Instead of having users check for FL_POSIX or FL_FLOCK to call the correct
locks API function, use the check within locks_lock_inode_wait(). This
allows for some later cleanup.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse updates from Miklos Szeredi:
"This is the start of improving fuse scalability.
An input queue and a processing queue is split out from the monolithic
fuse connection, each of those having their own spinlock. The end of
the patchset adds the ability to clone a fuse connection. This means,
that instead of having to read/write requests/answers on a single fuse
device fd, the fuse daemon can have multiple distinct file descriptors
open. Each of those can be used to receive requests and send answers,
currently the only constraint is that a request must be answered on
the same fd as it was read from.
This can be extended further to allow binding a device clone to a
specific CPU or NUMA node.
Based on a patchset by Srinivas Eeda and Ashish Samant. Thanks to
Ashish for the review of this series"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: (40 commits)
fuse: update MAINTAINERS entry
fuse: separate pqueue for clones
fuse: introduce per-instance fuse_dev structure
fuse: device fd clone
fuse: abort: no fc->lock needed for request ending
fuse: no fc->lock for pqueue parts
fuse: no fc->lock in request_end()
fuse: cleanup request_end()
fuse: request_end(): do once
fuse: add req flag for private list
fuse: pqueue locking
fuse: abort: group pqueue accesses
fuse: cleanup fuse_dev_do_read()
fuse: move list_del_init() from request_end() into callers
fuse: duplicate ->connected in pqueue
fuse: separate out processing queue
fuse: simplify request_wait()
fuse: no fc->lock for iqueue parts
fuse: allow interrupt queuing without fc->lock
fuse: iqueue locking
Use flags for representing the state in fuse_req. This is needed since
req->list will be protected by different locks in different states, hence
we'll want the state itself to be split into distinct bits, each protected
with the relevant lock in that state.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
FUSE_REQ_INIT is actually the same state as FUSE_REQ_PENDING and
FUSE_REQ_READING and FUSE_REQ_WRITING can be merged into a common
FUSE_REQ_IO state.
Reviewed-by: Ashish Samant <ashish.samant@oracle.com>
Finer grained locking will mean there's no single lock to protect
modification of bitfileds in fuse_req.
So move to using bitops. Can use the non-atomic variants for those which
happen while the request definitely has only one reference.
file_remove_suid() is a misnomer since it removes also file capabilities
stored in xattrs and sets S_NOSEC flag. Also should_remove_suid() tells
something else than whether file_remove_suid() call is necessary which
leads to bugs.
Currently, a bdi (backing_dev_info) embeds single wb (bdi_writeback)
and the role of the separation is unclear. For cgroup support for
writeback IOs, a bdi will be updated to host multiple wb's where each
wb serves writeback IOs of a different cgroup on the bdi. To achieve
that, a wb should carry all states necessary for servicing writeback
IOs for a cgroup independently.
This patch moves bdi->bdi_stat[] into wb.
* enum bdi_stat_item is renamed to wb_stat_item and the prefix of all
enums is changed from BDI_ to WB_.
* BDI_STAT_BATCH() -> WB_STAT_BATCH()
* [__]{add|inc|dec|sum}_wb_stat(bdi, ...) -> [__]{add|inc}_wb_stat(wb, ...)
* bdi_stat[_error]() -> wb_stat[_error]()
* bdi_writeout_inc() -> wb_writeout_inc()
* stat init is moved to bdi_wb_init() and bdi_wb_exit() is added and
frees stat.
* As there's still only one bdi_writeback per backing_dev_info, all
uses of bdi->stat[] are mechanically replaced with bdi->wb.stat[]
introducing no behavior changes.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
... avoiding write_iter/fcntl races.
... returning -E... upon error and amount of data left in iter after
(possible) truncation upon success. Note, that normal case gives
a non-zero (positive) return value, so any tests for != 0 _must_ be
updated.
fs/ext4/file.c
already done by caller. We used to call __fuse_direct_write(), which
called generic_write_checks(); now the former got expanded, bringing
the latter to the surface. It used to be called all along and calling
it from there had been wrong all along...
all remaining callers are passing 0; some just obscure that fact.
