path: root/fs/gfs2/ops_fstype.c
2008-09-18GFS2: high time to take some time over atimeSteven Whitehouse
Until now, we've used the same scheme as GFS1 for atime. This has failed since atime is a per vfsmnt flag, not a per fs flag and as such the "noatime" flag was not getting passed down to the filesystems. This patch removes all the "special casing" around atime updates and we simply use the VFS's atime code. The net result is that GFS2 will now support all the same atime related mount options of any other filesystem on a per-vfsmnt basis. We do lose the "lazy atime" updates, but we gain "relatime". We could add lazy atime to the VFS at a later date, if there is a requirement for that variant still - I suspect relatime will be enough. Also we lose about 100 lines of code after this patch has been applied, and I have a suspicion that it will speed things up a bit, even when atime is "on". So it seems like a nice clean up as well. From a user perspective, everything stays the same except the loss of the per-fs atime quantum tweekable (ought to be per-vfsmnt at the very least, and to be honest I don't think anybody ever used it) and that a number of options which were ignored before now work correctly. Please let me know if you've got any comments. I'm pushing this out early so that you can all see what my plans are. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-09-15GFS2: GFS2 will panic if you misspell any mount optionsAbhijith Das
The gfs2 superblock pointer is NULL after a failed mount. When control eventually goes to gfs2_kill_sb, we dereference this NULL pointer. This patch ensures that the gfs2 superblock pointer is not NULL before being dereferenced in gfs2_kill_sb. Signed-off-by: Abhijith Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-08-13GFS2: Fix metafs mountsSteven Whitehouse
This patch is intended to fix the issues reported in bz #457798. Instead of having the metafs as a separate filesystem, it becomes a second root of gfs2. As a result it will appear as type gfs2 in /proc/mounts, but it is still possible (for backwards compatibility purposes) to mount it as type gfs2meta. A new mount flag "meta" is introduced so that its possible to tell the two cases apart in /proc/mounts. As a result it becomes possible to mount type gfs2 with -o meta and get the same result as mounting type gfs2meta. So it is possible to mount just the metafs on its own. Currently if you do this, its then impossible to mount the "normal" root of the gfs2 filesystem without first unmounting the metafs root. I'm not sure if thats a feature or a bug :-) Either way, this is a great improvement on the previous scheme and I've verified that it works ok with bind mounts on both the "normal" root and the metafs root in various combinations. There were also a bunch of functions in super.c which didn't belong there, so this moves them into ops_fstype.c where they can be static. Hopefully the mount/umount sequence is now more obvious as a result. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com>
2008-07-10[GFS2] Replace rgrp "recent list" with mru listSteven Whitehouse
This patch removes the "recent list" which is used during allocation and replaces it with the (already existing) mru list used during deletion. The "recent list" was not a true mru list leading to a number of inefficiencies including a "next" function which made scanning the list an order N^2 operation wrt to the number of list elements. This should increase allocation performance with large numbers of rgrps. Its also a useful preparation and cleanup before some further changes which are planned in this area. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Remove remote lock dropping codeSteven Whitehouse
There are several reasons why this is undesirable: 1. It never happens during normal operation anyway 2. If it does happen it causes performance to be very, very poor 3. It isn't likely to solve the original problem (memory shortage on remote DLM node) it was supposed to solve 4. It uses a bunch of arbitrary constants which are unlikely to be correct for any particular situation and for which the tuning seems to be a black art. 5. In an N node cluster, only 1/N of the dropped locked will actually contribute to solving the problem on average. So all in all we are better off without it. This also makes merging the lock_dlm module into GFS2 a bit easier. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] No lock_nolockSteven Whitehouse
This patch merges the lock_nolock module into GFS2 itself. As well as removing some of the overhead of the module, it also means that its now impossible to build GFS2 without a lock module (which would be a pointless thing to do anyway). We also plan to merge lock_dlm into GFS2 in the future, but that is a more tricky task, and will therefore be a separate patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: David Teigland <teigland@redhat.com>
2008-05-12[GFS2] Prefer strlcpy() over snprintf()Jean Delvare
strlcpy is faster than snprintf when you don't use the returned value. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Invalidate cache at correct pointBenjamin Marzinski
GFS2 wasn't invalidating its cache before it called into the lock manager with a request that could potentially drop a lock. This was leaving a window where the lock could be actually be held by another node, but the file's page cache would still appear valid, causing coherency problems. This patch moves the cache invalidation to before the lock manager call when dropping a lock. It also adds the option to the lock_dlm lock manager to not use conversion mode deadlock avoidance, which, on a conversion from shared to exclusive, could internally drop the lock, and then reacquire in. GFS2 now asks lock_dlm to not do this. Instead, GFS2 manually drops the lock and reacquires it. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Remove drop of module ref where not neededSteven Whitehouse
