIDTYPE_PID for tgid lookup also be used to avoid taking the tasklist lock. Suggested-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2018-07-18Partially revert "locks: fix file locking on overlayfs"Miklos Szeredi
This partially reverts commit c568d68341be7030f5647def68851e469b21ca11. Overlayfs files will now automatically get the correct locks, no need to hack overlay support in VFS. It is a partial revert, because it leaves the locks_inode() calls in place and defines locks_inode() to file_inode(). We could revert those as well, but it would be unnecessary code churn and it makes sense to document that we are getting the inode for locking purposes. Don't revert MS_NOREMOTELOCK yet since that has been part of the userspace API for some time (though not in a useful way). Will try to remove internal flags later when the dust around the new mount API settles. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Jeff Layton <jlayton@kernel.org>
2018-07-18Revert "vfs: do get_write_access() on upper layer of overlayfs"Miklos Szeredi
This reverts commit 4d0c5ba2ff79ef9f5188998b29fd28fcb05f3667. We now get write access on both overlay and underlying layers so this patch is no longer needed for correct operation. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-06-15Merge tag 'vfs-timespec64' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/playground Pull inode timestamps conversion to timespec64 from Arnd Bergmann: "This is a late set of changes from Deepa Dinamani doing an automated treewide conversion of the inode and iattr structures from 'timespec' to 'timespec64', to push the conversion from the VFS layer into the individual file systems. As Deepa writes: 'The series aims to switch vfs timestamps to use struct timespec64. Currently vfs uses struct timespec, which is not y2038 safe. The series involves the following: 1. Add vfs helper functions for supporting struct timepec64 timestamps. 2. Cast prints of vfs timestamps to avoid warnings after the switch. 3. Simplify code using vfs timestamps so that the actual replacement becomes easy. 4. Convert vfs timestamps to use struct timespec64 using a script. This is a flag day patch. Next steps: 1. Convert APIs that can handle timespec64, instead of converting timestamps at the boundaries. 2. Update internal data structures to avoid timestamp conversions' Thomas Gleixner adds: 'I think there is no point to drag that out for the next merge window. The whole thing needs to be done in one go for the core changes which means that you're going to play that catchup game forever. Let's get over with it towards the end of the merge window'" * tag 'vfs-timespec64' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/playground: pstore: Remove bogus format string definition vfs: change inode times to use struct timespec64 pstore: Convert internal records to timespec64 udf: Simplify calls to udf_disk_stamp_to_time fs: nfs: get rid of memcpys for inode times ceph: make inode time prints to be long long lustre: Use long long type to print inode time fs: add timespec64_truncate()
2018-06-14fs/lock: show locks taken by processes from another pidnsKonstantin Khorenko
Currently if we face a lock taken by a process invisible in the current pidns we skip the lock completely, but this 1) makes the output not that nice (root@vz7)/: cat /proc/${PID_A2}/fdinfo/3 pos: 4 flags: 02100002 mnt_id: 257 lock: (root@vz7)/: 2) makes it more difficult to debug issues with leaked flocks if you get error on lock, but don't see any locks in /proc/$id/fdinfo/$file Let's show information about such locks again as previously, but show zero in the owner pid field. After the patch: =============== (root@vz7)/:cat /proc/${PID_A2}/fdinfo/3 pos: 4 flags: 02100002 mnt_id: 295 lock: 1: FLOCK ADVISORY WRITE 0 b6:f8a61:529946 0 EOF Fixes: 9d5b86ac13c5 ("fs/locks: Remove fl_nspid and use fs-specific l_pid for remote locks") Signed-off-by: Konstantin Khorenko <khorenko@virtuozzo.com> Acked-by: Andrey Vagin <avagin@openvz.org> Reviewed-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2018-06-14fs/lock: skip lock owner pid translation in case we are in init_pid_nsKonstantin Khorenko
