path: root/fs/freevxfs
2005-11-08fs/freevxfs/: add #include'sAdrian Bunk
Every file should #include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] vxfs: use generic_ro_fopsChristoph Hellwig
No need to duplicate a generic readonly file ops table in befs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm: rename kmem_cache_s to kmem_cachePekka J Enberg
This patch renames struct kmem_cache_s to kmem_cache so we can start using it instead of kmem_cache_t typedef. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fs: convert kcalloc to kzallocPekka Enberg
This patch converts kcalloc(1, ...) calls to use the new kzalloc() function. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-20[PATCH] freevxfs: fix breakage introduced by symlink fixesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[PATCH] Fix up symlink function pointersAl Viro
This fixes up the symlink functions for the calling convention change: * afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs, smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link() * befs, smbfs, xfs - same for ->put_link() Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: minor cleanupsPekka Enberg
This patch addresses the following minor issues: - Typo in printk - Redundant casts - Use C99 struct initializers instead of memset - Parenthesis around return value - Use inline instead of __inline__ Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: remove 2.4 compatabilityPekka Enberg
This patch removes 2.4 compatability header from freevxfs. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: fix buffer_head leakPekka Enberg
- fix a buffer_head leak in vxfs_getfsh() - s/SLAB_KERNEL/GFP_KERNEL/ - check sb_bread() return value - drop pointless buffer-mapped() test. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
