Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
... and switch of the obvious get_sb_bdev() users to ->mount()
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All uses of the BKL in freevxfs were the result of a pushdown into
code that doesn't really need it. As Christoph points out, this
is a read-only file system, which eliminates most of the races in
readdir/lookup.
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Signed-off-by: Jan Blunck <jblunck@infradead.org>
Cc: Matthew Wilcox <matthew@wil.cx>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Do not use the fallback default_llseek() if the readdir operation of the
filesystem still uses the big kernel lock.
Since llseek() modifies
file->f_pos of the directory directly it may need locking to not confuse
readdir which usually uses file->f_pos directly as well
Since the special characteristics of the BKL (unlocked on schedule) are
not necessary in this case, the inode mutex can be used for locking as
provided by generic_file_llseek(). This is only possible since all
filesystems, except reiserfs, either use a directory as a flat file or
with disk address offsets. Reiserfs on the other hand uses a 32bit hash
off the filename as the offset so generic_file_llseek() can get used as
well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) -
blocksize).
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Anders Larsen <al@alarsen.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
Ensure fast symlink targets are NUL-terminated, even if corrupted
on-disk.
Signed-off-by: Duane Griffin <duaneg@dghda.com>
Move the extern declarations of several structs to vxfs_extern.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Christoph Hellwig <hch@infradead.org>
Stop the FreeVXFS filesystem from using iget() and read_inode(). Replace
vxfs_read_inode() with vxfs_iget(), and call that instead of iget().
vxfs_iget() then uses iget_locked() directly and returns a proper error code
instead of an inode in the event of an error.
vxfs_fill_super() returns any error incurred when getting the root inode
instead of EINVAL.
Acked-by: Christoph Hellwig <hch@lst.de>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
gcc-4.3:
fs/freevxfs/vxfs_lookup.c: In function 'vxfs_find_entry':
fs/freevxfs/vxfs_lookup.c:139: warning: cast from pointer to integer of different size
fs/freevxfs/vxfs_lookup.c: In function 'vxfs_readdir':
fs/freevxfs/vxfs_lookup.c:294: warning: cast from pointer to integer of different size
sb_read may return NULL, so let's explicitly check it.
Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org>
Ensure pages are uptodate after returning from read_cache_page, which allows
us to cut out most of the filesystem-internal PageUptodate calls.
I didn't have a great look down the call chains, but this appears to fixes 7
possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in
ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in
block2mtd. All depending on whether the filler is async and/or can return
with a !uptodate page.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
SLAB_KERNEL is an alias of GFP_KERNEL.
If register_filesystem() fails, vxfs_inode cache must be destroyed.
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The following patches reduce the size of the VFS inode structure by 28 bytes
on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction
in the inode size on a UP kernel that is configured in a production mode
(i.e., with no spinlock or other debugging functions enabled; if you want to
save memory taken up by in-core inodes, the first thing you should do is
disable the debugging options; they are responsible for a huge amount of bloat
in the VFS inode structure).
This patch:
The filesystem or device-specific pointer in the inode is inside a union,
which is pretty pointless given that all 30+ users of this field have been
using the void pointer. Get rid of the union and rename it to i_private, with
a comment to explain who is allowed to use the void pointer. This is just a
cleanup, but it allows us to reuse the union 'u' for something something where
the union will actually be used.
[judith@osdl.org: powerpc build fix]
Signed-off-by: Judith Lebzelter <judith@osdl.org>
Commit 7b2fd697427e73c81d5fa659efd91bd07d303b0e in the historical GIT tree
stopped calling the readdir member of a file_operations struct with the big
kernel lock held, and fixed up all the readdir functions to do their own
locking. However, that change added calls to unlock_kernel() in
vxfs_readdir, but no call to lock_kernel(). Fix this by adding a call to
lock_kernel().
