commit 064d83892e9ba547f7d4eae22cbca066d95210ce upstream.
Free the buffer head if the journal descriptor block fails checksum
verification.
This is the jbd2 port of the e2fsprogs patch "e2fsck: free bh on csum
verify error in do_one_pass".
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 022eaa7517017efe4f6538750c2b59a804dc7df7 upstream.
When recovering the journal, don't fall into an infinite loop if we
encounter a corrupt journal block. Instead, just skip the block and
return an error, which fails the mount and thus forces the user to run
a full filesystem fsck.
commit 5dd214248f94d430d70e9230bda72f2654ac88a8 upstream.
The mount manpage says of the max_batch_time option,
This optimization can be turned off entirely
by setting max_batch_time to 0.
But the code doesn't do that. So fix the code to do
that.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit f6c07cad081ba222d63623d913aafba5586c1d2c upstream.
If a handle runs out of space, we currently stop the kernel with a BUG
in jbd2_journal_dirty_metadata(). This makes it hard to figure out
what might be going on. So return an error of ENOSPC, so we can let
the file system layer figure out what is going on, to make it more
likely we can get useful debugging information). This should make it
easier to debug problems such as the one which was reported by:
https://bugzilla.kernel.org/show_bug.cgi?id=44731
The only two callers of this function are ext4_handle_dirty_metadata()
and ocfs2_journal_dirty(). The ocfs2 function will trigger a
BUG_ON(), which means there will be no change in behavior. The ext4
function will call ext4_error_inode() which will print the useful
debugging information and then handle the situation using ext4's error
handling mechanisms (i.e., which might mean halting the kernel or
remounting the file system read-only).
Also, since both file systems already call WARN_ON(), drop the WARN_ON
from jbd2_journal_dirty_metadata() to avoid two stack traces from
being displayed.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: ocfs2-devel@oss.oracle.com
Acked-by: Joel Becker <jlbec@evilplan.org>
commit 39c04153fda8c32e85b51c96eb5511a326ad7609 upstream.
Once we decrement transaction->t_updates, if this is the last handle
holding the transaction from closing, and once we release the
t_handle_lock spinlock, it's possible for the transaction to commit
and be released. In practice with normal kernels, this probably won't
happen, since the commit happens in a separate kernel thread and it's
unlikely this could all happen within the space of a few CPU cycles.
On the other hand, with a real-time kernel, this could potentially
happen, so save the tid found in transaction->t_tid before we release
t_handle_lock. It would require an insane configuration, such as one
where the jbd2 thread was set to a very high real-time priority,
perhaps because a high priority real-time thread is trying to read or
write to a file system. But some people who use real-time kernels
have been known to do insane things, including controlling
laser-wielding industrial robots. :-)
commit fe52d17cdd343ac43c85cf72940a58865b9d3bfb upstream.
Some of the functions which modify the jbd2 superblock were not
updating the checksum before calling jbd2_write_superblock(). Move
the call to jbd2_superblock_csum_set() to jbd2_write_superblock(), so
that the checksum is calculated consistently.
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Mostly performance and bug fixes, plus some cleanups. The one new
feature this merge window is a new ioctl EXT4_IOC_SWAP_BOOT which
allows installation of a hidden inode designed for boot loaders."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (50 commits)
ext4: fix type-widening bug in inode table readahead code
ext4: add check for inodes_count overflow in new resize ioctl
ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUG
ext4: fix online resizing for ext3-compat file systems
jbd2: trace when lock_buffer in do_get_write_access takes a long time
ext4: mark metadata blocks using bh flags
buffer: add BH_Prio and BH_Meta flags
ext4: mark all metadata I/O with REQ_META
ext4: fix readdir error in case inline_data+^dir_index.
