path: root/fs/lockd
2012-04-27lockd: fix the endianness bugAl Viro
commit e847469bf77a1d339274074ed068d461f0c872bc upstream. comparing be32 values for < is not doing the right thing... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02lockd: fix arg parsing for grace_period and timeout.NeilBrown
commit de5b8e8e047534aac6bc9803f96e7257436aef9c upstream. If you try to set grace_period or timeout via a module parameter to lockd, and do this on a big-endian machine where sizeof(int) != sizeof(unsigned long) it won't work. This number given will be effectively shifted right by the difference in those two sizes. So cast kp->arg properly to get correct result. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-15NLM: Don't hang forever on NLM unlock requestsTrond Myklebust
If the NLM daemon is killed on the NFS server, we can currently end up hanging forever on an 'unlock' request, instead of aborting. Basically, if the rpcbind request fails, or the server keeps returning garbage, we really want to quit instead of retrying. Tested-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-01-25NLM: Fix "kernel BUG at fs/lockd/host.c:417!" or ".../host.c:283!"Chuck Lever
Nick Bowler <nbowler@elliptictech.com> reports: > We were just having some NFS server troubles, and my client machine > running 2.6.38-rc1+ (specifically, commit 2b1caf6ed7b888c95) crashed > hard (syslog output appended to this mail). > > I'm not sure what the exact timeline was or how to reproduce this, > but the server was rebooted during all this. Since I've never seen > this happen before, it is possibly a regression from previous kernel > releases. However, I recently updated my nfs-utils (on the client) to > version 1.2.3, so that might be related as well. [ BUG output redacted ] When done searching, the for_each_host loop in next_host_state() falls through and returns the final host on the host chain without bumping it's reference count. Since the host's ref count is only one at that point, releasing the host in nlm_host_rebooted() attempts to destroy the host prematurely, and therefore hits a BUG(). Likely, the original intent of the for_each_host behavior in next_host_state() was to handle the case when the host chain is empty. Searching the chain and finding no suitable host to return needs to be handled as well. Defensively restructure next_host_state() always to return NULL when the loop falls through. Introduced by commit b10e30f6 "lockd: reorganize nlm_host_rebooted". Cc: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04lockd: double unlock in next_host_state()Dan Carpenter
We unlock again after we goto out. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Remove src_sap and src_len from nlm_lookup_host_info structChuck Lever
Clean up. The contents of the src_sap field is not used in nlm_alloc_host(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Remove nlm_lookup_host()Chuck Lever
Clean up. Remove the now unused helper nlm_lookup_host(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Make nrhosts an unsigned longChuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Rename nlm_hostsChuck Lever
Clean up. nlm_hosts now contains only server-side entries. Rename it to match convention of client side cache. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Clean up nlmsvc_lookup_host()Chuck Lever
Clean up. Change nlmsvc_lookup_host() to be purpose-built for server-side nlm_host management. This replaces the generic nlm_lookup_host() helper function, just like on the client side. The lookup logic is specialized for server host lookups. The server side cache also gets its own specialized equivalent of the nlm_release_host() function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Create client-side nlm_host cacheChuck Lever
NFS clients don't need the garbage collection processing that is performed on nlm_host structures. The client picks up an nlm_host at mount time and holds a reference to it until the file system is unmounted. Servers, on the other hand, don't have a precise way to tell when an nlm_host is no longer being used, so zero refcount nlm_host entries are left to expire in the cache after a time. Basically there's nothing holding a reference to an nlm_host between individual server-side NLM requests, but we can't afford the expense of recreating them for every new NLM request from a client. The nlm_host cache adds some lifetime hysteresis to entries in the cache so the next time a particular nlm_host is needed, it's likely to be discovered by a lookup rather than created from whole cloth. With the new implementation, client nlm_host cache items are no longer garbage collected, and are destroyed directly by a new release function specialized for client entries, nlmclnt_release_host(). They are cached in their own data structure, and have their own lookup logic, simplified and specialized for client nlm_host entries. However, the client nlm_host cache still shares reboot recovery logic with the server nlm_host cache. The NSM "peer rebooted" downcall for clients and servers still come through the same RPC call. This is a legacy formal API that would be difficult to alter, and besides, the user space NSM implementation can't tell the difference between peers that are clients or servers. For this reason, the client cache continues to share the nlm_host_mutex (and reboot recovery logic) with the server cache. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Split nlm_release_call()Chuck Lever
The nlm_release_call() function is invoked from both the server and the client side. We're about to introduce a distinct server- and client-side nlm_release_host(), so nlm_release_call() must first be split into a client-side and a server-side version. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Add nlm_destroy_host_locked()Chuck Lever
Refactor the tail of nlm_gc_hosts() into nlm_destroy_host() so that this logic can be used separately from garbage collection. Rename it _locked() to document that it must be called with the hosts cache mutex held. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Add nlm_alloc_host()Chuck Lever
