[ Upstream commit d0eb06afe712b7b103b6361f40a9a0c638524669 ]
Alter the state-check assertion in fscache_enqueue_operation() to allow
cancelled operations to be given processing time so they can be cleaned up.
Also fix a debugging statement that was requiring such operations to have
an object assigned.
Fixes: 9ae326a69004 ("CacheFiles: A cache that backs onto a mounted filesystem")
Reported-by: Kiran Kumar Modukuri <kiran.modukuri@gmail.com>
[ Upstream commit 2c98425720233ae3e135add0c7e869b32913502f ]
If the fscache asynchronous write operation elects to discard a page that's
pending storage to the cache because the page would be over the store limit
then it needs to wake the page as someone may be waiting on completion of
the write.
The problem is that the store limit may be updated by a different
asynchronous operation - and so may miss the write - and that the store
limit may not even get updated until later by the netfs.
Fix the kernel hang by making fscache_write_op() mark as written any pages
that are over the limit.
commit d124b2c53c7bee6569d2a2d0b18b4a1afde00134 upstream.
When the file /proc/fs/fscache/objects (available with
CONFIG_FSCACHE_OBJECT_LIST=y) is opened, we request a user key with
description "fscache:objlist", then access its payload. However, a
revoked key has a NULL payload, and we failed to check for this.
request_key() *does* skip revoked keys, but there is still a window
where the key can be revoked before we access its payload.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 4fbf4291aa15 ("FS-Cache: Allow the current state of all objects to be dumped")
Reviewed-by: James Morris <james.l.morris@oracle.com>
[ Upstream commit 62deb8187d116581c88c69a2dd9b5c16588545d4 ]
Initialise the stores_lock in fscache netfs cookies. Technically, it
shouldn't be necessary, since the netfs cookie is an index and stores no
data, but initialising it anyway adds insignificant overhead.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
[ Upstream commit 6bdded59c8933940ac7e5b416448276ac89d1144 ]
fscache_disable_cookie() needs to clear the outstanding writes on the
cookie it's disabling because they cannot be completed after.
Without this, fscache_nfs_open_file() gets stuck because it disables the
cookie when the file is opened for writing but can't uncache the pages till
afterwards - otherwise there's a race between the open routine and anyone
who already has it open R/O and is still reading from it.
Looking in /proc/pid/stack of the offending process shows:
[<ffffffffa0142883>] __fscache_wait_on_page_write+0x82/0x9b [fscache]
[<ffffffffa014336e>] __fscache_uncache_all_inode_pages+0x91/0xe1 [fscache]
[<ffffffffa01740fa>] nfs_fscache_open_file+0x59/0x9e [nfs]
[<ffffffffa01ccf41>] nfs4_file_open+0x17f/0x1b8 [nfsv4]
[<ffffffff8117350e>] do_dentry_open+0x16d/0x2b7
[<ffffffff811743ac>] vfs_open+0x5c/0x65
[<ffffffff81184185>] path_openat+0x785/0x8fb
[<ffffffff81184343>] do_filp_open+0x48/0x9e
[<ffffffff81174710>] do_sys_open+0x13b/0x1cb
[<ffffffff811747b9>] SyS_open+0x19/0x1b
[<ffffffff81001c44>] do_syscall_64+0x80/0x17a
[<ffffffff8165c2da>] return_from_SYSCALL_64+0x0/0x7a
[<ffffffffffffffff>] 0xffffffffffffffff
Reported-by: Jianhong Yin <jiyin@redhat.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
[ Upstream commit e26bfebdfc0d212d366de9990a096665d5c0209a ]
Under some circumstances, an fscache object can become queued such that it
fscache_object_work_func() can be called once the object is in the
OBJECT_DEAD state. This results in the kernel oopsing when it tries to
invoke the handler for the state (which is hard coded to 0x2).
The way this comes about is something like the following:
(1) The object dispatcher is processing a work state for an object. This
is done in workqueue context.
(2) An out-of-band event comes in that isn't masked, causing the object to
be queued, say EV_KILL.
(3) The object dispatcher finishes processing the current work state on
that object and then sees there's another event to process, so,
without returning to the workqueue core, it processes that event too.
It then follows the chain of events that initiates until we reach
OBJECT_DEAD without going through a wait state (such as
WAIT_FOR_CLEARANCE).
At this point, object->events may be 0, object->event_mask will be 0
and oob_event_mask will be 0.
(4) The object dispatcher returns to the workqueue processor, and in due
course, this sees that the object's work item is still queued and
invokes it again.
(5) The current state is a work state (OBJECT_DEAD), so the dispatcher
jumps to it - resulting in an OOPS.
When I'm seeing this, the work state in (1) appears to have been either
LOOK_UP_OBJECT or CREATE_OBJECT (object->oob_table is
fscache_osm_lookup_oob).
The window for (2) is very small:
(A) object->event_mask is cleared whilst the event dispatch process is
underway - though there's no memory barrier to force this to the top
of the function.
The window, therefore is from the time the object was selected by the
workqueue processor and made requeueable to the time the mask was
cleared.
(B) fscache_raise_event() will only queue the object if it manages to set
the event bit and the corresponding event_mask bit was set.
The enqueuement is then deferred slightly whilst we get a ref on the
object and get the per-CPU variable for workqueue congestion. This
slight deferral slightly increases the probability by allowing extra
time for the workqueue to make the item requeueable.
Handle this by giving the dead state a processor function and checking the
for the dead state address rather than seeing if the processor function is
address 0x2. The dead state processor function can then set a flag to
indicate that it's occurred and give a warning if it occurs more than once
per object.
If this race occurs, an oops similar to the following is seen (note the RIP
value):
BUG: unable to handle kernel NULL pointer dereference at 0000000000000002
IP: [<0000000000000002>] 0x1
PGD 0
Oops: 0010 [#1] SMP
Modules linked in: ...
