path: root/fs/fat
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-02Make FAT users happier by not deadlockingJonathan Corbet
The FAT BKL removal patch can cause deadlocks. It turns out that the new lock_super() calls are unneeded, remove them (as directed by Linus). Reported-by: "Tony Luck" <tony.luck@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-06-20Replace BKL with superblock lock in fat/msdos/vfatLinus Torvalds
This replaces the use of the BKL in the FAT family of filesystems with the existing superblock lock instead. The code already appears to do mostly proper locking with its own private spinlocks (and mutexes), but while the BKL could possibly have been dropped entirely, converting it to use the superblock lock (which is just a regular mutex) is the conservative thing to do. As a per-filesystem mutex, it not only won't have any of the possible latency issues related to the BKL, but the lock is obviously private to the particular filesystem instance and will thus not cause problems for entirely unrelated users like the BKL can. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-06-12fat: relax the permission check of fat_setattr()OGAWA Hirofumi
New chmod() allows only acceptable permission, and if not acceptable, it returns -EPERM. Old one allows even if it can't store permission to on disk inode. But it seems too strict for users. E.g. https://bugzilla.redhat.com/show_bug.cgi?id=449080: With new one, rsync couldn't create the temporary file. So, this patch allows like old one, but now it doesn't change the permission if it can't store, and it returns 0. Also, this patch fixes missing check. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-29fat: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fatfs: fix build warning with 64k PAGE_SIZEOlof Johansson
Annoying gcc warning: fs/fat/inode.c: In function 'fat_fill_super': fs/fat/inode.c:1222: warning: comparison is always false due to limited range of data type Change it to compare with 4K instead of PAGE_CACHE_SIZE, as suggested by OGAWA-san. [FAT spec says: logical_sector_size should be 512, 1024, 2048 4096] So, at least for now, we limit it to 4096. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28FAT_VALID_MEDIA(): remove pointless testAndrew Morton
The on-disk media specification field in FAT is only 8-bits, so testing for <=0xff is pointless, and can generate a "comparison is always true due to limited range of data type" warning. While we're there, convert FAT_VALID_MEDIA() into a C function - the present implementation is buggy: it generates either one or two references to its argument. Cc: Frank Seidel <fseidel@suse.de> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: use __getname()OGAWA Hirofumi
__getname() is faster than __get_free_page(). Use it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vfat: bug fix for vfat cannot handle filename with 255Keith Mok
This patch fix the problem that the buffer allocated for convert of unicode to utf8 in fat/dir.c is too small. And cannot handle filename with 255 asian characters when mounted with utf8 options. Also it fix the filename length limitation checking in vfat/namei.c that the filename length should be checked against the number of converted unicode characters. Not the length before NLS/UTF8 converted. Signed-off-by: Keith Mok <ek9852@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: Remove fat_clusters_flush()OGAWA Hirofumi
This removes unneeded fat_clusters_flush(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: Update free_clusters even if it is untrustedOGAWA Hirofumi
Currently, free_clusters is not updated until it is trusted, because Windows doesn't update it correctly. But if user is using FAT driver of Linux, it updates free_clusters correctly. Instead, this updates it even if it's untrusted, so if free_clustes is correct, now keep correct value. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: Add allow_utime optionOGAWA Hirofumi
Normally utime(2) checks current process is owner of the file, or it has CAP_FOWNER capability. But FAT filesystem doesn't have uid/gid as on disk info, so normal check is too unflexible. With this option you can relax it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: fat_setattr() fixOGAWA Hirofumi
Fix fat_setattr() on the case of showexec option. If user specified showexec option, inode->i_mode may not have S_IXUGO. This just use inode->i_mode to fix it. And with this patch, we don't allow chmod() on memory inode, it's just bad behaviour. IOW, we allow changing S_IWUGO only which can be stored to disk. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: fat_notify_change() and check_mode() cleanupOGAWA Hirofumi
- Rename fat_notify_change() to fat_setattr() - check_mode() cleanup - Change layout of code Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: kill is_bad_inode() checkOGAWA Hirofumi
FAT doesn't need to check bad inode anymore. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08mount options: fix fatMiklos Szeredi
Add flush option to /proc/mounts for msdos and vfat filesystems. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop FAT from using iget() and read_inode()David Howells
Stop the FAT filesystem from using iget() and read_inode(). Replace the call to iget() with a call to ilookup(). Signed-off-by: David Howells <dhowells@redhat.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06FAT: Fix printk format stringsVegard Nossum
This makes sure printk format strings contain no more than a single line. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> [the message was tweaked.] Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/fat/: refine chmod checksJan Engelhardt
