Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: <linux-ext4@vger.kernel.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
This patch marks slab allocations by jbd2 as short-lived in support of
Mel Gorman's "Group short-lived and reclaimable kernel allocations"
patch. (Ported from similar changes made to fs/jbd/journal.c and
fs/jbd/revoke.c in Mel's patch.)
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The journal checksum feature adds two new flags i.e
JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT and JBD2_FEATURE_COMPAT_CHECKSUM.
JBD2_FEATURE_CHECKSUM flag indicates that the commit block contains the
checksum for the blocks described by the descriptor blocks.
Due to checksums, writing of the commit record no longer needs to be
synchronous. Now commit record can be sent to disk without waiting for
descriptor blocks to be written to disk. This behavior is controlled
using JBD2_FEATURE_ASYNC_COMMIT flag. Older kernels/e2fsck should not be
able to recover the journal with _ASYNC_COMMIT hence it is made
incompat.
The commit header has been extended to hold the checksum along with the
type of the checksum.
For recovery in pass scan checksums are verified to ensure the sanity
and completeness(in case of _ASYNC_COMMIT) of every transaction.
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Signed-off-by: Girish Shilamkar <girish@clusterfs.com>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
The patch below updates the jbd stats patch to 2.6.20/jbd2.
The initial patch was posted by Alex Tomas in December 2005
(http://marc.info/?l=linux-ext4&m=113538565128617&w=2).
It provides statistics via procfs such as transaction lifetime and size.
Sometimes, investigating performance problems, i find useful to have
stats from jbd about transaction's lifetime, size, etc. here is a
patch for review and inclusion probably.
for example, stats after creation of 3M files in htree directory:
[root@bob ~]# cat /proc/fs/jbd/sda/history
R/C tid wait run lock flush log hndls block inlog ctime write drop close
R 261 8260 2720 0 0 750 9892 8170 8187
C 259 750 0 4885 1
R 262 20 2200 10 0 770 9836 8170 8187
R 263 30 2200 10 0 3070 9812 8170 8187
R 264 0 5000 10 0 1340 0 0 0
C 261 8240 3212 4957 0
R 265 8260 1470 0 0 4640 9854 8170 8187
R 266 0 5000 10 0 1460 0 0 0
C 262 8210 2989 4868 0
R 267 8230 1490 10 0 4440 9875 8171 8188
R 268 0 5000 10 0 1260 0 0 0
C 263 7710 2937 4908 0
R 269 7730 1470 10 0 3330 9841 8170 8187
R 270 0 5000 10 0 830 0 0 0
C 265 8140 3234 4898 0
C 267 720 0 4849 1
R 271 8630 2740 20 0 740 9819 8170 8187
C 269 800 0 4214 1
R 272 40 2170 10 0 830 9716 8170 8187
R 273 40 2280 0 0 3530 9799 8170 8187
R 274 0 5000 10 0 990 0 0 0
where,
R - line for transaction's life from T_RUNNING to T_FINISHED
C - line for transaction's checkpointing
tid - transaction's id
wait - for how long we were waiting for new transaction to start
(the longest period journal_start() took in this transaction)
run - real transaction's lifetime (from T_RUNNING to T_LOCKED
lock - how long we were waiting for all handles to close
(time the transaction was in T_LOCKED)
flush - how long it took to flush all data (data=ordered)
log - how long it took to write the transaction to the log
hndls - how many handles got to the transaction
block - how many blocks got to the transaction
inlog - how many blocks are written to the log (block + descriptors)
ctime - how long it took to checkpoint the transaction
write - how many blocks have been written during checkpointing
drop - how many blocks have been dropped during checkpointing
close - how many running transactions have been closed to checkpoint this one
all times are in msec.
[root@bob ~]# cat /proc/fs/jbd/sda/info
280 transaction, each upto 8192 blocks
average:
1633ms waiting for transaction
3616ms running transaction
5ms transaction was being locked
1ms flushing data (in ordered mode)
1799ms logging transaction
11781 handles per transaction
5629 blocks per transaction
5641 logged blocks per transaction
Signed-off-by: Johann Lombardi <johann.lombardi@bull.net>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Mostly stolen from akpm's JBD cleanup patch.
- use `#ifdef foo' instead of `#if defined(foo)'
- Make journal_enable_debug __read_mostly just for the heck of it
- Make jbd_debugfs_dir and jbd_debug static
- debugfs_remove(NULL) is legal: remove unneeded tests
- remove unnecessary empty loops
Signed-off-by: Jose R. Santos <jrs@us.ibm.com>
change JBD_XXX macros to JBD2_XXX in JBD2/Ext4
Convert kmalloc to kzalloc() and get rid of the memset().
This patch cleans up jbd_kmalloc and replace it with kmalloc directly
JBD2: Replace slab allocations with page allocations
JBD2 allocate memory for committed_data and frozen_data from slab. However
JBD2 should not pass slab pages down to the block layer. Use page allocator
pages instead. This will also prepare JBD for the large blocksize patchset.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The jbd2-debug file used to be located in /proc/sys/fs/jbd2-debug, but it
incorrectly used create_proc_entry() instead of the sysctl routines, and
no proc entry was ever created.
Instead of fixing this we might as well move the jbd2-debug file to
debugfs which would be the preferred location for this kind of tunable.
The new location is now /sys/kernel/debug/jbd2/jbd2-debug.
When the JBD code was forked to create the new JBD2 code base, the
references to CONFIG_JBD_DEBUG where never changed to
CONFIG_JBD2_DEBUG. This patch fixes that.
If the thread failed to create the subsequent wait_event will hang forever.
This is likely to happen if kernel hits max_threads limit.
Will be critical for virtualization systems that limit the number of tasks
and kernel memory usage within the container.
(akpm: JBD should be converted fully to the kthread API: kthread_should_stop()
and kthread_stop()).
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
This is Eric Sesterhenn's jbd patch applied to jbd2.
Commit: 41716c7c21b15e7ecf14f0caf1eef3980707fb74
His words:
Since commit d1807793e1e7e502e3dc047115e9dbc3b50e4534 we dereference a NULL
pointer. Coverity id #1432. We set journal to NULL, and use it directly
afterwards.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Eric Sesterhenn <snakebyte@gmx.de>
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long.
JBD layer in-kernel block varibles type fixes to support >32 bit block number
and convert to sector_t type.
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach
Brown. This patch is useful only after adding support for 64-bit block
numbers in the filesystem.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Signed-off-by: Zach Brown <zach.brown@oracle.com>
jbd and jbd2 currently use the same slab names which must be unique. The
patch below just renames jbd2's slabs.
Mingming Cao originally did this work, and Shaggy reproduced it using some
scripts from her.
This is a simple copy of the files in fs/jbd to fs/jbd2 and
/usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h