CPU: 17 PID: 16077 Comm: kworker/u48:9 Not tainted 3.10.0-327.18.2.el7.x86_64 #1
Hardware name: HP ProLiant DL380 Gen9/ProLiant DL380 Gen9, BIOS P89 12/27/2015
Workqueue: fscache_object fscache_object_work_func [fscache]
task: ffff880302b63980 ti: ffff880717544000 task.ti: ffff880717544000
RIP: 0010:[<0000000000000002>] [<0000000000000002>] 0x1
RSP: 0018:ffff880717547df8 EFLAGS: 00010202
RAX: ffffffffa0368640 RBX: ffff880edf7a4480 RCX: dead000000200200
RDX: 0000000000000002 RSI: 00000000ffffffff RDI: ffff880edf7a4480
RBP: ffff880717547e18 R08: 0000000000000000 R09: dfc40a25cb3a4510
R10: dfc40a25cb3a4510 R11: 0000000000000400 R12: 0000000000000000
R13: ffff880edf7a4510 R14: ffff8817f6153400 R15: 0000000000000600
FS: 0000000000000000(0000) GS:ffff88181f420000(0000) knlGS:0000000000000000
CR2: 0000000000000002 CR3: 000000000194a000 CR4: 00000000001407e0
Stack:
ffffffffa0363695 ffff880edf7a4510 ffff88093f16f900 ffff8817faa4ec00
ffff880717547e60 ffffffff8109d5db 00000000faa4ec18 0000000000000000
ffff8817faa4ec18 ffff88093f16f930 ffff880302b63980 ffff88093f16f900
Call Trace:
[<ffffffffa0363695>] ? fscache_object_work_func+0xa5/0x200 [fscache]
[<ffffffff8109d5db>] process_one_work+0x17b/0x470
[<ffffffff8109e4ac>] worker_thread+0x21c/0x400
[<ffffffff8109e290>] ? rescuer_thread+0x400/0x400
[<ffffffff810a5acf>] kthread+0xcf/0xe0
[<ffffffff810a5a00>] ? kthread_create_on_node+0x140/0x140
[<ffffffff816460d8>] ret_from_fork+0x58/0x90
Acked-by: Jeremy McNicoll <jeremymc@redhat.com>
Tested-by: Frank Sorenson <sorenson@redhat.com>
Tested-by: Benjamin Coddington <bcodding@redhat.com>
Reviewed-by: Benjamin Coddington <bcodding@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into work.misc
Signed-off-by: Yan, Zheng <zyan@redhat.com>
it's not needed for file_operations of inodes located on fs defined
in the hosting module and for file_operations that go into procfs.
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Handle a write being requested to the page immediately beyond the EOF
marker on a cache object. Currently this gets an assertion failure in
CacheFiles because the EOF marker is used there to encode information about
a partial page at the EOF - which could lead to an unknown blank spot in
the file if we extend the file over it.
The problem is actually in fscache where we check the index of the page
being written against store_limit. store_limit is set to the number of
pages that we're allowed to store by fscache_set_store_limit() - which
means it's one more than the index of the last page we're allowed to store.
The problem is that we permit writing to a page with an index _equal_ to
the store limit - when we should reject that case.
Whilst we're at it, change the triggered assertion in CacheFiles to just
return -ENOBUFS instead.
The assertion failure looks something like this:
CacheFiles: Assertion failed
1000 < 7b1 is false
kernel BUG at fs/cachefiles/rdwr.c:962!
RIP: 0010:[<ffffffffa02c9e83>] [<ffffffffa02c9e83>] cachefiles_write_page+0x273/0x2d0 [cachefiles]
Cc: stable@vger.kernel.org # v2.6.31+; earlier - that + backport of a17754f (at least)
Only override netfs->primary_index when registering success.
Cc: stable@vger.kernel.org # v2.6.30+
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
If netfs exist, fscache should not increase the reference of parent's
usage and n_children, otherwise, never be decreased.
v2: thanks David's suggest,
move increasing reference of parent if success
use kmem_cache_free() freeing primary_index directly
v3: don't move "netfs->primary_index->parent = &fscache_fsdef_index;"
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
Merge the type-specific data with the payload data into one four-word chunk
as it seems pointless to keep them separate.
Use user_key_payload() for accessing the payloads of overloaded
user-defined keys.
cc: linux-cifs@vger.kernel.org
cc: ecryptfs@vger.kernel.org
cc: linux-ext4@vger.kernel.org
cc: linux-f2fs-devel@lists.sourceforge.net
cc: linux-nfs@vger.kernel.org
cc: ceph-devel@vger.kernel.org
cc: linux-ima-devel@lists.sourceforge.net
Now that the retrieval operation may be disposed of by fscache_put_operation()
before we actually set the context, the retrieval-specific cleanup operation
can produce a NULL-pointer dereference when it tries to unconditionally clean
up the netfs context.
Given that it is expected that we'll get at least as far as the place where we
currently set the context pointer and it is unlikely we'll go through the
error handling paths prior to that point, retain the context right from the
point that the retrieval op is allocated.
Concomitant to this, we need to retain the cookie pointer in the retrieval op
also so that we can call the netfs to release its context in the release
method.
In addition, we might now get into fscache_release_retrieval_op() with the op
only initialised. To this end, set the operation to DEAD only after the
release method has been called and skip the n_pages test upon cleanup if the
op is still in the INITIALISED state.
Without these changes, the following oops might be seen:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000b8
RIP: 0010:[<ffffffffa0089c98>] fscache_release_retrieval_op+0xae/0x100
Call Trace:
[<ffffffffa0088560>] fscache_put_operation+0x117/0x2e0
[<ffffffffa008b8f5>] __fscache_read_or_alloc_pages+0x351/0x3ac
[<ffffffffa00b761f>] __nfs_readpages_from_fscache+0x59/0xbf [nfs]
[<ffffffffa00b06c5>] nfs_readpages+0x10c/0x185 [nfs]
[<ffffffff81124925>] ? alloc_pages_current+0x119/0x13e
[<ffffffff810ee5fd>] ? __page_cache_alloc+0xfb/0x10a
[<ffffffff810f87f8>] __do_page_cache_readahead+0x188/0x22c
[<ffffffff810f8b3a>] ondemand_readahead+0x29e/0x2af
[<ffffffff810f8c92>] page_cache_sync_readahead+0x38/0x3a
[<ffffffff810ef337>] generic_file_read_iter+0x1a2/0x55a
[<ffffffffa00a9dff>] ? nfs_revalidate_mapping+0xd6/0x288 [nfs]
[<ffffffffa00a6a23>] nfs_file_read+0x49/0x70 [nfs]
[<ffffffff811363be>] new_sync_read+0x78/0x9c
[<ffffffff81137164>] __vfs_read+0x13/0x38
[<ffffffff8113721e>] vfs_read+0x95/0x121
[<ffffffff811372f6>] SyS_read+0x4c/0x8a
[<ffffffff81557a52>] system_call_fastpath+0x12/0x17
Reviewed-by: Steve Dickson <steved@redhat.com>
Acked-by: Jeff Layton <jeff.layton@primarydata.com>
Any time an incomplete operation is cancelled, the operation cancellation
function needs to be called to clean up. This is currently being passed
directly to some of the functions that might want to call it, but not all.
Instead, pass the cancellation method pointer to the fscache_operation_init()
and have that cache it in the operation struct. Further, plug in a dummy
cancellation handler if the caller declines to set one as this allows us to
call the function unconditionally (the extra overhead isn't worth bothering
about as we don't expect to be calling this typically).
The cancellation method must thence be called everywhere the CANCELLED state
is set. Note that we call it *before* setting the CANCELLED state such that
the method can use the old state value to guide its operation.
fscache_do_cancel_retrieval() needs moving higher up in the sources so that
the init function can use it now.