Refactor nlm_host allocation and initialization into a separate function. This will be the common piece of server and client nlm_host lookup logic after the nlm_host cache is split. Small change: use kmalloc() instead of kzalloc(), as we're overwriting almost all fields in the new nlm_host struct with non-zero values immediately after it is allocated. An added benefit is we now have an explicit reference to each field name where it is initialized (for all you cscope fans out there). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: reorganize nlm_host_rebootedJ. Bruce Fields
Minor reorganization; no change in behavior. This will save some duplicated code after we split the client and server host caches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> [ cel: Forward-ported to 2.6.37 ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: define host_for_each{_safe} macrosJ. Bruce Fields
We've got a lot of loops like this, and I find them a little easier to read with the macros. More such loops are coming. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> [ cel: Forward-ported to 2.6.37 ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR decoder APIChuck Lever
Now that all client-side XDR decoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC res *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each decoder function. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR encoder APIChuck Lever
Now that all client-side XDR encoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each encoder function. Also, all the client-side encoder functions return 0 now, making a return value superfluous. Take this opportunity to convert them to return void instead. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NSM: Avoid return code checking in NSM XDR encoder functionsChuck Lever
Clean up. The trend in the other XDR encoder functions is to BUG() when encoding problems occur, since a problem here is always due to a local coding error. Then, instead of a status, zero is unconditionally returned. Update the NSM XDR encoders to behave this way. To finish the update, use the new-style be32_to_cpup() and cpu_to_be32() macros, and compute the buffer sizes using raw integers instead of sizeof(). This matches the conventions used in other XDR functions Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Move nlmdbg_cookie2a() to svclock.cChuck Lever
Clean up. nlmdbg_cookie2a() is used only in svclock.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Introduce new-style XDR functions for NLMv4Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also want to be able to pass xdr_streams from call_encode() to all XDR encoding functions, rather than building an xdr_stream in every XDR encoding function in the kernel. Same idea as the NLM v3 XDR overhaul. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Introduce new-style XDR functions for NLMv3Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also eventually want to be able to pass xdr_streams from call_encode() and call_decode() to all XDR encoding functions, rather than building an xdr_stream in every XDR encoding and decoding function in the kernel. To do all of this, rewrite the XDR encoding and decoding functions in fs/lockd/xdr.c to use xdr_streams. This makes them more or less incompatible with server-side XDR helper functions, so break them out into a separate source file. Static helper functions are left without the "inline" directive. This allows the compiler to choose automatically how to optimize these for size or speed. SHARE-related functionality doesn't seem to be used, as those functions are hiding behind a #define that isn't set anywhere that I can find. And, they've been in there forever (at least as far back as the kernel's git history goes), yet remain unused. Let's take the opportunity to bin them. It should be easy enough for someone to introduce proper XDR functions if at some point SHARE-related NLM functionality is desired. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15NLM: Fix a regression in lockdTrond Myklebust
Nick Bowler reports: There are no unusual messages on the client... but I just logged into the server and I see lots of messages of the following form: nfsd: request from insecure port (192.168.8.199:35766)! nfsd: request from insecure port (192.168.8.199:35766)! nfsd: request from insecure port (192.168.8.199:35766)! nfsd: request from insecure port (192.168.8.199:35766)! nfsd: request from insecure port (192.168.8.199:35766)! Bisected to commit 9247685088398cf21bcb513bd2832b4cd42516c4 (SUNRPC: Properly initialize sock_xprt.srcaddr in all cases) Apparently, removing the 'transport->srcaddr.ss_family = family' from xs_create_sock() triggers this due to nlmclnt_lookup_host() incorrectly initialising the srcaddr family to AF_UNSPEC. Reported-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-27lockd: fix nlmsvc_notify_blocked lockingJ. Bruce Fields
nlmsvc_notify_blocked walks the nlm_blocked list, which requires nlm_blocked_lock. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-27lockd: push lock_flocks downArnd Bergmann
lockd should use lock_flocks() instead of lock_kernel() to lock against posix locks accessing the i_flock list. This is a prerequisite to turning lock_flocks into a spinlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: J. Bruce Fields <bfields@redhat.com>
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
2010-10-01sunrpc: Add net to rpc_create_argsPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-01sunrpc: Add net argument to svc_create_xprtPavel Emelyanov
2010-09-22lockd: Mostly remove BKL from the serverBryan Schumaker
This patch removes all but one call to lock_kernel() from the server. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22lockd: Remove BKL from the clientBryan Schumaker
