path: root/fs/fcntl.c
2009-05-11dup2: Fix return value with oldfd == newfd and invalid fdJeff Mahoney
The return value of dup2 when oldfd == newfd and the fd isn't valid is not getting properly sign extended. We end up with 4294967287 instead of -EBADF. I've reproduced this on SLE11 (2.6.27.21), openSUSE Factory (2.6.29-rc5), and Ubuntu 9.04 (2.6.28). This patch uses a signed int for the error value so it is properly extended. Commit 6c5d0512a091480c9f981162227fdb1c9d70e555 introduced this regression. Reported-by: Jiri Dluhos <jdluhos@novell.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Fix a lockdep warning in fasync_helper()Jonathan Corbet
Lockdep gripes if file->f_lock is taken in a no-IRQ situation, since that is not always the case. We don't really want to disable IRQs for every acquisition of f_lock; instead, just move it outside of fasync_lock. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Move FASYNC bit handling to f_op->fasync()Jonathan Corbet
Removing the BKL from FASYNC handling ran into the challenge of keeping the setting of the FASYNC bit in filp->f_flags atomic with regard to calls to the underlying fasync() function. Andi Kleen suggested moving the handling of that bit into fasync(); this patch does exactly that. As a result, we have a couple of internal API changes: fasync() must now manage the FASYNC bit, and it will be called without the BKL held. As it happens, every fasync() implementation in the kernel with one exception calls fasync_helper(). So, if we make fasync_helper() set the FASYNC bit, we can avoid making any changes to the other fasync() functions - as long as those functions, themselves, have proper locking. Most fasync() implementations do nothing but call fasync_helper() - which has its own lock - so they are easily verified as correct. The BKL had already been pushed down into the rest. The networking code has its own version of fasync_helper(), so that code has been augmented with explicit FASYNC bit handling. Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: David Miller <davem@davemloft.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-14[CVE-2009-0029] System call wrappers part 15Heiko Carstens
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-05Fix a race condition in FASYNC handlingJonathan Corbet
Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync() functions without the BKL) introduced a race which could leave file->f_flags in a state inconsistent with what the underlying driver/filesystem believes. Revert that change, and also fix the same races in ioctl_fioasync() and ioctl_fionbio(). This is a minimal, short-term fix; the real fix will not involve the BKL. Reported-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the filesystem subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-01[PATCH] clean dup2() up a bitAl Viro
2008-08-01[PATCH] merge locate_fd() and get_unused_fd()Al Viro
New primitive: alloc_fd(start, flags). get_unused_fd() and get_unused_fd_flags() become wrappers on top of it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] fix RLIM_NOFILE handlingAl Viro
* dup2() should return -EBADF on exceeded sysctl_nr_open * dup() should *not* return -EINVAL even if you have rlimit set to 0; it should get -EMFILE instead. Check for orig_start exceeding rlimit taken to sys_fcntl(). Failing expand_files() in dup{2,3}() now gets -EMFILE remapped to -EBADF. Consequently, remaining checks for rlimit are taken to expand_files(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] get rid of corner case in dup3() entirelyAl Viro
Since Ulrich is OK with getting rid of dup3(fd, fd, flags) completely, to hell the damn thing goes. Corner case for dup2() is handled in sys_dup2() (complete with -EBADF if dup2(fd, fd) is called with fd that is not open), the rest is done in dup3(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] dup3 fixUlrich Drepper
Al Viro notice one cornercase that the new dup3() code. The dup2() function, as a special case, handles dup-ing to the same file descriptor. In this case the current dup3() code does nothing at all. I.e., it ingnores the flags parameter. This shouldn't happen, the close-on-exec flag should be set if requested. In case the O_CLOEXEC bit in the flags parameter is not set the dup3() function should behave in this respect identical to dup2(). This means dup3(fd, fd, 0) should not actively reset the c-o-e flag. The patch below implements this minor change. [AV: credits to Artur Grabowski for bringing that up as potential subtle point in dup2() behaviour] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-24flag parameters: dup2Ulrich Drepper
This patch adds the new dup3 syscall. It extends the old dup2 syscall by one parameter which is meant to hold a flag value. Support for the O_CLOEXEC flag is added in this patch. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_dup3 # ifdef __x86_64__ # define __NR_dup3 292 # elif defined __i386__ # define __NR_dup3 330 # else # error "need __NR_dup3" # endif #endif int main (void) { int fd = syscall (__NR_dup3, 1, 4, 0); if (fd == -1) { puts ("dup3(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("dup3(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_dup3, 1, 4, O_CLOEXEC); if (fd == -1) { puts ("dup3(O_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("dup3(O_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02Call fasync() functions without the BKLJonathan Corbet
lock_kernel() calls have been pushed down into code which needs it, so there is no need to take the BKL at this level anymore. This work inspired and aided by Andi Kleen's unlocked_fasync() patches. Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-25[PATCH] sanitize locate_fd()Al Viro