Without this, the following oops may be seen:
FS-Cache: Assertion failed
FS-Cache: 3 == 0 is false
kernel BUG at ../fs/fscache/page.c:261!
RIP: 0010:[<ffffffffa0089c1b>] fscache_release_retrieval_op+0x77/0x100
[<ffffffffa008853d>] fscache_put_operation+0x114/0x2da
[<ffffffffa008b8c2>] __fscache_read_or_alloc_pages+0x358/0x3b3
The assertion is showing that the remaining number of pages (n_pages) is not 0
when the operation is being released.
Call fscache_put_operation() or a wrapper on any op that has gone through
fscache_operation_init() so that the accounting shown in /proc is done
correctly, specifically fscache_n_op_release.
fscache_put_operation() therefore now allows an op in the INITIALISED state as
well as in the CANCELLED and COMPLETE states.
Note that this means that an operation can get put that doesn't have its
->object pointer filled in, so anything that depends on the object needs to be
conditional in fscache_put_operation().
Cancellation of an in-progress operation needs to update the relevant counters
and start any operations that are pending waiting on this one.
Count and display through /proc/fs/fscache/stats the number of initialised
operations.
Out of line fscache_operation_init() so that it can access internal FS-Cache
features, such as stats, in a later commit.
Currently, fscache_cancel_op() only cancels pending operations - attempts to
cancel in-progress operations are ignored. This leads to a problem in
fscache_wait_for_operation_activation() whereby the wait is terminated, but
the object has been killed.
The check at the end of the function now triggers because it's no longer
contingent on the cache having produced an I/O error since the commit that
fixed the logic error in fscache_object_is_dead().
The result of the check is that it tries to cancel the operation - but since
the object may not be pending by this point, the cancellation request may be
ignored - with the result that the the object is just put by the caller and
fscache_put_operation has an assertion failure because the operation isn't in
either the COMPLETE or the CANCELLED states.
To fix this, we permit in-progress ops to be cancelled under some
circumstances.
The bug results in an oops that looks something like this:
FS-Cache: fscache_wait_for_operation_activation() = -ENOBUFS [obj dead 3]
FS-Cache:
FS-Cache: 3 == 5 is false
kernel BUG at ../fs/fscache/operation.c:432!
RIP: 0010:[<ffffffffa0088574>] fscache_put_operation+0xf2/0x2cd
Call Trace:
[<ffffffffa008b92a>] __fscache_read_or_alloc_pages+0x2ec/0x3b3
fscache_object_is_dead() returns true only if the object is marked dead and
the cache got an I/O error. This should be a logical OR instead. Since two
of the callers got split up into handling for separate subcases, expand the
other callers and kill the function. This is probably the right thing to do
anyway since one of the subcases isn't about the object at all, but rather
about the cache.
When an object is being marked as no longer live, do this under the object
spinlock to prevent a race with operation submission targeted on that object.
The problem occurs due to the following pair of intertwined sequences when the
cache tries to create an object that would take it over the hard available
space limit:
NETFS INTERFACE
(A) The netfs calls fscache_acquire_cookie(). object creation is deferred to
the object state machine and the netfs is allowed to continue.
OBJECT STATE MACHINE KTHREAD
(1) The object is looked up on disk by fscache_look_up_object()
calling cachefiles_walk_to_object(). The latter finds that the
object is not yet represented on disk and calls
fscache_object_lookup_negative().
(2) fscache_object_lookup_negative() sets FSCACHE_COOKIE_NO_DATA_YET
and clears FSCACHE_COOKIE_LOOKING_UP, thus allowing the netfs to
start queuing read operations.
(B) The netfs calls fscache_read_or_alloc_pages(). This calls
fscache_wait_for_deferred_lookup() which sees FSCACHE_COOKIE_LOOKING_UP
become clear, allowing the read to begin.
(C) A read operation is set up and passed to fscache_submit_op() to deal
with.
(3) cachefiles_walk_to_object() calls cachefiles_has_space(), which
fails (or one of the file operations to create stuff fails).
cachefiles returns an error to fscache.
(4) fscache_look_up_object() transits to the LOOKUP_FAILURE state,
(5) fscache_lookup_failure() sets FSCACHE_OBJECT_LOOKED_UP and
FSCACHE_COOKIE_UNAVAILABLE and clears FSCACHE_COOKIE_LOOKING_UP
then transits to the KILL_OBJECT state.
(6) fscache_kill_object() clears FSCACHE_OBJECT_IS_LIVE in an attempt
to reject any further requests from the netfs.
(7) object->n_ops is examined and found to be 0.
fscache_kill_object() transits to the DROP_OBJECT state.
(D) fscache_submit_op() locks the object spinlock, sees if it can dispatch
the op immediately by calling fscache_object_is_active() - which fails
since FSCACHE_OBJECT_IS_AVAILABLE has not yet been set.
(E) fscache_submit_op() then tests FSCACHE_OBJECT_LOOKED_UP - which is set.
It then queues the object and increments object->n_ops.
(8) fscache_drop_object() releases the object and eventually
fscache_put_object() calls cachefiles_put_object() which suffers
an assertion failure here:
ASSERTCMP(object->fscache.n_ops, ==, 0);
Locking the object spinlock in step (6) around the clearance of
FSCACHE_OBJECT_IS_LIVE ensures that the the decision trees in
fscache_submit_op() and fscache_submit_exclusive_op() don't see the IS_LIVE
flag being cleared mid-decision: either the op is queued before step (7) - in
which case fscache_kill_object() will see n_ops>0 and will deal with the op -
or the op will be rejected.
This, combined with rejecting op submission if the target object is dying, fix
the problem.
The problem shows up as the following oops:
CacheFiles: 1 == 0 is false
kernel BUG at ../fs/cachefiles/interface.c:339!
RIP: 0010:[<ffffffffa014fd9c>] [<ffffffffa014fd9c>] cachefiles_put_object+0x2a4/0x301 [cachefiles]
Call Trace:
[<ffffffffa008674b>] fscache_put_object+0x18/0x21 [fscache]
[<ffffffffa00883e6>] fscache_object_work_func+0x3ba/0x3c9 [fscache]
[<ffffffff81054dad>] process_one_work+0x226/0x441
[<ffffffff81055d91>] worker_thread+0x273/0x36b
[<ffffffff81055b1e>] ? rescuer_thread+0x2e1/0x2e1
[<ffffffff81059b9d>] kthread+0x10e/0x116
[<ffffffff81059a8f>] ? kthread_create_on_node+0x1bb/0x1bb
[<ffffffff815579ac>] ret_from_fork+0x7c/0xb0
Reject new operations that are being submitted against an object if that
object has failed its lookup or creation states or has been killed by the
cache backend for some other reason, such as having been culled.
