path: root/fs/gfs2/recovery.c
2009-12-03GFS2: Tag all metadata with jidSteven Whitehouse
There are two spare field in the header common to all GFS2 metadata. One is just the right size to fit a journal id in it, and this patch updates the journal code so that each time a metadata block is modified, we tag it with the journal id of the node which is performing the modification. The reason for this is that it should make it much easier to debug issues which arise if we can tell which node was the last to modify a particular metadata block. Since the field is updated before the block is written into the journal, each journal should only contain metadata which is tagged with its own journal id. The one exception to this is the journal header block, which might have a different node's id in it, if that journal was recovered by another node in the cluster. Thus each journal will contain a record of which nodes recovered it, via the journal header. The other field in the metadata header could potentially be used to hold information about what kind of operation was performed, but for the time being we just zero it on each transaction so that if we use it for that in future, we'll know that the information (where it exists) is reliable. I did consider using the other field to hold the journal sequence number, however since in GFS2's journaling we write the modified data into the journal and not the original data, this gives no information as to what action caused the modification, so I think we can probably come up with a better use for those 64 bits in the future. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-11-20SLOW_WORK: Fix GFS2 to #include <linux/module.h> before using THIS_MODULEDavid Howells
GFS2 has been altered to pass THIS_MODULE to slow_work_register_user(), but hasn't been altered to #include <linux/module.h> to provide it, resulting in the following error: fs/gfs2/recovery.c:596: error: 'THIS_MODULE' undeclared here (not in a function) Add the missing #include. Signed-off-by: David Howells <dhowells@redhat.com>
2009-11-19SLOW_WORK: Wait for outstanding work items belonging to a module to clearDavid Howells
Wait for outstanding slow work items belonging to a module to clear when unregistering that module as a user of the facility. This prevents the put_ref code of a work item from being taken away before it returns. Signed-off-by: David Howells <dhowells@redhat.com>
2009-05-19GFS2: Umount recovery race fixSteven Whitehouse
This patch fixes a race condition where we can receive recovery requests part way through processing a umount. This was causing problems since the recovery thread had already gone away. Looking in more detail at the recovery code, it was really trying to implement a slight variation on a work queue, and that happens to align nicely with the recently introduced slow-work subsystem. As a result I've updated the code to use slow-work, rather than its own home grown variety of work queue. When using the wait_on_bit() function, I noticed that the wait function that was supplied as an argument was appearing in the WCHAN field, so I've updated the function names in order to produce more meaningful output. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Merge lock_dlm module into GFS2Steven Whitehouse
This is the big patch that I've been working on for some time now. There are many reasons for wanting to make this change such as: o Reducing overhead by eliminating duplicated fields between structures o Simplifcation of the code (reduces the code size by a fair bit) o The locking interface is now the DLM interface itself as proposed some time ago. o Fewer lookups of glocks when processing replies from the DLM o Fewer memory allocations/deallocations for each glock o Scope to do further optimisations in the future (but this patch is more than big enough for now!) Please note that (a) this patch relates to the lock_dlm module and not the DLM itself, that is still a separate module; and (b) that we retain the ability to build GFS2 as a standalone single node filesystem with out requiring the DLM. This patch needs a lot of testing, hence my keeping it I restarted my -git tree after the last merge window. That way, this has the maximum exposure before its merged. This is (modulo a few minor bug fixes) the same patch that I've been posting on and off the the last three months and its passed a number of different tests so far. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Move four functions from super.cSteven Whitehouse
The functions which are being moved can all be marked static in their new locations, since they only have a single caller each. Their new locations are more logical than before and some of the functions are small enough that the compiler might well inline them. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Move gfs2_recoverd into recovery.cSteven Whitehouse
By moving gfs2_recoverd, we can make an additional function static and it also leaves only (the already scheduled for removal) gfs2_glockd in daemon.c. At the same time the declaration of gfs2_quotad is moved to quota.h to reflect the new location of gfs2_quotad in a previous patch. Also the recovery.h and quota.h headers are cleaned up. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] No lock_nolockSteven Whitehouse
This patch merges the lock_nolock module into GFS2 itself. As well as removing some of the overhead of the module, it also means that its now impossible to build GFS2 without a lock module (which would be a pointless thing to do anyway). We also plan to merge lock_dlm into GFS2 in the future, but that is a more tricky task, and will therefore be a separate patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: David Teigland <teigland@redhat.com>
2008-06-27[GFS2] Clean up the glock coreSteven Whitehouse
