path: root/fs/hfsplus
2016-10-31posix_acl: Clear SGID bit when setting file permissionsJan Kara
commit 073931017b49d9458aa351605b43a7e34598caef upstream. When file permissions are modified via chmod(2) and the user is not in the owning group or capable of CAP_FSETID, the setgid bit is cleared in inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file permissions as well as the new ACL, but doesn't clear the setgid bit in a similar way; this allows to bypass the check in chmod(2). Fix that. References: CVE-2016-7097 Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-13xattr handlers: Pass handler to operations instead of flagsAndreas Gruenbacher
The xattr_handler operations are currently all passed a file system specific flags value which the operations can use to disambiguate between different handlers; some file systems use that to distinguish the xattr namespace, for example. In some oprations, it would be useful to also have access to the handler prefix. To allow that, pass a pointer to the handler to operations instead of the flags value alone. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13hfsplus: Remove unused xattr handler list operationsAndreas Gruenbacher
The list operations can never be called; they are even documented to be unused. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-09-10hfs,hfsplus: cache pages correctly between bnode_create and bnode_freeHin-Tak Leung
Pages looked up by __hfs_bnode_create() (called by hfs_bnode_create() and hfs_bnode_find() for finding or creating pages corresponding to an inode) are immediately kmap()'ed and used (both read and write) and kunmap()'ed, and should not be page_cache_release()'ed until hfs_bnode_free(). This patch fixes a problem I first saw in July 2012: merely running "du" on a large hfsplus-mounted directory a few times on a reasonably loaded system would get the hfsplus driver all confused and complaining about B-tree inconsistencies, and generates a "BUG: Bad page state". Most recently, I can generate this problem on up-to-date Fedora 22 with shipped kernel 4.0.5, by running "du /" (="/" + "/home" + "/mnt" + other smaller mounts) and "du /mnt" simultaneously on two windows, where /mnt is a lightly-used QEMU VM image of the full Mac OS X 10.9: $ df -i / /home /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /dev/mapper/fedora-root 3276800 551665 2725135 17% / /dev/mapper/fedora-home 52879360 716221 52163139 2% /home /dev/nbd0p2 4294967295 1387818 4293579477 1% /mnt After applying the patch, I was able to run "du /" (60+ times) and "du /mnt" (150+ times) continuously and simultaneously for 6+ hours. There are many reports of the hfsplus driver getting confused under load and generating "BUG: Bad page state" or other similar issues over the years. [1] The unpatched code [2] has always been wrong since it entered the kernel tree. The only reason why it gets away with it is that the kmap/memcpy/kunmap follow very quickly after the page_cache_release() so the kernel has not had a chance to reuse the memory for something else, most of the time. The current RW driver appears to have followed the design and development of the earlier read-only hfsplus driver [3], where-by version 0.1 (Dec 2001) had a B-tree node-centric approach to read_cache_page()/page_cache_release() per bnode_get()/bnode_put(), migrating towards version 0.2 (June 2002) of caching and releasing pages per inode extents. When the current RW code first entered the kernel [2] in 2005, there was an REF_PAGES conditional (and "//" commented out code) to switch between B-node centric paging to inode-centric paging. There was a mistake with the direction of one of the REF_PAGES conditionals in __hfs_bnode_create(). In a subsequent "remove debug code" commit [4], the read_cache_page()/page_cache_release() per bnode_get()/bnode_put() were removed, but a page_cache_release() was mistakenly left in (propagating the "REF_PAGES <-> !REF_PAGE" mistake), and the commented-out page_cache_release() in bnode_release() (which should be spanned by !REF_PAGES) was never enabled. References: [1]: Michael Fox, Apr 2013 http://www.spinics.net/lists/linux-fsdevel/msg63807.html ("hfsplus volume suddenly inaccessable after 'hfs: recoff %d too large'") Sasha Levin, Feb 2015 http://lkml.org/lkml/2015/2/20/85 ("use after free") https://bugs.launchpad.net/ubuntu/+source/linux/+bug/740814 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1027887 https://bugzilla.kernel.org/show_bug.cgi?id=42342 https://bugzilla.kernel.org/show_bug.cgi?id=63841 https://bugzilla.kernel.org/show_bug.cgi?id=78761 [2]: http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\ fs/hfs/bnode.c?id=d1081202f1d0ee35ab0beb490da4b65d4bc763db commit d1081202f1d0ee35ab0beb490da4b65d4bc763db Author: Andrew Morton <akpm@osdl.org> Date: Wed Feb 25 16:17:36 2004 -0800 [PATCH] HFS rewrite http://git.kernel.org/cgit/linux/kernel/git/tglx/history.git/commit/\ fs/hfsplus/bnode.c?id=91556682e0bf004d98a529bf829d339abb98bbbd commit 91556682e0bf004d98a529bf829d339abb98bbbd Author: Andrew Morton <akpm@osdl.org> Date: Wed Feb 25 16:17:48 2004 -0800 [PATCH] HFS+ support [3]: http://sourceforge.net/projects/linux-hfsplus/ http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.1/ http://sourceforge.net/projects/linux-hfsplus/files/Linux%202.4.x%20patch/hfsplus%200.2/ http://linux-hfsplus.cvs.sourceforge.net/viewvc/linux-hfsplus/linux/\ fs/hfsplus/bnode.c?r1=1.4&r2=1.5 Date: Thu Jun 6 09:45:14 2002 +0000 Use buffer cache instead of page cache in bnode.c. Cache inode extents. [4]: http://git.kernel.org/cgit/linux/kernel/git/\ stable/linux-stable.git/commit/?id=a5e3985fa014029eb6795664c704953720cc7f7d commit a5e3985fa014029eb6795664c704953720cc7f7d Author: Roman Zippel <zippel@linux-m68k.org> Date: Tue Sep 6 15:18:47 2005 -0700 [PATCH] hfs: remove debug code Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Sergei Antonov <saproj@gmail.com> Reviewed-by: Anton Altaparmakov <anton@tuxera.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Sougata Santra <sougata@tuxera.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04fs: create and use seq_show_option for escapingKees Cook
Many file systems that implement the show_options hook fail to correctly escape their output which could lead to unescaped characters (e.g. new lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This could lead to confusion, spoofed entries (resulting in things like systemd issuing false d-bus "mount" notifications), and who knows what else. This looks like it would only be the root user stepping on themselves, but it's possible weird things could happen in containers or in other situations with delegated mount privileges. Here's an example using overlay with setuid fusermount trusting the contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use of "sudo" is something more sneaky: $ BASE="ovl" $ MNT="$BASE/mnt" $ LOW="$BASE/lower" $ UP="$BASE/upper" $ WORK="$BASE/work/ 0 0 none /proc fuse.pwn user_id=1000" $ mkdir -p "$LOW" "$UP" "$WORK" $ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt $ cat /proc/mounts none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0 none /proc fuse.pwn user_id=1000 0 0 $ fusermount -u /proc $ cat /proc/mounts cat: /proc/mounts: No such file or directory This fixes the problem by adding new seq_show_option and seq_show_option_n helpers, and updating the vulnerable show_option handlers to use them as needed. Some, like SELinux, need to be open coded due to unusual existing escape mechanisms. [akpm@linux-foundation.org: add lost chunk, per Kees] [keescook@chromium.org: seq_show_option should be using const parameters] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: J. R. Okajima <hooanon05g@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-02writeback: separate out include/linux/backing-dev-defs.hTejun Heo
With the planned cgroup writeback support, backing-dev related declarations will be more widely used across block and cgroup; unfortunately, including backing-dev.h from include/linux/blkdev.h makes cyclic include dependency quite likely. This patch separates out backing-dev-defs.h which only has the essential definitions and updates blkdev.h to include it. c files which need access to more backing-dev details now include backing-dev.h directly. This takes backing-dev.h off the common include dependency chain making it a lot easier to use it across block and cgroup. v2: fs/fat build failure fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17hfsplus: don't store special "osx" xattr prefix on-diskThomas Hebb
