path: root/fs/jffs2
2018-05-30jffs2: Fix use-after-free bug in jffs2_iget()'s error handling pathJake Daryll Obina
[ Upstream commit 5bdd0c6f89fba430e18d636493398389dadc3b17 ] If jffs2_iget() fails for a newly-allocated inode, jffs2_do_clear_inode() can get called twice in the error handling path, the first call in jffs2_iget() itself and the second through iget_failed(). This can result to a use-after-free error in the second jffs2_do_clear_inode() call, such as shown by the oops below wherein the second jffs2_do_clear_inode() call was trying to free node fragments that were already freed in the first jffs2_do_clear_inode() call. [ 78.178860] jffs2: error: (1904) jffs2_do_read_inode_internal: CRC failed for read_inode of inode 24 at physical location 0x1fc00c [ 78.178914] Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b6b7b [ 78.185871] pgd = ffffffc03a567000 [ 78.188794] [6b6b6b6b6b6b6b7b] *pgd=0000000000000000, *pud=0000000000000000 [ 78.194968] Internal error: Oops: 96000004 [#1] PREEMPT SMP ... [ 78.513147] PC is at rb_first_postorder+0xc/0x28 [ 78.516503] LR is at jffs2_kill_fragtree+0x28/0x90 [jffs2] [ 78.520672] pc : [<ffffff8008323d28>] lr : [<ffffff8000eb1cc8>] pstate: 60000105 [ 78.526757] sp : ffffff800cea38f0 [ 78.528753] x29: ffffff800cea38f0 x28: ffffffc01f3f8e80 [ 78.532754] x27: 0000000000000000 x26: ffffff800cea3c70 [ 78.536756] x25: 00000000dc67c8ae x24: ffffffc033d6945d [ 78.540759] x23: ffffffc036811740 x22: ffffff800891a5b8 [ 78.544760] x21: 0000000000000000 x20: 0000000000000000 [ 78.548762] x19: ffffffc037d48910 x18: ffffff800891a588 [ 78.552764] x17: 0000000000000800 x16: 0000000000000c00 [ 78.556766] x15: 0000000000000010 x14: 6f2065646f6e695f [ 78.560767] x13: 6461657220726f66 x12: 2064656c69616620 [ 78.564769] x11: 435243203a6c616e x10: 7265746e695f6564 [ 78.568771] x9 : 6f6e695f64616572 x8 : ffffffc037974038 [ 78.572774] x7 : bbbbbbbbbbbbbbbb x6 : 0000000000000008 [ 78.576775] x5 : 002f91d85bd44a2f x4 : 0000000000000000 [ 78.580777] x3 : 0000000000000000 x2 : 000000403755e000 [ 78.584779] x1 : 6b6b6b6b6b6b6b6b x0 : 6b6b6b6b6b6b6b6b ... [ 79.038551] [<ffffff8008323d28>] rb_first_postorder+0xc/0x28 [ 79.042962] [<ffffff8000eb5578>] jffs2_do_clear_inode+0x88/0x100 [jffs2] [ 79.048395] [<ffffff8000eb9ddc>] jffs2_evict_inode+0x3c/0x48 [jffs2] [ 79.053443] [<ffffff8008201ca8>] evict+0xb0/0x168 [ 79.056835] [<ffffff8008202650>] iput+0x1c0/0x200 [ 79.060228] [<ffffff800820408c>] iget_failed+0x30/0x3c [ 79.064097] [<ffffff8000eba0c0>] jffs2_iget+0x2d8/0x360 [jffs2] [ 79.068740] [<ffffff8000eb0a60>] jffs2_lookup+0xe8/0x130 [jffs2] [ 79.073434] [<ffffff80081f1a28>] lookup_slow+0x118/0x190 [ 79.077435] [<ffffff80081f4708>] walk_component+0xfc/0x28c [ 79.081610] [<ffffff80081f4dd0>] path_lookupat+0x84/0x108 [ 79.085699] [<ffffff80081f5578>] filename_lookup+0x88/0x100 [ 79.089960] [<ffffff80081f572c>] user_path_at_empty+0x58/0x6c [ 79.094396] [<ffffff80081ebe14>] vfs_statx+0xa4/0x114 [ 79.098138] [<ffffff80081ec44c>] SyS_newfstatat+0x58/0x98 [ 79.102227] [<ffffff800808354c>] __sys_trace_return+0x0/0x4 [ 79.106489] Code: d65f03c0 f9400001 b40000e1 aa0103e0 (f9400821) The jffs2_do_clear_inode() call in jffs2_iget() is unnecessary since iget_failed() will eventually call jffs2_do_clear_inode() if needed, so just remove it. Fixes: 5451f79f5f81 ("iget: stop JFFS2 from using iget() and read_inode()") Reviewed-by: Richard Weinberger <richard@nod.at> Signed-off-by: Jake Daryll Obina <jake.obina@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30do d_instantiate/unlock_new_inode combinations safelyAl Viro
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream. For anything NFS-exported we do _not_ want to unlock new inode before it has grown an alias; original set of fixes got the ordering right, but missed the nasty complication in case of lockdep being enabled - unlock_new_inode() does lockdep_annotate_inode_mutex_key(inode) which can only be done before anyone gets a chance to touch ->i_mutex. Unfortunately, flipping the order and doing unlock_new_inode() before d_instantiate() opens a window when mkdir can race with open-by-fhandle on a guessed fhandle, leading to multiple aliases for a directory inode and all the breakage that follows from that. Correct solution: a new primitive (d_instantiate_new()) combining these two in the right order - lockdep annotate, then d_instantiate(), then the rest of unlock_new_inode(). All combinations of d_instantiate() with unlock_new_inode() should be converted to that. Cc: stable@kernel.org # 2.6.29 and later Tested-by: Mike Marshall <hubcap@omnibond.com> Reviewed-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24jffs2_kill_sb(): deal with failed allocationsAl Viro