If the flock owner process is dead and its pid has been already freed, pid translation won't work, but we still want to show flock owner pid number when expecting /proc/$PID/fdinfo/$FD in init pidns. Reproducer: process A process A1 process A2 fork()---------> exit() open() flock() fork()---------> exit() sleep() Before the patch: ================ (root@vz7)/: cat /proc/${PID_A2}/fdinfo/3 pos: 4 flags: 02100002 mnt_id: 257 lock: (root@vz7)/: After the patch: =============== (root@vz7)/:cat /proc/${PID_A2}/fdinfo/3 pos: 4 flags: 02100002 mnt_id: 295 lock: 1: FLOCK ADVISORY WRITE ${PID_A1} b6:f8a61:529946 0 EOF Fixes: 9d5b86ac13c5 ("fs/locks: Remove fl_nspid and use fs-specific l_pid for remote locks") Signed-off-by: Konstantin Khorenko <khorenko@virtuozzo.com> Acked-by: Andrey Vagin <avagin@openvz.org> Reviewed-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2018-06-05vfs: change inode times to use struct timespec64Deepa Dinamani
struct timespec is not y2038 safe. Transition vfs to use y2038 safe struct timespec64 instead. The change was made with the help of the following cocinelle script. This catches about 80% of the changes. All the header file and logic changes are included in the first 5 rules. The rest are trivial substitutions. I avoid changing any of the function signatures or any other filesystem specific data structures to keep the patch simple for review. The script can be a little shorter by combining different cases. But, this version was sufficient for my usecase. virtual patch @ depends on patch @ identifier now; @@ - struct timespec + struct timespec64 current_time ( ... ) { - struct timespec now = current_kernel_time(); + struct timespec64 now = current_kernel_time64(); ... - return timespec_trunc( + return timespec64_trunc( ... ); } @ depends on patch @ identifier xtime; @@ struct \( iattr \| inode \| kstat \) { ... - struct timespec xtime; + struct timespec64 xtime; ... } @ depends on patch @ identifier t; @@ struct inode_operations { ... int (*update_time) (..., - struct timespec t, + struct timespec64 t, ...); ... } @ depends on patch @ identifier t; identifier fn_update_time =~ "update_time$"; @@ fn_update_time (..., - struct timespec *t, + struct timespec64 *t, ...) { ... } @ depends on patch @ identifier t; @@ lease_get_mtime( ... , - struct timespec *t + struct timespec64 *t ) { ... } @te depends on patch forall@ identifier ts; local idexpression struct inode *inode_node; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; identifier fn_update_time =~ "update_time$"; identifier fn; expression e, E3; local idexpression struct inode *node1; local idexpression struct inode *node2; local idexpression struct iattr *attr1; local idexpression struct iattr *attr2; local idexpression struct iattr attr; identifier i_xtime1 =~ "^i_[acm]time$"; identifier i_xtime2 =~ "^i_[acm]time$"; identifier ia_xtime1 =~ "^ia_[acm]time$"; identifier ia_xtime2 =~ "^ia_[acm]time$"; @@ ( ( - struct timespec ts; + struct timespec64 ts; | - struct timespec ts = current_time(inode_node); + struct timespec64 ts = current_time(inode_node); ) <+... when != ts ( - timespec_equal(&inode_node->i_xtime, &ts) + timespec64_equal(&inode_node->i_xtime, &ts) | - timespec_equal(&ts, &inode_node->i_xtime) + timespec64_equal(&ts, &inode_node->i_xtime) | - timespec_compare(&inode_node->i_xtime, &ts) + timespec64_compare(&inode_node->i_xtime, &ts) | - timespec_compare(&ts, &inode_node->i_xtime) + timespec64_compare(&ts, &inode_node->i_xtime) | ts = current_time(e) | fn_update_time(..., &ts,...) | inode_node->i_xtime = ts | node1->i_xtime = ts | ts = inode_node->i_xtime | <+... attr1->ia_xtime ...+> = ts | ts = attr1->ia_xtime | ts.tv_sec | ts.tv_nsec | btrfs_set_stack_timespec_sec(..., ts.tv_sec) | btrfs_set_stack_timespec_nsec(..., ts.tv_nsec) | - ts = timespec64_to_timespec( + ts = ... -) | - ts = ktime_to_timespec( + ts = ktime_to_timespec64( ...) | - ts = E3 + ts = timespec_to_timespec64(E3) | - ktime_get_real_ts(&ts) + ktime_get_real_ts64(&ts) | fn(..., - ts + timespec64_to_timespec(ts) ,...) ) ...