* 'file' argument is unused; lose it. * move setting flags from the caller (dupfd()) to locate_fd(); pass cloexec flag as new argument. Note that files_fdtable() that used to be in dupfd() isn't needed in the place in locate_fd() where the moved code ends up - we know that ->file_lock hadn't been dropped since the last time we calculated fdt because we can get there only if expand_files() returns 0 and it doesn't drop/reacquire in that case. * move getting/dropping ->file_lock into locate_fd(). Now the caller doesn't need to do anything with files_struct *files anymore and we can move that inside locate_fd() as well, killing the struct files_struct * argument. At that point locate_fd() is extremely similar to get_unused_fd_flags() and the next patches will merge those two. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08fs: remove fastcall, it is always emptyHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Pidns: make full use of xxx_vnr() callsPavel Emelyanov
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were _all_ converted to operate on the current pid namespace. After this each call like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo) one. Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where appropriate. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17F_DUPFD_CLOEXEC implementationUlrich Drepper
One more small change to extend the availability of creation of file descriptors with FD_CLOEXEC set. Adding a new command to fcntl() requires no new system call and the overall impact on code size if minimal. If this patch gets accepted we will also add this change to the next revision of the POSIX spec. To test the patch, use the following little program. Adjust the value of F_DUPFD_CLOEXEC appropriately. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #ifndef F_DUPFD_CLOEXEC # define F_DUPFD_CLOEXEC 12 #endif int main (int argc, char *argv[]) { if (argc > 1) { if (fcntl (3, F_GETFD) == 0) { puts ("descriptor not closed"); exit (1); } if (errno != EBADF) { puts ("error not EBADF"); exit (1); } exit (0); } int fd = fcntl (STDOUT_FILENO, F_DUPFD_CLOEXEC, 0); if (fd == -1 && errno == EINVAL) { puts ("F_DUPFD_CLOEXEC not supported"); return 0; } if (fd != 3) { puts ("program called with descriptors other than 0,1,2"); return 1; } execl ("/proc/self/exe", "/proc/self/exe", "1", NULL); puts ("execl failed"); return 1; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] file: Add locking to f_getownEric W. Biederman
This has been needed for a long time, but now with the advent of a reference counted struct pid there are real consequences for getting this wrong. Someone I think it was Oleg Nesterov pointed out that this construct was missing locking, when I introduced struct pid. After taking time to review the locking construct already present I figured out which lock needs to be taken. The other paths that access f_owner.pid take either the f_owner read or the write lock. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] file: modify struct fown_struct to use a struct pidEric W. Biederman
File handles can be requested to send sigio and sigurg to processes. By tracking the destination processes using struct pid instead of pid_t we make the interface safe from all potential pid wrap around problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in fs/fcntl.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner and can better optimized away Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-26[PATCH] Use __read_mostly on some hot fs variablesEric Dumazet
I discovered on oprofile hunting on a SMP platform that dentry lookups were slowed down because d_hash_mask, d_hash_shift and dentry_hashtable were in a cache line that contained inodes_stat. So each time inodes_stats is changed by a cpu, other cpus have to refill their cache line. This patch moves some variables to the __read_mostly section, in order to avoid false sharing. RCU dentry lookups can go full speed. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Shrinks sizeof(files_struct) and better layoutEric Dumazet
1) Reduce the size of (struct fdtable) to exactly 64 bytes on 32bits platforms, lowering kmalloc() allocated space by 50%. 2) Reduce the size of (files_struct), using a special 32 bits (or 64bits) embedded_fd_set, instead of a 1024 bits fd_set for the close_on_exec_init and open_fds_init fields. This save some ram (248 bytes per task) as most tasks dont open more than 32 files. D-Cache footprint for such tasks is also reduced to the minimum. 3) Reduce size of allocated fdset. Currently two full pages are allocated, that is 32768 bits on x86 for example, and way too much. The minimum is now L1_CACHE_BYTES. UP and SMP should benefit from this patch, because most tasks will touch only one cache line when open()/close() stdin/stdout/stderr (0/1/2), (next_fd, close_on_exec_init, open_fds_init, fd_array[0 .. 2] being in the same cache line) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] fcntl F_SETFL and read-only IS_APPEND filesdean gaudet
There is code in setfl() which attempts to preserve the O_APPEND flag on IS_APPEND files... however IS_APPEND files could also be opened O_RDONLY and in that case setfl() should not require O_APPEND... coreutils 5.93 tail -f attempts to set O_NONBLOCK even on regular files... unfortunately if you try this on an append-only log file the result is this: fcntl64(3, F_GETFL) = 0x8000 (flags O_RDONLY|O_LARGEFILE) fcntl64(3, F_SETFL, O_RDONLY|O_NONBLOCK|O_LARGEFILE) = -1 EPERM (Operation not permitted) I offer up the patch below as one way of fixing the problem... i've tested it fixes the problem with tail -f but haven't really tested beyond that. (I also reported the coreutils bug upstream... it shouldn't fail imho... <https://savannah.gnu.org/bugs/index.php?func=detailitem&item_id=15473>) Signed-off-by: dean gaudet <dean@arctic.org> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] sigio: cleanup, don't take tasklist twiceOleg Nesterov
The only user of send_sigio_to_task() already holds tasklist_lock, so it is better not to send the signal via send_group_sig_info() (which takes tasklist recursively) but use group_send_sig_info(). The same change in send_sigurg()->send_sigurg_to_task(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: lock-free fd look-upDipankar Sarma