commit c66b23c2840446a82c389e4cb1a12eb2a71fa2e4 upstream. jffs2_fill_super() might fail to allocate jffs2_sb_info; jffs2_kill_sb() must survive that. Cc: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-10Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "xattr stuff from Andreas This completes the switch to xattr_handler ->get()/->set() from ->getxattr/->setxattr/->removexattr" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Remove {get,set,remove}xattr inode operations xattr: Stop calling {get,set,remove}xattr inode operations vfs: Check for the IOP_XATTR flag in listxattr xattr: Add __vfs_{get,set,remove}xattr helpers libfs: Use IOP_XATTR flag for empty directory handling vfs: Use IOP_XATTR flag for bad-inode handling vfs: Add IOP_XATTR inode operations flag vfs: Move xattr_resolve_name to the front of fs/xattr.c ecryptfs: Switch to generic xattr handlers sockfs: Get rid of getxattr iop sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names kernfs: Switch to generic xattr handlers hfs: Switch to generic xattr handlers jffs2: Remove jffs2_{get,set,remove}xattr macros xattr: Remove unnecessary NULL attribute name check
2016-10-07vfs: Remove {get,set,remove}xattr inode operationsAndreas Gruenbacher
These inode operations are no longer used; remove them. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-06jffs2: Remove jffs2_{get,set,remove}xattr macrosAndreas Gruenbacher
When CONFIG_JFFS2_FS_XATTR is off, jffs2_xattr_handlers is defined as NULL. With sb->s_xattr == NULL, the generic_{get,set,remove}xattr functions produce the same result as setting the {get,set,remove}xattr inode operations to NULL, so there is no need for these macros. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: Replace CURRENT_TIME_SEC with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME_SEC is not y2038 safe. current_time() will be transitioned to use 64 bit time along with vfs in a separate patch. There is no plan to transistion CURRENT_TIME_SEC to use y2038 safe time interfaces. current_time() will also be extended to use superblock range checking parameters when range checking is introduced. This works because alloc_super() fills in the the s_time_gran in super block to NSEC_PER_SEC. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: support RENAME_NOREPLACE for local filesystemsMiklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags doesn't have any other than RENAME_NOREPLACE - assign foo_rename() to .rename2 instead of .rename Filesystems converted: affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos, nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Boaz Harrosh <ooo@electrozaur.com> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Bob Copeland <me@bobcopeland.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Jaegeuk Kim <jaegeuk@kernel.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-09-22posix_acl: Clear SGID bit when setting file permissionsJan Kara
When file permissions are modified via chmod(2) and the user is not in the owning group or capable of CAP_FSETID, the setgid bit is cleared in inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file permissions as well as the new ACL, but doesn't clear the setgid bit in a similar way; this allows to bypass the check in chmod(2). Fix that. References: CVE-2016-7097 Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
2016-06-10vfs: make the string hashes salt the hashLinus Torvalds
We always mixed in the parent pointer into the dentry name hash, but we did it late at lookup time. It turns out that we can simplify that lookup-time action by salting the hash with the parent pointer early instead of late. A few other users of our string hashes also wanted to mix in their own pointers into the hash, and those are updated to use the same mechanism. Hash users that don't have any particular initial salt can just use the NULL pointer as a no-salt. Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: George Spelvin <linux@sciencehorizons.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27switch xattr_handler->set() to passing dentry and inode separatelyAl Viro