+> ( <... when != ts - return ts; + return timespec64_to_timespec(ts); ...> ) | - timespec_equal(&node1->i_xtime1, &node2->i_xtime2) + timespec64_equal(&node1->i_xtime2, &node2->i_xtime2) | - timespec_equal(&node1->i_xtime1, &attr2->ia_xtime2) + timespec64_equal(&node1->i_xtime2, &attr2->ia_xtime2) | - timespec_compare(&node1->i_xtime1, &node2->i_xtime2) + timespec64_compare(&node1->i_xtime1, &node2->i_xtime2) | node1->i_xtime1 = - timespec_trunc(attr1->ia_xtime1, + timespec64_trunc(attr1->ia_xtime1, ...) | - attr1->ia_xtime1 = timespec_trunc(attr2->ia_xtime2, + attr1->ia_xtime1 = timespec64_trunc(attr2->ia_xtime2, ...) | - ktime_get_real_ts(&attr1->ia_xtime1) + ktime_get_real_ts64(&attr1->ia_xtime1) | - ktime_get_real_ts(&attr.ia_xtime1) + ktime_get_real_ts64(&attr.ia_xtime1) ) @ depends on patch @ struct inode *node; struct iattr *attr; identifier fn; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; expression e; @@ ( - fn(node->i_xtime); + fn(timespec64_to_timespec(node->i_xtime)); | fn(..., - node->i_xtime); + timespec64_to_timespec(node->i_xtime)); | - e = fn(attr->ia_xtime); + e = fn(timespec64_to_timespec(attr->ia_xtime)); ) @ depends on patch forall @ struct inode *node; struct iattr *attr; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; identifier fn; @@ { + struct timespec ts; <+... ( + ts = timespec64_to_timespec(node->i_xtime); fn (..., - &node->i_xtime, + &ts, ...); | + ts = timespec64_to_timespec(attr->ia_xtime); fn (..., - &attr->ia_xtime, + &ts, ...); ) ...+> } @ depends on patch forall @ struct inode *node; struct iattr *attr; struct kstat *stat; identifier ia_xtime =~ "^ia_[acm]time$"; identifier i_xtime =~ "^i_[acm]time$"; identifier xtime =~ "^[acm]time$"; identifier fn, ret; @@ { + struct timespec ts; <+... ( + ts = timespec64_to_timespec(node->i_xtime); ret = fn (..., - &node->i_xtime, + &ts, ...); | + ts = timespec64_to_timespec(node->i_xtime); ret = fn (..., - &node->i_xtime); + &ts); | + ts = timespec64_to_timespec(attr->ia_xtime); ret = fn (..., - &attr->ia_xtime, + &ts, ...); | + ts = timespec64_to_timespec(attr->ia_xtime); ret = fn (..., - &attr->ia_xtime); + &ts); | + ts = timespec64_to_timespec(stat->xtime); ret = fn (..., - &stat->xtime); + &ts); ) ...+> } @ depends on patch @ struct inode *node; struct inode *node2; identifier i_xtime1 =~ "^i_[acm]time$"; identifier i_xtime2 =~ "^i_[acm]time$"; identifier i_xtime3 =~ "^i_[acm]time$"; struct iattr *attrp; struct iattr *attrp2; struct iattr attr ; identifier ia_xtime1 =~ "^ia_[acm]time$"; identifier ia_xtime2 =~ "^ia_[acm]time$"; struct kstat *stat; struct kstat stat1; struct timespec64 ts; identifier xtime =~ "^[acmb]time$"; expression e; @@ ( ( node->i_xtime2 \| attrp->ia_xtime2 \| attr.ia_xtime2 \) = node->i_xtime1 ; | node->i_xtime2 = \( node2->i_xtime1 \| timespec64_trunc(...) \); | node->i_xtime2 = node->i_xtime1 = node->i_xtime3 = \(ts \| current_time(...) \); | node->i_xtime1 = node->i_xtime3 = \(ts \| current_time(...) \); | stat->xtime = node2->i_xtime1; | stat1.xtime = node2->i_xtime1; | ( node->i_xtime2 \| attrp->ia_xtime2 \) = attrp->ia_xtime1 ; | ( attrp->ia_xtime1 \| attr.ia_xtime1 \) = attrp2->ia_xtime2; | - e = node->i_xtime1; + e = timespec64_to_timespec( node->i_xtime1 ); | - e = attrp->ia_xtime1; + e = timespec64_to_timespec( attrp->ia_xtime1 ); | node->i_xtime1 = current_time(...); | node->i_xtime2 = node->i_xtime1 = node->i_xtime3 = - e; + timespec_to_timespec64(e); | node->i_xtime1 = node->i_xtime3 = - e; + timespec_to_timespec64(e); | - node->i_xtime1 = e; + node->i_xtime1 = timespec_to_timespec64(e); ) Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Cc: <anton@tuxera.com> Cc: <balbi@kernel.org> Cc: <bfields@fieldses.org> Cc: <darrick.wong@oracle.com> Cc: <dhowells@redhat.com> Cc: <dsterba@suse.com> Cc: <dwmw2@infradead.org> Cc: <hch@lst.de> Cc: <hirofumi@mail.parknet.co.jp> Cc: <hubcap@omnibond.com> Cc: <jack@suse.com> Cc: <jaegeuk@kernel.org> Cc: <jaharkes@cs.cmu.edu> Cc: <jslaby@suse.com> Cc: <keescook@chromium.org> Cc: <mark@fasheh.com> Cc: <miklos@szeredi.hu> Cc: <nico@linaro.org> Cc: <reiserfs-devel@vger.kernel.org> Cc: <richard@nod.at> Cc: <sage@redhat.com> Cc: <sfrench@samba.org> Cc: <swhiteho@redhat.com> Cc: <tj@kernel.org> Cc: <trond.myklebust@primarydata.com> Cc: <tytso@mit.edu> Cc: <viro@zeniv.linux.org.uk>