ext4: fix readdir error in the case of inline_data+dir_index
jbd2: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
ext4: mext_insert_extents should update extent block checksum
ext4: move quota initialization out of inode allocation transaction
ext4: reserve xattr index for Rich ACL support
jbd2: reduce journal_head size
ext4: clear buffer_uninit flag when submitting IO
ext4: use io_end for multiple bios
ext4: make ext4_bio_write_page() use BH_Async_Write flags
ext4: Use kstrtoul() instead of parse_strtoul()
ext4: defragmentation code cleanup
bh allocation uses kmem_cache_zalloc() so we needn't call
'init_buffer(bh, NULL, NULL)' and perform other set-zero-operations.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
While investigating interactivity problems it was clear that processes
sometimes stall for long periods of times if an attempt is made to
lock a buffer which is undergoing writeback. It would stall in
a trace looking something like
[<ffffffff811a39de>] __lock_buffer+0x2e/0x30
[<ffffffff8123a60f>] do_get_write_access+0x43f/0x4b0
[<ffffffff8123a7cb>] jbd2_journal_get_write_access+0x2b/0x50
[<ffffffff81220f79>] __ext4_journal_get_write_access+0x39/0x80
[<ffffffff811f3198>] ext4_reserve_inode_write+0x78/0xa0
[<ffffffff811f3209>] ext4_mark_inode_dirty+0x49/0x220
[<ffffffff811f57d1>] ext4_dirty_inode+0x41/0x60
[<ffffffff8119ac3e>] __mark_inode_dirty+0x4e/0x2d0
[<ffffffff8118b9b9>] update_time+0x79/0xc0
[<ffffffff8118ba98>] file_update_time+0x98/0x100
[<ffffffff81110ffc>] __generic_file_aio_write+0x17c/0x3b0
[<ffffffff811112aa>] generic_file_aio_write+0x7a/0xf0
[<ffffffff811ea853>] ext4_file_write+0x83/0xd0
[<ffffffff81172b23>] do_sync_write+0xa3/0xe0
[<ffffffff811731ae>] vfs_write+0xae/0x180
[<ffffffff8117361d>] sys_write+0x4d/0x90
[<ffffffff8159d62d>] system_call_fastpath+0x1a/0x1f
[<ffffffffffffffff>] 0xffffffffffffffff
The jbd2_alloc_handle() function is only called by new_handle(). So
this commit uses kmem_cache_zalloc() instead of
kmem_cache_alloc()/memset().
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Cc: stable@vger.kernel.org
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
jbd2_journal_dirty_metadata() didn't get a reference to journal_head it
was working with. This is OK in most of the cases since the journal head
should be attached to a transaction but in rare occasions when we are
journalling data, __ext4_journalled_writepage() can race with
jbd2_journal_invalidatepage() stripping buffers from a page and thus
journal head can be freed under hands of jbd2_journal_dirty_metadata().
Fix the problem by getting own journal head reference in
jbd2_journal_dirty_metadata() (and also in jbd2_journal_set_triggers()
which can possibly have the same issue).
Reported-by: Zheng Liu <gnehzuil.liu@gmail.com>
If start_this_handle() failed handle will be initialized
to ERR_PTR() and can not be dereferenced.
paging request at fffffffffffffff6
IP: [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290
PGD 200e067 PUD 200f067 PMD 0
Oops: 0000 [#1] SMP
CPU 0 journal commit I/O error
Pid: 2694, comm: fio Not tainted 3.8.0-rc3+ #79 /DQ67SW
RIP: 0010:[<ffffffff813c073f>] [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290
RSP: 0018:ffff880233b8ba58 EFLAGS: 00010292
RAX: 00000000ffffffe2 RBX: ffffffffffffffe2 RCX: 0000000000000006
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff82128f48
RBP: ffff880233b8ba98 R08: 0000000000000000 R09: ffff88021440a6e0
There are multiple reasons to move away from debugfs. First of all,
we are only using it for a single parameter, and it is much more
complicated to set up (some 30 lines of code compared to 3), and one
more thing that might fail while loading the jbd2 module.
Secondly, as a module paramter it can be specified as a boot option if
jbd2 is built into the kernel, or as a parameter when the module is
loaded, and it can also be manipulated dynamically under
/sys/module/jbd2/parameters/jbd2_debug. So it is more flexible.
Ultimately we want to move away from using jbd_debug() towards
tracepoints, but for now this is still a useful simplification of the
code base.
Handles which stay open a long time are problematic when it comes time
to close down a transaction so it can be committed. These tracepoints
will help us determine which ones are the problematic ones, and to
validate whether changes makes things better or worse.
Track the delay between when we first request that the commit begin
and when it actually begins, so we can see how much of a gap exists.
In theory, this should just be the remaining scheduling quantuum of
the thread which requested the commit (assuming it was not a
synchronous operation which triggered the commit request) plus
scheduling overhead; however, it's possible that real time processes
might get in the way of letting the kjournald thread from executing.