When submitting an operation, prefer to cancel the operation immediately
rather than queuing it for later processing if the object is marked as dying
(ie. the object state machine has reached the KILL_OBJECT state).
Whilst we're at it, change the series of related test_bit() calls into a
READ_ONCE() and bitwise-AND operators to reduce the number of load
instructions (test_bit() has a volatile address).
Move fscache_report_unexpected_submission() up within operation.c so that it
can be called from fscache_submit_exclusive_op() too.
Count the number of objects that get culled by the cache backend and the
number of objects that the cache backend declines to instantiate due to lack
of space in the cache.
These numbers are made available through /proc/fs/fscache/stats
Reduce boilerplate code by using __seq_open_private() instead of seq_open()
in fscache_objlist_open().
Signed-off-by: Rob Jones <rob.jones@codethink.co.uk>
In rare cases under heavy VMA pressure the ref count for a fscache cookie
becomes corrupt. In this case we decrement ref count even if we fail before
incrementing the refcount.
FS-Cache: Assertion failed bnode-eca5f9c6/syslog
0 > 0 is false
kernel BUG at fs/fscache/cookie.c:519!
invalid opcode: 0000 [#1] SMP
Call Trace:
[<ffffffffa01ba060>] __fscache_relinquish_cookie+0x50/0x220 [fscache]
[<ffffffffa02d64ce>] ceph_fscache_unregister_inode_cookie+0x3e/0x50 [ceph]
[<ffffffffa02ae1d3>] ceph_destroy_inode+0x33/0x200 [ceph]
[<ffffffff811cf67e>] ? __fsnotify_inode_delete+0xe/0x10
[<ffffffff811a9e0c>] destroy_inode+0x3c/0x70
[<ffffffff811a9f51>] evict+0x111/0x180
[<ffffffff811aa763>] iput+0x103/0x190
[<ffffffff811a5de8>] __dentry_kill+0x1c8/0x220
[<ffffffff811a5f31>] shrink_dentry_list+0xf1/0x250
[<ffffffff811a762c>] prune_dcache_sb+0x4c/0x60
[<ffffffff811930af>] super_cache_scan+0xff/0x170
[<ffffffff8113d7a0>] shrink_slab_node+0x140/0x2c0
[<ffffffff8113f2da>] shrink_slab+0x8a/0x130
[<ffffffff81142572>] balance_pgdat+0x3e2/0x5d0
[<ffffffff811428ca>] kswapd+0x16a/0x4a0
[<ffffffff810a43f0>] ? __wake_up_sync+0x20/0x20
[<ffffffff81142760>] ? balance_pgdat+0x5d0/0x5d0
[<ffffffff81083e09>] kthread+0xc9/0xe0
[<ffffffff81010000>] ? ftrace_raw_event_xen_mmu_release_ptpage+0x70/0x90
[<ffffffff81083d40>] ? flush_kthread_worker+0xb0/0xb0
[<ffffffff8159f63c>] ret_from_fork+0x7c/0xb0
RIP [<ffffffffa01b984b>] __fscache_disable_cookie+0x1db/0x210 [fscache]
RSP <ffff8803bc85f9b8>
---[ end trace 254d0d7c74a01f25 ]---
Signed-off-by: Milosz Tanski <milosz@adfin.com>
I've been seeing issues with disposing cookies under vma pressure. The symptom
is that the refcount gets out of sync. In this case we fail to decrement the
refcount if submit fails. I found this while auditing the error in and around
cookie operations.
This is meant to avoid a recusive hang caused by underlying filesystem trying
to grab a free page and causing a write-out.
INFO: task kworker/u30:7:28375 blocked for more than 120 seconds.
Not tainted 3.15.0-virtual #74
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
kworker/u30:7 D 0000000000000000 0 28375 2 0x00000000
Workqueue: fscache_operation fscache_op_work_func [fscache]
ffff88000b147148 0000000000000046 0000000000000000 ffff88000b1471c8
ffff8807aa031820 0000000000014040 ffff88000b147fd8 0000000000014040
ffff880f0c50c860 ffff8807aa031820 ffff88000b147158 ffff88007be59cd0
Call Trace:
[<ffffffff815930e9>] schedule+0x29/0x70
[<ffffffffa018bed5>] __fscache_wait_on_page_write+0x55/0x90 [fscache]
[<ffffffff810a4350>] ? __wake_up_sync+0x20/0x20
[<ffffffffa018c135>] __fscache_maybe_release_page+0x65/0x1e0 [fscache]
[<ffffffffa02ad813>] ceph_releasepage+0x83/0x100 [ceph]
[<ffffffff811635b0>] ? anon_vma_fork+0x130/0x130
[<ffffffff8112cdd2>] try_to_release_page+0x32/0x50
[<ffffffff81140096>] shrink_page_list+0x7e6/0x9d0
[<ffffffff8113f278>] ? isolate_lru_pages.isra.73+0x78/0x1e0
[<ffffffff81140932>] shrink_inactive_list+0x252/0x4c0
[<ffffffff811412b1>] shrink_lruvec+0x3e1/0x670
[<ffffffff8114157f>] shrink_zone+0x3f/0x110
[<ffffffff81141b06>] do_try_to_free_pages+0x1d6/0x450
[<ffffffff8114a939>] ? zone_statistics+0x99/0xc0
[<ffffffff81141e44>] try_to_free_pages+0xc4/0x180
[<ffffffff81136982>] __alloc_pages_nodemask+0x6b2/0xa60
[<ffffffff811c1d4e>] ? __find_get_block+0xbe/0x250
[<ffffffff810a405e>] ? wake_up_bit+0x2e/0x40
[<ffffffff811740c3>] alloc_pages_current+0xb3/0x180
[<ffffffff8112cf07>] __page_cache_alloc+0xb7/0xd0
[<ffffffff8112da6c>] grab_cache_page_write_begin+0x7c/0xe0
[<ffffffff81214072>] ? ext4_mark_inode_dirty+0x82/0x220
[<ffffffff81214a89>] ext4_da_write_begin+0x89/0x2d0
[<ffffffff8112c6ee>] generic_perform_write+0xbe/0x1d0
[<ffffffff811a96b1>] ? update_time+0x81/0xc0
[<ffffffff811ad4c2>] ? mnt_clone_write+0x12/0x30
[<ffffffff8112e80e>] __generic_file_aio_write+0x1ce/0x3f0
[<ffffffff8112ea8e>] generic_file_aio_write+0x5e/0xe0
[<ffffffff8120b94f>] ext4_file_write+0x9f/0x410
[<ffffffff8120af56>] ? ext4_file_open+0x66/0x180
[<ffffffff8118f0da>] do_sync_write+0x5a/0x90
[<ffffffffa025c6c9>] cachefiles_write_page+0x149/0x430 [cachefiles]
[<ffffffff812cf439>] ? radix_tree_gang_lookup_tag+0x89/0xd0
[<ffffffffa018c512>] fscache_write_op+0x222/0x3b0 [fscache]
[<ffffffffa018b35a>] fscache_op_work_func+0x3a/0x100 [fscache]
[<ffffffff8107bfe9>] process_one_work+0x179/0x4a0
[<ffffffff8107d47b>] worker_thread+0x11b/0x370
[<ffffffff8107d360>] ? manage_workers.isra.21+0x2e0/0x2e0
[<ffffffff81083d69>] kthread+0xc9/0xe0
[<ffffffff81083ca0>] ? flush_kthread_worker+0xb0/0xb0
[<ffffffff8159eefc>] ret_from_fork+0x7c/0xb0
fscache_sysctls and fscache_sysctls_root are only used in main.c
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Joe Perches <joe@perches.com>
The current "wait_on_bit" interface requires an 'action'
function to be provided which does the actual waiting.