preparation for similar switch in ->setxattr() (see the next commit for rationale). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-09more trivial ->iterate_shared conversionsAl Viro
2016-05-02Merge getxattr prototype change into work.lookupsAl Viro
The rest of work.xattr stuff isn't needed for this branch
2016-04-10xattr_handler: pass dentry and inode as separate arguments of ->get()Al Viro
... and do not assume they are already attached to each other Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-10don't bother with ->d_inode->i_sb - it's always equal to ->d_sbAl Viro
... and neither can ever be NULL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-31posix_acl: Inode acl caching fixesAndreas Gruenbacher
When get_acl() is called for an inode whose ACL is not cached yet, the get_acl inode operation is called to fetch the ACL from the filesystem. The inode operation is responsible for updating the cached acl with set_cached_acl(). This is done without locking at the VFS level, so another task can call set_cached_acl() or forget_cached_acl() before the get_acl inode operation gets to calling set_cached_acl(), and then get_acl's call to set_cached_acl() results in caching an outdate ACL. Prevent this from happening by setting the cached ACL pointer to a task-specific sentinel value before calling the get_acl inode operation. Move the responsibility for updating the cached ACL from the get_acl inode operations to get_acl(). There, only set the cached ACL if the sentinel value hasn't changed. The sentinel values are chosen to have odd values. Likewise, the value of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have an even value (ACLs are aligned in memory). This allows to distinguish uncached ACLs values from ACL objects. In addition, switch from guarding inode->i_acl and inode->i_default_acl upates by the inode->i_lock spinlock to using xchg() and cmpxchg(). Filesystems that do not want ACLs returned from their get_acl inode operations to be cached must call forget_cached_acl() to prevent the VFS from doing so. (Patch written by Al Viro and Andreas Gruenbacher.) Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-03-24Merge tag 'for-linus-20160324' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "NAND: - Add sunxi_nand randomizer support - begin refactoring NAND ecclayout structs - fix pxa3xx_nand dmaengine usage - brcmnand: fix support for v7.1 controller - add Qualcomm NAND controller driver SPI NOR: - add new ls1021a, ls2080a support to Freescale QuadSPI - add new flash ID entries - support bottom-block protection for Winbond flash - support Status Register Write Protect - remove broken QPI support for Micron SPI flash JFFS2: - improve post-mount CRC scan efficiency General: - refactor bcm63xxpart parser, to later extend for NAND - add writebuf size parameter to mtdram Other minor code quality improvements" * tag 'for-linus-20160324' of git://git.infradead.org/linux-mtd: (72 commits) mtd: nand: remove kerneldoc for removed function parameter mtd: nand: Qualcomm NAND controller driver dt/bindings: qcom_nandc: Add DT bindings mtd: nand: don't select chip in nand_chip's block_bad op mtd: spi-nor: support lock/unlock for a few Winbond chips mtd: spi-nor: add TB (Top/Bottom) protect support mtd: spi-nor: add SPI_NOR_HAS_LOCK flag mtd: spi-nor: use BIT() for flash_info flags mtd: spi-nor: disallow further writes to SR if WP# is low mtd: spi-nor: make lock/unlock bounds checks more obvious and robust mtd: spi-nor: silently drop lock/unlock for already locked/unlocked region mtd: spi-nor: wait for SR_WIP to clear on initial unlock mtd: nand: simplify nand_bch_init() usage mtd: mtdswap: remove useless if (!mtd->ecclayout) test mtd: create an mtd_oobavail() helper and make use of it mtd: kill the ecclayout->oobavail field mtd: nand: check status before reporting timeout mtd: bcm63xxpart: give width specifier an 'int', not 'size_t' mtd: mtdram: Add parameter for setting writebuf size mtd: nand: pxa3xx_nand: kill unused field 'drcmr_cmd' ...