With the use of RCU in files structure, the look-up of files using fds can now be lock-free. The lookup is protected by rcu_read_lock()/rcu_read_unlock(). This patch changes the readers to use lock-free lookup. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: files struct with RCUDipankar Sarma
Patch to eliminate struct files_struct.file_lock spinlock on the reader side and use rcu refcounting rcuref_xxx api for the f_count refcounter. The updates to the fdtable are done by allocating a new fdtable structure and setting files->fdt to point to the new structure. The fdtable structure is protected by RCU thereby allowing lock-free lookup. For fd arrays/sets that are vmalloced, we use keventd to free them since RCU callbacks can't sleep. A global list of fdtable to be freed is not scalable, so we use a per-cpu list. If keventd is already handling the current cpu's work, we use a timer to defer queueing of that work. Since the last publication, this patch has been re-written to avoid using explicit memory barriers and use rcu_assign_pointer(), rcu_dereference() premitives instead. This required that the fd information is kept in a separate structure (fdtable) and updated atomically. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] stale POSIX lock handlingPeter Staubach
I believe that there is a problem with the handling of POSIX locks, which the attached patch should address. The problem appears to be a race between fcntl(2) and close(2). A multithreaded application could close a file descriptor at the same time as it is trying to acquire a lock using the same file descriptor. I would suggest that that multithreaded application is not providing the proper synchronization for itself, but the OS should still behave correctly. SUS3 (Single UNIX Specification Version 3, read: POSIX) indicates that when a file descriptor is closed, that all POSIX locks on the file, owned by the process which closed the file descriptor, should be released. The trick here is when those locks are released. The current code releases all locks which exist when close is processing, but any locks in progress are handled when the last reference to the open file is released. There are three cases to consider. One is the simple case, a multithreaded (mt) process has a file open and races to close it and acquire a lock on it. In this case, the close will release one reference to the open file and when the fcntl is done, it will release the other reference. For this situation, no locks should exist on the file when both the close and fcntl operations are done. The current system will handle this case because the last reference to the open file is being released. The second case is when the mt process has dup(2)'d the file descriptor. The close will release one reference to the file and the fcntl, when done, will release another, but there will still be at least one more reference to the open file. One could argue that the existence of a lock on the file after the close has completed is okay, because it was acquired after the close operation and there is still a way for the application to release the lock on the file, using an existing file descriptor. The third case is when the mt process has forked, after opening the file and either before or after becoming an mt process. In this case, each process would hold a reference to the open file. For each process, this degenerates to first case above. However, the lock continues to exist until both processes have released their references to the open file. This lock could block other lock requests. The changes to release the lock when the last reference to the open file aren't quite right because they would allow the lock to exist as long as there was a reference to the open file. This is too long. The new proposed solution is to add support in the fcntl code path to detect a race with close and then to release the lock which was just acquired when such as race is detected. This causes locks to be released in a timely fashion and for the system to conform to the POSIX semantic specification. This was tested by instrumenting a kernel to detect the handling locks and then running a program which generates case #3 above. A dangling lock could be reliably generated. When the changes to detect the close/fcntl race were added, a dangling lock could no longer be generated. Cc: Matthew Wilcox <willy@debian.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] AYSNC IO using singals other than SIGIOBharath Ramesh
A question on sigwaitinfo based IO mechanism in multithreaded applications. I am trying to use RT signals to notify me of IO events using RT signals instead of SIGIO in a multithreaded applications. I noticed that there was some discussion on lkml during november 1999 with the subject of the discussion as "Signal driven IO". In the thread I noticed that RT signals were being delivered to the worker thread. I am running 2.6.10 kernel and I am trying to use the very same mechanism and I find that only SIGIO being propogated to the worker threads and RT signals only being propogated to the main thread and not the worker threads where I actually want them to be propogated too. On further inspection I found that the following patch which I have attached solves the problem. I am not sure if this is a bug or feature in the kernel. Roland McGrath <roland@redhat.com> said: This relates only to fcntl F_SETSIG, which is a Linux extension. So there is no POSIX issue. When changing various things like the normal SIGIO signalling to do group signals, I was concerned strictly with the POSIX semantics and generally avoided touching things in the domain of Linux inventions. That's why I didn't change this when I changed the call right next to it. There is no reason I can see that F_SETSIG-requested signals shouldn't use a group signal like normal SIGIO does. I'm happy to ACK this patch, there is nothing wrong with its change to the semantics in my book. But neither POSIX nor I care a whit what F_SETSIG does. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
