Unlike what its documentation suggests, the releasepage address space
operation can currently be called on dirty pages via shrink_active_list.
This may eventually be changed when the remaining code relying on the
current behavior has been fixed, but until then, it makes no sense to
warn on dirty buffers in gfs2_releasepage.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Replace 1 << value shift by more explicit BIT() macro
Also fixes two bare unsigned definitions:
WARNING: Prefer 'unsigned int' to bare use of 'unsigned'
+ unsigned hsize = BIT(ip->i_depth);
Signed-off-by: Fabian Frederick <fabf@skynet.be>
When gfs2 attempts to write a page to a file that is being truncated,
and notices that the page is completely outside of the file size, it
tries to invalidate it. However, this may require a transaction for
journaled data files to revoke any buffers from the page on the active
items list. Unfortunately, this can happen inside a log flush, where a
transaction cannot be started. Also, gfs2 may need to be able to remove
the buffer from the ail1 list before it can finish the log flush.
To deal with this, when writing a page of a file with data journalling
enabled gfs2 now skips the check to see if the write is outside the file
size, and simply writes it anyway. This situation can only occur when
the truncate code still has the file locked exclusively, and hasn't
marked this block as free in the metadata (which happens later in
truc_dealloc). After gfs2 writes this page out, the truncation code
will shortly invalidate it and write out any revokes if necessary.
To do this, gfs2 now implements its own version of block_write_full_page
without the check, and calls the newly exported __block_write_full_page.
It also no longer calls gfs2_writepage_common from gfs2_jdata_writepage.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"We've got nine patches this time:
- Abhi Das has two patches that fix a GFS2 splice issue (and an
adjustment).
- Ben Marzinski has a patch which allows the proper unmount of a GFS2
file system after hitting a withdraw error.
- I have a patch to fix a problem where GFS2 would dereference an
error value, plus three cosmetic / refactoring patches.
- Daniel DeFreez has a patch to fix two glock reference count
problems, where GFS2 was not properly "uninitializing" its glock
holder on error paths.
- Denys Vlasenko has a patch to change a function to not be inlined,
thus reducing the memory footprint of the GFS2 module"
* tag 'gfs2-4.7.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Refactor gfs2_remove_from_journal
GFS2: Remove allocation parms from gfs2_rbm_find
gfs2: use inode_lock/unlock instead of accessing i_mutex directly
GFS2: Add calls to gfs2_holder_uninit in two error handlers
GFS2: Don't dereference inode in gfs2_inode_lookup until it's valid
GFS2: fs/gfs2/glock.c: Deinline do_error, save 1856 bytes
gfs2: Use gfs2 wrapper to sync inode before calling generic_file_splice_read()
GFS2: Get rid of dead code in inode_go_demote_ok
GFS2: ignore unlock failures after withdraw
This patch makes two simple changes to function gfs2_remove_from_journal.
First, it removes the parameter that specifies the transaction.
Since it's always passed in as current->journal_info, we might as well
set that in the function rather than passing it in. Second, it changes
the meta parameter to use an enum to make the code more clear.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually
work, so eliminate the superflous argument.
This patch fixes two locations that do not call gfs2_holder_uninit
if gfs2_glock_nq returns an error.
Signed-off-by: Daniel DeFreez <dcdefreez@ucdavis.edu>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
The fsx test in xfstests was failing because it was using direct IO
writes which were using a bad calculation. It was using
loff_t lstart = offset & (PAGE_CACHE_SIZE - 1); when it should be
loff_t lstart = offset & ~(PAGE_CACHE_SIZE - 1);
Thus, the write at offset 0x67e00 was calculating lstart to be
0xe00, the address of our corruption. Instead, it should have been
0x67000. This patch fixes the calculation.
This patch basically reverts the majority of patch 5407e24.
That patch eliminated the gfs2_qadata structure in favor of just
using the reservations structure. The problem with doing that is that
it increases the size of the reservations structure. That is not an
issue until it comes time to fold the reservations structure into the
inode in memory so we know it's always there. By separating out the
quota structure again, we aren't punishing the non-quota users by
making all the inodes bigger, requiring more slab space. This patch
creates a new slab area to allocate the quota stuff so it's managed
a little more sanely.
git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2
"Here are the patches we've accumulated for GFS2 for the current
upstream merge window. We have a good mixture this time. Here are
some of the features:
- Fix a problem with RO mounts writing to the journal.
- Further improvements to quotas on GFS2.
- Added support for rename2 and RENAME_EXCHANGE on GFS2.
- Increase performance by making glock lru_list less of a bottleneck.
- Increase performance by avoiding unnecessary buffer_head releases.
- Increase performance by using average glock round trip time from all CPUs.
- Fixes for some compiler warnings and minor white space issues.