2016-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes: Fix for my dumb braino in ncpfs and a long-standing breakage on recovery from failed rename() in jffs2" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: jffs2: reduce the breakage on recovery from halfway failed rename() ncpfs: fix a braino in OOM handling in ncp_fill_cache()
2016-03-07jffs2: reduce the breakage on recovery from halfway failed rename()Al Viro
d_instantiate(new_dentry, old_inode) is absolutely wrong thing to do - it will oops if new_dentry used to be positive, for starters. What we need is d_invalidate() the target and be done with that. Cc: stable@vger.kernel.org # v3.18+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-03-07mtd: kill the ecclayout->oobavail fieldBoris BREZILLON
ecclayout->oobavail is just redundant with the mtd->oobavail field. Moreover, it prevents static const definition of ecc layouts since the NAND framework is calculating this value based on the ecclayout->oobfree field. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2016-02-29jffs2: Improve post-mount CRC scan efficiencyDavid Woodhouse
We need to finish doing the CRC checks before we can allow writes to happen, and we currently process the inodes in order. This means a call to jffs2_get_ino_cache() for each possible inode# up to c->highest_ino. There may be a lot of lookups which fail, if the inode# space is used sparsely. And the inode# space is *often* used sparsely, if a file system contains a lot of stuff that was put there in the original image, followed by lots of creation and deletion of new files. Instead of processing them numerically with a lookup each time, just walk the hash buckets instead. [fix locking typo reported by Dan Carpenter] Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2016-02-25Fix directory hardlinks from deleted directoriesDavid Woodhouse
When a directory is deleted, we don't take too much care about killing off all the dirents that belong to it — on the basis that on remount, the scan will conclude that the directory is dead anyway. This doesn't work though, when the deleted directory contained a child directory which was moved *out*. In the early stages of the fs build we can then end up with an apparent hard link, with the child directory appearing both in its true location, and as a child of the original directory which are this stage of the mount process we don't *yet* know is defunct. To resolve this, take out the early special-casing of the "directories shall not have hard links" rule in jffs2_build_inode_pass1(), and let the normal nlink processing happen for directories as well as other inodes. Then later in the build process we can set ic->pino_nlink to the parent inode#, as is required for directories during normal operaton, instead of the nlink. And complain only *then* about hard links which are still in evidence even after killing off all the unreachable paths. Reported-by: Liu Song <liu.song11@zte.com.cn> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@vger.kernel.org
2016-02-25jffs2: Fix page lock / f->sem deadlockDavid Woodhouse
With this fix, all code paths should now be obtaining the page lock before f->sem. Reported-by: Szabó Tamás <sztomi89@gmail.com> Tested-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@vger.kernel.org
2016-02-25Revert "jffs2: Fix lock acquisition order bug in jffs2_write_begin"Thomas Betker
This reverts commit 5ffd3412ae55 ("jffs2: Fix lock acquisition order bug in jffs2_write_begin"). The commit modified jffs2_write_begin() to remove a deadlock with jffs2_garbage_collect_live(), but this introduced new deadlocks found by multiple users. page_lock() actually has to be called before mutex_lock(&c->alloc_sem) or mutex_lock(&f->sem) because jffs2_write_end() and jffs2_readpage() are called with the page locked, and they acquire c->alloc_sem and f->sem, resp. In other words, the lock order in jffs2_write_begin() was correct, and it is the jffs2_garbage_collect_live() path that has to be changed. Revert the commit to get rid of the new deadlocks, and to clear the way for a better fix of the original deadlock. Reported-by: Deng Chao <deng.chao1@zte.com.cn> Reported-by: Ming Liu <liu.ming50@gmail.com> Reported-by: wangzaiwei <wangzaiwei@top-vision.cn> Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@vger.kernel.org