This patch implements a number of cleanups to the core of the GFS2 glock code. As a result a lot of code is removed. It looks like a really big change, but actually a large part of this patch is either removing or moving existing code. There are some new bits too though, such as the new run_queue() function which is considerably streamlined. Highlights of this patch include: o Fixes a cluster coherency bug during SH -> EX lock conversions o Removes the "glmutex" code in favour of a single bit lock o Removes the ->go_xmote_bh() for inodes since it was duplicating ->go_lock() o We now only use the ->lm_lock() function for both locks and unlocks (i.e. unlock is a lock with target mode LM_ST_UNLOCKED) o The fast path is considerably shortly, giving performance gains especially with lock_nolock o The glock_workqueue is now used for all the callbacks from the DLM which allows us to simplify the lock_dlm module (see following patch) o The way is now open to make further changes such as eliminating the two threads (gfs2_glockd and gfs2_scand) in favour of a more efficient scheme. This patch has undergone extensive testing with various test suites so it should be pretty stable by now. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2008-04-10[GFS2] fix GFP_KERNEL misusesJosef Bacik
There are several places where GFP_KERNEL allocations happen under a glock, which will result in hangs if we're under memory pressure and go to re-enter the fs in order to flush stuff out. This patch changes the culprits to GFS_NOFS to keep this problem from happening. Thank you, Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] fs/gfs2/recovery.c: suppress warningsakpm@linux-foundation.org
fs/gfs2/recovery.c: In function 'get_log_header': fs/gfs2/recovery.c:152: warning: 'lh.lh_sequence' may be used uninitialized in this function fs/gfs2/recovery.c:152: warning: 'lh.lh_flags' may be used uninitialized in this function fs/gfs2/recovery.c:152: warning: 'lh.lh_tail' may be used uninitialized in this function fs/gfs2/recovery.c:152: warning: 'lh.lh_blkno' may be used uninitialized in this function fs/gfs2/recovery.c:152: warning: 'lh.lh_hash' may be used uninitialized in this function Cc: David Teigland <teigland@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Remove lm.[ch] and distribute contentSteven Whitehouse
The functions in lm.c were just wrappers which were mostly only used in one other file. By moving the functions to the files where they are being used, they can be marked static and also this will usually result in them being inlined since they are often only used from one point in the code. A couple of really trivial functions have been inlined by hand into the function which called them as it makes the code clearer to do that. We also gain from one fewer function call in the glock lock and unlock paths. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-02-03fs/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-25[GFS2] Allow journal recovery on read-only mountAbhijith Das
This patch allows gfs2 to perform journal recovery even if it is mounted read-only. Strictly speaking, a read-only mount should not be writing to the filesystem, but we do this only to perform journal recovery. A read-only mount will fail if we don't recover the dirty journal. Also, when gfs2 is used as a root filesystem, it will be mounted read-only before being mounted read-write during the boot sequence. A failed read-only mount will panic the machine during bootup. Signed-off-by: Abhijith Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Remove function gfs2_get_blockBob Peterson
This patch is just a cleanup. Function gfs2_get_block() just calls function gfs2_block_map reversing the last two parameters. By reversing the parameters, gfs2_block_map() may be called directly and function gfs2_get_block may be eliminated altogether. Since this function is done for every block operation, this streamlines the code and makes it a little bit more efficient. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Ensure journal file cache is flushed after recoveryBob Peterson
This is for bugzilla bug #248176: GFS2: invalid metadata block Patches 1 thru 3 were accepted upstream, but there were problems with 4 and 5. Those issues have been resolved and now the recovery tests are passing without errors. This code has gone through 41 * 3 successful gfs2 recovery tests before it hit an unrelated (openais) problem. I'm continuing to test it. This is a complete rewrite of patch 5 for bug #248176, written by Steve Whitehouse. This is referred to in the bugzilla record as "new 6" and "a different solution". The problem was that the journal inodes, although protected by a glock, were not synched with the other nodes because they don't use the inode glock synch operations (i.e. no "glops" were defined). Therefore, journal recovery on a journal-recovering node were causing the blocks to get out of sync with the node that was actually trying to use that journal as it comes back up from a reboot. There are two possible solutions: (1) To make the journals use the normal inode glock sync operations, or (2) To make the journal operations take effect immediately (i.e. no caching). Although option 1 works, it turns out to be a lot more code. Steve opted for option 2, which is much simpler and therefore less prone to regression errors. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> --
2007-07-09[GFS2] Fix sign problem in quota/statfs and cleanup _host structuresSteven Whitehouse
This patch fixes some sign issues which were accidentally introduced into the quota & statfs code during the endianess annotation process. Also included is a general clean up which moves all of the _host structures out of gfs2_ondisk.h (where they should not have been to start with) and into the places where they are actually used (often only one place). Also those _host structures which are not required any more are removed entirely (which is the eventual plan for all of them). The conversion routines from ondisk.c are also moved into the places where they are actually used, which for almost every one, was just one single place, so all those are now static functions. This also cleans up the end of gfs2_ondisk.h which no longer needs the #ifdef __KERNEL__. The net result is a reduction of about 100 lines of code, many functions now marked static plus the bug fixes as mentioned above. For good measure I ran the code through sparse after making these changes to check that there are no warnings generated. This fixes Red Hat bz #239686 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-12-05[GFS2] Fix indent in recovery.cSteven Whitehouse