There are over 20 such functions, many of them identical.
Most cases can be satisfied by one of just two functions, one
which uses io_schedule() and one which just uses schedule().
So:
Rename wait_on_bit and wait_on_bit_lock to
wait_on_bit_action and wait_on_bit_lock_action
to make it explicit that they need an action function.
Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io
which are *not* given an action function but implicitly use
a standard one.
The decision to error-out if a signal is pending is now made
based on the 'mode' argument rather than being encoded in the action
function.
All instances of the old wait_on_bit and wait_on_bit_lock which
can use the new version have been changed accordingly and their
action functions have been discarded.
wait_on_bit{_lock} does not return any specific error code in the
event of a signal so the caller must check for non-zero and
interpolate their own error code as appropriate.
The wait_on_bit() call in __fscache_wait_on_invalidate() was
ambiguous as it specified TASK_UNINTERRUPTIBLE but used
fscache_wait_bit_interruptible as an action function.
David Howells confirms this should be uniformly
"uninterruptible"
The main remaining user of wait_on_bit{,_lock}_action is NFS
which needs to use a freezer-aware schedule() call.
A comment in fs/gfs2/glock.c notes that having multiple 'action'
functions is useful as they display differently in the 'wchan'
field of 'ps'. (and /proc/$PID/wchan).
As the new bit_wait{,_io} functions are tagged "__sched", they
will not show up at all, but something higher in the stack. So
the distinction will still be visible, only with different
function names (gds2_glock_wait versus gfs2_glock_dq_wait in the
gfs2/glock.c case).
Since first version of this patch (against 3.15) two new action
functions appeared, on in NFS and one in CIFS. CIFS also now
uses an action function that makes the same freezer aware
schedule call as NFS.
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: David Howells <dhowells@redhat.com> (fscache, keys)
Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2)
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Steve French <sfrench@samba.org>
Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown
This typedef is unnecessary and should just be removed.
Replace seq_printf where possible + coalesce formats from 2 existing
seq_puts
All printk converted to pr_foo() except internal.h: printk(KERN_DEBUG
Coalesce formats.
Add pr_fmt
When FS-Cache allocates an object, the following sequence of events can
occur:
-->fscache_alloc_object()
-->cachefiles_alloc_object() [via cache->ops->alloc_object]
<--[returns new object]
-->fscache_attach_object()
<--[failed]
-->cachefiles_put_object() [via cache->ops->put_object]
-->fscache_object_destroy()
-->fscache_objlist_remove()
-->rb_erase() to remove the object from fscache_object_list.
resulting in a crash in the rbtree code.
The problem is that the object is only added to fscache_object_list on
the success path of fscache_attach_object() where it calls
fscache_objlist_add().
So if fscache_attach_object() fails, the object won't have been added to
the objlist rbtree. We do, however, unconditionally try to remove the
object from the tree.
Thanks to NeilBrown for finding this and suggesting this solution.
Reported-by: NeilBrown <neilb@suse.de>
Tested-by: (a customer of) NeilBrown <neilb@suse.de>
Pull block IO core updates from Jens Axboe:
"This is the pull request for the core changes in the block layer for
3.13. It contains:
- The new blk-mq request interface.
This is a new and more scalable queueing model that marries the
best part of the request based interface we currently have (which
is fully featured, but scales poorly) and the bio based "interface"
which the new drivers for high IOPS devices end up using because
it's much faster than the request based one.
The bio interface has no block layer support, since it taps into
the stack much earlier. This means that drivers end up having to
implement a lot of functionality on their own, like tagging,
timeout handling, requeue, etc. The blk-mq interface provides all
these. Some drivers even provide a switch to select bio or rq and
has code to handle both, since things like merging only works in
the rq model and hence is faster for some workloads. This is a
huge mess. Conversion of these drivers nets us a substantial code
reduction. Initial results on converting SCSI to this model even
shows an 8x improvement on single queue devices. So while the
model was intended to work on the newer multiqueue devices, it has
substantial improvements for "classic" hardware as well. This code
has gone through extensive testing and development, it's now ready
to go. A pull request is coming to convert virtio-blk to this
model will be will be coming as well, with more drivers scheduled
for 3.14 conversion.
- Two blktrace fixes from Jan and Chen Gang.
- A plug merge fix from Alireza Haghdoost.
- Conversion of __get_cpu_var() from Christoph Lameter.
- Fix for sector_div() with 64-bit divider from Geert Uytterhoeven.
- A fix for a race between request completion and the timeout
handling from Jeff Moyer. This is what caused the merge conflict
with blk-mq/core, in case you are looking at that.
- A dm stacking fix from Mike Snitzer.
- A code consolidation fix and duplicated code removal from Kent
Overstreet.
- A handful of block bug fixes from Mikulas Patocka, fixing a loop
crash and memory corruption on blk cg.
- Elevator switch bug fix from Tomoki Sekiyama.
A heads-up that I had to rebase this branch. Initially the immutable
bio_vecs had been queued up for inclusion, but a week later, it became
clear that it wasn't fully cooked yet. So the decision was made to
pull this out and postpone it until 3.14. It was a straight forward
rebase, just pruning out the immutable series and the later fixes of
problems with it. The rest of the patches applied directly and no
further changes were made"
* 'for-3.13/core' of git://git.kernel.dk/linux-block: (31 commits)
block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
block: Do not call sector_div() with a 64-bit divisor
kernel: trace: blktrace: remove redundent memcpy() in compat_blk_trace_setup()
block: Consolidate duplicated bio_trim() implementations
block: Use rw_copy_check_uvector()
block: Enable sysfs nomerge control for I/O requests in the plug list
block: properly stack underlying max_segment_size to DM device
elevator: acquire q->sysfs_lock in elevator_change()
elevator: Fix a race in elevator switching and md device initialization
block: Replace __get_cpu_var uses
bdi: test bdi_init failure
block: fix a probe argument to blk_register_region
loop: fix crash if blk_alloc_queue fails
blk-core: Fix memory corruption if blkcg_init_queue fails
block: fix race between request completion and timeout handling
blktrace: Send BLK_TN_PROCESS events to all running traces
blk-mq: don't disallow request merges for req->special being set
blk-mq: mq plug list breakage
blk-mq: fix for flush deadlock
__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
#define __get_cpu_var(var) (*this_cpu_ptr(&(var)))
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
At the end of the patch set all uses of __get_cpu_var have been removed so
the macro is removed too.