2016-01-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull final vfs updates from Al Viro: - The ->i_mutex wrappers (with small prereq in lustre) - a fix for too early freeing of symlink bodies on shmem (they need to be RCU-delayed) (-stable fodder) - followup to dedupe stuff merged this cycle * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: abort dedupe loop if fatal signals are pending make sure that freeing shmem fast symlinks is RCU-delayed wrappers for ->i_mutex access lustre: remove unused declaration
2016-01-22tree wide: use kvfree() than conditional kfree()/vfree()Tetsuo Handa
There are many locations that do if (memory_was_allocated_by_vmalloc) vfree(ptr); else kfree(ptr); but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory using is_vmalloc_addr(). Unless callers have special reasons, we can replace this branch with kvfree(). Please check and reply if you found problems. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Andreas Dilger <andreas.dilger@intel.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: David Rientjes <rientjes@google.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Boris Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-13Merge tag 'for-linus-20160112' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "Generic MTD: - populate the MTD device 'of_node' field (and get a proper 'of_node' symlink in sysfs) This yielded some new helper functions, and changes across a variety of drivers - partitioning cleanups, to prepare for better device-tree based partitioning in the future Eliminate a lot of boilerplate for drivers that want to use OF-based partition parsing The DT bindings for this didn't settle yet, so most non-cleanup portions are deferred for a future release NAND: - embed a struct mtd_info inside struct nand_chip This is really long overdue; too many drivers have to do the same silly boilerplate to allocate and link up two "independent" structs, when in fact, everyone is assuming there is an exact 1:1 relationship between a NAND chips struct and its underlying MTD. This aids improved helpers and should make certain abstractions easier in the future. Also causes a lot of churn, helped along by some automated code transformations - add more core support for detecting (and "correcting") bitflips in erased pages; requires opt-in by drivers, but at least we kill a few bad implementations and hopefully stave off future ones - pxa3xx_nand: cleanups, a few fixes, and PM improvements - new JZ4780 NAND driver SPI NOR: - provide default erase function, for controllers that just want to send the SECTOR_ERASE command directly - fix some module auto-loading issues with device tree ("jedec,spi-nor") - error handling fixes - new Mediatek QSPI flash driver Other: - cfi: force valid geometry Kconfig (finally!) This one used to trip up randconfigs occasionally, since bots aren't deterred by big scary "advanced configuration" menus More? Probably. See the commit logs" * tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits) mtd: jz4780_nand: replace if/else blocks with switch/case mtd: nand: jz4780: Update ecc correction error codes mtd: nandsim: use nand_get_controller_data() mtd: jz4780_nand: remove useless mtd->priv = chip assignment staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers mtd: nand: make use of nand_set/get_controller_data() helpers ARM: make use of nand_set/get_controller_data() helpers mtd: nand: add helpers to access ->priv mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs mtd: nand: jz4740: remove custom 'erased check' implementation mtd: nand: diskonchip: remove custom 'erased check' implementation mtd: nand: davinci: remove custom 'erased check' implementation mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions mtd: nand: return consistent error codes in ecc.correct() implementations doc: dt: mtd: new binding for jz4780-{nand,bch} mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc mtd: spi-nor: wait until lock/unlock operations are ready mtd: tests: consolidate kmalloc/memset 0 call to kzalloc jffs2: use to_delayed_work mtd: nand: assign reasonable default name for NAND drivers ...
