path: root/fs/jffs2
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] jffs/jffs2: remove wrong function prototypesAdrian Bunk
This patch removes prototypes for the generic_file_open and generic_file_llseek functions. Besides being superfluous because they are already present in fs.h, they were also wrong because the actual functions aren't weak functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[PATCH] Fix up symlink function pointersAl Viro
This fixes up the symlink functions for the calling convention change: * afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs, smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link() * befs, smbfs, xfs - same for ->put_link() Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[PATCH] jffs2: fix symlink error handlingAl Viro
The current calling conventions for ->follow_link() are already fairly complex. What we have is 1) you can return -error; then you must release nameidata yourself and ->put_link() will _not_ be called. 2) you can do nd_set_link(nd, ERR_PTR(-error)) and return 0 3) you can do nd_set_link(nd, path) and return 0 4) you can return 0 (after having moved nameidata yourself) jffs2 follow_link() is broken - it has an exit where it returns -EIO and leaks nameidata. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-15[JFFS2] Fix node allocation leakThomas Gleixner
In the rare case of failing to write the cleanmarker the allocated node was not freed. Pointed out by Forrest Zhao Initial cleanup by Joern Engel Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-13[JFFS2] Avoid compiler warnings when JFFS2_FS_WRITEBUFFER=nTodd Poynor
Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-13[JFFS2] Init locks early during mountArtem B. Bityuckiy
In case of a mount error locks might be uninitialized but accessed by the resulting call to jffs2_kill_sb(). Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-12[JFFS2] Rename function and update commentsArtem B. Bityuckiy
We recently changed the method of collecting and sorting of tmp_dnode objects to use a temporary RB-tree instead of a temporary list. Rename function and update comments. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-12[JFFS2] Remove needless variable initializationArtem B. Bityuckiy
2005-07-12[JFFS2] Avoid alloc/dealloc for zero sized nodesArtem B. Bityuckiy
2005-07-06[JFFS2] Simplify the tree insert code.Artem B. Bityuckiy
It isn't _normal_ that we allow key collision in rbtrees, but it does not matter as long as the two nodes with the same version are together. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-06[JFFS2] Remove compatibilty cruft for ancient kernelsDavid Woodhouse
2005-07-06[JFFS2] Optimise jffs2_add_tn_to_list David Woodhouse
Use an rbtree instead of a simple linked list. We were wasting an amazing amount of time in jffs2_add_tn_to_list(). Thanks to Artem Bityuckiy and Jarkko Jlavinen for noticing. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-06-26Merge with rsync://fileserver/linuxThomas Gleixner
Update to Linus latest
2005-06-26[PATCH] jffs2 build fixAndrew Morton
Missed conversion in the swsusp cleanup. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-23[JFFS2] Whitespace cleanup. Fix missing debug messageThomas Gleixner
2005-05-23[JFFS2] Fix crosscompileThomas Gleixner
Include sched.h instead of asm/semaphore.h to make it compile everywhere. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix cleanup in case of GC-Task not startedThomas Gleixner
Do not call wait_for_completion, when the gc task is not there. Prevent an oops when the gc thread was not started. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Convert thread start semaphore to completionThomas Gleixner
2005-05-23[JFFS2] Kill GC thread before cleanupArtem B. Bityuckiy
First kill GC thread, then start clearing the internal structures Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Suppress annoying debug messagesArtem B. Bityuckiy
Embrace uneeded messages in D1(). Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix NOR only compileArtem B. Bityuckiy
Fix the bug that caouses problems when compiling for NOR. We read a newly erased block so we don't need to check ECC. Define jffs2_is_writebuffered as zero if there is no wbuf. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix inode allocation raceDavid Woodhouse
2005-05-23[JFFS2] Fix race in garbage collectorArtem B. Bityuckiy
Fix the race problem described here: http://lists.infradead.org/pipermail/linux-mtd/2005-April/012361.html Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Add KERN_DEBUG level to printksArtem B. Bityuckiy