Don't send an extra wakeup to kjournald in the case where we
already have the proper target in j_commit_request, i.e. that
transaction has already been requested for commit.
commit deeeaf13 "jbd2: fix fsync() tid wraparound bug" changed
the logic leading to a wakeup, but it caused some extra wakeups
which were found to lead to a measurable performance regression.
[tytso@mit.edu: reworked check to make it clearer]
Pull ext4 bug fixes from Ted Ts'o:
"Various bug fixes for ext4. Perhaps the most serious bug fixed is one
which could cause file system corruptions when performing file punch
operations."
ext4: avoid hang when mounting non-journal filesystems with orphan list
ext4: lock i_mutex when truncating orphan inodes
ext4: do not try to write superblock on ro remount w/o journal
ext4: include journal blocks in df overhead calcs
ext4: remove unaligned AIO warning printk
ext4: fix an incorrect comment about i_mutex
ext4: fix deadlock in journal_unmap_buffer()
ext4: split off ext4_journalled_invalidatepage()
jbd2: fix assertion failure in jbd2_journal_flush()
ext4: check dioread_nolock on remount
ext4: fix extent tree corruption caused by hole punch
We cannot wait for transaction commit in journal_unmap_buffer()
because we hold page lock which ranks below transaction start. We
solve the issue by bailing out of journal_unmap_buffer() and
jbd2_journal_invalidatepage() with -EBUSY. Caller is then responsible
for waiting for transaction commit to finish and try invalidation
again. Since the issue can happen only for page stradding i_size, it
is simple enough to manually call jbd2_journal_invalidatepage() for
such page from ext4_setattr(), check the return value and wait if
necessary.
The following race is possible between start_this_handle() and someone
calling jbd2_journal_flush().
Process A Process B
start_this_handle().
if (journal->j_barrier_count) # false
if (!journal->j_running_transaction) { #true
read_unlock(&journal->j_state_lock);
jbd2_journal_lock_updates()
write_lock(&journal->j_state_lock);
if (journal->j_running_transaction) {
# false
... wait for committing trans ...
write_unlock(&journal->j_state_lock);
if (!journal->j_running_transaction) { # true
jbd2_get_transaction(journal, new_transaction);
goto repeat; # eventually blocks on j_barrier_count > 0
J_ASSERT(!journal->j_running_transaction);
# fails
We fix the race by rechecking j_barrier_count after reacquiring j_state_lock
in exclusive mode.
Reported-by: yjwsignal@empal.com
Pull ext4 update from Ted Ts'o:
"There are two major features for this merge window. The first is
inline data, which allows small files or directories to be stored in
the in-inode extended attribute area. (This requires that the file
system use inodes which are at least 256 bytes or larger; 128 byte
inodes do not have any room for in-inode xattrs.)
The second new feature is SEEK_HOLE/SEEK_DATA support. This is
enabled by the extent status tree patches, and this infrastructure
will be used to further optimize ext4 in the future.
Beyond that, we have the usual collection of code cleanups and bug
fixes."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (63 commits)
ext4: zero out inline data using memset() instead of empty_zero_page
ext4: ensure Inode flags consistency are checked at build time
ext4: Remove CONFIG_EXT4_FS_XATTR
ext4: remove unused variable from ext4_ext_in_cache()
ext4: remove redundant initialization in ext4_fill_super()
ext4: remove redundant code in ext4_alloc_inode()
ext4: use sync_inode_metadata() when syncing inode metadata
ext4: enable ext4 inline support
ext4: let fallocate handle inline data correctly
ext4: let ext4_truncate handle inline data correctly
ext4: evict inline data out if we need to strore xattr in inode
ext4: let fiemap work with inline data
ext4: let ext4_rename handle inline dir
ext4: let empty_dir handle inline dir
ext4: let ext4_delete_entry() handle inline data
ext4: make ext4_delete_entry generic
ext4: let ext4_find_entry handle inline data
ext4: create a new function search_dir
ext4: let ext4_readdir handle inline data
ext4: let add_dir_entry handle inline data properly
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
ext4_handle_release_buffer() was intended to remove journal
write access from a buffer, but it doesn't actually do anything
at all other than add a BUFFER_TRACE point, but it's not reliably
used for that either. Remove all the associated dead code.
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
"The big new feature added this time is supporting online resizing
using the meta_bg feature. This allows us to resize file systems
which are greater than 16TB. In addition, the speed of online
resizing has been improved in general.
We also fix a number of races, some of which could lead to deadlocks,
in ext4's Asynchronous I/O and online defrag support, thanks to good
work by Dmitry Monakhov.
