path: root/fs/jfs
2006-12-04[PATCH] severing fs.h, radix-tree.h -> sched.hAl Viro
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-02JFS: Remove redundant xattr permission checkingDave Kleikamp
The vfs handles most permissions for setting and retrieving xattrs. This patch removes a redundant and wrong check so that it won't override the correct behavior which is being fixed in the vfs. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-30jfs: Add splice supportDaniel Drake
This allows the splice() and tee() syscalls to be used with JFS. Signed-off-by: Daniel Drake <ddrake@brontes3d.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-13JFS: pageno needs to be longDave Kleikamp
diRead and diWrite are representing the page number as an unsigned int. This causes file system corruption on volumes larger than 16TB. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-10-02[PATCH] JFS: return correct error when i-node allocation failedAkinobu Mita
I have seen confusing behavior on JFS when I injected many intentional slab allocation errors. The cp command failed with no disk space error with enough disk space. This patch makes: - change the return value in case slab allocation failures happen from -ENOSPC to -ENOMEM - ialloc() return error code so that the caller can know the reason of failures Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from 2b46f77976f798f3fe800809a1d0ed38763c71c8 commit)
2006-10-02JFS: Remove shadow variable from fs/jfs/jfs_txnmgr.c:xtLog()Tony Breeds
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from bdc3d9e5af7d9c105be734dd7b5c3f1d9425a15a commit)
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] fs/jfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28JFS: Fix bug in quota code. tmp_bh.b_size must be initializedDave Kleikamp
2006-07-26JFS: Quota support broken, no quota_read and quota_writeDave Kleikamp
jfs_quota_read/write are very near duplicates of ext2_quota_read/write. Cleaned up jfs_get_block as long as I had to change it to be non-static. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: commit_mutex cleanups
2006-06-30typo fixes: aquire -> acquireAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05JFS: commit_mutex cleanupsEvgeniy Dushistov
I look at code, and see that 1)locks wasn't release in the opposite order in which they were taken 2)in jfs_rename we lock new_ip, and in "error path" we didn't unlock it 3)I see strange expression: "! !" May be this worth to fix? Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-05-24JFS: Fix multiple errors in metapage_releasepageDave Kleikamp
It looks like metapage_releasepage was making in invalid assumption that the releasepage method would not be called on a dirty page. Instead of issuing a warning and releasing the metapage, it should return 0, indicating that the private data for the page cannot be released. I also realized that metapage_releasepage had the return code all wrong. If it is successful in releasing the private data, it should return 1, otherwise it needs to return 0. Lastly, there is no need to call wait_on_page_writeback, since try_to_release_page will not call us with a page in writback state. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] remove ->get_blocks() supportBadari Pulavarty
Now that get_block() can handle mapping multiple disk blocks, no need to have ->get_blocks(). This patch removes fs specific ->get_blocks() added for DIO and makes it users use get_block() instead. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] map multiple blocks for mpage_readpages()Badari Pulavarty
This patch changes mpage_readpages() and get_block() to get the disk mapping information for multiple blocks at the same time. b_size represents the amount of disk mapping that needs to mapped. On the successful get_block() b_size indicates the amount of disk mapping thats actually mapped. Only the filesystems who care to use this information and provide multiple disk blocks at a time can choose to do so. No changes are needed for the filesystems who wants to ignore this. [akpm@osdl.org: cleanups] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: use mempool_create_slab_pool()Matthew Dobson
Modify well over a dozen mempool users to call mempool_create_slab_pool() rather than calling mempool_create() with extra arguments, saving about 30 lines of code and increasing readability. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->invalidatepage return voidNeilBrown
The return value of this function is never used, so let's be honest and declare it as void. Some places where invalidatepage returned 0, I have inserted comments suggesting a BUG_ON. [akpm@osdl.org: JBD BUG fix] [akpm@osdl.org: rework for git-nfs] [akpm@osdl.org: don't go BUG in block_invalidate_page()] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: fs/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Cc: Robert Love <rml@tech9.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09JFS: add uid, gid, and umask mount optionsDave Kleikamp
OS/2 doesn't initialize the uid, gid, or unix-style permission bits. The uid, gid, & umask mount options perform pretty much like those for the fat file system, overriding what is stored on disk. This is useful for users sharing the file system with OS/2. I implemented a little feature so that if you mask the execute bit, it will be re-enabled on directories when the appropriate read bit is unmasked. I didn't want to implement an fmask & dmask option. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-03-08JFS: Take logsync lock before testing mp->lsnDave Kleikamp
This fixes a race where lsn could be cleared before taking the lock Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-23JFS: kzalloc conversionEric Sesterhenn
this converts fs/jfs to kzalloc() usage. compile tested with make allyesconfig Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-22JFS: Add missing file from fa3241d24cf1182b0ffb6e4d412c3bc2a2ab7bf6Herbert Poetzl
My mistake here. I failed to checkin fs/jfs/ioctl.c Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-15JFS: Use the kthread_ APIChristoph Hellwig
Use the kthread_ API instead of opencoding lots of hairy code for kernel thread creation and teardown. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-10JFS: Fix regression. fsck complains if symlinks do not have INLINEEA attributeDave Kleikamp
2006-02-09JFS: ext2 inode attributes for jfsHerbert Poetzl
ext2 inode attributes with relevance for jfs: 'a' EXT2_APPEND_FL -> append only 'i' EXT2_IMMUTABLE_FL -> immutable file 's' EXT2_SECRM_FL -> zero file 'u' EXT2_UNRM_FL -> allow for unrm 'A' EXT2_NOATIME_FL -> no access time 'D' EXT2_DIRSYNC_FL -> dirsync 'S' EXT2_SYNC_FL -> sync overview of jfs flags (partially for OS/2) value (OS/2) Linux ext2 attrs ------------------------------------------------ 0x00010000 IFJOURNAL - 0x00020000 ISPARSE used 0x00040000 INLINEEA used 0x00080000 - - JFS_NOATIME_FL 0x00100000 - - JFS_DIRSYNC_FL 0x00200000 - - JFS_SYNC_FL 0x00400000 - - JFS_SECRM_FL 0x00800000 ISWAPFILE - JFS_UNRM_FL 0x01000000 - - JFS_APPEND_FL 0x02000000 IREADONLY - JFS_IMMUTABLE_FL 0x04000000 IHIDDEN - - 0x08000000 ISYSTEM - - 0x10000000 - - 0x20000000 IDIRECTORY used 0x40000000 IARCHIVE - 0x80000000 INEWNAME - the implementation is straight forward, except for the fact that the attributes have to be mapped to match with the ext2 ones to avoid a separate tool for manipulating them (this could be avoided when using a separate flag field in the on-disk representation, but the overhead is minimal) a special jfs_ioctl is added to allow for the new JFS_IOC_GETFLAGS and JFS_IOC_SETFLAGS calls. a helper function jfs_set_inode_flags() to transfer the flags from the on-disk version to the inode minor changes to allow flag inheritance on inode creation, as well as a cleanup of the on-disk flags (including the new ones) beforementioned helper to map between ext2 and jfs versions of the new flags ... the JFS_SECRM_FL and JFS_UNRM_FL are not done yet and I'm not 100% sure they are worth the effort, the rest seems to work out of the box ... Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-24JFS: semaphore to mutex conversion.Ingo Molnar
the conversion was generated via scripts, and the result was validated automatically via a script as well. build and boot tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-24Merge with /home/shaggy/git/linus-clean/Dave Kleikamp
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove jfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