On Mac OS X, HFS+ extended attributes are not namespaced. Since we want to be compatible with OS X filesystems and yet still support the Linux namespacing system, the hfsplus driver implements a special "osx" namespace that is reported for any attribute that is not namespaced on-disk. However, the current code for getting and setting these unprefixed attributes is broken. hfsplus_osx_setattr() and hfsplus_osx_getattr() are passed names that have already had their "osx." prefixes stripped by the generic functions. The functions first, quite correctly, check those names to make sure that they aren't prefixed with a known namespace, which would allow namespace access restrictions to be bypassed. However, the functions then prepend "osx." to the name they're given before passing it on to hfsplus_getattr() and hfsplus_setattr(). Not only does this cause the "osx." prefix to be stored on-disk, defeating its purpose, it also breaks the check for the special "com.apple.FinderInfo" attribute, which is reported for all files, and as a consequence makes some userspace applications (e.g. GNU patch) fail even when extended attributes are not otherwise in use. There are five commits which have touched this particular code: 127e5f5ae51e ("hfsplus: rework functionality of getting, setting and deleting of extended attributes") b168fff72109 ("hfsplus: use xattr handlers for removexattr") bf29e886b242 ("hfsplus: correct usage of HFSPLUS_ATTR_MAX_STRLEN for non-English attributes") fcacbd95e121 ("fs/hfsplus: move xattr_name allocation in hfsplus_getxattr()") ec1bbd346f18 ("fs/hfsplus: move xattr_name allocation in hfsplus_setxattr()") The first commit creates the functions to begin with. The namespace is prepended by the original code, which I believe was correct at the time, since hfsplus_?etattr() stripped the prefix if found. The second commit removes this behavior from hfsplus_?etattr() and appears to have been intended to also remove the prefixing from hfsplus_osx_?etattr(). However, what it actually does is remove a necessary strncpy() call completely, breaking the osx namespace entirely. The third commit re-adds the strncpy() call as it was originally, but doesn't mention it in its commit message. The final two commits refactor the code and don't affect its functionality. This commit does what b168fff attempted to do (prevent the prefix from being added), but does it properly, instead of passing in an empty buffer (which is what b168fff actually did). Fixes: b168fff72109 ("hfsplus: use xattr handlers for removexattr") Signed-off-by: Thomas Hebb <tommyhebb@gmail.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Sergei Antonov <saproj@gmail.com> Cc: Anton Altaparmakov <anton@tuxera.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Viacheslav Dubeyko <slava@dubeyko.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17hfsplus: fix expand when not enough available spaceSergei Antonov
Fix a bug which is reproduced as follows. Create a file: echo abc > test_file Try to expand the file beyond available space: truncate --size=<size exceeding available space> test_file Since HFS+ does not support file size > allocated size, truncate should fail. However, it ends successfully. The driver returns success despite having been unable to allocate the requested space for the file. Also filesystem check finds an error: Checking catalog file. Incorrect size for file test_file (It should be 469094400 instead of 1000000000) Add a piece of code analogous to code in the fat driver. Now a proper error is returned and filesystem remains consistent. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Reviewed-by: Anton Altaparmakov <anton@tuxera.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Sougata Santra <sougata@tuxera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17hfsplus: incorrect return valueChengyu Song
In case of memory allocation error, the return should be -ENOMEM, instead of -ENOSPC. Signed-off-by: Chengyu Song <csong84@gatech.edu> Reviewed-by: Sergei Antonov <saproj@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/hfsplus: replace if/BUG by BUG_ONFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/hfsplus: use bool instead of int for is_known_namespace() return valueFabian Frederick