There are also a large number of more minor bug fixes and cleanups
from a number of other ext4 contributors, quite of few of which have
submitted fixes for the first time."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (69 commits)
ext4: fix ext4_flush_completed_IO wait semantics
ext4: fix mtime update in nodelalloc mode
ext4: fix ext_remove_space for punch_hole case
ext4: punch_hole should wait for DIO writers
ext4: serialize truncate with owerwrite DIO workers
ext4: endless truncate due to nonlocked dio readers
ext4: serialize unlocked dio reads with truncate
ext4: serialize dio nonlocked reads with defrag workers
ext4: completed_io locking cleanup
ext4: fix unwritten counter leakage
ext4: give i_aiodio_unwritten a more appropriate name
ext4: ext4_inode_info diet
ext4: convert to use leXX_add_cpu()
ext4: ext4_bread usage audit
fs: reserve fallocate flag codepoint
ext4: remove redundant offset check in mext_check_arguments()
ext4: don't clear orphan list on ro mount with errors
jbd2: fix assertion failure in commit code due to lacking transaction credits
ext4: release donor reference when EXT4_IOC_MOVE_EXT ioctl fails
ext4: enable FITRIM ioctl on bigalloc file system
ext4 users of data=journal mode with blocksize < pagesize were
occasionally hitting assertion failure in
jbd2_journal_commit_transaction() checking whether the transaction has
at least as many credits reserved as buffers attached. The core of the
problem is that when a file gets truncated, buffers that still need
checkpointing or that are attached to the committing transaction are
left with buffer_mapped set. When this happens to buffers beyond i_size
attached to a page stradding i_size, subsequent write extending the file
will see these buffers and as they are mapped (but underlying blocks
were freed) things go awry from here.
The assertion failure just coincidentally (and in this case luckily as
we would start corrupting filesystem) triggers due to journal_head not
being properly cleaned up as well.
We fix the problem by unmapping buffers if possible (in lots of cases we
just need a buffer attached to a transaction as a place holder but it
must not be written out anyway). And in one case, we just have to bite
the bullet and wait for transaction commit to finish.
CC: Josef Bacik <jbacik@fusionio.com>
This sequence:
# truncate --size=1g fsfile
# mkfs.ext4 -F fsfile
# mount -o loop,ro fsfile /mnt
# umount /mnt
# dmesg | tail
results in an IO error when unmounting the RO filesystem:
[ 318.020828] Buffer I/O error on device loop1, logical block 196608
[ 318.027024] lost page write due to I/O error on loop1
[ 318.032088] JBD2: Error -5 detected when updating journal superblock for loop1-8.
This was a regression introduced by commit 24bcc89c7e7c: "jbd2: split
updating of journal superblock and marking journal empty".
"The following are all bug fixes and regressions. The most notable are
the ones which cause problems for ext4 on RAID --- a performance
problem when mounting very large filesystems, and a kernel OOPS when
doing an rm -rf on large directory hierarchies on fast devices."
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: fix kernel BUG on large-scale rm -rf commands
ext4: fix long mount times on very big file systems
ext4: don't call ext4_error while block group is locked
ext4: avoid kmemcheck complaint from reading uninitialized memory
ext4: make sure the journal sb is written in ext4_clear_journal_err()
blkdev_issue_flush() can fail; make sure the error gets properly
propagated.
This is a port of the equivalent jbd patch from commit 349ecd6a3c0e.
After we transfer set the EXT4_ERROR_FS bit in the file system
superblock, it's not enough to call jbd2_journal_clear_err() to clear
the error indication from journal superblock --- we need to call
jbd2_journal_update_sb_errno() as well. Otherwise, when the root file
system is mounted read-only, the journal is replayed, and the error
indicator is transferred to the superblock --- but the s_errno field
in the jbd2 superblock is left set (since although we cleared it in
memory, we never flushed it out to disk).
This can end up confusing e2fsck. We should make e2fsck more robust
in this case, but the kernel shouldn't be leaving things in this
confused state, either.
Cc: stable@kernel.org
The '->write_super' superblock method is gone, and this patch removes all the
references to 'write_super' from various jbd and jbd2.
Cc: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Use kmem_cache_zalloc wrapper instead of flag __GFP_ZERO.
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Calculate and verify checksums of each data block being stored in the journal.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Calculate and verify the checksum of commit blocks. In checksum v2,
deprecate most of the checksum v1 commit block checksum fields, since
each block has its own checksum.