2018-05-16proc: introduce proc_create_seq_privateChristoph Hellwig
Variant of proc_create_data that directly take a struct seq_operations argument + a private state size and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-03-26treewide: Align function definition open/close bracesJoe Perches
Some functions definitions have either the initial open brace and/or the closing brace outside of column 1. Move those braces to column 1. This allows various function analyzers like gnu complexity to work properly for these modified functions. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Nicolin Chen <nicoleotsuka@gmail.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2018-02-08Merge tag 'nfsd-4.16' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd update from Bruce Fields: "A fairly small update this time around. Some cleanup, RDMA fixes, overlayfs fixes, and a fix for an NFSv4 state bug. The bigger deal for nfsd this time around was Jeff Layton's already-merged i_version patches" * tag 'nfsd-4.16' of git://linux-nfs.org/~bfields/linux: svcrdma: Fix Read chunk round-up NFSD: hide unused svcxdr_dupstr() nfsd: store stat times in fill_pre_wcc() instead of inode times nfsd: encode stat->mtime for getattr instead of inode->i_mtime nfsd: return RESOURCE not GARBAGE_ARGS on too many ops nfsd4: don't set lock stateid's sc_type to CLOSED nfsd: Detect unhashed stids in nfsd4_verify_open_stid() sunrpc: remove dead code in svc_sock_setbufsize svcrdma: Post Receives in the Receive completion handler nfsd4: permit layoutget of executable-only files lockd: convert nlm_rqst.a_count from atomic_t to refcount_t lockd: convert nlm_lockowner.count from atomic_t to refcount_t lockd: convert nsm_handle.sm_count from atomic_t to refcount_t
2018-02-08nfsd: encode stat->mtime for getattr instead of inode->i_mtimeAmir Goldstein
The values of stat->mtime and inode->i_mtime may differ for overlayfs and stat->mtime is the correct value to use when encoding getattr. This is also consistent with the fact that other attr times are also encoded from stat values. Both callers of lease_get_mtime() already have the value of stat->mtime, so the only needed change is that lease_get_mtime() will not overwrite this value with inode->i_mtime in case the inode does not have an exclusive lease. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Jeff Layton <jlayton@kernel.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2017-11-27Rename superblock flags (MS_xyz -> SB_xyz)Linus Torvalds
This is a pure automated search-and-replace of the internal kernel superblock flags. The s_flags are now called SB_*, with the names and the values for the moment mirroring the MS_* flags that they're equivalent to. Note how the MS_xyz flags are the ones passed to the mount system call, while the SB_xyz flags are what we then use in sb->s_flags. The script to do this was: # places to look in; re security/*: it generally should *not* be # touched (that stuff parses mount(2) arguments directly), but # there are two places where we really deal with superblock flags. FILES="drivers/mtd drivers/staging/lustre fs ipc mm \ include/linux/fs.h include/uapi/linux/bfs_fs.h \ security/apparmor/apparmorfs.c security/apparmor/include/lib.h" # the list of MS_... constants SYMS="RDONLY NOSUID NODEV NOEXEC SYNCHRONOUS REMOUNT MANDLOCK \ DIRSYNC NOATIME NODIRATIME BIND MOVE REC VERBOSE SILENT \ POSIXACL UNBINDABLE PRIVATE SLAVE SHARED RELATIME KERNMOUNT \ I_VERSION STRICTATIME LAZYTIME SUBMOUNT NOREMOTELOCK NOSEC BORN \ ACTIVE NOUSER" SED_PROG= for i in $SYMS; do SED_PROG="$SED_PROG -e s/MS_$i/SB_$i/g"; done # we want files that contain at least one of MS_..., # with fs/namespace.c and fs/pnode.c excluded. L=$(for i in $SYMS; do git grep -w -l MS_$i $FILES; done| sort|uniq|grep -v '^fs/namespace.c'|grep -v '^fs/pnode.c') for f in $L; do sed -i $f $SED_PROG; done Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-21locks: restore a warn for leaked locks on closeBenjamin Coddington