Signed-off-by: Josh Triplett <josh@freedesktop.org>
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
Fix of some spelling errors in fs/freevxfs error messages and comments
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Add read_mapping_page() which is used for callers that pass
mapping->a_ops->readpage as the filler for read_cache_page. This removes
some duplication from filesystem code.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Cc: Roland Dreier <rolandd@cisco.com>
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD
memory spreading.
If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's
in a cpuset with the 'memory_spread_slab' option enabled goes to allocate
from such a slab cache, the allocations are spread evenly over all the
memory nodes (task->mems_allowed) allowed to that task, instead of favoring
allocation on the node local to the current cpu.
The following inode and similar caches are marked SLAB_MEM_SPREAD:
file cache
fs/adfs/super.c adfs_inode_cache
fs/affs/super.c affs_inode_cache
fs/befs/linuxvfs.c befs_inode_cache
fs/bfs/inode.c bfs_inode_cache
fs/block_dev.c bdev_cache
fs/cifs/cifsfs.c cifs_inode_cache
fs/coda/inode.c coda_inode_cache
fs/dquot.c dquot
fs/efs/super.c efs_inode_cache
fs/ext2/super.c ext2_inode_cache
fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr
fs/ext3/super.c ext3_inode_cache
fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr
fs/fat/cache.c fat_cache
fs/fat/inode.c fat_inode_cache
fs/freevxfs/vxfs_super.c vxfs_inode
fs/hpfs/super.c hpfs_inode_cache
fs/isofs/inode.c isofs_inode_cache
fs/jffs/inode-v23.c jffs_fm
fs/jffs2/super.c jffs2_i
fs/jfs/super.c jfs_ip
fs/minix/inode.c minix_inode_cache
fs/ncpfs/inode.c ncp_inode_cache
fs/nfs/direct.c nfs_direct_cache
fs/nfs/inode.c nfs_inode_cache
fs/ntfs/super.c ntfs_big_inode_cache_name
fs/ntfs/super.c ntfs_inode_cache
fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache
fs/ocfs2/super.c ocfs2_inode_cache
fs/proc/inode.c proc_inode_cache
fs/qnx4/inode.c qnx4_inode_cache
fs/reiserfs/super.c reiser_inode_cache
fs/romfs/inode.c romfs_inode_cache
fs/smbfs/inode.c smb_inode_cache
fs/sysv/inode.c sysv_inode_cache
fs/udf/super.c udf_inode_cache
fs/ufs/super.c ufs_inode_cache
net/socket.c sock_inode_cache
net/sunrpc/rpc_pipe.c rpc_inode_cache
The choice of which slab caches to so mark was quite simple. I marked
those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache,
inode_cache, and buffer_head, which were marked in a previous patch. Even
though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same
potentially large file system i/o related slab caches as we need for memory
spreading.
Given that the rule now becomes "wherever you would have used a
SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use
the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain.
Future file system writers will just copy one of the existing file system
slab cache setups and tend to get it right without thinking.
Signed-off-by: Paul Jackson <pj@sgi.com>
We've had two instances recently of overflows when doing
64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT)
I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result.
- afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken.
- jfs and jffs are limited to 4GB anyway.
- reiserfs map_block_for_writepage() takes an unsigned long for the block -
it should take sector_t. (It'll fail for huge filesystems with
blocksize<PAGE_CACHE_SIZE)
- cramfs_read() needs to use sector_t (I think cramsfs is busted on large
filesystems anyway)
- affs is limited in file size anyway.
- I generally didn't fix 32-bit overflows in directory operations.
- arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G?
- gss_wrap_req_priv() needs checking (snd_buf->page_base)
Cc: Oleg Drokin <green@linuxhacker.ru>
Cc: <reiserfs-dev@namesys.com>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Every file should #include the headers containing the prototypes for
it's global functions.
No need to duplicate a generic readonly file ops table in befs.
This patch renames struct kmem_cache_s to kmem_cache so we can start using
it instead of kmem_cache_t typedef.
