path: root/fs/file_table.c
2018-08-21Merge tag 'ovl-update-4.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs Pull overlayfs updates from Miklos Szeredi: "This contains two new features: - Stack file operations: this allows removal of several hacks from the VFS, proper interaction of read-only open files with copy-up, possibility to implement fs modifying ioctls properly, and others. - Metadata only copy-up: when file is on lower layer and only metadata is modified (except size) then only copy up the metadata and continue to use the data from the lower file" * tag 'ovl-update-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: (66 commits) ovl: Enable metadata only feature ovl: Do not do metacopy only for ioctl modifying file attr ovl: Do not do metadata only copy-up for truncate operation ovl: add helper to force data copy-up ovl: Check redirect on index as well ovl: Set redirect on upper inode when it is linked ovl: Set redirect on metacopy files upon rename ovl: Do not set dentry type ORIGIN for broken hardlinks ovl: Add an inode flag OVL_CONST_INO ovl: Treat metacopy dentries as type OVL_PATH_MERGE ovl: Check redirects for metacopy files ovl: Move some dir related ovl_lookup_single() code in else block ovl: Do not expose metacopy only dentry from d_real() ovl: Open file with data except for the case of fsync ovl: Add helper ovl_inode_realdata() ovl: Store lower data inode in ovl_inode ovl: Fix ovl_getattr() to get number of blocks from lower ovl: Add helper ovl_dentry_lowerdata() to get lower data dentry ovl: Copy up meta inode data from lowest data inode ovl: Modify ovl_lookup() and friends to lookup metacopy dentry ...
2018-07-18vfs: make open_with_fake_path() not contribute to nr_filesMiklos Szeredi
Stacking file operations in overlay will store an extra open file for each overlay file opened. The overhead is just that of "struct file" which is about 256bytes, because overlay already pins an extra dentry and inode when the file is open, which add up to a much larger overhead. For fear of breaking working setups, don't start accounting the extra file. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-07-12make alloc_file() staticAl Viro
Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12new helper: alloc_file_clone()Al Viro
alloc_file_clone(old_file, mode, ops): create a new struct file with ->f_path equal to that of old_file. pipe converted. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12new wrapper: alloc_file_pseudo()Al Viro
takes inode, vfsmount, name, O_... flags and file_operations and either returns a new struct file (in which case inode reference we held is consumed) or returns ERR_PTR(), in which case no refcounts are altered. converted aio_private_file() and sock_alloc_file() to it Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12fold put_filp() into fput()Al Viro
Just check FMODE_OPENED in __fput() and be done with that... Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12introduce FMODE_OPENEDAl Viro
basically, "is that instance set up enough for regular fput(), or do we want put_filp() for that one". NOTE: the only alloc_file() caller that could be followed by put_filp() is in arch/ia64/kernel/perfmon.c, which is (Kconfig-level) broken. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12pass ->f_flags value to alloc_empty_file()Al Viro
... and have it set the f_flags-derived part of ->f_mode. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12pass creds to get_empty_filp(), make sure dentry_open() passes the right credsAl Viro
... and rename get_empty_filp() to alloc_empty_file(). dentry_open() gets creds as argument, but the only thing that sees those is security_file_open() - file->f_cred still ends up with current_cred(). For almost all callers it's the same thing, but there are several broken cases. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-12alloc_file(): switch to passing O_... flags instead of FMODE_... modeAl Viro
... so that it could set both ->f_flags and ->f_mode, without callers having to set ->f_flags manually. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-07-10fold security_file_free() into file_free()Al Viro
.. and the call of file_free() in case of security_file_alloc() failure in get_empty_filp() should be simply file_free_rcu() - no point in rcu-delays there, anyway. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-12-07vfs: remove unused hardirq.hYang Shi
Preempt counter APIs have been split out, currently, hardirq.h just includes irq_enter/exit APIs which are not used by vfs at all. So, remove the unused hardirq.h. Signed-off-by: Yang Shi <yang.s@alibaba-inc.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-11-15fs, mm: account filp cache to kmemcgShakeel Butt
The allocations from filp cache can be directly triggered by userspace applications. A buggy application can consume a significant amount of unaccounted system memory. Though we have not noticed such buggy applications in our production but upon close inspection, we found that a lot of machines spend very significant amount of memory on these caches. One way to limit allocations from filp cache is to set system level limit of maximum number of open files. However this limit is shared between different users on the system and one user can hog this resource. To cater that, we can charge filp to kmemcg and set the maximum limit very high and let the memory limit of each user limit the number of files they can open and indirectly limiting their allocations from filp cache. One side effect of this change is that it will allow _sysctl() to return ENOMEM and the man page of _sysctl() does not specify that. However the man page also discourages to use _sysctl() at all. Link: http://lkml.kernel.org/r/20171011190359.34926-1-shakeelb@google.com Signed-off-by: Shakeel Butt <shakeelb@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-08ima: call ima_file_free() prior to calling fasyncMimi Zohar