The patch set includes passes over all arches as well. Once these operations
are used throughout then specialized macros can be defined in non -x86
arches as well in order to optimize per cpu access by f.e. using a global
register that may be set to the per cpu base.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
this_cpu_inc(y)
Signed-off-by: Christoph Lameter <cl@linux.com>
Provide the ability to enable and disable fscache cookies. A disabled cookie
will reject or ignore further requests to:
Acquire a child cookie
Invalidate and update backing objects
Check the consistency of a backing object
Allocate storage for backing page
Read backing pages
Write to backing pages
but still allows:
Checks/waits on the completion of already in-progress objects
Uncaching of pages
Relinquishment of cookies
Two new operations are provided:
(1) Disable a cookie:
void fscache_disable_cookie(struct fscache_cookie *cookie,
bool invalidate);
If the cookie is not already disabled, this locks the cookie against other
dis/enablement ops, marks the cookie as being disabled, discards or
invalidates any backing objects and waits for cessation of activity on any
associated object.
This is a wrapper around a chunk split out of fscache_relinquish_cookie(),
but it reinitialises the cookie such that it can be reenabled.
All possible failures are handled internally. The caller should consider
calling fscache_uncache_all_inode_pages() afterwards to make sure all page
markings are cleared up.
(2) Enable a cookie:
void fscache_enable_cookie(struct fscache_cookie *cookie,
bool (*can_enable)(void *data),
void *data)
If the cookie is not already enabled, this locks the cookie against other
dis/enablement ops, invokes can_enable() and, if the cookie is not an
index cookie, will begin the procedure of acquiring backing objects.
The optional can_enable() function is passed the data argument and returns
a ruling as to whether or not enablement should actually be permitted to
begin.
All possible failures are handled internally. The cookie will only be
marked as enabled if provisional backing objects are allocated.
A later patch will introduce these to NFS. Cookie enablement during nfs_open()
is then contingent on i_writecount <= 0. can_enable() checks for a race
between open(O_RDONLY) and open(O_WRONLY/O_RDWR). This simplifies NFS's cookie
handling and allows us to get rid of open(O_RDONLY) accidentally introducing
caching to an inode that's open for writing already.
One operation has its API modified:
(3) Acquire a cookie.
struct fscache_cookie *fscache_acquire_cookie(
struct fscache_cookie *parent,
const struct fscache_cookie_def *def,
void *netfs_data,
bool enable);
This now has an additional argument that indicates whether the requested
cookie should be enabled by default. It doesn't need the can_enable()
function because the caller must prevent multiple calls for the same netfs
object and it doesn't need to take the enablement lock because no one else
can get at the cookie before this returns.
Add wrapper functions for dealing with cookie->n_active:
(*) __fscache_use_cookie() to increment it.
(*) __fscache_unuse_cookie() to decrement and test against zero.
(*) __fscache_wake_unused_cookie() to wake up anyone waiting for it to reach
zero.
The second and third are split so that the third can be done after cookie->lock
has been released in case the waiter wakes up whilst we're still holding it and
tries to get it.
We will need to wake-on-zero once the cookie disablement patch is applied
because it will then be possible to see n_active become zero without the cookie
being relinquished.
Also move the cookie usement out of fscache_attr_changed_op() and into
fscache_attr_changed() and the operation struct so that cookie disablement
will be able to track it.
Whilst we're at it, only increment n_active if we're about to do
fscache_submit_op() so that we don't have to deal with undoing it if anything
earlier fails. Possibly this should be moved into fscache_submit_op() which
could look at FSCACHE_OP_UNUSE_COOKIE.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull ceph fixes from Sage Weil:
"These fix several bugs with RBD from 3.11 that didn't get tested in
time for the merge window: some error handling, a use-after-free, and
a sequencing issue when unmapping and image races with a notify
operation.
There is also a patch fixing a problem with the new ceph + fscache
code that just went in"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
fscache: check consistency does not decrement refcount
rbd: fix error handling from rbd_snap_name()
rbd: ignore unmapped snapshots that no longer exist
rbd: fix use-after free of rbd_dev->disk
rbd: make rbd_obj_notify_ack() synchronous
rbd: complete notifies before cleaning up osd_client and rbd_dev
libceph: add function to ensure notifies are complete
With users of radix_tree_preload() run from interrupt (block/blk-ioc.c is
one such possible user), the following race can happen:
radix_tree_insert()
radix_tree_node_alloc()
if (rtp->nr) {
ret = rtp->nodes[rtp->nr - 1];
<interrupt>
radix_tree_insert()
if (rtp->nr) {
And we give out one radix tree node twice. That clearly results in radix
tree corruption with different results (usually OOPS) depending on which
two users of radix tree race.
We fix the problem by making radix_tree_node_alloc() always allocate fresh
radix tree nodes when in interrupt. Using preloading when in interrupt
doesn't make sense since all the allocations have to be atomic anyway and
we cannot steal nodes from process-context users because some users rely
on radix_tree_insert() succeeding after radix_tree_preload().
in_interrupt() check is somewhat ugly but we cannot simply key off passed
gfp_mask as that is acquired from root_gfp_mask() and thus the same for
all preload users.
Another part of the fix is to avoid node preallocation in
radix_tree_preload() when passed gfp_mask doesn't allow waiting. Again,
preallocation in such case doesn't make sense and when preallocation would
happen in interrupt we could possibly leak some allocated nodes. However,
some users of radix_tree_preload() require following radix_tree_insert()
to succeed. To avoid unexpected effects for these users,
radix_tree_preload() only warns if passed gfp mask doesn't allow waiting
and we provide a new function radix_tree_maybe_preload() for those users
which get different gfp mask from different call sites and which are
prepared to handle radix_tree_insert() failure.
Cc: Jens Axboe <jaxboe@fusionio.com>
__fscache_check_consistency() does not decrement the count of operations
active after it finishes in the success case. This leads to a hung tasks on
cookie de-registration (commonly in inode eviction).