In an earlier patch "[GFS2] fix file_system_type leak on gfs2meta mount" we removed the code to grab a ref to the module which was not needed (since we know that the module cannot be unloaded at that time) so this patch removes the code to drop that reference. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] fix file_system_type leak on gfs2meta mountChristoph Hellwig
get_gfs2_sb does a get_fs_type without doing a put_filesystem and thus leaking a file_system_type reference everytime it's called. Just use gfs2_fs_type directly instead of doing the lookup and thus fix the problem. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Remove rgrp and glock version numbersBob Peterson
This patch further reduces GFS2's memory requirements by eliminating the 64-bit version number fields in lieu of a couple bits. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Remove lm.[ch] and distribute contentSteven Whitehouse
The functions in lm.c were just wrappers which were mostly only used in one other file. By moving the functions to the files where they are being used, they can be marked static and also this will usually result in them being inlined since they are often only used from one point in the code. A couple of really trivial functions have been inlined by hand into the function which called them as it makes the code clearer to do that. We also gain from one fewer function call in the glock lock and unlock paths. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25[GFS2] Initialize extent_list earlierBob Peterson
Here is a patch for the latest upstream GFS2 code: The journal extent map needs to be initialized sooner than it currently is. Otherwise failed mount attempts (e.g. not enough journals, etc.) may panic trying to access the uninitialized list. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Minor correctionBob Peterson
This is a small correction to my previously posted patch1. It just changes a divide to a shift. It's faster and doesn't introduce odd dependencies on 32-bit compiles. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Eliminate the no longer needed sd_statfs_mutexBob Peterson
This patch eliminates the unneeded sd_statfs_mutex mutex but preserves the ordering as discussed. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Journal extent mappingBob Peterson
This patch saves a little time when gfs2 writes to the journals by keeping a mapping between logical and physical blocks on disk. That's better than constantly looking up indirect pointers in buffers, when the journals are several levels of indirection (which they typically are). Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Use atomic_t for journal free blocks counterSteven Whitehouse
This patch changes the counter which keeps track of the free blocks in the journal to an atomic_t in preparation for the following patch which will update the log reservation code. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Don't add glocks to the journalSteven Whitehouse
The only reason for adding glocks to the journal was to keep track of which locks required a log flush prior to release. We add a flag to the glock to allow this check to be made in a simpler way. This reduces the size of a glock (by 12 bytes on i386, 24 on x86_64) and means that we can avoid extra work during the journal flush. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Alternate gfs2_iget to avoid looking up inodes being freedBenjamin Marzinski
There is a possible deadlock between two processes on the same node, where one process is deleting an inode, and another process is looking for allocated but unused inodes to delete in order to create more space. process A does an iput() on inode X, and it's i_count drops to 0. This causes iput_final() to be called, which puts an inode into state I_FREEING at generic_delete_inode(). There no point between when iput_final() is called, and when I_FREEING is set where GFS2 could acquire any glocks. Once I_FREEING is set, no other process on that node can successfully look up that inode until the delete finishes. process B locks the the resource group for the same inode in get_local_rgrp(), which is called by gfs2_inplace_reserve_i() process A tries to lock the resource group for the inode in gfs2_dinode_dealloc(), but it's already locked by process B process B waits in find_inode for the inode to have the I_FREEING state cleared. Deadlock. This patch solves the problem by adding an alternative to gfs2_iget(), gfs2_iget_skip(), that simply skips any inodes that are in the I_FREEING state.o The alternate test function is just like the original one, except that it fails if the inode is being freed, and sets a skipped flag. The alternate set function is just like the original, except that it fails if the skipped flag is set. Only try_rgrp_unlink() calls gfs2_iget_skip() instead of gfs2_iget(). Signed-off-by: Benjamin E. Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up journaled data writingSteven Whitehouse
This patch cleans up the code for writing journaled data into the log. It also removes the need to allocate a small "tag" structure for each block written into the log. Instead we just keep count of the outstanding I/O so that we can be sure that its all been written at the correct time. Another result of this patch is that a number of ll_rw_block() calls have become submit_bh() calls, closing some races at the same time. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up ordered write codeSteven Whitehouse
The following patch removes the ordered write processing from databuf_lo_before_commit() and moves it to log.c. This has the effect of greatly simplyfying databuf_lo_before_commit() and well as potentially making the ordered write code more efficient. As a side effect of this, its now possible to remove ordered buffers from the ordered buffer list at any time, so we now make use of this in invalidatepage and releasepage to ensure timely release of these buffers. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] panic after can't parse mount argumentsAbhijith Das