Calculate and verify a checksum of each descriptor block.
Compute and verify revoke blocks inside the journal.
Calculate and verify a checksum covering the journal superblock.
Obtain a reference to the crc32c driver if needed for the v2 checksum.
Add in the necessary code so that journal clients can enable the new
journal checksumming features.
Define flags and allocate space in on-disk journal structures to support
checksumming of journal metadata.
flush request is issued in transaction commit code path, so looks using
GFP_KERNEL to allocate memory for flush request bio falls into the classic
deadlock issue. I saw btrfs and dm get it right, but ext4, xfs and md are
using GFP.
Signed-off-by: Shaohua Li <shli@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Pull ext4 updates for 3.4 from Ted Ts'o:
"Ext4 commits for 3.3 merge window; mostly cleanups and bug fixes
The changes to export dirty_writeback_interval are from Artem's s_dirt
cleanup patch series. The same is true of the change to remove the
s_dirt helper functions which never got used by anyone in-tree. I've
run these changes by Al Viro, and am carrying them so that Artem can
more easily fix up the rest of the file systems during the next merge
window. (Originally we had hopped to remove the use of s_dirt from
ext4 during this merge window, but his patches had some bugs, so I
ultimately ended dropping them from the ext4 tree.)"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (66 commits)
vfs: remove unused superblock helpers
mm: export dirty_writeback_interval
ext4: remove useless s_dirt assignment
ext4: write superblock only once on unmount
ext4: do not mark superblock as dirty unnecessarily
ext4: correct ext4_punch_hole return codes
ext4: remove restrictive checks for EOFBLOCKS_FL
ext4: always set then trimmed blocks count into len
ext4: fix trimmed block count accunting
ext4: fix start and len arguments handling in ext4_trim_fs()
ext4: update s_free_{inodes,blocks}_count during online resize
ext4: change some printk() calls to use ext4_msg() instead
ext4: avoid output message interleaving in ext4_error_<foo>()
ext4: remove trailing newlines from ext4_msg() and ext4_error() messages
ext4: add no_printk argument validation, fix fallout
ext4: remove redundant "EXT4-fs: " from uses of ext4_msg
ext4: give more helpful error message in ext4_ext_rm_leaf()
ext4: remove unused code from ext4_ext_map_blocks()
ext4: rewrite punch hole to use ext4_ext_remove_space()
jbd2: cleanup journal tail after transaction commit
Pull power management updates for 3.4 from Rafael Wysocki:
"Assorted extensions and fixes including:
* Introduction of early/late suspend/hibernation device callbacks.
* Generic PM domains extensions and fixes.
* devfreq updates from Axel Lin and MyungJoo Ham.
* Device PM QoS updates.
* Fixes of concurrency problems with wakeup sources.
* System suspend and hibernation fixes."
* tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits)
PM / Domains: Check domain status during hibernation restore of devices
PM / devfreq: add relation of recommended frequency.
PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on()
PM / shmobile: Make CMT driver use pm_genpd_dev_always_on()
PM / shmobile: Make TMU driver use pm_genpd_dev_always_on()
PM / Domains: Introduce "always on" device flag
PM / Domains: Fix hibernation restore of devices, v2
PM / Domains: Fix handling of wakeup devices during system resume
sh_mmcif / PM: Use PM QoS latency constraint
tmio_mmc / PM: Use PM QoS latency constraint
PM / QoS: Make it possible to expose PM QoS latency constraints
PM / Sleep: JBD and JBD2 missing set_freezable()
PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case
PM / Freezer: Remove references to TIF_FREEZE in comments
PM / Sleep: Add more wakeup source initialization routines
PM / Hibernate: Enable usermodehelpers in hibernate() error path
PM / Sleep: Make __pm_stay_awake() delete wakeup source timers
PM / Sleep: Fix race conditions related to wakeup source timer function
PM / Sleep: Fix possible infinite loop during wakeup source destruction
PM / Hibernate: print physical addresses consistently with other parts of kernel
Normally, we have to issue a cache flush before we can update journal tail in
journal superblock, effectively wiping out old transactions from the journal.
So use the fact that during transaction commit we issue cache flush anyway and
opportunistically push journal tail as far as we can. Since update of journal
superblock is still costly (we have to use WRITE_FUA), we update log tail only
if we can free significant amount of space.