As per comments from Andrew Morton and Jan Engelhardt, this fixes the indent and removes the "static" from a variable declaration since its not needed in this case (now allocated on the stack of the function in question). Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Cc: Andrew Morton <akpm@osdl.org>
2006-11-30[GFS2] Fix crc32 calculation in recovery.cSteven Whitehouse
Commit "[GFS2] split and annotate gfs2_log_head" resulted in an incorrect checksum calculation for log headers. This patch corrects the problem without resorting to copying the whole log header as the previous code used to. Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] split and annotate gfs2_log_headAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-20[GFS2] Fix bmap to map extents properlySteven Whitehouse
This fix means that bmap will map extents of the length requested by the VFS rather than guessing at it, or just mapping one block at a time. The other callers of gfs2_block_map are audited to ensure they send the correct max extent lengths (i.e. set bh->b_size correctly). Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-25[GFS2/DLM] Fix trailing whitespaceSteven Whitehouse
As per Andrew Morton's request, removed trailing whitespace. Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-21[GFS2] Tidy up meta_io codeSteven Whitehouse
Fix a bug in the directory reading code, where we might have dereferenced a NULL pointer in case of OOM. Updated the directory code to use the new & improved version of gfs2_meta_ra() which now returns the first block that was being read. Previously it was releasing it requiring following code to grab the block again at each point it was called. Also turned off readahead on directory lookups since we are reading a hash table, and therefore reading the entries in order is very unlikely. Readahead is still used for all other calls to the directory reading function (e.g. when growing the hash table). Removed the DIO_START constant. Everywhere this was used, it was used to unconditionally start i/o aside from a couple of places, so I've removed it and made the couple of exceptions to this rule into separate functions. Also hunted through the other DIO flags and removed them as arguments from functions which were always called with the same combination of arguments. Updated gfs2_meta_indirect_buffer to be a bit more efficient and hopefully also be a bit easier to read. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-19[GFS2] Export lm_interface to kernel headersFabio Massimo Di Nitto
lm_interface.h has a few out of the tree clients such as GFS1 and userland tools. Right now, these clients keeps a copy of the file in their build tree that can go out of sync. Move lm_interface.h to include/linux, export it to userland and clean up fs/gfs2 to use the new location. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-18[GFS2] Map multiple blocks at once where possibleSteven Whitehouse
This is a tidy up of the GFS2 bmap code. The main change is that the bh is passed to gfs2_block_map allowing the flags to be set directly rather than having to repeat that code several times in ops_address.c. At the same time, the extent mapping code from gfs2_extent_map has been moved into gfs2_block_map. This allows all calls to gfs2_block_map to map extents in the case that no allocation is taking place. As a result reads and non-allocating writes should be faster. A quick test with postmark appears to support this. There is a limit on the number of blocks mapped in a single bmap call in that it will only ever map blocks which are pointed to from a single pointer block. So in other words, it will never try to do additional i/o in order to satisfy read-ahead. The maximum number of blocks is thus somewhat less than 512 (the GFS2 4k block size minus the header divided by sizeof(u64)). I've further limited the mapping of "normal" blocks to 32 blocks (to avoid extra work) since readpages() will currently read a maximum of 32 blocks ahead (128k). Some further work will probably be needed to set a suitable value for DIO as well, but for now thats left at the maximum 512 (see ops_address.c:gfs2_get_block_direct). There is probably a lot more that can be done to improve bmap for GFS2, but this is a good first step. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-05[GFS2] Style changes in logging codeSteven Whitehouse
As per Jan Engelhardt's comments, removed some unused code and removed some brackets which were not required. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Change all types to uX styleSteven Whitehouse
This makes all fixed size types have consistent names. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-08-10[GFS2] Fix a couple of refcount leaks.Russell Cattelan
recovery.c add a brelse to deal with gfs2_replay_read_block being called twice on the same block. add a dput to drop the ref count on the root inode. This was causing lingering glocks and thus causing a mount failure to hang. Fix a endian conversion macro that was was swizzling 16bits when it should have been swizzling 32. Signed-off-by: Russell Cattelan <cattelan@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-08-04[GFS2] Fix lock ordering bug in page fault pathSteven Whitehouse
Mmapped files were able to trigger a lock ordering bug. Private maps do not need to take the glock so early on. Shared maps do unfortunately, however we can get around that by adding a flag into the flags for the struct gfs2_file. This only works because we are taking an exclusive lock at this point, so we know that nobody else can be racing with us. Fixes Red Hat bugzilla: #201196 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-14[GFS2] Fix unlinked file handlingSteven Whitehouse
