path: root/fs/hfsplus/inode.c
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "xattr stuff from Andreas This completes the switch to xattr_handler ->get()/->set() from ->getxattr/->setxattr/->removexattr" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Remove {get,set,remove}xattr inode operations xattr: Stop calling {get,set,remove}xattr inode operations vfs: Check for the IOP_XATTR flag in listxattr xattr: Add __vfs_{get,set,remove}xattr helpers libfs: Use IOP_XATTR flag for empty directory handling vfs: Use IOP_XATTR flag for bad-inode handling vfs: Add IOP_XATTR inode operations flag vfs: Move xattr_resolve_name to the front of fs/xattr.c ecryptfs: Switch to generic xattr handlers sockfs: Get rid of getxattr iop sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names kernfs: Switch to generic xattr handlers hfs: Switch to generic xattr handlers jffs2: Remove jffs2_{get,set,remove}xattr macros xattr: Remove unnecessary NULL attribute name check
2016-10-07vfs: Remove {get,set,remove}xattr inode operationsAndreas Gruenbacher
These inode operations are no longer used; remove them. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: Replace CURRENT_TIME_SEC with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME_SEC is not y2038 safe. current_time() will be transitioned to use 64 bit time along with vfs in a separate patch. There is no plan to transistion CURRENT_TIME_SEC to use y2038 safe time interfaces. current_time() will also be extended to use superblock range checking parameters when range checking is introduced. This works because alloc_super() fills in the the s_time_gran in super block to NSEC_PER_SEC. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-05-29file_inode(f)->i_mapping is f->f_mappingAl Viro
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
2016-05-12hfsplus: switch to ->iterate_shared()Al Viro
We need to protect the list of hfsplus_readdir_data against parallel insertions (in readdir) and removals (in release). Add a spinlock for that. Note that it has nothing to do with protection of hfsplus_readdir_data->key - we have an exclusion between hfsplus_readdir() and hfsplus_delete_cat() on directory lock and between several hfsplus_readdir() for the same struct file on ->f_pos_lock. The spinlock is strictly for list changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17hfsplus: fix expand when not enough available spaceSergei Antonov
Fix a bug which is reproduced as follows. Create a file: echo abc > test_file Try to expand the file beyond available space: truncate --size=<size exceeding available space> test_file Since HFS+ does not support file size > allocated size, truncate should fail. However, it ends successfully. The driver returns success despite having been unable to allocate the requested space for the file. Also filesystem check finds an error: Checking catalog file. Incorrect size for file test_file (It should be 469094400 instead of 1000000000) Add a piece of code analogous to code in the fat driver. Now a proper error is returned and filesystem remains consistent. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Reviewed-by: Anton Altaparmakov <anton@tuxera.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Sougata Santra <sougata@tuxera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-05-06switch {__,}blockdev_direct_IO() to iov_iterAl Viro
2014-05-06get rid of pointless iov_length() in ->direct_IO()Al Viro
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-10hfsplus: add HFSX subfolder count supportSergei Antonov
Adds support for HFSX 'HasFolderCount' flag and a corresponding 'folderCount' field in folder records. (For reference see HFS_FOLDERCOUNT and kHFSHasFolderCountBit/kHFSHasFolderCountMask in Apple's source code.) Ignoring subfolder count leads to fs errors found by Mac: ... Checking catalog hierarchy. HasFolderCount flag needs to be set (id = 105) (It should be 0x10 instead of 0) Incorrect folder count in a directory (id = 2) (It should be 7 instead of 6) ... Steps to reproduce: Format with "newfs_hfs -s /dev/diskXXX". Mount in Linux. Create a new directory in root. Unmount. Run "fsck_hfs /dev/diskXXX". The patch handles directory creation, deletion, and rename. Signed-off-by: Sergei Antonov <saproj@gmail.com> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-31hfsplus: use xattr handlers for removexattrChristoph Hellwig
hfsplus was already using the handlers for get and set operations, and with the removal of can_set_xattr we've now allow operations that wouldn't otherwise be allowed. With this we can also centralize the special-casing of the osx. attrs that don't have prefixes on disk in the osx xattr handlers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Assorted stuff; the biggest pile here is Christoph's ACL series. Plus assorted cleanups and fixes all over the place... There will be another pile later this week" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits) __dentry_path() fixes vfs: Remove second variable named error in __dentry_path vfs: Is mounted should be testing mnt_ns for NULL or error. Fix race when checking i_size on direct i/o read hfsplus: remove can_set_xattr nfsd: use get_acl and ->set_acl fs: remove generic_acl nfs: use generic posix ACL infrastructure for v3 Posix ACLs gfs2: use generic posix ACL infrastructure jfs: use generic posix ACL infrastructure xfs: use generic posix ACL infrastructure reiserfs: use generic posix ACL infrastructure ocfs2: use generic posix ACL infrastructure jffs2: use generic posix ACL infrastructure hfsplus: use generic posix ACL infrastructure f2fs: use generic posix ACL infrastructure ext2/3/4: use generic posix ACL infrastructure btrfs: use generic posix ACL infrastructure fs: make posix_acl_create more useful fs: make posix_acl_chmod more useful ...