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
it's actually shorter that way *and* later we'll want iocb in scope
of generic_write_check() caller.
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Most callers in the kernel want to perform synchronous file I/O, but
still have to bloat the stack with a full struct kiocb. Split out
the parts needed in filesystem code from those in the aio code, and
only allocate those needed to pass down argument on the stack. The
aio code embedds the generic iocb in the one it allocates and can
easily get back to it by using container_of.
Also add a ->ki_complete method to struct kiocb, this is used to call
into the aio code and thus removes the dependency on aio for filesystems
impementing asynchronous operations. It will also allow other callers
to substitute their own completion callback.
We also add a new ->ki_flags field to work around the nasty layering
violation recently introduced in commit 5e33f6 ("usb: gadget: ffs: add
eventfd notification about ffs events").
Based on a patch from Maxim Patlasov <MPatlasov@parallels.com>.
Pull backing device changes from Jens Axboe:
"This contains a cleanup of how the backing device is handled, in
preparation for a rework of the life time rules. In this part, the
most important change is to split the unrelated nommu mmap flags from
it, but also removing a backing_dev_info pointer from the
address_space (and inode), and a cleanup of other various minor bits.
Christoph did all the work here, I just fixed an oops with pages that
have a swap backing. Arnd fixed a missing export, and Oleg killed the
lustre backing_dev_info from staging. Last patch was from Al,
unexporting parts that are now no longer needed outside"
* 'for-3.20/bdi' of git://git.kernel.dk/linux-block:
Make super_blocks and sb_lock static
mtd: export new mtd_mmap_capabilities
fs: make inode_to_bdi() handle NULL inode
staging/lustre/llite: get rid of backing_dev_info
fs: remove default_backing_dev_info
fs: don't reassign dirty inodes to default_backing_dev_info
nfs: don't call bdi_unregister
ceph: remove call to bdi_unregister
fs: remove mapping->backing_dev_info
fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info
nilfs2: set up s_bdi like the generic mount_bdev code
block_dev: get bdev inode bdi directly from the block device
block_dev: only write bdev inode on close
fs: introduce f_op->mmap_capabilities for nommu mmap support
fs: kill BDI_CAP_SWAP_BACKED
fs: deduplicate noop_backing_dev_info
Nobody uses it anymore.
[akpm@linux-foundation.org: fix filemap_xip.c]
Now that we got rid of the bdi abuse on character devices we can always use
sb->s_bdi to get at the backing_dev_info for a file, except for the block
device special case. Export inode_to_bdi and replace uses of
mapping->backing_dev_info with it to prepare for the removal of
mapping->backing_dev_info.
Reviewed-by: Tejun Heo <tj@kernel.org>
Pull fuse update from Miklos Szeredi:
"The first part makes sure we don't hold up umount with pending async
requests. In addition to being a cleanup, this is a small behavioral
change (for the better) and unlikely to break anything.
The second part prepares for a cleanup of the fuse device I/O code by
adding a helper for simple request submission, with some savings in
line numbers already realized"
fuse: use file_inode() in fuse_file_fallocate()
fuse: introduce fuse_simple_request() helper
fuse: reduce max out args
fuse: hold inode instead of path after release
fuse: flush requests on umount
fuse: don't wake up reserved req in fuse_conn_kill()
The following pattern is repeated many times:
req = fuse_get_req_nopages(fc);
/* Initialize req->(in|out).args */
fuse_request_send(fc, req);
err = req->out.h.error;
fuse_put_request(req);
Create a new replacement helper:
/* Initialize args */
err = fuse_simple_request(fc, &args);
In addition to reducing the code size, this will ease moving from the
complex arg-based to a simpler page-based I/O on the fuse device.
path_put() in release could trigger a DESTROY request in fuseblk. The
possible deadlock was worked around by doing the path_put() with
schedule_work().