When you try to mount gfs2 with -o garbage, the mount fails and the gfs2 superblock is deallocated and becomes NULL. The vfs comes around later on and calls gfs2_kill_sb. At this point the hidden gfs2 superblock pointer (sb->s_fs_info) is NULL and dereferencing it through gfs2_meta_syncfs causes the panic. (the other function call to gfs2_delete_debugfs_file() succeeds because this function already checks for a NULL pointer) Signed-off-by: Abhijith Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up invalidatepage/releasepageSteven Whitehouse
This patch fixes some bugs relating to journaled data files by cleaning up the gfs2_invalidatepage() and gfs2_releasepage() functions. We now never block during gfs2_releasepage(), instead we always either release or refuse to release depending on the status of the buffers. This fixes Red Hat bugzillas #248969 and #252392. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2007-10-10[GFS2] fixed a NULL pointer assignment BUGDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] better code for translating charactersDenis Cheng
the original code could work, but I think this code could work better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] unneeded typecastDenis Cheng
sb->s_fs_info is a void pointer, thus the type cast is not needed. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] use list_for_each_entry insteadDenis Cheng
2007-10-10[GFS2] Ensure journal file cache is flushed after recoveryBob Peterson
This is for bugzilla bug #248176: GFS2: invalid metadata block Patches 1 thru 3 were accepted upstream, but there were problems with 4 and 5. Those issues have been resolved and now the recovery tests are passing without errors. This code has gone through 41 * 3 successful gfs2 recovery tests before it hit an unrelated (openais) problem. I'm continuing to test it. This is a complete rewrite of patch 5 for bug #248176, written by Steve Whitehouse. This is referred to in the bugzilla record as "new 6" and "a different solution". The problem was that the journal inodes, although protected by a glock, were not synched with the other nodes because they don't use the inode glock synch operations (i.e. no "glops" were defined). Therefore, journal recovery on a journal-recovering node were causing the blocks to get out of sync with the node that was actually trying to use that journal as it comes back up from a reboot. There are two possible solutions: (1) To make the journals use the normal inode glock sync operations, or (2) To make the journal operations take effect immediately (i.e. no caching). Although option 1 works, it turns out to be a lot more code. Steve opted for option 2, which is much simpler and therefore less prone to regression errors. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> --
2007-10-10[GFS2] Reduce number of gfs2_scand processes to oneSteven Whitehouse
We only need a single gfs2_scand process rather than the one per filesystem which we had previously. As a result the parameter determining the frequency of gfs2_scand runs becomes a module parameter rather than a mount parameter as it was before. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] use the declaration of gfs2_dops in the header file insteadDenis Cheng
2007-07-09[GFS2] Obtaining no_formal_ino from directory entryWendy Cheng
GFS2 lookup code doesn't ask for inode shared glock. This implies during in-memory inode creation for existing file, GFS2 will not disk-read in the inode contents. This leaves no_formal_ino un-initialized during lookup time. The un-initialized no_formal_ino is subsequently encoded into file handle. Clients will get ESTALE error whenever it tries to access these files. Signed-off-by: S. Wendy Cheng <wcheng@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Can't mount GFS2 file system on AoE deviceRobert Peterson
This patch fixes bug 243131: Can't mount GFS2 file system on AoE device. When using AoE devices with lock_nolock, there is no locking table, so gfs2 (and gfs1) uses the superblock s_id. This turns out to be the device name in some cases. In the case of AoE, the device contains a slash, (e.g. "etherd/e1.1p2") which is an invalid character when we try to register the table in sysfs. This patch replaces the "/" with underscore. Rather than add a new variable to the stack, I'm just reusing a (char *) variable that's no longer used: table. This code has been tested on the failing system using a RHEL5 patch. The upstream code was tested by using gfs2_tool sb to interject a "/" into the table name of a clustered gfs2 file system. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Add nanosecond timestamp featureSteven Whitehouse
This adds a nanosecond timestamp feature to the GFS2 filesystem. Due to the way that the on-disk format works, older filesystems will just appear to have this field set to zero. When mounted by an older version of GFS2, the filesystem will simply ignore the extra fields so that it will again appear to have whole second resolution, so that its trivially backward compatible. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Fix sign problem in quota/statfs and cleanup _host structuresSteven Whitehouse
This patch fixes some sign issues which were accidentally introduced into the quota & statfs code during the endianess annotation process. Also included is a general clean up which moves all of the _host structures out of gfs2_ondisk.h (where they should not have been to start with) and into the places where they are actually used (often only one place). Also those _host structures which are not required any more are removed entirely (which is the eventual plan for all of them). The conversion routines from ondisk.c are also moved into the places where they are actually used, which for almost every one, was just one single place, so all those are now static functions. This also cleans up the end of gfs2_ondisk.h which no longer needs the #ifdef __KERNEL__. The net result is a reduction of about 100 lines of code, many functions now marked static plus the bug fixes as mentioned above. For good measure I ran the code through sparse after making these changes to check that there are no warnings generated. This fixes Red Hat bz #239686 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Clean up inode number handlingSteven Whitehouse
