path: root/fs/jfs
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: remove iget abuseChristoph Hellwig
When the exportfs interface was added the expectation was that filesystems provide an operation to convert from a file handle to an inode/dentry, but it kept a backwards compat option that still calls into iget. Calling into iget from non-filesystem code is very bad, because it gives too little information to filesystem, and simply crashes if the filesystem doesn't implement the ->read_inode routine. Fortunately there are only two filesystems left using this fallback: efs and jfs. This patch moves a copy of export_iget to each of those to implement the get_dentry method. While this is a temporary increase of lines of code in the kernel it allows for a much cleaner interface and important code restructuring in later patches. [akpm@linux-foundation.org: add jfs_get_inode_flags() declaration] Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-13JFS: Update print_hex_dump() syntaxDave Kleikamp
2007-06-06JFS: use print_hex_dump() rather than private dump_mem() functionDave Kleikamp
2007-06-06JFS: Whitespace cleanup and remove some dead codeDave Kleikamp
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: Fix race waking up jfsIO kernel thread JFS: use __set_current_state() Copy i_flags to jfs inode flags on write JFS: document uid, gid, and umask mount options in jfs.txt
2007-05-05JFS: Fix race waking up jfsIO kernel threadDave Kleikamp
It's possible for a journal I/O request to be added to the log_redrive queue and the jfsIO thread to be awakened after the thread releases log_redrive_lock but before it sets its state to TASK_INTERRUPTIBLE. The jfsIO thread should set the state before giving up the spinlock, so the waking thread will really wake it. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2007-04-26JFS: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_* Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-04-25Copy i_flags to jfs inode flags on writeDave Kleikamp
This mirrors Jan Kara's patches for ext3. This patch makes sure that changes made to inode->i_flags are reflected on disk for jfs. It also moves a call of jfs_set_inode_flags() to be more consistent with where jfs_get_inode_flags() is called. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: Get rid of "may be used uninitialized" warnings
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-09JFS: Get rid of "may be used uninitialized" warningsDave Kleikamp
2007-01-26JFS: Remove incorrect kgdb defineDave Kleikamp
jfs_debug.h uses an incorrect CONFIG_KERNEL_ASSERT ifdef to redefine the assert macro for kgdb use. I believe the code worked a long time ago, but today it's not a valid config option. Since I'm not aware of anybody interested in debugging jfs with kgdb, it should just be removed. Thanks to Robert P. J. Day for reporting this. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2007-01-17JFS: call io_schedule() instead of schedule() to avoid deadlockDave Kleikamp
The introduction of Jens Axboe's explicit i/o plugging patches introduced a deadlock in jfs. This was caused by the process initiating I/O not unplugging the queue before waiting on the commit thread. The commit thread itself was waiting for that I/O to complete. Calling io_schedule() rather than schedule() unplugs the I/O queue avoiding the deadlock, and it appears to be the right function to call in any case. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2007-01-09JFS: Add lockdep annotationsDave Kleikamp
Yeah, it's about time. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2007-01-09JFS: Avoid BUG() on a damaged file systemDave Kleikamp
On Mon, 2006-12-18 at 19:51 +0100, Eric Sesterhenn wrote: > hi, > > while playing around with fsfuzzer, i got the following oops with jfs: > > [ 851.804875] BUG at fs/jfs/jfs_xtree.c:760 > assert(!BT_STACK_FULL(btstack)) > [ 851.805179] ------------[ cut here ]------------ > [ 851.805238] kernel BUG at fs/jfs/jfs_xtree.c:760! JFS should mark the superblock dirty and return an error rather than calling BUG(). Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-12-21[PATCH] Fix JFS after clear_page_dirty() removalDave Kleikamp
This patch removes some questionable code that attempted to make a no-longer-used page easier to reclaim. Calling metapage_writepage against such a page will not result in any I/O being performed, so removing this code shouldn't be a big deal. [ It's likely that we could have just replaced the "clear_page_dirty()" call with a call to "cancel_dirty_page()" instead, but in the meantime this is cleaner and simpler anyway, so unless there is some overriding reason (and Dave implies there isn't) I'll just use this patch as-is. - Linus ] Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: Fix conflicting superblock flags
2006-12-08[PATCH] struct path: convert jfsJosef Sipek
2006-12-07[PATCH] fs/*: trivial vsnprintf() conversionAlexey Dobriyan
It would very lame to get buffer overflow via one of the following. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06JFS: Fix conflicting superblock flagsDave Kleikamp
JFS_NOINTEGRITY and JFS_USRQUOTA are defined to be the same value. Change JFS_NOINTEGRITY to 0x40 and re-order the flags in the header file to avoid repeating this problem. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-12-04[PATCH] severing fs.h, radix-tree.h -> sched.hAl Viro
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-02JFS: Remove redundant xattr permission checkingDave Kleikamp
The vfs handles most permissions for setting and retrieving xattrs. This patch removes a redundant and wrong check so that it won't override the correct behavior which is being fixed in the vfs. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-30jfs: Add splice supportDaniel Drake
This allows the splice() and tee() syscalls to be used with JFS. Signed-off-by: Daniel Drake <ddrake@brontes3d.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-13JFS: pageno needs to be longDave Kleikamp
diRead and diWrite are representing the page number as an unsigned int. This causes file system corruption on volumes larger than 16TB. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-10-02[PATCH] JFS: return correct error when i-node allocation failedAkinobu Mita
I have seen confusing behavior on JFS when I injected many intentional slab allocation errors. The cp command failed with no disk space error with enough disk space. This patch makes: - change the return value in case slab allocation failures happen from -ENOSPC to -ENOMEM - ialloc() return error code so that the caller can know the reason of failures Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from 2b46f77976f798f3fe800809a1d0ed38763c71c8 commit)
2006-10-02JFS: Remove shadow variable from fs/jfs/jfs_txnmgr.c:xtLog()Tony Breeds
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from bdc3d9e5af7d9c105be734dd7b5c3f1d9425a15a commit)
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] fs/jfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28JFS: Fix bug in quota code. tmp_bh.b_size must be initializedDave Kleikamp