2005-05-23[JFFS2] Fix race problems with wbuf.Artem B. Bityuckiy
2005-05-23[JFFS2] Prevent deadlock when flushing write bufferArtem B. Bityuckiy
2005-05-23[JFFS2] Forbid to free inode_cache objects if its nlink isn't zero.Artem B. Bityuckiy
2005-05-23[JFFS2] Improve garbage collector block selectionArtem B. Bityuckiy
Make sure the erase_pending_wbuf_list's blocks are taken into account when picking the block to GC. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Use function to manipulate superblock dirty flagArtem B. Bityuckiy
Use the corresponding function to mark Superblock dirty instead of doing it directly. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Add symlink caching support.Artem B. Bityuckiy
2005-05-23[JFFS2] Fix NOR specific scan BUG Artem B. Bityuckiy
Fix fairly sad NOR-specific bug - during FS building ic->scan_dents isn't zero, but jffs2_mark_node_obsolete() migt be called it tries to finde the ic corresponding to ref - this requires ic->scan_dents = 0. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Prevent ino cache removal for inodes in useDavid Woodhouse
Don't remove inocache for inodes which are in read_inode() or clear_inode() until they're done. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix node lookupArtem B. Bityuckiy
Look the ref->next_phys field instead of ->next_in_ino to determine if the block has more then one node. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Use a single config option for write buffer supportAndrew Victor
This patch replaces the current CONFIG_JFFS2_FS_NAND, CONFIG_JFFS2_FS_NOR_ECC and CONFIG_JFFS2_FS_DATAFLASH with a single configuration option - CONFIG_JFFS2_FS_WRITEBUFFER. The only functional change of this patch is that the slower div/mod calculations for SECTOR_ADDR(), PAGE_DIV() and PAGE_MOD() are now always used when CONFIG_JFFS2_FS_WRITEBUFFER is enabled. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Add support for JFFS2-on-Dataflash devices.Andrew Victor
For Dataflash, can_mark_obsolete = false and the NAND write buffering code (wbuf.c) is used. Since the DataFlash chip will automatically erase pages when writing, the cleanmarkers are not needed - so cleanmarker_oob = false and cleanmarker_size = 0 DataFlash page-sizes are not a power of two (they're multiples of 528 bytes). The SECTOR_ADDR macro (added in the previous core patch) is replaced with a (slower) div/mod version if CONFIG_JFFS2_FS_DATAFLASH is selected. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Core changes required to support JFFS2-on-Dataflash devices.Andrew Victor
DataFlash page-sizes are not a power of two (they're multiples of 528 bytes). There are a few places in JFFS2 code where sector_size is used as a bitmask. A new macro (SECTOR_ADDR) was defined to calculate these sector addresses. For non-DataFlash devices, the original (faster) bitmask operation is still used. In scan.c, the EMPTY_SCAN_SIZE was a constant of 1024. Since this could be larger than the sector size of the DataFlash, this is now basically set to MIN(sector_size, 1024). Addition of a jffs2_is_writebuffered() macro. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Prevent deadlock during write buffer recoveryEstelle Hammache
Prevent deadlock when checking erased block for space allocation during wbuf recovery. Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Remove NAND dependencies for NOR FLASHDavid Woodhouse
make NAND code work on NOR flash again Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Code cleanup Estelle Hammache
Code beautification and block filing correction for optimization. Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix refile of blocks due to write failure. Estelle Hammache
avoid segfault when nextblock was refiled because of a write failure - avoid filing blocks on the clean list when they have wasted space Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix block refilingEstelle Hammache
- block refiling when writing directly to flash a buffer which is bigger than wbuf - retry cases for flushing wbuf Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix write buffer retry caseEstelle Hammache
Correction of retry case to avoid silent failure of rmdir when jffs2_wbuf_recover GCs the previous entry (+ corresponding dnode case). Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Avoid warning for empty filesystemsTodd Poynor
Avoid "Eep. No valid nodes for ino #1" message for just-created filesystem. Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