Prohibit mode changes in non-quiet mode that cannot be stored reliably with the on-disk format. Suppose a vfat filesystem is mounted with umask=0 and [not-quiet]. Then all files will have mode 0777. Trying to change the owner will fail, because fat does not know about owners or groups. chmod 0770, on the other hand, will succeed, even though fat does not know about the permission triplet [user/group/other]. So this patch changes fat's not-quiet behavior so that only UNIX modes are accepted that can be mapped lossless between the fat disk format and the local system. There is only one attribute, and that is the readonly attribute, which is mapped to the UNIX write permission bit(s). chmod 0555 is therefore valid (taking away the +w bits <=> setting the readonly attribute). Since chmod 0775 and chmod 0755 is an ambiguous case as to whether to set or clear the readonly bit, these modes are also denied. In quiet mode, chmod and chown will continue to "succeed" as they did before, meaning that a subsequent stat() will temporarily return the new mode as long as the inode is not reread from disk, and chown will silently do nothing, not even return the new uid/gid in stat(). Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08fat: optimize fat_count_free_clusters()OGAWA Hirofumi
On large partition, scanning the free clusters is very slow if users doesn't use "usefree" option. For optimizing it, this patch uses sb_breadahead() to read of FAT sectors. On some user's 15GB partition, this patch improved it very much (1min => 600ms). The following is the result of 2GB partition on my machine. without patch: root@devron (/)# time df -h > /dev/null real 0m1.202s user 0m0.000s sys 0m0.440s with patch: root@devron (/)# time df -h > /dev/null real 0m0.378s user 0m0.012s sys 0m0.168s Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22fat: new export opsChristoph Hellwig
Very little changes here, fat had a mostly no op decode_fh before and does not store any parent information. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fat: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: Fix the race of read/write the FAT12 entryOGAWA Hirofumi
FAT12 entry is 12bits, so it needs 2 phase to update the value. And writer and reader access it without any lock, so reader can get the half updated value. This fixes the long standing race condition by adding a global spinlock to only FAT12 for avoiding any impact against FAT16/32. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: gcc 4.3 warning fixOGAWA Hirofumi
This patch fixes the following warnings. fs/fat/dir.c: In function 'fat_parse_long': include/linux/msdos_fs.h:294: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds The ->name is defined as "name[8], ext[3]", but fat_checksum() uses those as name[11]. There is no actual problem, but it's not a good manner. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08fat: fix VFAT compat ioctls on 64-bit systemsOGAWA Hirofumi
If you compile and run the below test case in an msdos or vfat directory on an x86-64 system with -m32 you'll get garbage in the kernel_dirent struct followed by a SIGSEGV. The patch fixes this. Reported and initial fix by Bart Oldeman #include <sys/types.h> #include <sys/ioctl.h> #include <dirent.h> #include <stdio.h> #include <unistd.h> #include <fcntl.h> struct kernel_dirent { long d_ino; long d_off; unsigned short d_reclen; char d_name[256]; /* We must not include limits.h! */ }; #define VFAT_IOCTL_READDIR_BOTH _IOR('r', 1, struct kernel_dirent [2]) #define VFAT_IOCTL_READDIR_SHORT _IOR('r', 2, struct kernel_dirent [2]) int main(void) { int fd = open(".", O_RDONLY); struct kernel_dirent de[2]; while (1) { int i = ioctl(fd, VFAT_IOCTL_READDIR_BOTH, (long)de); if (i == -1) break; if (de[0].d_reclen == 0) break; printf("SFN: reclen=%2d off=%d ino=%d, %-12s", de[0].d_reclen, de[0].d_off, de[0].d_ino, de[0].d_name); if (de[1].d_reclen) printf("\tLFN: reclen=%2d off=%d ino=%d, %s", de[1].d_reclen, de[1].d_off, de[1].d_ino, de[1].d_name); printf("\n"); } return 0; } Signed-off-by: Bart Oldeman <bartoldeman@users.sourceforge.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fat: don't use free_clusters for fat32OGAWA Hirofumi
It seems that the recent Windows changed specification, and it's undocumented. Windows doesn't update ->free_clusters correctly. This patch doesn't use ->free_clusters by default. (instead, add "usefree" for forcing to use it) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Juergen Beisert <juergen127@kreuzholzen.de> Cc: Andreas Schwab <schwab@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08is_power_of_2 in fatVignesh Babu BM
Replacing (n & (n-1)) in the context of power of 2 checks with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] FAT: DIO-write fallback to normal bufferedOGAWA Hirofumi
If the DIO write on FAT is expanding the size, it will be fail by -EINVAL, because FAT can't handle it now. This patch fallback it to the normal buffered-write and would return success. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] fat: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the fat filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-16[PATCH] fat: add fat_getattr()OGAWA Hirofumi
This adds fat_getattr() for setting stat->blksize. (FAT uses the size of cluster for proper I/O) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Remove unnecessary check in fs/fat/inode.cEric Sesterhenn
Aince all callers dereference sb, and this function does so earlier too, we dont need the check. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] fs/fat endianness annotationsAl Viro
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the msdos device ioctl compat stuff to the msdos driver ↵David Howells
[try #6] Move the msdos device ioctl compat stuff from fs/compat_ioctl.c to the msdos driver so that the msdos header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