is_known_namespace() only returns true/false. Also remove inline and let compiler decide what to do with static functions. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/hfsplus: atomically set inode->i_flagsFabian Frederick
According to commit 5f16f3225b06 ("ext4: atomically set inode->i_flags in ext4_set_inode_flags()"). Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/hfsplus: move xattr_name allocation in hfsplus_setxattr()Fabian Frederick
security/trusted/user/osx setxattr did the same xattr_name initialization. Move that operation in hfsplus_setxattr(). Tested with security/trusted/user getfattr/setfattr Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/hfsplus: move xattr_name allocation in hfsplus_getxattr()Fabian Frederick
security/trusted/user/osx getxattr did the same xattr_name initialization. Move that operation in hfsplus_getxattr(). Tested with security/trusted/user getfattr/setfattr Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17hfsplus: add missing curly braces in hfsplus_delete_cat()Dan Carpenter
This doesn't change how the code works, but clearly the curly braces were intended. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Sougata Santra <sougata@tuxera.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-09Merge branch 'iocb' into for-davemAl Viro
trivial conflict in net/socket.c and non-trivial one in crypto - that one had evaded aio_complete() removal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25hfsplus: fix B-tree corruption after insertion at position 0Sergei Antonov
Fix B-tree corruption when a new record is inserted at position 0 in the node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is called to update the parent index node (if exists) and it is passed hfs_find_data with a search_key containing a newly inserted key instead of the key to be updated. This results in an inconsistent index node. The bug reproduces on my machine after an extents overflow record for the catalog file (CNID=4) is inserted into the extents overflow B-tree. Because of a low (reserved) value of CNID=4, it has to become the first record in the first leaf node. The resulting first leaf node is correct: ---------------------------------------------------- | key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... | ---------------------------------------------------- But the parent index key0 still contains the previous key CNID=123: ----------------------- | key0.CNID=123 | ... | ----------------------- A change in hfs_brec_insert() makes hfs_brec_update_parent() work correctly by preventing it from getting fd->record=-1 value from __hfs_brec_find(). Along the way, I removed duplicate code with unification of the if condition. The resulting code is equivalent to the original code because node is never 0. Also hfs_brec_update_parent() will now return an error after getting a negative fd->record value. However, the return value of hfs_brec_update_parent() is not checked anywhere in the file and I'm leaving it unchanged by this patch. brec.c lacks error checking after some other calls too, but this issue is of less importance than the one being fixed by this patch. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Joe Perches <joe@perches.com> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-18hfsplus: fix longname handlingSougata Santra
Longname is not correctly handled by hfsplus driver. If an attempt to create a longname(>255) file/directory is made, it succeeds by creating a file/directory with HFSPLUS_MAX_STRLEN and incorrect catalog key. Thus leaving the volume in an inconsistent state. This patch fixes this issue. Although lookup is always called first to create a negative entry, so just doing a check in lookup would probably fix this issue. I choose to propagate error to other iops as well. Please NOTE: I have factored out hfsplus_cat_build_key_with_cnid from hfsplus_cat_build_key, to avoid unncessary branching. Thanks a lot. TEST: ------ dir="TEST_DIR" cdir=`pwd` name255="_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ _123456789_123456789_123456789_123456789_123456789_1234" name256="${name255}5" mkdir $dir cd $dir touch $name255 rm -f $name255 touch $name256 ls -la cd $cdir rm -rf $dir RESULT: ------- [sougata@ultrabook tmp]$ cdir=`pwd` [sougata@ultrabook tmp]$ name255="_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_123456789_123456789\ > _123456789_123456789_123456789_123456789_123456789_1234" [sougata@ultrabook tmp]$ name256="${name255}5" [sougata@ultrabook tmp]$ [sougata@ultrabook tmp]$ mkdir $dir [sougata@ultrabook tmp]$ cd $dir [sougata@ultrabook TEST_DIR]$ touch $name255 [sougata@ultrabook TEST_DIR]$ rm -f $name255 [sougata@ultrabook TEST_DIR]$ touch $name256 [sougata@ultrabook TEST_DIR]$ ls -la ls: cannot access _123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234: No such file or directory total 0 drwxrwxr-x 1 sougata sougata 3 Feb 20 19:56 . drwxrwxrwx 1 root root 6 Feb 20 19:56 .. -????????? ? ? ? ? ? _123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_123456789_1234 [sougata@ultrabook TEST_DIR]$ cd $cdir [sougata@ultrabook tmp]$ rm -rf $dir rm: cannot remove `TEST_DIR': Directory not empty -ENAMETOOLONG returned from hfsplus_asc2uni was not propaged to iops. This allowed hfsplus to create files/directories with HFSPLUS_MAX_STRLEN and incorrect keys, leaving the FS in an inconsistent state. This patch fixes this issue. Signed-off-by: Sougata Santra <sougata@tuxera.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-06hfsplus: fix compiler warning on PowerPCChristian Kujau
Commit a99b7069aab8 ("hfsplus: Fix undefined __divdi3 in hfsplus_init_header_node()") introduced do_div() to xattr.c and the warning below too. As Geert remarked: "tmp" is "loff_t" which is "__kernel_loff_t", which is "long long", i.e. signed, while include/asm-generic/div64.h compares its type with "uint64_t". As inode sizes are positive, it should be safe to change the type of "tmp" to "u64". In file included from arch/powerpc/include/asm/div64.h:1:0, from include/linux/kernel.h:124, from include/asm-generic/bug.h:13, from arch/powerpc/include/asm/bug.h:127, from include/linux/bug.h:4, from include/linux/thread_info.h:11, from include/asm-generic/preempt.h:4, from arch/powerpc/include/generated/asm/preempt.h:1, from include/linux/preempt.h:18, from include/linux/spinlock.h:50, from include/linux/wait.h:8, from include/linux/fs.h:6, from fs/hfsplus/hfsplus_fs.h:19, from fs/hfsplus/xattr.c:9: fs/hfsplus/xattr.c: In function 'hfsplus_init_header_node': include/asm-generic/div64.h:43:28: warning: comparison of distinct pointer types lacks a cast [enabled by default] (void)(((typeof((n)) *)0) == ((uint64_t *)0)); \ ^ fs/hfsplus/xattr.c:86:2: note: in expansion of macro 'do_div' do_div(tmp, node_size); ^ Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Sergei Antonov <saproj@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/hfsplus: fix pr_foo() and hfs_dbg formatsFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Suggested-By: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: coding style fix for declarations in hfsplus_fs.hSergei Antonov
Some function declarations in hfsplus_fs.h were with argument names, some without, and some were mixed. This patch adds argument names everywhere, sorts function in order they go in .c files, and moves hfs_part_find() to a proper section. Auto-formatting and sorting was done with: cfunctions *.c | indent -linux | sed "s| \* | \*|" Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/hfsplus/wrapper.c: replace shift loop by ilog2Fabian Frederick
Replace while blocksize;shift by ilog2 Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: fix "unused node is not erased" errorSergei Antonov
Zero newly allocated extents in the catalog tree if volume attributes tell us to. Not doing so we risk getting the "unused node is not erased" error. See kHFSUnusedNodeFix flag in Apple's source code for reference. There was a previous commit clearing the node when it is freed: commit 899bed05e9f6 ("hfsplus: fix issue with unzeroed unused b-tree nodes"). But it did not handle newly allocated extents (this patch fixes it). And it zeroed nodes in all trees unconditionally which is an overkill. This patch adds a condition and also switches to 'tree->node_size' as a simpler method of getting the length to zero. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Kyle Laracey <kalaracey@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/hfsplus/wrapper.c: replace min/casting by min_tFabian Frederick
Also add * before function comments (it was not detected by kernel-doc) Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/hfsplus/options.c: replace seq_printf by seq_putsFabian Frederick