The file hash is calculated and written out as an xattr after calling fasync(). In order for the file data and metadata to be written out to disk at the same time, this patch calculates the file hash and stores it as an xattr before calling fasync. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2017-08-28fput: Don't reinvent the wheel but use existing llist APIByungchul Park
Although llist provides proper APIs, they are not used. Make them used. Signed-off-by: Byungchul Park <byungchul.park@lge.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-07-06fs: new infrastructure for writeback error handling and reportingJeff Layton
Most filesystems currently use mapping_set_error and filemap_check_errors for setting and reporting/clearing writeback errors at the mapping level. filemap_check_errors is indirectly called from most of the filemap_fdatawait_* functions and from filemap_write_and_wait*. These functions are called from all sorts of contexts to wait on writeback to finish -- e.g. mostly in fsync, but also in truncate calls, getattr, etc. The non-fsync callers are problematic. We should be reporting writeback errors during fsync, but many places spread over the tree clear out errors before they can be properly reported, or report errors at nonsensical times. If I get -EIO on a stat() call, there is no reason for me to assume that it is because some previous writeback failed. The fact that it also clears out the error such that a subsequent fsync returns 0 is a bug, and a nasty one since that's potentially silent data corruption. This patch adds a small bit of new infrastructure for setting and reporting errors during address_space writeback. While the above was my original impetus for adding this, I think it's also the case that current fsync semantics are just problematic for userland. Most applications that call fsync do so to ensure that the data they wrote has hit the backing store. In the case where there are multiple writers to the file at the same time, this is really hard to determine. The first one to call fsync will see any stored error, and the rest get back 0. The processes with open fds may not be associated with one another in any way. They could even be in different containers, so ensuring coordination between all fsync callers is not really an option. One way to remedy this would be to track what file descriptor was used to dirty the file, but that's rather cumbersome and would likely be slow. However, there is a simpler way to improve the semantics here without incurring too much overhead. This set adds an errseq_t to struct address_space, and a corresponding one is added to struct file. Writeback errors are recorded in the mapping's errseq_t, and the one in struct file is used as the "since" value. This changes the semantics of the Linux fsync implementation such that applications can now use it to determine whether there were any writeback errors since fsync(fd) was last called (or since the file was opened in the case of fsync having never been called). Note that those writeback errors may have occurred when writing data that was dirtied via an entirely different fd, but that's the case now with the current mapping_set_error/filemap_check_error infrastructure. This will at least prevent you from getting a false report of success. The new behavior is still consistent with the POSIX spec, and is more reliable for application developers. This patch just adds some basic infrastructure for doing this, and ensures that the f_wb_err "cursor" is properly set when a file is opened. Later patches will change the existing code to use this new infrastructure for reporting errors at fsync time. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz>
2017-03-02sched/headers: Prepare to remove <linux/cred.h> inclusion from <linux/sched.h>Ingo Molnar
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h doing that for them. Note that even if the count where we need to add extra headers seems high, it's still a net win, because <linux/sched.h> is included in over 2,200 files ... Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-05constify alloc_file()Al Viro
2015-08-07fs, file table: reinit files_stat.max_files after deferred memory initialisationMel Gorman
Dave Hansen reported the following; My laptop has been behaving strangely with 4.2-rc2. Once I log in to my X session, I start getting all kinds of strange errors from applications and see this in my dmesg: VFS: file-max limit 8192 reached The problem is that the file-max is calculated before memory is fully initialised and miscalculates how much memory the kernel is using. This patch recalculates file-max after deferred memory initialisation. Note that using memory hotplug infrastructure would not have avoided this problem as the value is not recalculated after memory hot-add. 4.1: files_stat.max_files = 6582781 4.2-rc2: files_stat.max_files = 8192 4.2-rc2 patched: files_stat.max_files = 6562467 Small differences with the patch applied and 4.1 but not enough to matter. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Dave Hansen <dave.hansen@intel.com> Cc: Nicolai Stange <nicstange@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Alex Ng <alexng@microsoft.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23remove the pointless include of lglock.hAl Viro
2015-04-11->aio_read and ->aio_write removedAl Viro
