Commit afddba49d18f ("fs: introduce write_begin, write_end, and
perform_write aops") introduced AOP_FLAG_UNINTERRUPTIBLE flag which was
checked in pagecache_write_begin(), but that check was removed by
4e02ed4b4a2f ("fs: remove prepare_write/commit_write").
Between these two commits, commit d9414774dc0c ("cifs: Convert cifs to
new aops.") added a check in cifs_write_begin(), but that check was soon
removed by commit a98ee8c1c707 ("[CIFS] fix regression in
cifs_write_begin/cifs_write_end").
Therefore, AOP_FLAG_UNINTERRUPTIBLE flag is checked nowhere. Let's
remove this flag. This patch has no functionality changes.
Link: http://lkml.kernel.org/r/1489294781-53494-1-git-send-email-penguin-kernel@I-love.SAKURA.ne.jp
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Cc: Nick Piggin <npiggin@gmail.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-By: Vyacheslav Dubeyko <slava@dubeyko.com>
Zero newly allocated extents in the catalog tree if volume attributes
tell us to. Not doing so we risk getting the "unused node is not
erased" error. See kHFSUnusedNodeFix flag in Apple's source code for
reference.
There was a previous commit clearing the node when it is freed: commit
899bed05e9f6 ("hfsplus: fix issue with unzeroed unused b-tree nodes").
But it did not handle newly allocated extents (this patch fixes it).
And it zeroed nodes in all trees unconditionally which is an overkill.
This patch adds a condition and also switches to 'tree->node_size' as a
simpler method of getting the length to zero.
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Cc: Anton Altaparmakov <aia21@cam.ac.uk>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Kyle Laracey <kalaracey@gmail.com>
Concurrent access to alloc_blocks in hfsplus_inode_info() is protected
by extents_lock mutex. This patch fixes two instances where
alloc_blocks modification was not protected with this lock.
This fixes possible allocation bitmap corruption in race conditions
while extending and truncating files.
[akpm@linux-foundation.org: take extents_lock before taking a copy of ->alloc_blocks]
[akpm@linux-foundation.org: remove now-unused label `out']
Signed-off-by: Sougata Santra <sougata@tuxera.com>
Cc: Alexey Khoroshilov <khoroshilov@ispras.ru>
The variable is defined but not used. Generally it compiles away with
-O2 optimization hence it does not show a warning.
__hfsplus_ext_write_extent() suppresses errors coming from
hfs_brec_find(). The patch implements error code propagation.
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Use a more current logging style.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
hfsplus now uses "hfsplus: " for all messages.
Coalesce formats.
Prefix debugging messages too.
Rename macro and uses.
Add do {} while (0) to macro.
Add DBG_ to macro.
Add and use hfs_dbg_cont variant where appropriate.
Change a u32 to loff_t hfsplus_file_truncate().
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Add support of manipulation by attributes file.
Reported-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Jan Kara <jack@suse.cz>
Currently, it doesn't process error codes from the hfsplus_block_free()
call in hfsplus_free_extents() method. Add some error code processing.
Implement error propagation through the callers of
hfsplus_ext_write_extent_locked().
hfs_find_init() may fail with ENOMEM, but there are places, where
the returned value is not checked. The consequences can be very
unpleasant, e.g. kfree uninitialized pointer and
inappropriate mutex unlocking.
The patch adds checks for errors in hfs_find_init().
Found by Linux Driver Verification project (linuxtesting.org).
For filesystems larger than 2TB the final sector number passed to
map_bh might overflow the range representable in a 32-bit data type.
Make sure we use a sector_t for it and the arithmetics calculating it.
Signed-off-by: Christoph Hellwig <hch@tuxera.com>
Revert an incorrect hunk from commit b2837fcf4994e699a4def002e26f274d95b387c1,
"hfsplus: %L-to-%ll, macro correction, and remove unneeded braces"
revert a pointless change of comparism operation argument order, which turned
out to not even be equivalent.
Reported-by: Joe Perches <joe@perches.com>
Clean-up based on checkpatch.pl report against unnecessary braces
(`{' and `}'), non-standard format option %Lu (%llu recommended)
as well as one trailing statement in a macro definition which
should have been on the next line.
Signed-off-by: Anton Salikhmetov <alexo@tuxera.com>
Match coding style restriction against C99 comments where
checkpatch.pl reported errors about their usage.
Match coding style line length limitation where checkpatch.pl
reported over-80-character-line warnings.
Avoid doing unessecary work in fsync. Do nothing unless the inode
was marked dirty, and only write the various metadata inodes out if
they contain any dirty state from this inode. This is archived by
adding three new dirty bits to the hfsplus-specific inode which are
set in the correct places.
Split the flags field in the hfsplus inode into an extent_state
flag that is locked by the extent_lock, and a new flags field
that uses atomic bitops. The second will grow more flags in the
next patch.
Most of the extent handling code already does proper SMP locking, but
hfsplus_write_inode was calling into hfsplus_ext_write_extent without
taking the extents_lock. Fix this by splitting hfsplus_ext_write_extent
into an internal helper that expects the lock, and a public interface
that first acquires it.
Also add a few locking asserts and document the locking rules in
hfsplus_fs.h.
HFSPLUS_I doesn't return a pointer to the hfsplus-specific inode
information like all other FOO_I macros, but dereference the pointer in a way
that made it look like a direct struct derefence. This only works as long
as the HFSPLUS_I macro is used directly and prevents us from keepig a local
hfsplus_inode_info pointer. Fix the calling convention and introduce a local
hip variable in all functions that use it constantly.
HFSPLUS_SB doesn't return a pointer to the hfsplus-specific superblock
information like all other FOO_SB macros, but dereference the pointer in a way
as the HFSPLUS_SB macro is used directly and prevents us from keepig a local
hfsplus_sb_info pointer. Fix the calling convention and introduce a local
sbi variable in all functions that use it constantly.
A corrupted extent for the extent file itself may try to get an impossible
extent, causing a deadlock if I see it correctly.
Check the inode number after the first_blocks checks and fail if it's the
extent file, as according to the spec the extent file should have no
extent for itself.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Cc: Roman Zippel <zippel@linux-m68k.org>
Apple Extended HFS file system: The semaphore extents lock is used as a
mutex. Convert it to the mutex API.
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Add support for HFSX, which allows for case-sensitive filenames.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Add the log level and a "hfs: " prefix to all kernel prints. (HFS and HFS+
will use the same prefix, as they share some code and could be merged at some
point.)
This patch removes almost all inclusions of linux/version.h. The 3
#defines are unused in most of the touched files.
A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is
unfortunatly in linux/version.h.
There are also lots of #ifdef for long obsolete kernels, this was not
touched. In a few places, the linux/version.h include was move to where
the LINUX_VERSION_CODE was used.
quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'`
search pattern:
/UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h
Signed-off-by: Olaf Hering <olh@suse.de>
If inode size hasn't changed, don't do anything further in truncate, which
also prevents a dirty inode, what might upset some readonly devices quite
badly.
infrastructure for it.
Let it rip!
