path: root/fs/jfs
2008-11-14CRED: Wrap task credential accesses in the JFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: jfs-discussion@lists.sourceforge.net Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] pass fmode_t to blkdev_put()Al Viro
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: move function-macros from quota.h to quotaops.hJan Kara
Move declarations of some macros, which should be in fact functions to quotaops.h. This way they can be later converted to inline functions because we can now use declarations from quota.h. Also add necessary includes of quotaops.h to a few files. [akpm@linux-foundation.org: fix JFS build] [akpm@linux-foundation.org: fix UFS build] [vegard.nossum@gmail.com: fix QUOTA=n build] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Arjen Pool <arjenpool@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-10jfs: remove DIRENTSIZAdrian Bunk
After fat gets fixed the unused DIRENTSIZ macro was the last user of struct dirent we should get rid of since the kernel and userspace versions differed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-05-28JFS: diAlloc() should return -EIO rather than EIOLi Zefan
The comment above the function says one of its return value is -EIO, and also the caller of diAlloc() checks for -EIO: struct inode *ialloc(struct inode *parent, umode_t mode) { ... rc = diAlloc(parent, S_ISDIR(mode), inode); if (rc) { jfs_warn("ialloc: diAlloc returned %d!", rc); if (rc == -EIO) make_bad_inode(inode); ... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-05-21JFS: skip bad iput() call in error pathDave Kleikamp
If jfs_iget() fails, we can't call iput() on the returned error. Thanks to Eric Sesterhenn's fuzzer testing for reporting the problem. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-05-13JFS: switch to seq_filesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-05-12JFS: 0 is not valid errno value so return NULL from jfs_lookupMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: jfs-discussion@lists.sourceforge.net Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2008-04-29proc: remove proc_root_fsAlexey Dobriyan
Use creation by full path instead: "fs/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-05jfs: replace __inline with inlineHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-02-13jfs: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: jfs-discussion@lists.sourceforge.net
2008-02-07BKL-removal: Implement a compat_ioctl handler for JFSAndi Kleen
The ioctls were already compatible except for the actual values so this was fairly easy to do. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-02-07BKL-removal: Use unlocked_ioctl for jfsAndi Kleen
Convert jfs_ioctl over to not use the BKL. The only potential race I could see was with two ioctls in parallel changing the flags and losing the updates. Use the i_mutex to protect against this. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-02-07iget: stop JFS from using iget() and read_inode()David Howells
Stop the JFS filesystem from using iget() and read_inode(). Replace jfs_read_inode() with jfs_iget(), and call that instead of iget(). jfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. jfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-24mount options: fix jfsMiklos Szeredi
Add iocharset= and errors= options to /proc/mounts for jfs filesystems. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-10JFS: simplify types to get rid of sparse warningDave Kleikamp
jfs_metapage.c was using uints and unsigned ints inconsistently when regular ints suffice. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03JFS: FIx one more plain integer as NULL pointer warningDave Kleikamp
2008-01-03JFS: Remove defconfig ptr comparison to 0Joe Perches
Remove sparse warning: Using plain integer as NULL pointer Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03JFS: use DIV_ROUND_UP where appropriateShaun Zinck
This replaces some macros and code, which do the same thing as DIV_ROUND_UP defined in kernel.h, to use the DIV_ROUND_UP macro. Signed-off-by: Shaun Zinck <shaun.zinck@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03Remove unnecessary kmalloc casts in the jfs filesystemJack Stone
Signed-off-by: Jack Stone <jack@hawkeye.stone.uk.eu.org> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03JFS is missing a memory barrierNick Piggin
JFS is missing a memory barrier needed to close the critical section before clearing the lock bit. Use lock bitops for this. unlock_page() has a second barrier after clearing the lock, which is required because it checks whether the waitqueue is active without locks. Such a barrier is not required here because the waitqueue spinlock is always taken (something to think about if performance is an issue). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03JFS: Make sure special inode data is written after journal is flushedDave Kleikamp
This patch makes sure that data that we tried to flush before the journal was completely written actually gets pushed to disk. To avoid duplicating code, moved common code to write_special_inodes(). Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-01-03JFS: clear PAGECACHE_TAG_DIRTY for no-write pagesDave Kleikamp
When JFS decides to drop a dirty metapage, it simply clears the META_dirty bit and leave alone the PG_dirty and PAGECACHE_TAG_DIRTY bits. When such no-write page goes to metapage_writepage(), the `relic' PAGECACHE_TAG_DIRTY tag should be cleared, to prevent pdflush from repeatedly trying to sync them. This is done through set_page_writeback(), so call it should be called in all cases. If no I/O is initiated, end_page_writeback() should be called immediately. This is how __block_write_full_page() does things. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> CC: Fengguang Wu <wfg@mail.ustc.edu.cn>
2007-11-14Forbid user to change file flags on quota filesJan Kara
Forbid user from changing file flags on quota files. User has no bussiness in playing with these flags when quota is on. Furthermore there is a remote possibility of deadlock due to a lock inversion between quota file's i_mutex and transaction's start (i_mutex for quota file is locked only when trasaction is started in quota operations) in ext3 and ext4. Signed-off-by: Jan Kara <jack@suse.cz> Cc: LIOU Payphone <lioupayphone@gmail.com> Cc: <linux-ext4@vger.kernel.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22jfs: new export opsChristoph Hellwig
Trivial switch over to the new generic helpers. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: restore nobhNick Piggin
Implement nobh in new aops. This is a bit tricky. FWIW, nobh_truncate is now implemented in a way that does not create blocks in sparse regions, which is a silly thing for it to have been doing (isn't it?) ext2 survives fsx and fsstress. jfs is converted as well... ext3 should be easy to do (but not done yet). [akpm@linux-foundation.org: coding-style fixes] Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16jfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14more low-hanging fruits - kernel, fs, lib signednessAl Viro
2007-10-13JFS: Bio cleanup: Replace missing return statementsDave Kleikamp
commit e30408b2a99cb7b8bf529c7dc2328a19d71894cf ("JFS: fix bio-related build breakage") removed some "return 0;" statements, rather than changing them to null returns. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12Fix up more bio falloutAl Viro
2007-10-11JFS: fix bio-related build breakageJeff Garzik
Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: remove iget abuseChristoph Hellwig
When the exportfs interface was added the expectation was that filesystems provide an operation to convert from a file handle to an inode/dentry, but it kept a backwards compat option that still calls into iget. Calling into iget from non-filesystem code is very bad, because it gives too little information to filesystem, and simply crashes if the filesystem doesn't implement the ->read_inode routine. Fortunately there are only two filesystems left using this fallback: efs and jfs. This patch moves a copy of export_iget to each of those to implement the get_dentry method. While this is a temporary increase of lines of code in the kernel it allows for a much cleaner interface and important code restructuring in later patches. [akpm@linux-foundation.org: add jfs_get_inode_flags() declaration] Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-13JFS: Update print_hex_dump() syntaxDave Kleikamp