no remaining users Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The big thing in this pile is Eric's unmount-on-rmdir series; we finally have everything we need for that. The final piece of prereqs is delayed mntput() - now filesystem shutdown always happens on shallow stack. Other than that, we have several new primitives for iov_iter (Matt Wilcox, culled from his XIP-related series) pushing the conversion to ->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c cleanups and fixes (including the external name refcounting, which gives consistent behaviour of d_move() wrt procfs symlinks for long and short names alike) and assorted cleanups and fixes all over the place. This is just the first pile; there's a lot of stuff from various people that ought to go in this window. Starting with unionmount/overlayfs mess... ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits) fs/file_table.c: Update alloc_file() comment vfs: Deduplicate code shared by xattr system calls operating on paths reiserfs: remove pointless forward declaration of struct nameidata don't need that forward declaration of struct nameidata in dcache.h anymore take dname_external() into fs/dcache.c let path_init() failures treated the same way as subsequent link_path_walk() fix misuses of f_count() in ppp and netlink ncpfs: use list_for_each_entry() for d_subdirs walk vfs: move getname() from callers to do_mount() gfs2_atomic_open(): skip lookups on hashed dentry [infiniband] remove pointless assignments gadgetfs: saner API for gadgetfs_create_file() f_fs: saner API for ffs_sb_create_file() jfs: don't hash direct inode [s390] remove pointless assignment of ->f_op in vmlogrdr ->open() ecryptfs: ->f_op is never NULL android: ->f_op is never NULL nouveau: __iomem misannotations missing annotation in fs/file.c fs: namespace: suppress 'may be used uninitialized' warnings ...
2014-10-12fs/file_table.c: Update alloc_file() commentEric Biggers
This comment is 5 years outdated; init_file() no longer exists. Signed-off-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-06fs: convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06new methods: ->read_iter() and ->write_iter()Al Viro
Beginning to introduce those. Just the callers for now, and it's clumsier than it'll eventually become; once we finish converting aio_read and aio_write instances, the things will get nicer. For now, these guys are in parallel to ->aio_read() and ->aio_write(); they take iocb and iov_iter, with everything in iov_iter already validated. File offset is passed in iocb->ki_pos, iov/nr_segs - in iov_iter. Main concerns in that series are stack footprint and ability to split the damn thing cleanly. [fix from Peter Ujfalusi <peter.ujfalusi@ti.com> folded] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06replace checking for ->read/->aio_read presence with check in ->f_modeAl Viro
Since we are about to introduce new methods (read_iter/write_iter), the tests in a bunch of places would have to grow inconveniently. Check once (at open() time) and store results in ->f_mode as FMODE_CAN_READ and FMODE_CAN_WRITE resp. It might end up being a temporary measure - once everything switches from ->aio_{read,write} to ->{read,write}_iter it might make sense to return to open-coded checks. We'll see... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-04Merge branch 'locks-3.15' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking updates from Jeff Layton: "Highlights: - maintainership change for fs/locks.c. Willy's not interested in maintaining it these days, and is OK with Bruce and I taking it. - fix for open vs setlease race that Al ID'ed - cleanup and consolidation of file locking code - eliminate unneeded BUG() call - merge of file-private lock implementation" * 'locks-3.15' of git://git.samba.org/jlayton/linux: locks: make locks_mandatory_area check for file-private locks locks: fix locks_mandatory_locked to respect file-private locks locks: require that flock->l_pid be set to 0 for file-private locks locks: add new fcntl cmd values for handling file private locks locks: skip deadlock detection on FL_FILE_PVT locks locks: pass the cmd value to fcntl_getlk/getlk64 locks: report l_pid as -1 for FL_FILE_PVT locks locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT" locks: rename locks_remove_flock to locks_remove_file locks: consolidate checks for compatible filp->f_mode values in setlk handlers locks: fix posix lock range overflow handling locks: eliminate BUG() call when there's an unexpected lock on file close locks: add __acquires and __releases annotations to locks_start and locks_stop locks: remove "inline" qualifier from fl_link manipulation functions locks: clean up comment typo locks: close potential race between setlease and open MAINTAINERS: update entry for fs/locks.c
2014-04-01get rid of files_defer_init()Al Viro
the only thing it's doing these days is calculation of upper limit for fs.nr_open sysctl and that can be done statically Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01mark struct file that had write access grabbed by open()Al Viro
new flag in ->f_mode - FMODE_WRITER. Set by do_dentry_open() in case when it has grabbed write access, checked by __fput() to decide whether it wants to drop the sucker. Allows to stop bothering with mnt_clone_write() in alloc_file(), along with fewer special_file() checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01get rid of DEBUG_WRITECOUNTAl Viro
it only makes control flow in __fput() and friends more convoluted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01don't bother with {get,put}_write_access() on non-regular filesAl Viro