This complexity isn't needed if we just hold the inode instead of the path.
Since we now flush all requests before destroying the super block we can be
sure that all held inodes will be dropped.
The third argument of fuse_get_user_pages() "nbytesp" refers to the number of
bytes a caller asked to pack into fuse request. This value may be lesser
than capacity of fuse request or iov_iter. So fuse_get_user_pages() must
ensure that *nbytesp won't grow.
Now, when helper iov_iter_get_pages() performs all hard work of extracting
pages from iov_iter, it can be done by passing properly calculated
"maxsize" to the helper.
The other caller of iov_iter_get_pages() (dio_refill_pages()) doesn't need
this capability, so pass LONG_MAX as the maxsize argument here.
Fixes: c9c37e2e6378 ("fuse: switch to iov_iter_get_pages()")
Reported-by: Werner Baumann <werner.baumann@onlinehome.de>
Tested-by: Maxim Patlasov <mpatlasov@parallels.com>
... instead of maximal size.
Pull fuse fixes from Miklos Szeredi:
"This contains miscellaneous fixes"
fuse: replace count*size kzalloc by kcalloc
fuse: release temporary page if fuse_writepage_locked() failed
fuse: restructure ->rename2()
fuse: avoid scheduling while atomic
fuse: handle large user and group ID
fuse: inode: drop cast
fuse: ignore entry-timeout on LOOKUP_REVAL
fuse: timeout comparison fix
kcalloc manages count*sizeof overflow.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
tmp_page to be freed if fuse_write_file_get() returns NULL.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
lease codepaths
Currently, the fl_owner isn't set for flock locks. Some filesystems use
byte-range locks to simulate flock locks and there is a common idiom in
those that does:
fl->fl_owner = (fl_owner_t)filp;
fl->fl_start = 0;
fl->fl_end = OFFSET_MAX;
Since flock locks are generally "owned" by the open file description,
move this into the common flock lock setup code. The fl_start and fl_end
fields are already set appropriately, so remove the unneeded setting of
that in flock ops in those filesystems as well.
Finally, the lease code also sets the fl_owner as if they were owned by
the process and not the open file description. This is incorrect as
leases have the same ownership semantics as flock locks. Set them the
same way. The lease code doesn't actually use the fl_owner value for
anything, so this is more for consistency's sake than a bugfix.
Reported-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: Jeff Layton <jlayton@poochiereds.net>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> (Staging portion)
Acked-by: J. Bruce Fields <bfields@fieldses.org>
New variant of iov_iter - ITER_BVEC in iter->type, backed with
bio_vec array instead of iovec one. Primitives taught to deal
with such beasts, __swap_write() switched to using that kind
of iov_iter.
Note that bio_vec is just a <page, offset, length> triple - there's
nothing block-specific about it. I've left the definition where it
was, but took it from under ifdef CONFIG_BLOCK.
Next target: ->splice_write()...
Now It Can Be Done(tm) - we don't need to do iov_shorten() in
generic_file_direct_write() anymore, now that all ->direct_IO()
instances are converted to proper iov_iter methods and honour
iter->count and iter->iov_offset properly.
Get rid of count/ocount arguments of generic_file_direct_write(),
while we are at it.
counts the pages covered by iov_iter, up to given limit.
do_block_direct_io() and fuse_iter_npages() switched to
it.
... to fuse_direct_{read,write}(). ->direct_IO() path uses the
iov_iter passed by the caller instead.
For now, just use the same thing we pass to ->direct_IO() - it's all
iovec-based at the moment. Pass it explicitly to iov_iter_init() and
account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO()
uses.
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter)
unmodified, for now
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already
checked - generic_segment_checks() done after that is just an odd way
to spell iov_length().
The patch extends fuse_setattr_in, and extends the flush procedure
(fuse_flush_times()) called on ->write_inode() to send the ctime as well as
mtime.
Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com>