INFO: task kworker/1:2:4214 blocked for more than 120 seconds.
kworker/1:2 D ffff880443513fc0 0 4214 2 0x00000000
Workqueue: ceph-msgr con_work [libceph]
Call Trace:
[<ffffffff81569fc6>] ? _raw_spin_unlock_irqrestore+0x16/0x20
[<ffffffffa0016570>] ? fscache_wait_bit_interruptible+0x30/0x30 [fscache]
[<ffffffff81568d09>] schedule+0x29/0x70
[<ffffffffa001657e>] fscache_wait_atomic_t+0xe/0x20 [fscache]
[<ffffffff815665cf>] out_of_line_wait_on_atomic_t+0x9f/0xe0
[<ffffffff81083560>] ? autoremove_wake_function+0x40/0x40
[<ffffffffa0015a9c>] __fscache_relinquish_cookie+0x15c/0x310 [fscache]
[<ffffffffa00a4fae>] ceph_fscache_unregister_inode_cookie+0x3e/0x50 [ceph]
[<ffffffffa007e373>] ceph_destroy_inode+0x33/0x200 [ceph]
[<ffffffff811c13ae>] ? __fsnotify_inode_delete+0xe/0x10
[<ffffffff8119ba1c>] destroy_inode+0x3c/0x70
[<ffffffff8119bb69>] evict+0x119/0x1b0
Signed-off-by: Sage Weil <sage@inktank.com>
Currently the fscache code expect the netfs to call fscache_readpages_or_alloc
inside the aops readpages callback. It marks all the pages in the list
provided by readahead with PG_private_2. In the cases that the netfs fails to
read all the pages (which is legal) it ends up returning to the readahead and
triggering a BUG. This happens because the page list still contains marked
pages.
This patch implements a simple fscache_readpages_cancel function that the netfs
should call before returning from readpages. It will revoke the pages from the
underlying cache backend and unmark them.
The problem was originally worked out in the Ceph devel tree, but it also
occurs in CIFS. It appears that NFS, AFS and 9P are okay as read_cache_pages()
will clean up the unprocessed pages in the case of an error.
This can be used to address the following oops:
[12410647.597278] BUG: Bad page state in process petabucket pfn:3d504e
[12410647.597292] page:ffffea000f541380 count:0 mapcount:0 mapping:
(null) index:0x0
[12410647.597298] page flags: 0x200000000001000(private_2)
[12410647.597334] Call Trace:
[12410647.597345] [<ffffffff815523f2>] dump_stack+0x19/0x1b
[12410647.597356] [<ffffffff8111def7>] bad_page+0xc7/0x120
[12410647.597359] [<ffffffff8111e49e>] free_pages_prepare+0x10e/0x120
[12410647.597361] [<ffffffff8111fc80>] free_hot_cold_page+0x40/0x170
[12410647.597363] [<ffffffff81123507>] __put_single_page+0x27/0x30
[12410647.597365] [<ffffffff81123df5>] put_page+0x25/0x40
[12410647.597376] [<ffffffffa02bdcf9>] ceph_readpages+0x2e9/0x6e0 [ceph]
[12410647.597379] [<ffffffff81122a8f>] __do_page_cache_readahead+0x1af/0x260
[12410647.597382] [<ffffffff81122ea1>] ra_submit+0x21/0x30
[12410647.597384] [<ffffffff81118f64>] filemap_fault+0x254/0x490
[12410647.597387] [<ffffffff8113a74f>] __do_fault+0x6f/0x4e0
[12410647.597391] [<ffffffff810125bd>] ? __switch_to+0x16d/0x4a0
[12410647.597395] [<ffffffff810865ba>] ? finish_task_switch+0x5a/0xc0
[12410647.597398] [<ffffffff8113d856>] handle_pte_fault+0xf6/0x930
[12410647.597401] [<ffffffff81008c33>] ? pte_mfn_to_pfn+0x93/0x110
[12410647.597403] [<ffffffff81008cce>] ? xen_pmd_val+0xe/0x10
[12410647.597405] [<ffffffff81005469>] ? __raw_callee_save_xen_pmd_val+0x11/0x1e
[12410647.597407] [<ffffffff8113f361>] handle_mm_fault+0x251/0x370
[12410647.597411] [<ffffffff812b0ac4>] ? call_rwsem_down_read_failed+0x14/0x30
[12410647.597414] [<ffffffff8155bffa>] __do_page_fault+0x1aa/0x550
[12410647.597418] [<ffffffff8108011d>] ? up_write+0x1d/0x20
[12410647.597422] [<ffffffff8113141c>] ? vm_mmap_pgoff+0xbc/0xe0
[12410647.597425] [<ffffffff81143bb8>] ? SyS_mmap_pgoff+0xd8/0x240
[12410647.597427] [<ffffffff8155c3ae>] do_page_fault+0xe/0x10
[12410647.597431] [<ffffffff81558818>] page_fault+0x28/0x30
Extend the fscache netfs API so that the netfs can ask as to whether a cache
object is up to date with respect to its corresponding netfs object:
int fscache_check_consistency(struct fscache_cookie *cookie)
This will call back to the netfs to check whether the auxiliary data associated
with a cookie is correct. It returns 0 if it is and -ESTALE if it isn't; it
may also return -ENOMEM and -ERESTARTSYS.
The backends now have to implement a mandatory operation pointer:
int (*check_consistency)(struct fscache_object *object)
that corresponds to the above API call. FS-Cache takes care of pinning the
object and the cookie in memory and managing this call with respect to the
object state.
Original-author: Hongyi Jia <jiayisuse@gmail.com>
cc: Hongyi Jia <jiayisuse@gmail.com>
cc: Milosz Tanski <milosz@adfin.com>
Under certain circumstances, spin_is_locked() is hardwired to 0 - even when the
code would normally be in a locked section where it should return 1. This
means it cannot be used for an assertion that checks that a spinlock is locked.
Remove such usages from FS-Cache.
The following oops might otherwise be observed:
BUG: failure at fs/fscache/operation.c:270/fscache_start_operations()!
Kernel panic - not syncing: BUG!
CPU: 0 PID: 10 Comm: kworker/u2:1 Not tainted 3.10.0-rc1-00133-ge7ebb75 #2
7f091c48 603c8947 7f090000 7f9b1361 7f25f080 00000001 7f26d440 7f091c90
60299eb8 7f091d90 602951c5 7f26d440 3000000008 7f091da0 7f091cc0 7f091cd0
00000007 00000007 00000006 7f091ae0 00000010 0000010e 7f9af330 7f091ae0
Call Trace:
7f091c88: [<60299eb8>] dump_stack+0x17/0x19
7f091c98: [<602951c5>] panic+0xf4/0x1e9
7f091d38: [<6002b10e>] set_signals+0x1e/0x40
7f091d58: [<6005b89e>] __wake_up+0x4e/0x70
7f091d98: [<7f9aa003>] fscache_start_operations+0x43/0x50 [fscache]
7f091da8: [<7f9aa1e3>] fscache_op_complete+0x1d3/0x220 [fscache]
7f091db8: [<60082985>] unlock_page+0x55/0x60
7f091de8: [<7fb25bb0>] cachefiles_read_copier+0x250/0x330 [cachefiles]
7f091e58: [<7f9ab03c>] fscache_op_work_func+0xac/0x120 [fscache]
7f091e88: [<6004d5b0>] process_one_work+0x250/0x3a0
7f091ef8: [<6004edc7>] worker_thread+0x177/0x2a0
7f091f38: [<6004ec50>] worker_thread+0x0/0x2a0
7f091f58: [<60054418>] kthread+0xd8/0xe0
7f091f68: [<6005bb27>] finish_task_switch.isra.64+0x37/0xa0
7f091fd8: [<600185cf>] new_thread_handler+0x8f/0xb0
Reported-by: Milosz Tanski <milosz@adfin.com>
Reviewed-and-tested-By: Milosz Tanski <milosz@adfin.com>
struct fscache_retrieval contains a count of the number of pages that still
need some processing (n_pages). This is decremented as the pages are
processed.