When locks.c moved to using file_lock_context, the check for any locks that were not released was moved from the __fput() to destroy_inode() path in commit 8634b51f6ca2 ("locks: convert lease handling to file_lock_context"). This warning has been quite useful for catching bugs, particularly in NFS where lock handling still sees some churn. Let's bring back the warning for leaked locks on __fput, as this warning is much more likely to be seen and reported by users. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2017-07-16fs/locks: Remove fl_nspid and use fs-specific l_pid for remote locksBenjamin Coddington
Since commit c69899a17ca4 "NFSv4: Update of VFS byte range lock must be atomic with the stateid update", NFSv4 has been inserting locks in rpciod worker context. The result is that the file_lock's fl_nspid is the kworker's pid instead of the original userspace pid. The fl_nspid is only used to represent the namespaced virtual pid number when displaying locks or returning from F_GETLK. There's no reason to set it for every inserted lock, since we can usually just look it up from fl_pid. So, instead of looking up and holding struct pid for every lock, let's just look up the virtual pid number from fl_pid when it is needed. That means we can remove fl_nspid entirely. The translaton and presentation of fl_pid should handle the following four cases: 1 - F_GETLK on a remote file with a remote lock: In this case, the filesystem should determine the l_pid to return here. Filesystems should indicate that the fl_pid represents a non-local pid value that should not be translated by returning an fl_pid <= 0. 2 - F_GETLK on a local file with a remote lock: This should be the l_pid of the lock manager process, and translated. 3 - F_GETLK on a remote file with a local lock, and 4 - F_GETLK on a local file with a local lock: These should be the translated l_pid of the local locking process. Fuse was already doing the correct thing by translating the pid into the caller's namespace. With this change we must update fuse to translate to init's pid namespace, so that the locks API can then translate from init's pid namespace into the pid namespace of the caller. With this change, the locks API will expect that if a filesystem returns a remote pid as opposed to a local pid for F_GETLK, that remote pid will be <= 0. This signifies that the pid is remote, and the locks API will forego translating that pid into the pid namespace of the local calling process. Finally, we convert remote filesystems to present remote pids using negative numbers. Have lustre, 9p, ceph, cifs, and dlm negate the remote pid returned for F_GETLK lock requests. Since local pids will never be larger than PID_MAX_LIMIT (which is currently defined as <= 4 million), but pid_t is an unsigned int, we should have plenty of room to represent remote pids with negative numbers if we assume that remote pid numbers are similarly limited. If this is not the case, then we run the risk of having a remote pid returned for which there is also a corresponding local pid. This is a problem we have now, but this patch should reduce the chances of that occurring, while also returning those remote pid numbers, for whatever that may be worth. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2017-07-16fs/locks: Use allocation rather than the stack in fcntl_getlk()Benjamin Coddington
Struct file_lock is fairly large, so let's save some space on the stack by using an allocation for struct file_lock in fcntl_getlk(), just as we do for fcntl_setlk(). Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2017-05-27fs/locks: pass kernel struct flock to fcntl_getlk/setlkChristoph Hellwig
This will make it easier to implement a sane compat fcntl syscall. [ jlayton: fix undeclared identifiers in 32-bit fcntl64 syscall handler ] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com>