This patch fixes the way we have been dealing with unlinked, but still open files. It removes all limits (other than memory for inodes, as per every other filesystem) on numbers of these which we can support on GFS2. It also means that (like other fs) its the responsibility of the last process to close the file to deallocate the storage, rather than the person who did the unlinking. Note that with GFS2, those two events might take place on different nodes. Also there are a number of other changes: o We use the Linux inode subsystem as it was intended to be used, wrt allocating GFS2 inodes o The Linux inode cache is now the point which we use for local enforcement of only holding one copy of the inode in core at once (previous to this we used the glock layer). o We no longer use the unlinked "special" file. We just ignore it completely. This makes unlinking more efficient. o We now use the 4th block allocation state. The previously unused state is used to track unlinked but still open inodes. o gfs2_inoded is no longer needed o Several fields are now no longer needed (and removed) from the in core struct gfs2_inode o Several fields are no longer needed (and removed) from the in core superblock There are a number of future possible optimisations and clean ups which have been made possible by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Update copyright date to 2006Steven Whitehouse
2006-05-18[GFS2] Remove semaphore.h from C filesSteven Whitehouse
We no longer use semaphores, everything has been converted to mutex or rwsem, so we don't need to include this header any more. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-05[GFS2] Readpages supportSteven Whitehouse
This adds readpages support (and also corrects a small bug in the readpage error path at the same time). Hopefully this will improve performance by allowing GFS to submit larger lumps of I/O at a time. In order to simplify the setting of BH_Boundary, it currently gets set when we hit the end of a indirect pointer block. There is always a boundary at this point with the current allocation code. It doesn't get all the boundaries right though, so there is still room for improvement in this. See comments in fs/gfs2/ops_address.c for further information about readpages with GFS2. Signed-off-by: Steven Whitehouse
2006-04-26[GFS2] Remove GL_NEVER_RECURSE flagSteven Whitehouse
There is no point in keeping this flag since recursion is not now allowed for any glock. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-26[GFS2] Don't do recursive locking in glock layerSteven Whitehouse
This patch changes the last user of recursive locking so that it no longer needs this feature and removes it from the glock layer. This makes the glock code a lot simpler and easier to understand. Its also a prerequsite to adding support for the AOP_TRUNCATED_PAGE return code (or at least it is if you don't want your brain to melt in the process) I've left in a couple of checks just in case there is some place else in the code which is still using this feature that I didn't spot yet, but they can probably be removed long term. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-20[GFS2] journal recovery patchDavid Teigland
This is one of the changes related to journal recovery I mentioned a couple weeks ago. We can get into a situation where there are only readonly nodes currently mounting the fs, but there are journals that need to be recovered. Since the readonly nodes can't recover journals, the next rw mounter needs to go through and check all journals and recover any that are dirty (i.e. what the first node to mount the fs does). This rw mounter needs to skip the journals held by the existing readonly nodes. Skipping those journals amounts to using the TRY flag on the journal locks so acquiring the lock of a journal held by a readonly node will fail instead of blocking indefinately. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-03-30[GFS] Fix bug in endian conversion for metadata headerSteven Whitehouse
In some cases 16 bit functions were being used rather than 32 bit functions. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-03-28[GFS2] Further updates to dir and logging codeSteven Whitehouse
This reduces the size of the directory code by about 3k and gets readdir() to use the functions which were introduced in the previous directory code update. Two memory allocations are merged into one. Eliminates zeroing of some buffers which were never used before they were initialised by other data. There is still scope for further improvement in the directory code. On the logging side, a hand created mutex has been replaced by a standard Linux mutex in the log allocation code. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-27[GFS2] Macros removal in gfs2.hSteven Whitehouse
As suggested by Pekka Enberg <penberg@cs.helsinki.fi>. The DIV_RU macro is renamed DIV_ROUND_UP and and moved to kernel.h The other macros are gone from gfs2.h as (although not requested by Pekka Enberg) are a number of included header file which are now included individually. The inode number comparison function is now an inline function. The DT2IF and IF2DT may be addressed in a future patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-27[GFS2] 80 Column audit of GFS2Steven Whitehouse
Requested by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-13[GFS2] Fix for root inode ref count bugSteven Whitehouse
Umount is now working correctly again. The bug was due to not getting an extra ref count when mounting the fs. We should have bumped it by two (once for the internal pointer to the root inode from the super block and once for the inode hanging off the dcache entry for root). Also this patch tidys up the code dealing with looking up and creating inodes. We now pass Linux inodes (with gfs2_inodes attached) rather than the other way around and this reduces code duplication in various places. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] The core of GFS2David Teigland
This patch contains all the core files for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
