path: root/fs/f2fs/debug.c
2016-06-02f2fs: flush inode metadata when checkpoint is doingJaegeuk Kim
This patch registers all the inodes which have dirty metadata to sync when checkpoint is doing. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-05-18f2fs: use percpu_counter for page countersJaegeuk Kim
This patch substitutes percpu_counter for atomic_counter when counting various types of pages. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-05-18f2fs: use bio count instead of F2FS_WRITEBACK page countJaegeuk Kim
This can reduce page counting overhead. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-05-11f2fs: show # of orphan inodesJaegeuk Kim
This adds debug information for # of orphan inodes. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-04-15f2fs: show current mount statusJaegeuk Kim
This patch remains the current mount status to f2fs status info. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-13Merge tag 'for-f2fs-4.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This series adds two ioctls to control cached data and fragmented files. Most of the rest fixes missing error cases and bugs that we have not covered so far. Summary: Enhancements: - support an ioctl to execute online file defragmentation - support an ioctl to flush cached data - speed up shrinking of extent_cache entries - handle broken superblock - refector dirty inode management infra - revisit f2fs_map_blocks to handle more cases - reduce global lock coverage - add detecting user's idle time Major bug fixes: - fix data race condition on cached nat entries - fix error cases of volatile and atomic writes" * tag 'for-f2fs-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (87 commits) f2fs: should unset atomic flag after successful commit f2fs: fix wrong memory condition check f2fs: monitor the number of background checkpoint f2fs: detect idle time depending on user behavior f2fs: introduce time and interval facility f2fs: skip releasing nodes in chindless extent tree f2fs: use atomic type for node count in extent tree f2fs: recognize encrypted data in f2fs_fiemap f2fs: clean up f2fs_balance_fs f2fs: remove redundant calls f2fs: avoid unnecessary f2fs_balance_fs calls f2fs: check the page status filled from disk f2fs: introduce __get_node_page to reuse common code f2fs: check node id earily when readaheading node page f2fs: read isize while holding i_mutex in fiemap Revert "f2fs: check the node block address of newly allocated nid" f2fs: cover more area with nat_tree_lock f2fs: introduce max_file_blocks in sbi f2fs crypto: check CONFIG_F2FS_FS_XATTR for encrypted symlink f2fs: introduce zombie list for fast shrinking extent trees ...
2016-01-11f2fs: monitor the number of background checkpointJaegeuk Kim
This patch adds to show the number of background checkpoint. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2016-01-06fs: use block_device name vsprintf helperDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-31f2fs: monitor zombie_tree countJaegeuk Kim
This patch adds an entry to show the number of zombie extent_tree. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-12-22f2fs: use atomic variable for total_extent_treeJaegeuk Kim
It would be better to use atomic variable for total_extent_tree. Reviewed-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-12-17f2fs: stat dirty regular/symlink inodesChao Yu
Add to stat dirty regular and symlink inode for showing in debugfs. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-12-15f2fs: introduce dirty list node in inode infoChao Yu
Add a new dirt list node member in inode info for linking the inode to global dirty list in superblock, instead of old implementation which allocate slab cache memory as an entry to inode. It avoids memory pressure due to slab cache allocation, and also makes codes more clean. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-12-04f2fs: use sbi->blocks_per_seg to avoid unnecessary calculationChao Yu
Use sbi->blocks_per_seg directly to avoid unnecessary calculation when using 1 << sbi->log_blocks_per_seg. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-12-04f2fs: report error of f2fs_create_root_statsChao Yu
f2fs_create_root_stats can fail due to no memory, report it to user. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-10-09f2fs: use atomic64_t for extent cache hit statChao Yu
Our hit stat of extent cache will increase all the time until remount, and we use atomic_t type for the stat variable, so it may easily incur overflow when we query extent cache frequently in a long time running fs. So to avoid that, this patch uses atomic64_t for hit stat variables. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-10-09f2fs: fix incorrect bimodal calculationChao Yu
In update_sit_info, we use div_u64 to handle 'u64 divide u64' case, but div_u64 can only handle 32-bits divisor, so our divisor with u64 type passed to div_u64 will overflow, result in the wrong calculation when show debug info of f2fs as below: BDF: 464, avg. vblocks: 23509 (BDF should never exceed 100) So change to use div64_u64 to handle this case correctly. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-10-09f2fs: fix overflow of size calculationChao Yu