However, this needs to be atomic as fscache_retrieval_complete() (I think) just
occasionally may be called from cachefiles_read_backing_file() and
cachefiles_read_copier() simultaneously.
This happens when an fscache_read_or_alloc_pages() request containing a lot of
pages (say a couple of hundred) is being processed. The read on each backing
page is dispatched individually because we need to insert a monitor into the
waitqueue to catch when the read completes. However, under low-memory
conditions, we might be forced to wait in the allocator - and this gives the
I/O on the backing page a chance to complete first.
When the I/O completes, fscache_enqueue_retrieval() chucks the retrieval onto
the workqueue without waiting for the operation to finish the initial I/O
dispatch (we want to release any pages we can as soon as we can), thus both can
end up running simultaneously and potentially attempting to partially complete
the retrieval simultaneously (ENOMEM may occur, backing pages may already be in
the page cache).
This was demonstrated by parallelling the non-atomic counter with an atomic
counter and printing both of them when the assertion fails. At this point, the
atomic counter has reached zero, but the non-atomic counter has not.
To fix this, make the counter an atomic_t.
This results in the following bug appearing
3 == 5 is false
kernel BUG at fs/fscache/operation.c:421!
or
3 == 5 is false
kernel BUG at fs/fscache/operation.c:414!
With a backtrace like the following:
RIP: 0010:[<ffffffffa0211b1d>] fscache_put_operation+0x1ad/0x240 [fscache]
Call Trace:
[<ffffffffa0213185>] fscache_retrieval_work+0x55/0x270 [fscache]
[<ffffffffa0213130>] ? fscache_retrieval_work+0x0/0x270 [fscache]
[<ffffffff81090b10>] worker_thread+0x170/0x2a0
[<ffffffff81096d10>] ? autoremove_wake_function+0x0/0x40
[<ffffffff810909a0>] ? worker_thread+0x0/0x2a0
[<ffffffff81096966>] kthread+0x96/0xa0
[<ffffffff8100c0ca>] child_rip+0xa/0x20
[<ffffffff810968d0>] ? kthread+0x0/0xa0
[<ffffffff8100c0c0>] ? child_rip+0x0/0x20
Simplify the way fscache cache objects retain their cookie. The way I
implemented the cookie storage handling made synchronisation a pain (ie. the
object state machine can't rely on the cookie actually still being there).
Instead of the the object being detached from the cookie and the cookie being
freed in __fscache_relinquish_cookie(), we defer both operations:
(*) The detachment of the object from the list in the cookie now takes place
in fscache_drop_object() and is thus governed by the object state machine
(fscache_detach_from_cookie() has been removed).
(*) The release of the cookie is now in fscache_object_destroy() - which is
called by the cache backend just before it frees the object.
This means that the fscache_cookie struct is now available to the cache all the
way through from ->alloc_object() to ->drop_object() and ->put_object() -
meaning that it's no longer necessary to take object->lock to guarantee access.
However, __fscache_relinquish_cookie() doesn't wait for the object to go all
the way through to destruction before letting the netfs proceed. That would
massively slow down the netfs. Since __fscache_relinquish_cookie() leaves the
cookie around, in must therefore break all attachments to the netfs - which
includes ->def, ->netfs_data and any outstanding page read/writes.
To handle this, struct fscache_cookie now has an n_active counter:
(1) This starts off initialised to 1.
(2) Any time the cache needs to get at the netfs data, it calls
fscache_use_cookie() to increment it - if it is not zero. If it was zero,
then access is not permitted.
(3) When the cache has finished with the data, it calls fscache_unuse_cookie()
to decrement it. This does a wake-up on it if it reaches 0.
(4) __fscache_relinquish_cookie() decrements n_active and then waits for it to
reach 0. The initialisation to 1 in step (1) ensures that we only get
wake ups when we're trying to get rid of the cookie.
This leaves __fscache_relinquish_cookie() a lot simpler.
This fixes a problem in the current code whereby if fscache_invalidate() is
followed sufficiently quickly by fscache_relinquish_cookie() then it is
possible for __fscache_relinquish_cookie() to have detached the cookie from the
object and cleared the pointer before a thread is dispatched to process the
invalidation state in the object state machine.
Since the pending write clearance was deferred to the invalidation state to
make it asynchronous, we need to either wait in relinquishment for the stores
tree to be cleared in the invalidation state or we need to handle the clearance
in relinquishment.
Further, if the relinquishment code does clear the tree, then the invalidation
state need to make the clearance contingent on still having the cookie to hand
(since that's where the tree is rooted) and we have to prevent the cookie from
disappearing for the duration.
This can lead to an oops like the following:
BUG: unable to handle kernel NULL pointer dereference at 000000000000000c
RIP: 0010:[<ffffffff8151023e>] _spin_lock+0xe/0x30
CR2: 000000000000000c ...
Process kslowd002 (...)
Call Trace:
[<ffffffffa01c3278>] fscache_invalidate_writes+0x38/0xd0 [fscache]
[<ffffffff810096f0>] ? __switch_to+0xd0/0x320
[<ffffffff8105e759>] ? find_busiest_queue+0x69/0x150
[<ffffffff8110ddd4>] ? slow_work_enqueue+0x104/0x180
[<ffffffffa01c1303>] fscache_object_slow_work_execute+0x5e3/0x9d0 [fscache]
[<ffffffff81096b67>] ? bit_waitqueue+0x17/0xd0
[<ffffffff8110e233>] slow_work_execute+0x233/0x310
[<ffffffff8110e515>] slow_work_thread+0x205/0x360
[<ffffffff81096ca0>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8110e310>] ? slow_work_thread+0x0/0x360
[<ffffffff81096936>] kthread+0x96/0xa0
[<ffffffff810968a0>] ? kthread+0x0/0xa0
The parameter to fscache_invalidate_writes() was object->cookie which is NULL.
Tested-By: Milosz Tanski <milosz@adfin.com>