- Other misc bug fixes"
* tag 'gfs2-merge-window' of git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Don't brelse rgrp buffer_heads every allocation
GFS2: Don't add all glocks to the lru
gfs2: Don't support fallocate on jdata files
gfs2: s64 cast for negative quota value
gfs2: limit quota log messages
gfs2: fix quota updates on block boundaries
gfs2: fix shadow warning in gfs2_rbm_find()
gfs2: kerneldoc warning fixes
gfs2: convert simple_str to kstr
GFS2: make sure S_NOSEC flag isn't overwritten
GFS2: add support for rename2 and RENAME_EXCHANGE
gfs2: handle NULL rgd in set_rgrp_preferences
GFS2: inode.c: indent with TABs, not spaces
GFS2: mark the journal idle to fix ro mounts
GFS2: Average in only non-zero round-trip times for congestion stats
GFS2: Use average srttb value in congestion calculations
Fixes the following kernel-doc warnings:
Warning(fs/gfs2/aops.c:180): No description found for parameter 'wbc'
Warning(fs/gfs2/aops.c:236): No description found for parameter 'end'
Warning(fs/gfs2/aops.c:236): No description found for parameter 'done_index'
Warning(fs/gfs2/aops.c:236): Excess function parameter 'writepage' description in 'gfs2_write_jdata_pagevec'
Warning(fs/gfs2/aops.c:346): Excess function parameter 'writepage' description in 'gfs2_write_cache_jdata'
Warning(fs/gfs2/aops.c:346): Excess function parameter 'data' description in 'gfs2_write_cache_jdata'
Warning(fs/gfs2/aops.c:605): No description found for parameter 'file'
Warning(fs/gfs2/aops.c:605): No description found for parameter 'mapping'
Warning(fs/gfs2/aops.c:605): No description found for parameter 'pages'
Warning(fs/gfs2/aops.c:605): No description found for parameter 'nr_pages'
Warning(fs/gfs2/aops.c:870): No description found for parameter 'copied'
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
"Here is a list of patches we've accumulated for GFS2 for the current
Most of the patches fix GFS2 quotas, which were not properly enforced.
There's another that adds me as a GFS2 co-maintainer, and a couple
patches that fix a kernel panic doing splice_write on GFS2 as well as
a few correctness patches"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
gfs2: fix quota refresh race in do_glock()
gfs2: incorrect check for debugfs returns
gfs2: allow fallocate to max out quotas/fs efficiently
gfs2: allow quota_check and inplace_reserve to return available blocks
gfs2: perform quota checks against allocation parameters
GFS2: Move gfs2_file_splice_write outside of #ifdef
GFS2: Allocate reservation during splice_write
GFS2: gfs2_set_acl(): Cache "no acl" as well
Add myself (Bob Peterson) as a maintainer of GFS2
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
Most filesystems call through to these at some point, so we'll start
here.
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Use struct gfs2_alloc_parms as an argument to gfs2_quota_check()
and gfs2_quota_lock_check() to check for quota violations while
accounting for the new blocks requested by the current operation
in ap->target.
Previously, the number of new blocks requested during an operation
were not accounted for during quota_check and would allow these
operations to exceed quota. This was not very apparent since most
operations allocated only 1 block at a time and quotas would get
violated in the next operation. i.e. quota excess would only be by
1 block or so. With fallocate, (where we allocate a bunch of blocks
at once) the quota excess is non-trivial and is addressed by this
patch.
Signed-off-by: Abhi Das <adas@redhat.com>
Now that we got rid of the bdi abuse on character devices we can always use
sb->s_bdi to get at the backing_dev_info for a file, except for the block
device special case. Export inode_to_bdi and replace uses of
mapping->backing_dev_info with it to prepare for the removal of
mapping->backing_dev_info.
Reviewed-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
GFS2 has a transaction glock, which must be grabbed for every
transaction, whose purpose is to deal with freezing the filesystem.
Aside from this involving a large amount of locking, it is very easy to
make the current fsfreeze code hang on unfreezing.
This patch rewrites how gfs2 handles freezing the filesystem. The
transaction glock is removed. In it's place is a freeze glock, which is
cached (but not held) in a shared state by every node in the cluster
when the filesystem is mounted. This lock only needs to be grabbed on
freezing, and actions which need to be safe from freezing, like
recovery.
When a node wants to freeze the filesystem, it grabs this glock
exclusively. When the freeze glock state changes on the nodes (either
from shared to unlocked, or shared to exclusive), the filesystem does a
special log flush. gfs2_log_flush() does all the work for flushing out
the and shutting down the incore log, and then it tries to grab the
freeze glock in a shared state again. Since the filesystem is stuck in
gfs2_log_flush, no new transaction can start, and nothing can be written
to disk. Unfreezing the filesytem simply involes dropping the freeze
glock, allowing gfs2_log_flush() to grab and then release the shared
lock, so it is cached for next time.