This patch removes all calls to lock_kernel() from the client. This patch should be applied after the "fs/lock.c prepare for BKL removal" patch submitted by Arnd Bergmann on September 18. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-08lockd: don't clear sm_monitored on nsm_reboot_lookupJeff Layton
When lockd gets a notify downcall from statd, it'll search its hosts cache and then clear the sm_monitored bit on the host it finds. The idea is apparently to make lockd redo a SM_MON on the next lock request. This is unnecessary and causes the kernel's NSM cache to go out of sync with statd. statd doesn't stop monitoring a host when it gets a SM_NOTIFY and there's no guarantee that another lock will occur after the reclaim and before the unmount. In that event, no SM_UNMON will occur. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-02-08lockd: release reference to nsm_handle in nlm_host_rebootedJeff Layton
nsm_reboot_lookup takes a reference to the nsm_handle that it returns, but nlm_host_rebooted never releases that reference. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-26SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt()Chuck Lever
Clean up: Bruce observed we have more or less common logic in each of svc_create_xprt()'s callers: the check to create an IPv6 RPC listener socket only if CONFIG_IPV6 is set. I'm about to add another case that does just the same. If we move the ifdefs into __svc_xpo_create(), then svc_create_xprt() call sites can get rid of the "#ifdef" ugliness, and can use the same logic with or without IPv6 support available in the kernel. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-14lockd: Remove un-used nfsd headers #includesBoaz Harrosh
In what history where these ever needed? Well not any more. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl fs: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22Merge branch 'for-2.6.32' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.32' of git://linux-nfs.org/~bfields/linux: (68 commits) nfsd4: nfsv4 clients should cross mountpoints nfsd: revise 4.1 status documentation sunrpc/cache: avoid variable over-loading in cache_defer_req sunrpc/cache: use list_del_init for the list_head entries in cache_deferred_req nfsd: return success for non-NFS4 nfs4_state_start nfsd41: Refactor create_client() nfsd41: modify nfsd4.1 backchannel to use new xprt class nfsd41: Backchannel: Implement cb_recall over NFSv4.1 nfsd41: Backchannel: cb_sequence callback nfsd41: Backchannel: Setup sequence information nfsd41: Backchannel: Server backchannel RPC wait queue nfsd41: Backchannel: Add sequence arguments to callback RPC arguments nfsd41: Backchannel: callback infrastructure nfsd4: use common rpc_cred for all callbacks nfsd4: allow nfs4 state startup to fail SUNRPC: Defer the auth_gss upcall when the RPC call is asynchronous nfsd4: fix null dereference creating nfsv4 callback client nfsd4: fix whitespace in NFSPROC4_CLNT_CB_NULL definition nfsd41: sunrpc: add new xprt class for nfsv4.1 backchannel sunrpc/cache: simplify cache_fresh_locked and cache_fresh_unlocked. ...
2009-09-22const: make lock_manager_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make file_lock_operations constAlexey Dobriyan
2009-08-21sunrpc: add routine for comparing addressesJeff Layton
lockd needs these sort of routines, as does the NFSv4 callback code. Move lockd's routines into common code and rename them so that they can be used by others. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-09lockd: Replace nsm_display_address() with rpc_ntop()Chuck Lever
2009-08-09lockd: Replace nlm_clear_port()Chuck Lever
Clean up: Use shared rpc_set_port() function instead of nlm_clear_port(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-17lockd: Don't bother with RPC ping for NSM upcallsChuck Lever
Cut NSM upcall RPC traffic in half -- don't do a NULL call first. The cases where a ping would be helpful are rare. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17lockd: Update NSM state from SM_MON repliesChuck Lever
When rpc.statd starts up in user space at boot time, it attempts to write the latest NSM local state number into /proc/sys/fs/nfs/nsm_local_state. If lockd.ko isn't loaded yet (as is the case in most configurations), that file doesn't exist, thus the kernel's NSM state remains set to its initial value of zero during lockd operation. This is a problem because rpc.statd and lockd use the NSM state number to prevent repeated lock recovery on rebooted hosts. If lockd sends a zero NSM state, but then a delayed SM_NOTIFY with a real NSM state number is received, there is no way for lockd or rpc.statd to distinguish that stale SM_NOTIFY from an actual reboot. Thus lock recovery could be performed after the rebooted host has already started reclaiming locks, and those locks will be lost. We could change /etc/init.d/nfslock so it always modprobes lockd.ko before starting rpc.statd. However, if lockd.ko is ever unloaded and reloaded, we are back at square one, since the NSM state is not preserved across an unload/reload cycle. This may happen frequently on clients that use automounter. A period of NFS inactivity causes lockd.ko to be unloaded, and the kernel loses its NSM state setting. Instead, let's use the fact that rpc.statd plants the local system's NSM state in every SM_MON (and SM_UNMON) reply. lockd performs a synchronous SM_MON upcall to the local rpc.statd _before_ sending its first NLM request to a new remote. This would permit rpc.statd to provide the current NSM state to lockd, even after lockd.ko had been unloaded and reloaded. Note that NLMPROC_LOCK arguments are constructed before the nsm_monitor() call, so we have to rearrange argument construction very slightly to make this all work out. And, the kernel appears to treat NSM state as a u32 (see struct nlm_args and nsm_res). Make nsm_local_state a u32 as well, to ensure we don't get bogus comparison results. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