Replace seq_printf where possible Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/hfsplus/bnode.c: replace min/casting by min_tFabian Frederick
Also fixes some pr_ formats Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: emit proper file type from readdirSergei Antonov
hfsplus_readdir() incorrectly returned DT_REG for symbolic links and special files. Return DT_REG, DT_LNK, DT_FIFO, DT_CHR, DT_BLK, DT_SOCK, or DT_UNKNOWN according to mode field in catalog record. Programs relying on information from readdir will now work correctly with HFS+. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: remove unused routine hfsplus_attr_build_key_uniHin-Tak Leung
The directory/file catalog b-tree equivalent, hfsplus_build_key_uni(), is used by hfsplus_find_cat() for internal referencing between catalog records. There is no corresponding usage for attributes - attribute records do not refer to one another. Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Sougata Santra <sougata@tuxera.com> Cc: Anton Altaparmakov <anton@tuxera.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: correct usage of HFSPLUS_ATTR_MAX_STRLEN for non-English attributesHin-Tak Leung
HFSPLUS_ATTR_MAX_STRLEN (=127) is the limit of attribute names for the number of unicode character (UTF-16BE) storable in the HFS+ file system. Almost all the current usage of it is wrong, in relation to NLS to on-disk conversion. Except for one use calling hfsplus_asc2uni (which should stay the same) and its uses in calling hfsplus_uni2asc (which was corrected in the earlier patch in this series concerning usage of hfsplus_uni2asc), all the other uses are of the forms: - char buffer[size] - bound check: "if (namespace_adjusted_input_length > size) return failure;" Conversion between on-disk unicode representation and NLS char strings (in whichever direction) always needs to accommodate the worst-case NLS conversion, so all char buffers of that size need to have a NLS_MAX_CHARSET_SIZE x . The bound checks are all wrong, since they compare nls_length derived from strlen() to a unicode length limit. It turns out that all the bound-checks do is to protect hfsplus_asc2uni(), which can fail if the input is too large. There is only one usage of it as far as attributes are concerned, in hfsplus_attr_build_key(). It is in turn used by hfsplus_find_attr(), hfsplus_create_attr(), hfsplus_delete_attr(). Thus making sure that errors from hfsplus_asc2uni() is caught in hfsplus_attr_build_key() and propagated is sufficient to replace all the bound checks. Unpropagated errors from hfsplus_asc2uni() in the file catalog code was addressed recently in an independent patch "hfsplus: fix longname handling" by Sougata Santra. Before this patch, trying to set a 55 CJK character (in a UTF-8 locale, > 127/3=42) attribute plus user prefix fails with: $ setfattr -n user.`cat testing-string` -v `cat testing-string` \ testing-string setfattr: testing-string: Operation not supported and retrieving a stored long attributes is particular ugly(!): find /mnt/* -type f -exec getfattr -d {} \; getfattr: /mnt/testing-string: Input/output error with console log: [268008.389781] hfsplus: unicode conversion failed After the patch, both of the above works. FYI, the test attribute string is prepared with: echo -e -n \ "\xe9\x80\x99\xe6\x98\xaf\xe4\xb8\x80\xe5\x80\x8b\xe9\x9d\x9e\xe5" \ "\xb8\xb8\xe6\xbc\xab\xe9\x95\xb7\xe8\x80\x8c\xe6\xa5\xb5\xe5\x85" \ "\xb6\xe4\xb9\x8f\xe5\x91\xb3\xe5\x92\x8c\xe7\x9b\xb8\xe7\x95\xb6" \ "\xe7\x84\xa1\xe8\xb6\xa3\xe3\x80\x81\xe4\xbb\xa5\xe5\x8f\x8a\xe7" \ "\x84\xa1\xe7\x94\xa8\xe7\x9a\x84\xe3\x80\x81\xe5\x86\x8d\xe5\x8a" \ "\xa0\xe4\xb8\x8a\xe6\xaf\xab\xe7\x84\xa1\xe6\x84\x8f\xe7\xbe\xa9" \ "\xe7\x9a\x84\xe6\x93\xb4\xe5\xb1\x95\xe5\xb1\xac\xe6\x80\xa7\xef" \ "\xbc\x8c\xe8\x80\x8c\xe5\x85\xb6\xe5\x94\xaf\xe4\xb8\x80\xe5\x89" \ "\xb5\xe5\xbb\xba\xe7\x9b\xae\xe7\x9a\x84\xe5\x83\x85\xe6\x98\xaf" \ "\xe7\x82\xba\xe4\xba\x86\xe6\xb8\xac\xe8\xa9\xa6\xe4\xbd\x9c\xe7" \ "\x94\xa8\xe3\x80\x82" | tr -d ' ' (= "pointlessly long attribute for testing", elaborate Chinese in UTF-8 enoding). However, it is not possible to set double the size (110 + 5 is still under 127) in a UTF-8 locale: $setfattr -n user.