However, in order for the unfreezing ioctl to occur, gfs2 needs to get a
shared lock on the filesystem root directory inode to check permissions.
If that glock has already been grabbed exclusively, fsfreeze will be
unable to get the shared lock and unfreeze the filesystem.
In order to allow the unfreeze, this patch makes gfs2 grab a shared lock
on the filesystem root directory during the freeze, and hold it until it
unfreezes the filesystem. The functions which need to grab a shared
lock in order to allow the unfreeze ioctl to be issued now use the lock
grabbed by the freeze code instead.
The freeze and unfreeze code take care to make sure that this shared
lock will not be dropped while another process is using it.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter)
unmodified, for now
GFS2 has carried what is more or less a copy of the
write_cache_pages() for some time. It seems that this
copy has slipped behind the core code over time. This
patch brings it back uptodate, and in addition adds the
tracepoint which would otherwise be missing.
We could go further, and eliminate some or all of the
code duplication here. The issue is that if we do that,
then the function we need to split out from the existing
write_cache_pages(), which will look a lot like
gfs2_jdata_write_pagevec(), would land up putting quite a
lot of extra variables on the stack. I know that has been
a problem in the past in the writeback code path, which
is why I've hesitated to do it here.
We recently fixed the writeback of pages prior to performing
direct i/o, however the initial fix was perhaps a bit heavy
handed. There is no need to invalidate pages if the direct i/o
is only a read, since they will be identical to what has been
flushed to disk anyway.
For historical reasons, we drop and retake the log lock in ->releasepage()
however, since there is no reason why we cannot hold the log lock over
the whole function, this allows some simplification. In particular,
pinning a buffer is only ever done under the log lock, so it is possible
here to remove the test for pinned buffers in the second loop, since it
is impossible for that to happen (it is also tested in the first loop).
As a result, two tests made later in the second loop become constants
and can also be reduced to the only possible branch. So the net result
is to remove various bits of unreachable code and make this more
readable.
In patch 209806aba9d540dde3db0a5ce72307f85f33468f we allowed
local deferred locks to be granted against a cached exclusive
lock. That opened up a corner case which this patch now
fixes.
The solution to the problem is to check whether we have cached
pages each time we do direct I/O and if so to unmap, flush
and invalidate those pages. Since the glock state machine
normally does that for us, mostly the code will be a no-op.
This patch adds a structure to contain allocation parameters with
the intention of future expansion of this structure. The idea is
that we should be able to add more information about the allocation
in the future in order to allow the allocator to make a better job
of placing the requests on-disk.
There is no functional difference from applying this patch.
GFS2 was only setting I_DIRTY_DATASYNC on files that it wrote to, when
it actually increased the file size. If gfs2_fsync was called without
I_DIRTY_DATASYNC set, it didn't flush the incore data to the log before
returning, so any metadata or journaled data changes were not getting
fsynced. This meant that writes to the middle of files were not always
getting fsynced properly.
This patch makes gfs2 set I_DIRTY_DATASYNC whenever metadata has been
updated during a write. It also make gfs2_sync flush the incore log
if I_DIRTY_PAGES is set, and the file is using data journalling. This
will make sure that all incore logged data gets written to disk before
returning from a fsync.
The writepages function was recently merged between writeback
and ordered mode. This completes the change by doing the same
with writepage. The remaining differences in writepage were
left over from some earlier time and not actually doing anything
useful.
->invalidatepage() aop now accepts range to invalidate so we can make
use of it in gfs2_invalidatepage().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Cc: cluster-devel@redhat.com
Currently there is no way to truncate partial page where the end
truncate point is not at the end of the page. This is because it was not
needed and the functionality was enough for file system truncate
operation to work properly. However more file systems now support punch
hole feature and it can benefit from mm supporting truncating page just
up to the certain point.
Specifically, with this functionality truncate_inode_pages_range() can
be changed so it supports truncating partial page at the end of the
range (currently it will BUG_ON() if 'end' is not at the end of the
page).
This commit changes the invalidatepage() address space operation
prototype to accept range to be invalidated and update all the instances
for it.
We also change the block_invalidatepage() in the same way and actually
make a use of the new length argument implementing range invalidation.
Actual file system implementations will follow except the file systems
where the changes are really simple and should not change the behaviour
in any way .Implementation for truncate_page_range() which will be able
to accept page unaligned ranges will follow as well.
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
In order to allow transactions and log flushes to happen at the same
time, gfs2 needs to move the transaction accounting and active items
list code into the gfs2_trans structure. As a first step toward this,
this patch removes the gfs2_ail structure, and handles the active items
list in the gfs_trans structure. This keeps gfs2 from allocating an ail
structure on log flushes, and gives us a struture that can later be used
to store the transaction accounting outside of the gfs2 superblock
structure.
