path: root/fs/jfs/xattr.c
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-13JFS: Update print_hex_dump() syntaxDave Kleikamp
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-06-06JFS: use print_hex_dump() rather than private dump_mem() functionDave Kleikamp
2007-06-06JFS: Whitespace cleanup and remove some dead codeDave Kleikamp
2006-11-02JFS: Remove redundant xattr permission checkingDave Kleikamp
The vfs handles most permissions for setting and retrieving xattrs. This patch removes a redundant and wrong check so that it won't override the correct behavior which is being fixed in the vfs. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-10-01[PATCH] fs/jfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-24JFS: semaphore to mutex conversion.Ingo Molnar
the conversion was generated via scripts, and the result was validated automatically via a script as well. build and boot tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove jfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01JFS: Implement jfs_init_securityDave Kleikamp
This atomically initializes the security xattr when an object is created Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-01JFS: allow extended attributes to be set within a existing transactionDave Kleikamp
2005-07-13JFS: Need to be root to create files with security contextIan Dall
It turns out this is due to some inverted logic in xattr.c Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-13JFS: Allow security.* xattrs to be set on symlinksDave Kleikamp
All of the different xattr namespaces have different rules. user.* and ACL's are not allowed on symlinks, and since these were the first xattrs implemented, I assumed there was no need to support xattrs on symlinks. This one-line patch should fix it. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-06-23[PATCH] remove <linux/xattr_acl.h>Christoph Hellwig
This file duplicates <linux/posix_acl_xattr.h>, using slightly different names. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-09JFS: Remove redundant kfree() NULL pointer checksJesper Juhl
kfree() can handle a NULL pointer, don't worry about passing it one. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