2016-01-11Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "Andreas' xattr cleanup series. It's a followup to his xattr work that went in last cycle; -0.5KLoC" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: xattr handlers: Simplify list operation ocfs2: Replace list xattr handler operations nfs: Move call to security_inode_listsecurity into nfs_listxattr xfs: Change how listxattr generates synthetic attributes tmpfs: listxattr should include POSIX ACL xattrs tmpfs: Use xattr handler infrastructure btrfs: Use xattr handler infrastructure vfs: Distinguish between full xattr names and proper prefixes posix acls: Remove duplicate xattr name definitions gfs2: Remove gfs2_xattr_acl_chmod vfs: Remove vfs_xattr_cmp
2016-01-06jffs2: use to_delayed_workGeliang Tang
Use to_delayed_work() instead of open-coding it. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-12-13xattr handlers: Simplify list operationAndreas Gruenbacher
Change the list operation to only return whether or not an attribute should be listed. Copying the attribute names into the buffer is moved to the callers. Since the result only depends on the dentry and not on the attribute name, we do not pass the attribute name to list operations. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06vfs: Distinguish between full xattr names and proper prefixesAndreas Gruenbacher
Add an additional "name" field to struct xattr_handler. When the name is set, the handler matches attributes with exactly that name. When the prefix is set instead, the handler matches attributes with the given prefix and with a non-empty suffix. This patch should avoid bugs like the one fixed in commit c361016a in the future. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13xattr handlers: Pass handler to operations instead of flagsAndreas Gruenbacher
The xattr_handler operations are currently all passed a file system specific flags value which the operations can use to disambiguate between different handlers; some file systems use that to distinguish the xattr namespace, for example. In some oprations, it would be useful to also have access to the handler prefix. To allow that, pass a pointer to the handler to operations instead of the flags value alone. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13jffs2: Add missing capability check for listing trusted xattrsAndreas Gruenbacher
The vfs checks if a task has the appropriate access for get and set operations, but it cannot do that for the list operation; the file system must check for that itself. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: linux-mtd@lists.infradead.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - most of the rest of MM - procfs - lib/ updates - printk updates - bitops infrastructure tweaks - checkpatch updates - nilfs2 update - signals - various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc, dma-debug, dma-mapping, ... * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits) ipc,msg: drop dst nil validation in copy_msg include/linux/zutil.h: fix usage example of zlib_adler32() panic: release stale console lock to always get the logbuf printed out dma-debug: check nents in dma_sync_sg* dma-mapping: tidy up dma_parms default handling pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode kexec: use file name as the output message prefix fs, seqfile: always allow oom killer seq_file: reuse string_escape_str() fs/seq_file: use seq_* helpers in seq_hex_dump() coredump: change zap_threads() and zap_process() to use for_each_thread() coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT) signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread() signal: turn dequeue_signal_lock() into kernel_dequeue_signal() signals: kill block_all_signals() and unblock_all_signals() nilfs2: fix gcc uninitialized-variable warnings in powerpc build nilfs2: fix gcc unused-but-set-variable warnings MAINTAINERS: nilfs2: add header file for tracing nilfs2: add tracepoints for analyzing reading and writing metadata files ...
2015-11-06signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)Oleg Nesterov
jffs2_garbage_collect_thread() does allow_signal(SIGCONT) for no reason, SIGCONT will wake a stopped task up even if it is ignored. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()Oleg Nesterov
jffs2_garbage_collect_thread() can race with SIGCONT and sleep in TASK_STOPPED state after it was already sent. Add the new helper, kernel_signal_stop(), which does this correctly. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signal: turn dequeue_signal_lock() into kernel_dequeue_signal()Oleg Nesterov
1. Rename dequeue_signal_lock() to kernel_dequeue_signal(). This matches another "for kthreads only" kernel_sigaction() helper. 2. Remove the "tsk" and "mask" arguments, they are always current and current->blocked. And it is simply wrong if tsk != current. 3. We could also remove the 3rd "siginfo_t *info" arg but it looks potentially useful. However we can simplify the callers if we change kernel_dequeue_signal() to accept info => NULL. 4. Remove _irqsave, it is never called from atomic context. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06fs/jffs2/wbuf.c: remove stray semicolonAndrew Morton
Reported-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-04jffs2: fix a memleak in read_direntry()Wei Fang
Need to free the memory allocated for 'fd' if failed to read all of the remainder name. Signed-off-by: Wei Fang <fangwei1@huawei.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-09-28jffs2: remove unneeded kfreefangwei
c->oobbuf hasn't been kmalloced in jffs2_dataflash_setup, so there is no need to free it. Signed-off-by: Wei Fang <fangwei1@huawei.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-09-28jffs2: remove unnecessary new_valid_dev checkYaowei Bai
As new_valid_dev always returns 1, so !new_valid_dev check is not needed, remove it. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-09-21jffs2: drop null test before destroy functionsJulia Lawall
Remove unneeded NULL test. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x; @@ -if (x != NULL) \(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