With this patch, at the end of a transaction, gfs2 will add the
gfs2_trans structure to the superblock if there is not one already.
This structure now has the active items fields that were previously in
gfs2_ail. This is not necessary in the case where the transaction was
simply used to add revokes, since these are never written outside of the
journal, and thus, don't need an active items list.
Also, in order to make sure that the transaction structure is not
removed while it's still in use by gfs2_trans_end, unlocking the
sd_log_flush_lock has to happen slightly later in ending the
transaction.
Instead of using a list of buffers to write ahead of the journal
flush, this now uses a list of inodes and calls ->writepages
via filemap_fdatawrite() in order to achieve the same thing. For
most use cases this results in a shorter ordered write list,
as well as much larger i/os being issued.
The ordered write list is sorted by inode number before writing
in order to retain the disk block ordering between inodes as
per the previous code.
The previous ordered write code used to conflict in its assumptions
about how to write out the disk blocks with mpage_writepages()
so that with this updated version we can also use mpage_writepages()
for GFS2's ordered write, writepages implementation. So we will
also send larger i/os from writeback too.
There is little common content in gfs2_trans_add_bh() between the data
and meta classes by the time that the functions which it calls are
taken into account. The intent here is to split this into two
separate functions. Stage one is to introduce gfs2_trans_add_data()
and gfs2_trans_add_meta() and update the callers accordingly.
Later patches will then pull in the content of gfs2_trans_add_bh()
and its dependent functions in order to clean up the code in this
area.
Just like ext3, this works on the root directory and any directory
with the +T flag set. Also, just like ext3, any subdirectory created
in one of the just mentioned cases will be allocated to a random
resource group (GFS2 equivalent of a block group).
If you are creating a set of directories, each of which will contain a
job running on a different node, then by setting +T on the parent
directory before creating the subdirectories, each will land up in a
different resource group, and thus resource group contention between
nodes will be kept to a minimum.
This patch changes function gfs2_direct_IO so that it uses a normal
call to gfs2_glock_dq rather than a call to a multiple-dq of one item.
The rs_requested field is left over from the original allocation
code, however this should have been a parameter passed to the
various functions from gfs2_inplace_reserve() and not a member of the
reservation structure as the value is not required after the
initial allocation.
This also helps simplify the code since we no longer need to set
the rs_requested to zero. Also the gfs2_inplace_release()
function can also be simplified since the reservation structure
will always be defined when it is called, and the only remaining
task is to unlock the rgrp if required. It can also now be
called unconditionally too, resulting in a further simplification.
This patch moves the ancillary quota data structures into the
block reservations structure. This saves GFS2 some time and
effort in allocating and deallocating the qadata structure.
This patch lengthens the lifespan of the reservations structure for
inodes. Before, they were allocated and deallocated for every write
operation. With this patch, they are allocated when the first write
occurs, and deallocated when the last process closes the file.
It's more efficient to do it this way because it saves GFS2 a lot of
unnecessary allocates and frees. It also gives us more flexibility
for the future: (1) we can now fold the qadata structure back into
the structure and save those alloc/frees, (2) we can use this for
multi-block reservations.
This patch eliminates the gfs2_log_element data structure and
rolls its two components into the gfs2_bufdata. This makes the code
easier to understand and makes it easier to migrate to a rbtree
to keep the list sorted.
gfs2_internal_read accepts an unused ra_state argument, left over from
when we did readahead on the rindex. Since there are currently no plans
to add back this readahead, this patch removes the ra_state parameter
and updates the functions which call gfs2_internal_read accordingly.
Signed-off-by: Andrew Price <anprice@redhat.com>
This is another clean up in the logging code. This per-transaction
list was largely unused. Its main function was to ensure that the
number of buffers in a transaction was correct, however that counter
was only used to check the number of buffers in the bd_list_tr, plus
an assert at the end of each transaction. With the assert now changed
to use the calculated buffer counts, we can remove both bd_list_tr and
its associated counter.
This should make the code easier to understand as well as shrinking
a couple of structures.
This patch makes function gfs2_page_add_databufs static.
This patch allows caching of the rindex glock. We were previously
setting the GL_NOCACHE bit when the glock was released. That forced
the rindex inode to be invalidated, which caused us to re-read
rindex at the next access. However, it caused the glock to be
unnecessarily bounced around the cluster. This patch allows
the glock to remain cached, but it still causes the rindex to be
re-read once it has been written to by gfs2_grow.
Ben and I have tested single-node gfs2_grow cases and I've tested
clustered gfs2_grow cases on my four-node cluster.
Signed-off-by: Cong Wang <amwang@redhat.com>