it's pointless and actually leads to wrong behaviour in at least one moderately convoluted case (pipe(), close one end, try to get to another via /proc/*/fd and run into ETXTBUSY). Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-31locks: rename locks_remove_flock to locks_remove_fileJeff Layton
This function currently removes leases in addition to flock locks and in a later patch we'll have it deal with file-private locks too. Rename it to locks_remove_file to indicate that it removes locks that are associated with a particular struct file, and not just flock locks. Acked-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-03-10vfs: atomic f_pos accesses as per POSIXLinus Torvalds
Our write() system call has always been atomic in the sense that you get the expected thread-safe contiguous write, but we haven't actually guaranteed that concurrent writes are serialized wrt f_pos accesses, so threads (or processes) that share a file descriptor and use "write()" concurrently would quite likely overwrite each others data. This violates POSIX.1-2008/SUSv4 Section XSI 2.9.7 that says: "2.9.7 Thread Interactions with Regular File Operations All of the following functions shall be atomic with respect to each other in the effects specified in POSIX.1-2008 when they operate on regular files or symbolic links: [...]" and one of the effects is the file position update. This unprotected file position behavior is not new behavior, and nobody has ever cared. Until now. Yongzhi Pan reported unexpected behavior to Michael Kerrisk that was due to this. This resolves the issue with a f_pos-specific lock that is taken by read/write/lseek on file descriptors that may be shared across threads or processes. Reported-by: Yongzhi Pan <panyongzhi@gmail.com> Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-09get rid of s_files and files_lockAl Viro
The only thing we need it for is alt-sysrq-r (emergency remount r/o) and these days we can do just as well without going through the list of files. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24file->f_op is never NULL...Al Viro
2013-10-20nfsd regression since delayed fput()Al Viro
Background: nfsd v[23] had throughput regression since delayed fput went in; every read or write ends up doing fput() and we get a pair of extra context switches out of that (plus quite a bit of work in queue_work itselfi, apparently). Use of schedule_delayed_work() gives it a chance to accumulate a bit before we do __fput() on all of them. I'm not too happy about that solution, but... on at least one real-world setup it reverts about 10% throughput loss we got from switch to delayed fput. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-11fs/file_table.c:fput(): make comment more truthfulAndrew Morton
Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-03only regular files with FMODE_WRITE need to be on s_filesAl Viro
2013-07-13fput: turn "list_head delayed_fput_list" into llist_headOleg Nesterov
fput() and delayed_fput() can use llist and avoid the locking. This is unlikely path, it is not that this change can improve the performance, but this way the code looks simpler. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13fs/file_table.c:fput(): add commentAndrew Morton
A missed update to "fput: task_work_add() can fail if the caller has passed exit_task_work()". Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: David Howells <dhowells@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29Replace a bunch of file->dentry->d_inode refs with file_inode()David Howells
Replace a bunch of file->dentry->d_inode refs with file_inode(). In __fput(), use file->f_inode instead so as not to be affected by any tricks that file_inode() might grow. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-15fput: task_work_add() can fail if the caller has passed exit_task_work()Oleg Nesterov
fput() assumes that it can't be called after exit_task_work() but this is not true, for example free_ipc_ns()->shm_destroy() can do this. In this case fput() silently leaks the file. Change it to fallback to delayed_fput_work if task_work_add() fails. The patch looks complicated but it is not, it changes the code from if (PF_KTHREAD) { schedule_work(...); return; } task_work_add(...) to if (!PF_KTHREAD) { if (!task_work_add(...)) return; /* fallback */ } schedule_work(...); As for shm_destroy() in particular, we could make another fix but I think this change makes sense anyway. There could be another similar user, it is not safe to assume that task_work_add() can't fail. Reported-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-01cache the value of file_inode() in struct fileAl Viro
Note that this thing does *not* contribute to inode refcount; it's pinned down by dentry. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22fs: Preserve error code in get_empty_filp(), part 2Anatol Pomozov
Allocating a file structure in function get_empty_filp() might fail because of several reasons: - not enough memory for file structures - operation is not allowed - user is over its limit Currently the function returns NULL in all cases and we loose the exact reason of the error. All callers of get_empty_filp() assume that the function can fail with ENFILE only. Return error through pointer. Change all callers to preserve this error code. [AV: cleaned up a bit, carved the get_empty_filp() part out into a separate commit (things remaining here deal with alloc_file()), removed pipe(2) behaviour change] Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22propagate error from get_empty_filp() to its callersAl Viro
Based on parts from Anatol's patch (the rest is the next commit). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