`cat testing-string testing-string` -v \ `cat testing-string testing-string` testing-string setfattr: testing-string: Numerical result out of range 110 CJK char in UTF-8 is 330 bytes - the generic get/set attribute system call code in linux/fs/xattr.c imposes a 255 byte limit. One can use a combination of iconv to encode content, changing terminal locale for viewing, and an nls=cp932/cp936/cp949/cp950 mount option to fully use 127-unicode attribute in a double-byte locale. Also, as an additional information, it is possible to (mis-)use unicode half-width/full-width forms (U+FFxx) to write attributes which looks like english but not actually ascii. Thanks Anton Altaparmakov for reviewing the earlier ideas behind this change. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix build] Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Anton Altaparmakov <anton@tuxera.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Sougata Santra <sougata@tuxera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06hfsplus: fix worst-case unicode to char conversion of file names and attributesHin-Tak Leung
This is a series of 3 patches which corrects issues in HFS+ concerning the use of non-english file names and attributes. Names and attributes are stored internally as UTF-16 units up to a fixed maximum size, and convert to and from user-representation by NLS. The code incorrectly assume that NLS string lengths are equal to unicode lengths, which is only true for English ascii usage. This patch (of 3): The HFS Plus Volume Format specification (TN1150) states that file names are stored internally as a maximum of 255 unicode characters, as defined by The Unicode Standard, Version 2.0 [Unicode, Inc. ISBN 0-201-48345-9]. File names are converted by the NLS system on Linux before presented to the user. 255 CJK characters converts to UTF-8 with 1 unicode character to up to 3 bytes, and to GB18030 with 1 unicode character to up to 4 bytes. Thus, trying in a UTF-8 locale to list files with names of more than 85 CJK characters results in: $ ls /mnt ls: reading directory /mnt: File name too long The receiving buffer to hfsplus_uni2asc() needs to be 255 x NLS_MAX_CHARSET_SIZE bytes, not 255 bytes as the code has always been. Similar consideration applies to attributes, which are stored internally as a maximum of 127 UTF-16BE units. See XNU source for an up-to-date reference on attributes. Strictly speaking, the maximum value of NLS_MAX_CHARSET_SIZE = 6 is not attainable in the case of conversion to UTF-8, as going beyond 3 bytes requires the use of surrogate pairs, i.e. consuming two input units. Thanks Anton Altaparmakov for reviewing an earlier version of this change. This patch fixes all callers of hfsplus_uni2asc(), and also enables the use of long non-English file names in HFS+. The getting and setting, and general usage of long non-English attributes requires further forthcoming work, in the following patches of this series. [akpm@linux-foundation.org: fix build] Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Reviewed-by: Anton Altaparmakov <anton@tuxera.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Sougata Santra <sougata@tuxera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-05-06switch {__,}blockdev_direct_IO() to iov_iterAl Viro
2014-05-06get rid of pointless iov_length() in ->direct_IO()Al Viro
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-04-03fs/hfsplus/attributes.c: add __init to hfsplus_create_attr_tree_cache()Fabian Frederick
hfsplus_create_attr_tree_cache is only called by __init init_hfsplus_fs Signed-off-by: Fabian Frederick <fabf@skynet.be> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs/hfsplus/extents.c: fix concurrent acess of alloc_blocksSougata Santra
Concurrent access to alloc_blocks in hfsplus_inode_info() is protected by extents_lock mutex. This patch fixes two instances where alloc_blocks modification was not protected with this lock. This fixes possible allocation bitmap corruption in race conditions while extending and truncating files. [akpm@linux-foundation.org: take extents_lock before taking a copy of ->alloc_blocks] [akpm@linux-foundation.org: remove now-unused label `out'] Signed-off-by: Sougata Santra <sougata@tuxera.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
