This allows the DAX code to use it.
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Originally-From: Christoph Hellwig <hch@lst.de>
This function uses the iomap infrastructure to re-write all pages
in a given range. This is useful for doing a copy-up of COW ranges,
and might be useful for scrubbing in the future.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Filesystems like XFS that use extents should not set the
FIEMAP_EXTENT_MERGED flag in the fiemap extent structures. To allow
for both behaviors for the upcoming gfs2 usage split the iomap
type field into type and flags, and only set FIEMAP_EXTENT_MERGED if
the IOMAP_F_MERGED flag is set. The flags field will also come in
handy for future features such as shared extents on reflink-enabled
file systems.
Reported-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: Darrick J. Wong <darrick.wong@oracle.com>
No need to implement it for read-only mappings.
By bassing through an -ENOENT, similar to the old XFS implementation of
FIEMAP_FLAG_XATTR.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
[hch: split from a larger patch]
The flag is checked as supported, but then we do an unconditional
sync of the file, regardless of whether the flag is set or not. Make
the sync conditional on having the FIEMAP_FLAG_SYNC flag set.
iov_iter_copy_from_user_atomic disables page faults internally, no need to
do it around the call. This also brings the iomap code in line with
the original filemap version.
This catches up with commit 2457ae ("mm: non-atomically mark page
accessed during page cache allocation where possible"), which
moved the initial access marking into the pagecache allocator.
Add a simple fiemap implementation based on iomap_ops, partially based
on a previous implementation from Bob Peterson <rpeterso@redhat.com>.
This avoid needing a separate inefficient get_block based DAX zero_range
implementation in file systems.
Add infrastructure for multipage buffered writes. This is implemented
using an main iterator that applies an actor function to a range that
can be written.
This infrastucture is used to implement a buffered write helper, one
to zero file ranges and one to implement the ->page_mkwrite VM
operations. All of them borrow a fair amount of code from fs/buffers.
for now by using an internal version of __block_write_begin that
gets passed an iomap and builds the corresponding buffer head.
The file system is gets a set of paired ->iomap_begin and ->iomap_end
calls which allow it to map/reserve a range and get a notification
once the write code is finished with it.
Based on earlier code from Dave Chinner.
Reviewed-by: Bob Peterson <rpeterso@redhat.com>