This patch cleans up the inode number handling code. The main difference is that instead of looking up the inodes using a struct gfs2_inum_host we now use just the no_addr member of this structure. The tests relating to no_formal_ino can then be done by the calling code. This has advantages in that we want to do different things in different code paths if the no_formal_ino doesn't match. In the NFS patch we want to return -ESTALE, but in the ->lookup() path, its a bug in the fs if the no_formal_ino doesn't match and thus we can withdraw in this case. In order to later fix bz #201012, we need to be able to look up an inode without knowing no_formal_ino, as the only information that is known to us is the on-disk location of the inode in question. This patch will also help us to fix bz #236099 at a later date by cleaning up a lot of the code in that area. There are no user visible changes as a result of this patch and there are no changes to the on-disk format either. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-01[GFS2] lockdump improvementsRobert Peterson
The patch below consists of the following changes (in code order): 1. I fixed a minor compiler warning regarding the printing of a kernel symbol address. 2. I implemented a suggestion from Dave Teigland that moves the debugfs information for gfs2 into a subdirectory so we can easily expand our use of debugfs in the future. The current code keeps the glock information in: /debug/gfs2/<fs> With the patch, the new code keeps the glock information in: /debug/gfs2/<fs>/glock That will allow us to create more debugfs files in the future. 3. This fixes a bug whereby a failed mount attempt causes the debugfs file to not be deleted. Failed mount attempts should always clean up after themselves, including deleting the debugfs file and/or directory. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-01[GFS2] Add gfs2_tool lockdump support to gfs2 (bz 228540)Robert Peterson
The attached patch resolves bz 228540. This adds the capability for gfs2 to dump gfs2 locks through the debugfs file system. This used to exist in gfs1 as "gfs_tool lockdump" but it's missing from gfs2 because all the ioctls were stripped out. Please see the bugzilla for more history about the fix. This patch is also attached to the bugzilla record. The patch is against Steve Whitehouse's latest nmw git tree kernel (2.6.21-rc1) and has been tested on system trin-10. Signed-off-by: Robert Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-03-07[GFS2] add newline to printk messageRichard Fearn
Patch for the 2.6.20 stable tree that adds a missing newline to one of the printk messages in fs/gfs2/ops_fstype.c. Signed-off-by: Richard Fearn <richardfearn@gmail.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-01-11[PATCH] Revert bd_mount_mutex back to a semaphoreDavid Chinner
Revert bd_mount_mutex back to a semaphore so that xfs_freeze -f /mnt/newtest; xfs_freeze -u /mnt/newtest works safely and doesn't produce lockdep warnings. (XFS unlocks the semaphore from a different task, by design. The mutex code warns about this) Signed-off-by: Dave Chinner <dgc@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30[GFS2] split and annotate gfs2_inumAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-20[GFS2] fs/gfs2/ops_fstype.c:fill_super_meta(): fix NULL dereferenceAdrian Bunk
Don't dereference new->s_root when we do know it's NULL. Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-20[GFS2] fs/gfs2/ops_fstype.c:gfs2_get_sb_meta(): remove unused variableAdrian Bunk
The Coverity checker spotted this unused variable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-02[GFS2] Remove duplicate sb reading codeSteven Whitehouse
For some reason we had two different sets of code for reading in the superblock. This removes one of them in favour of the other. Also we don't need the temporary buffer for the sb since we already have one in the gfs2 sb itself. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-25[GFS2/DLM] Fix trailing whitespaceSteven Whitehouse
As per Andrew Morton's request, removed trailing whitespace. Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-19[GFS2] Export lm_interface to kernel headersFabio Massimo Di Nitto
lm_interface.h has a few out of the tree clients such as GFS1 and userland tools. Right now, these clients keeps a copy of the file in their build tree that can go out of sync. Move lm_interface.h to include/linux, export it to userland and clean up fs/gfs2 to use the new location. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-08[GFS2] vfree should be kfreeSteven Whitehouse
This was missed in an earlier patch when changing over from vmalloc to kmalloc for the superblock. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-07[GFS2] Forgot to remove unused include vmalloc.hSteven Whitehouse
Excatly as the subject line says. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-07[GFS2] Move glock hash table out of superblockSteven Whitehouse
There are several reasons why we want to do this: - Firstly its large and thus we'll scale better with multiple GFS2 fs mounted at the same time - Secondly its easier to scale its size as required (thats a plan for later patches) - Thirdly, we can use kzalloc rather than vmalloc when allocating the superblock (its now only 4888 bytes) - Fourth its all part of my plan to eventually be able to use RCU with the glock hash. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