2014-01-25hfsplus: use generic posix ACL infrastructureChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-23hfsplus: remove hfsplus_file_lookup()Sougata Santra
HFS+ resource fork lookup breaks opendir() library function. Since opendir first calls open() with O_DIRECTORY flag set. O_DIRECTORY means "refuse to open if not a directory". The open system call in the kernel does a check for inode->i_op->lookup and returns -ENOTDIR. So if hfsplus_file_lookup is set it allows opendir() for plain files. Also resource fork lookup in HFS+ does not work. Since it is never invoked after VFS permission checking. It will always return with -EACCES. When we call opendir() on a file, it does not return NULL. opendir() library call is based on open with O_DIRECTORY flag passed and then layered on top of getdents() system call. O_DIRECTORY means "refuse to open if not a directory". The open() system call in the kernel does a check for: do_sys_open() -->..--> can_lookup() i.e it only checks inode->i_op->lookup and returns ENOTDIR if this function pointer is not set. In OSX, we can open "file/rsrc" to get the resource fork of "file". This behavior is emulated inside hfsplus on Linux, which means that to some degree every file acts like a directory. That is the reason lookup() inode operations is supported for files, and it is possible to do a lookup on this specific name. As a result of this open succeeds without returning ENOTDIR for HFS+ Please see the LKML discussion thread on this issue: http://marc.info/?l=linux-fsdevel&m=122823343730412&w=2 I tried to test file/rsrc lookup in HFS+ driver and the feature does not work. From OSX: $ touch test $ echo "1234" > test/..namedfork/rsrc $ ls -l test..namedfork/rsrc --rw-r--r-- 1 tuxera staff 5 10 dec 12:59 test/..namedfork/rsrc [sougata@ultrabook tmp]$ id uid=1000(sougata) gid=1000(sougata) groups=1000(sougata),5(tty),18(dialout),1001(vboxusers) [sougata@ultrabook tmp]$ mount /dev/sdb1 on /mnt/tmp type hfsplus (rw,relatime,umask=0,uid=1000,gid=1000,nls=utf8) [sougata@ultrabook tmp]$ ls -l test/rsrc ls: cannot access test/rsrc: Permission denied According to this LKML thread it is expected behavior. http://marc.info/?t=121139033800008&r=1&w=4 I guess now that permission checking happens in vfs generic_permission() ? So it turns out that even though the lookup() inode_operation exists for HFS+ files. It cannot really get invoked ?. So if we can disable this feature to make opendir() work for HFS+. Signed-off-by: Sougata Santra <sougata@tuxera.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11hfsplus: integrate POSIX ACLs support into driverVyacheslav Dubeyko
Integrate implemented POSIX ACLs support into hfsplus driver. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30hfs/hfsplus: convert printks to pr_<level>Joe Perches
Use a more current logging style. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt hfsplus now uses "hfsplus: " for all messages. Coalesce formats. Prefix debugging messages too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hfsplus: add support of manipulation by attributes fileVyacheslav Dubeyko
Add support of manipulation by attributes file. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20hfsplus: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-21userns: Convert hfsplus to use kuid and kgid where appropriateEric W. Biederman
2012-07-22hfsplus: get rid of write_superArtem Bityutskiy
This patch makes hfsplus stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20hfsplus: initialise userflagsMatthew Garrett
The userflags field was being written to the filesystem without being initialised. Make sure it's clear, since otherwise files end up with garbage attributes. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03hfsplus: propagate umode_tAl Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-07hfsplus: add error checking for hfs_find_init()Alexey Khoroshilov
hfs_find_init() may fail with ENOMEM, but there are places, where the returned value is not checked. The consequences can be very unpleasant, e.g. kfree uninitialized pointer and inappropriate mutex unlocking. The patch adds checks for errors in hfs_find_init(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