We have potential overflow issue when calculating size of object, when we left shift index with PAGE_CACHE_SHIFT bits, if type of index has only 32-bits space in 32-bit architecture, left shifting will incur overflow, i.e: pgoff_t index = 0xFFFFFFFF; loff_t size = index << PAGE_CACHE_SHIFT; size: 0xFFFFF000 So we should cast index with 64-bits type to avoid this issue. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-08-21f2fs: adjust showing of extent cache statChao Yu
This patch alters to replace total hit stat with rbtree hit stat, and then adjust showing of extent cache stat: Hit Count: L1-1: for largest node hit count; L1-2: for last cached node hit count; L2: for extent node hit after lookuping in rbtree. Hit Ratio: ratio (hit count / total lookup count) Inner Struct Count: tree count, node count. Before: Extent Hit Ratio: 0 / 2 Extent Tree Count: 3 Extent Node Count: 2 Patched: Exten Cacache: - Hit Count: L1-1:4871 L1-2:2074 L2:208 - Hit Ratio: 1% (7153 / 550751) - Inner Struct Count: tree: 26560, node: 11824 Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-08-21f2fs: add largest/cached stat in extent cacheChao Yu
This patch adds to stat the hit count of largest/cached node for showing in debugfs. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-08-05f2fs: use atomic_t to record hit ratio info of extent cacheChao Yu
Variables for recording extent cache ratio info were updated without protection, this patch tries to alter them to atomic_t type for more accurate stat. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-08-05f2fs: stat inline xattr inode numberChao Yu
This patch adds to stat the number of inline xattr inode for showing in debugfs. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-06-01f2fs: fix building on 32-bit architecturesArnd Bergmann
A bug fix to the debug output extended the type of some local variables to 64-bit, which now causes the kernel to fail building because of missing 64-bit division functions: ERROR: "__aeabi_uldivmod" [fs/f2fs/f2fs.ko] undefined! In the kernel, we have to use div_u64 or do_div to do this, in order to annotate that this is an expensive operation. As the function is only called for debug out, we know this is not performance critical, so it is safe to use div_u64. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: d1f85bd38db19 ("f2fs: avoid value overflow in showing current status") Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-05-28f2fs: avoid value overflow in showing current statusJaegeuk Kim
This patch fixes overflow when do cat /sys/kernel/debug/f2fs/status. If a section is relatively large, dist value can be overflowed. Reported-by: Yossi Goldfill <ygoldfill@radianmemory.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-05-28f2fs: introduce discard_map for f2fs_trim_fsJaegeuk Kim
This patch adds a bitmap for discard issues from f2fs_trim_fs. There-in rule is to issue discard commands only for invalidated blocks after mount. Once mount is done, f2fs_trim_fs trims out whole invalid area. After ehn, it will not issue and discrads redundantly. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-04-10f2fs: add stat info for moved blocks by background gcChangman Lee
This patch is for looking into gc performance of f2fs in detail. Signed-off-by: Changman Lee <cm224.lee@samsung.com> [Jaegeuk Kim: fix build errors] Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-03-03f2fs: show extent tree, node stat info in debugfsChao Yu
This patch add and show stat info of total memory footprint for extent tree,node in debugfs. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-02-11f2fs: avoid variable length arrayJaegeuk Kim
Instead of using variable length array, this patch let preallocate memory for them. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-02-11f2fs: show the number of writeback pages in statJaegeuk Kim
This patch adds the # of writeback pages in stat info. Reviewed-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-02-11f2fs: update memory footprint informationJaegeuk Kim
This patch adds missing memory usages, and splits them in detail. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-02-11f2fs: fix wrong memory footprint statistics in debugfsChao Yu
Our value of memory footprint statistics showed in debugfs is not calculated correctly. Fix it in this patch. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-01-09f2fs: add nat/sit entries into statusJaegeuk Kim
This patch adds NAT/SIT entry informations. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-01-09f2fs: reuse inode_entry_slab in gc procedure for using slab more effectivelyChao Yu
There are two slab cache inode_entry_slab and winode_slab using the same structure as below: struct dir_inode_entry { struct list_head list; /* list head */ struct inode *inode; /* vfs inode pointer */ }; struct inode_entry { struct list_head list; struct inode *inode; }; It's a little waste that the two cache can not share their memory space for each other. So in this patch we remove one redundant winode_slab slab cache, then use more universal name struct inode_entry as remaining data structure name of slab, finally we reuse the inode_entry_slab to store dirty dir item and gc item for more effective. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-01-09f2fs: add block count by in-place-update in stat infoChangman Lee
This patch adds block count by in-place-update in stat. Signed-off-by: Changman Lee <cm224.lee@samsung.com> Reviewed-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-12-08f2fs: use atomic for counting inode with inline_{dir,inode} flagChao Yu
As inline_{dir,inode} stat is increased/decreased concurrently by multi threads, so the value is not so accurate, let's use atomic type for counting accurately. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-12-08f2fs: count the number of inmemory pagesJaegeuk Kim
This patch adds counting # of inmemory pages in the page cache. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-11-19f2fs: introduce struct inode_management to wrap inner fieldsChao Yu
Now in f2fs, we have three inode cache: ORPHAN_INO, APPEND_INO, UPDATE_INO, and we manage fields related to inode cache separately in struct f2fs_sb_info for each inode cache type. This makes codes a bit messy, so that this patch intorduce a new struct inode_management to wrap inner fields as following which make codes more neat. /* for inner inode cache management */ struct inode_management { struct radix_tree_root ino_root; /* ino entry array */ spinlock_t ino_lock; /* for ino entry lock */ struct list_head ino_list; /* inode list head */ unsigned long ino_num; /* number of entries */ }; struct f2fs_sb_info { ... struct inode_management im[MAX_INO_ENTRY]; /* manage inode cache */ ... } Signed-off-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-11-06f2fs: introduce the number of inode entriesJaegeuk Kim
This patch adds to monitor the number of ino entries. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-11-03f2fs: add stat info for inline_dentry inodesJaegeuk Kim
This patch adds status information for inline_dentry inodes. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-09-30f2fs: check the use of macros on block counts and addressesJaegeuk Kim
This patch cleans up the existing and new macros for readability. Rule is like this. ,-----------------------------------------> MAX_BLKADDR -, | ,------------- TOTAL_BLKS ----------------------------, | | | | ,- seg0_blkaddr ,----- sit/nat/ssa/main blkaddress | block | | (SEG0_BLKADDR) | | | | (e.g., MAIN_BLKADDR) | address 0..x................ a b c d ............................. | | global seg# 0...................... m ............................. | | | | `------- MAIN_SEGS -----------' `-------------- TOTAL_SEGS ---------------------------' | | seg# 0..........xx.................. = Note = o GET_SEGNO_FROM_SEG0 : blk address -> global segno o GET_SEGNO : blk address -> segno o START_BLOCK : segno -> starting block address Reviewed-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-08-19f2fs: fix typoarter97
Fix typo and some grammatical errors. The words "filesystem" and "readahead" are being used without the space treewide. Signed-off-by: Park Ju Hyung <qkrwngud825@gmail.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-07-29f2fs: add infra for ino managementJaegeuk Kim
This patch changes the naming of orphan-related data structures to use as inode numbers managed globally. Later, we can use this facility for managing any inode number lists. Reviewed-by: Chao Yu <chao2.yu@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-07-11f2fs: cleanup the needless return of f2fs_create_root_statsGu Zheng
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-03-20f2fs: remove unnecessary thresholdJaegeuk Kim
The NM_WOUT_THRESHOLD is now obsolete since f2fs starts to control on a basis of the memory footprint. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-02-24f2fs: implement a lock-free stat_showJaegeuk Kim
The stat_show is just to show the current status of f2fs. So, we can remove all the there-in locks. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-02-17f2fs: show counts of checkpoint in statusChangman Lee
This patch shows the counts of checkpoint in f2fs' status. Signed-off-by: Changman Lee <cm224.lee@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-01-22f2fs: introduce NODE_MAPPING for code consistencyJaegeuk Kim
This patch adds NODE_MAPPING which is similar as META_MAPPING introduced by Gu Zheng. Cc: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-01-22f2fs: add help function META_MAPPINGGu Zheng
Introduce help function META_MAPPING() to get the cache meta blocks' address space. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-01-20f2fs: clean checkpatch warningsChris Fries
Fixed a variety of trivial checkpatch warnings. The only delta should be some minor formatting on log strings that were split / too long. Signed-off-by: Chris Fries <cfries@motorola.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2014-01-14f2fs: add delimiter to seperate name and value in debug phraseChangman Lee
Support for f2fs-tools/tools/f2stat to monitor /sys/kernel/debug/f2fs/status Signed-off-by: Changman Lee <cm224.lee@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
